MeshKit  1.0
test_camaltetmesher.cpp
00001
00007 #include "meshkit/MKCore.hpp"
00008 #include "meshkit/CAMALTetMesher.hpp"
00009 #include "meshkit/SizingFunction.hpp"
00010 #include "meshkit/ModelEnt.hpp"
00011
00012 using namespace MeshKit;
00013
00014 #include "TestUtil.hpp"
00015
00016 MKCore *mk = NULL;
00017 bool save_mesh = true;
00018
00019 void threeholecube_test();
00020 void simpletet_test();
00021 void mesh_test(std::string filebase, double size);
00022
00023 #ifdef HAVE_ACIS
00024 std::string extension = ".sat";
00025 #elif HAVE_OCC
00026 std::string extension = ".stp";
00027 #endif
00028
00029 int main(int argc, char **argv)
00030 {
00031
00032     // start up MK and load the geometry
00033   mk = new MKCore;
00034   int num_fail = 0;
00035
00036   if (argc == 2) save_mesh = true;
00037   // Test 1
00038   num_fail += RUN_TEST(simpletet_test);
00039   // delete all for running next test case
00040   mk->delete_all();
00041   // Test 2
00042   num_fail += RUN_TEST(threeholecube_test);
00043
00044   return num_fail;
00045 }
00046
00047 void simpletet_test()
00048 {
00049   mesh_test("simpletet", 0.25);
00050 }
00051
00052 void threeholecube_test()
00053 {
00054   mesh_test("threeholecube", 0.05);
00055 }
00056
00057 void mesh_test(std::string filebase, double size)
00058 {
00059   std::string file_name = TestDir + "/" + filebase + extension;
00060   mk->load_geometry(file_name.c_str());
00061
00062     // get the volume
00063   MEntVector dum, vols;
00064   mk->get_entities_by_dimension(3, dum);
00065   vols.push_back(*dum.rbegin());
00066   mk->construct_meshop("CAMALTetMesher", vols);
00067
00068     // make a sizing function and set it on the surface
00069   SizingFunction esize(mk, -1, size);
00070   vols[0]->sizing_function_index(esize.core_index());
00071
00072     // mesh the surface, by calling execute
00073   mk->setup_and_execute();
00074
00075     // report the number of tets
00076   moab::Range tets;
00077   moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 3, tets);
00078   CHECK_EQUAL(moab::MB_SUCCESS, rval);
00079   std::cout << tets.size() << " tets generated." << std::endl;
00080
00081   if (save_mesh) {
00082         // output mesh
00083     std::string outfile = filebase + std::string(".h5m");
00084     moab::EntityHandle out_set = vols[0]->mesh_handle();
00085     rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL, &out_set, 1);
00086     MBERRCHK(rval, mk->moab_instance());
00087   }
00088
00089   mk->clear_graph();
00090 }
00091
