MeshKit  1.0
cw_func Namespace Reference
Classes
struct  coords_and_id
Functions
ErrorCode check_mesh_for_watertightness (EntityHandle input_set, double tol, bool &sealed, bool test, bool verbose, bool check_topology)
int compare_by_handle (const void *a, const void *b)
int compare_by_coords (const void *a, const void *b)
moab::ErrorCode check_mesh_for_watertightness (moab::EntityHandle input_set, double tol, bool &sealed, bool test=false, bool verbose=false, bool check_topology=false)
Function Documentation
moab::ErrorCode cw_func::check_mesh_for_watertightness ( moab::EntityHandle  input_set,
double  tol,
bool &  sealed,
bool  test = false,
bool  verbose = false,
bool  check_topology = false
checks the input mesh for watertightness. If check_topology=true, then the mesh will be checked topologically only, no tolerances allowed. If check_topology = false, then the model will be checked for watertightness by proximity. (i.e. so long as paired vertices are within tol of each other, the mesh will be considered watertight)
ErrorCode cw_func::check_mesh_for_watertightness ( EntityHandle  input_set,
double  tol,
bool &  sealed,
bool  test,
bool  verbose,
bool  check_topology
Definition at line 34 of file cw_func.cpp.
int compare_by_coords ( const void *  a,
const void *  b
Definition at line 428 of file cw_func.cpp.
int compare_by_handle ( const void *  a,
const void *  b
Definition at line 409 of file cw_func.cpp.
