MeshKit  1.0
pushbmesh.cpp
00001 #include "meshkit/PostBL.hpp"
00002 namespace MeshKit
00003 {
00004   int PostBL::push_bulk_mesh(VerdictWrapper vw)
00005   // ---------------------------------------------------------------------------
00009   // ---------------------------------------------------------------------------
00010   {
00011     // swap nodal coordinates of input nodes with innermost BL nodes to push the bulk mesh
00012     int count = -1;
00013
00014     int matindx = -1;
00015     for (Range::iterator kter = nodes.begin(); kter != nodes.end(); ++kter){
00016         ++count;
00017         if(all_bl[count] == 0 ){
00018
00019             int nid = (count+1)*m_Intervals - 1;
00020             MBERRCHK(mb->get_coords(&new_vert[nid], 1, coords_new_quad),mb);
00021             MBERRCHK(mb->get_coords(&(*kter), 1, coords_old_quad),mb);
00022
00023             //TODO: Set connectivity for pushed hexes
00024             if (debug) {
00025                 m_LogFile << std::setprecision (3) << std::scientific << " : NID: " << (nid)
00026                           << coords_old_quad[0]
00027                           << ", " << coords_old_quad[1] << ", " << coords_old_quad[2] << " OLD:- coords: NEW" << coords_new_quad[0]
00028                           << ", " << coords_new_quad[1] << ", " << coords_new_quad[2]  << std::endl;
00029               }
00030             moab::Range deformed_hex;
00031             MBERRCHK(mb->get_adjacencies(&(*kter), 1, m_GD, false, deformed_hex, Interface::UNION), mb);
00032             std::vector<moab::EntityHandle> dhex_conn;
00033             for(Range::iterator fmter = deformed_hex.begin(); fmter != deformed_hex.end(); ++fmter){
00034                 mb->get_connectivity(&(*fmter), 1, dhex_conn);
00035                 if(dhex_conn.size () > 0){
00036                     for(int i=0; i < (int)dhex_conn.size(); i++){
00037                         if((*kter) == dhex_conn[i]){
00038                             // push the bulk mesh
00039                             dhex_conn[i] = new_vert[nid];
00040                           }
00041                       }
00042                     MBERRCHK(mb->set_connectivity(*fmter, &dhex_conn[0], dhex_conn.size()), mb);
00043                   }
00044                 double jac = 0;
00045                 vw.quality_measure(*fmter, MB_JACOBIAN, jac);
00046                 ++m_JacCalls;
00047                 if (jac < 0){
00048                     m_LogFile << "ck BL thickness/intervals. Stopping." << std::endl;
00049                     exit(0);
00050                   }
00051               }
00052           }
00053         else if(all_bl[count] > 0 && fixmat != -1){
00054             // node belongs to more than one material and fixmat specified
00055             int nid = (count+1)*m_Intervals - 1;
00056             MBERRCHK(mb->get_coords(&new_vert[nid], 1, coords_new_quad),mb);
00057             MBERRCHK(mb->get_coords(&(*kter), 1, coords_old_quad),mb);
00058
00059             if (debug) {
00060                 m_LogFile << std::setprecision (3) << std::scientific << " : NID: " << (nid)
00061                           << coords_old_quad[0]
00062                           << ", " << coords_old_quad[1] << ", " << coords_old_quad[2] << " OLD:- coords: NEW" << coords_new_quad[0]
00063                           << ", " << coords_new_quad[1] << ", " << coords_new_quad[2]  << std::endl;
00064               }
00065
00066             // now find the hex in fixmat_ents that was affected by this swap and UNswap the coords
00067             moab::Range fhex;
00068             MBERRCHK(mb->get_adjacencies(&(*kter), 1, m_GD, false, fhex, Interface::UNION), mb);
00069             moab::Range fmhex= intersect(fhex,fixmat_ents);
00070             moab::Range non_fixhex = subtract(fhex, fmhex);
00071
00072             std::vector<int> tag_non_fixhex(non_fixhex.size(),0);
