MeshKit  1.0
test_camalmb2.cpp
00001
00007 #include "meshkit/MKCore.hpp"
00008 #include "meshkit/SizingFunction.hpp"
00009 #include "meshkit/ModelEnt.hpp"
00010
00011 using namespace MeshKit;
00012
00013 MKCore * mk;
00014 bool save_mesh = false;
00015 bool quadMesh = true;
00016 double mesh_size = 0.3;
00017 std::string file_name; //="shell.h5m";
00018 std::string output_file; //="output.h5m";
00019
00020 #include "TestUtil.hpp"
00021
00022 void meshFB2();
00023
00024 int main(int argc, char **argv)
00025 {
00026   // start up a new iGeom engine, based on moab
00027   /*moab::Interface * mb = new moab::Core();
00028    iGeom * fbiGeom = new FBiGeom(mb); // true means smooth
00029    MKCore mk(fbiGeom, mb); // iMesh, iRel, will be constructed*/
00030
00031   file_name = TestDir + "/" + "shell.h5m";// default test file
00032   output_file = "output.h5m";
00033
00034   if (argc < 5) {
00035     {
00036       std::cout << "Usage : filename  output  < q, t >  <mesh_size> \n";
00037       std::cout << "use default options: " << file_name << " " << output_file <<
00038           (quadMesh ? " q " : " t " ) << mesh_size << "\n";
00039     }
00040   }
00041   else
00042   {
00043     file_name = argv[1];
00044     output_file = argv[2];
00045     if (!strcmp(argv[3], "t"))
00046       quadMesh = false;
00047     mesh_size = atof(argv[4]);
00048     save_mesh = true;
00049   }
00050
00051   int num_fail = 0;
00052   num_fail += RUN_TEST(meshFB2);
00053
00054   return num_fail;
00055 }
00056 void meshFB2()
00057 {
00058   mk = new MKCore;
00059
00060   mk->load_mesh(file_name.c_str(), NULL, 0, 0, 0, false, false);
00061   int indx=  mk->initialize_mesh_based_geometry(0);
00062
00063   moab::Range tris;
00064   moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(
00065       (moab::EntityHandle)0 , 2,
00066       tris);
00067
00068   int nbInitial = tris.size();
00069   tris.clear();
00070   // initial number of triangles
00071   std::cout << nbInitial << " initial elements in the model" << std::endl;
00072   //fbiGeom->Init();
00073
00074   // get the surface model ents
00075   MEntVector surfs;
00076   mk->get_entities_by_dimension(2, surfs);
00077
00078   // create surface mesher for them, either quad or tri mesher
00079   if (quadMesh)
00080     mk->construct_meshop("CAMALPaver", surfs);
00081   else
00082     mk->construct_meshop("CAMALTriAdvance", surfs);
00083
00084
00085   // size the mesh
00086   SizingFunction *sf = new SizingFunction(mk, -1, mesh_size);
00087   for (unsigned int i = 0; i < surfs.size(); i++)
00088     surfs[i]->sizing_function_index(sf->core_index());
00089
00090   // now mesh them
00091   mk->setup_and_execute();
00092
00093   std::cout<<" after execute:\n";
00094   // just for debugging
00095   mk->print_graph();
00096
00097   // report the number of triangles generated
00098   // put it in a new set in moab
00099
00100   rval = mk->moab_instance()->get_entities_by_dimension(0, 2, tris);
00101   CHECK_EQUAL(moab::MB_SUCCESS, rval);
00102   std::string elem =(quadMesh? " quads ": " triangles");
00103   std::cout << tris.size() - nbInitial << elem << " generated." << std::endl;
00104
00105   mk->remove_mesh_based_geometry(indx);
00106   if (save_mesh) {
00107     // output mesh for surfaces (implicitly for edges too, as edges are children of surface sets)
00108     mk->save_mesh_from_model_ents(output_file.c_str(), surfs);
00109   }
00110   // delete the model ents too, unload geometry
00111
00112   delete mk;
00113 }