00073             MBERRCHK(mb->tag_get_data(MatIDTag, non_fixhex, &tag_non_fixhex[0]), mb);
00074             m_LogFile << quads.size() << std::endl;
00075
00076             if( matindx < (int) quads.size() ){
00077                 ++matindx;
00078                 // handling more than 2 materials in MM case is not supported
00079                 blmaterial_id[matindx] = tag_non_fixhex[0];
00080               }
00081             std::vector<moab::EntityHandle> fmconn;
00082             for(Range::iterator fmter = non_fixhex.begin(); fmter != non_fixhex.end(); ++fmter){
00083                 mb->get_connectivity(&(*fmter), 1, fmconn);
00084                 if(fmconn.size () > 0){
00085                     for(int i=0; i < (int)fmconn.size(); i++){
00086                         if((*kter) == fmconn[i]){
00087                             // push the bulk mesh
00088                             fmconn[i] = new_vert[nid];
00089                           }
00090                       }
00091                     MBERRCHK(mb->set_connectivity(*fmter, &fmconn[0], fmconn.size()), mb);
00092                   }
00093                 double jac = 0;
00094                 vw.quality_measure(*fmter, MB_JACOBIAN, jac);
00095                 ++m_JacCalls;
00096                 if (jac < 0){
00097                     m_LogFile << "ck BL thickness/intervals. Stopping." << std::endl;
00098                     exit(0);
00099                   }
00100               }
00101             m_LogFile << "Multiple material case: working along the edge" << std::endl;
00102           }
00103         else if(all_bl[count] > 0 && fixmat == -1){ // node belongs to more than one material and fixmat not specified
00104             // NODE ON BOUNDARY
00105             int nid = (count+1)*m_Intervals - 1;
00106             MBERRCHK(mb->get_coords(&new_vert[nid], 1, coords_new_quad),mb);
00107             MBERRCHK(mb->get_coords(&(*kter), 1, coords_old_quad),mb);
00108             MBERRCHK(mb->set_coords(&(*kter), 1, coords_new_quad),mb);
00109             MBERRCHK(mb->set_coords(&new_vert[nid], 1, coords_old_quad),mb);
00110
00111             m_LogFile << std::setprecision (3) << std::scientific << " : NID:" << (nid)
00112                       << coords_old_quad[0]
00113                       << ", " << coords_old_quad[1] << ", " << coords_old_quad[2] << " OLD:- coords: NEW" << coords_new_quad[0]
00114                       << ", " << coords_new_quad[1] << ", " << coords_new_quad[2]  << std::endl;
00115           }
00116       } // for loop ends
00117
00118     if(debug == true){
00119         MBERRCHK(mb->write_mesh("bulkpushed.exo"),mb);
00120         m_LogFile <<  "\n\nWrote Mesh File: bulkpushed.exo" << std::endl;
00121       }
00122     // check for the volume of penultimate elements if -ve volume encountered. Report.
00123     count = -1;
00124     // Try to move another layer attached to it.
00125     for (Range::iterator kter = nodes.begin(); kter != nodes.end(); ++kter){
00126         ++count;
00127         for(int j=0; j< m_Intervals; j++){
00128             int nid = count*m_Intervals+j;
00129             double coords_new_quad[3];
00130             MBERRCHK(mb->get_coords(&new_vert[nid], 1, coords_new_quad),mb);
00131             m_LogFile << std::setprecision (3) << std::scientific << " : NID:" << (nid)
00132                       << " of " << new_vert.size() << " new nodes:- coords: " << coords_new_quad[0]
00133                       << ", " << coords_new_quad[1] << ", " << coords_new_quad[2]  << std::endl;
00134           }
00135       }
00136     // shoot multiple normals for multiple materials case only.
00137     // This can be used of regular case also how to invoke it. mention in algorithm
00138     // mention local and global smoothing.
00139     //    qcount = -1;
00140     //    int flag[quads.size()];
00141     return 0;
00142   }
00143 }
