MeshKit  1.0
test_edgemesher.cpp
00001
00007 #include "meshkit/MKCore.hpp"
00008 #include "meshkit/EdgeMesher.hpp"
00009 #include "meshkit/SizingFunction.hpp"
00010 #include "meshkit/SizingFunctionVar.hpp"
00011 #include "meshkit/ModelEnt.hpp"
00012 #include "meshkit/Matrix.hpp"
00013 #include "meshkit/VertexMesher.hpp"
00014
00015 using namespace MeshKit;
00016
00017 #include "TestUtil.hpp"
00018
00019 MKCore *mk = NULL;
00020
00021 void edgemesh_hole();
00022 void edgemesh_square();
00023 void edgemesh_brick();
00024 void edgemesh_var();
00025 void edgemesh_dual();
00026
00027 #ifdef HAVE_ACIS
00028 std::string extension = ".sat";
00029 #elif HAVE_OCC
00030 std::string extension = ".stp";
00031 #else
00032 std::string extension = ".facet";
00033 #define HAVE_FACET
00034 #endif
00035
00036 int main(int argc, char **argv)
00037 {
00038
00039     // start up MK and load the geometry
00040   mk = new MKCore();
00041
00042   int num_fail = 0;
00043   num_fail += RUN_TEST(edgemesh_brick);
00044   num_fail += RUN_TEST(edgemesh_square);
00045   num_fail += RUN_TEST(edgemesh_var);
00046 #ifndef HAVE_FACET
00047   num_fail += RUN_TEST(edgemesh_hole);
00048   num_fail += RUN_TEST(edgemesh_dual);
00049 #endif
00050 #if HAVE_OCC
00051   return 0;
00052 #else
00053   return num_fail;
00054 #endif
00055 }
00056
00057 void edgemesh_hole()
00058 {
00059   std::string file_name = TestDir + "/holysurf" + extension;
00060   mk->load_geometry(file_name.c_str());
00061
00062     // get the surface
00063   MEntVector surfs, curves, loops;
00064   mk->get_entities_by_dimension(2, surfs);
00065   CHECK_EQUAL(1, (int)surfs.size());
00066
00067     // test getting loops
00068   std::vector<int> senses, loop_sizes;
00069   surfs[0]->boundary(0, loops, &senses, &loop_sizes);
00070   CHECK_EQUAL(4, (int)loop_sizes.size());
00071
00072     // add up the loop sizes, should add to 8
00073   unsigned int l = 0;
00074   for (unsigned int i = 0; i < loop_sizes.size(); i++) l += loop_sizes[i];
00075   CHECK_EQUAL(8, (int)l);
00076
00077     // make an edge mesher
00078   mk->get_entities_by_dimension(1, curves);
00079   EdgeMesher *em = (EdgeMesher*) mk->construct_meshop("EdgeMesher", curves);
00080
00081     // make a sizing function and set it on the surface
00082   SizingFunction esize(mk, -1, 0.25);
00083   surfs[0]->sizing_function_index(esize.core_index());
00084
00085     // mesh the edges, by calling execute
00086   mk->setup_and_execute();
00087
00088     // make sure we got the right number of edges
00089   moab::Range edges;
00090   moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 1, edges);
00091   CHECK_EQUAL(moab::MB_SUCCESS, rval);
00092   CHECK_EQUAL(79, (int)edges.size());
00093
00094     // clean up
00095   delete em;
00096   delete mk->vertex_mesher();
00097 }
00098
00099 void edgemesh_square()
00100 {
00101   std::string file_name = TestDir + "/squaresurf" + extension;
00102   mk->load_geometry(file_name.c_str());
00103
00104     // get the surface
00105   MEntVector surfs, curves, loops;
00106   mk->get_entities_by_dimension(2, surfs);
00107   ModelEnt *this_surf = (*surfs.rbegin());
00108
00109     // test getting loops
00110   std::vector<int> senses, loop_sizes;
00111   this_surf->boundary(0, loops, &senses, &loop_sizes);
00112   CHECK_EQUAL(1, (int)loop_sizes.size());
00113
00114     // make an edge mesher
00115   this_surf->get_adjacencies(1, curves);
00116   mk->construct_meshop("EdgeMesher", curves);
00117
00118     // make a sizing function and set it on the surface
00119   SizingFunction esize(mk, 1, 1.0);
00120   this_surf->sizing_function_index(esize.core_index());
00121
00122     // mesh the edges, by calling execute
00123   mk->setup_and_execute();
00124
00125   senses.clear();
00126   loop_sizes.clear();
00127   std::vector<moab::EntityHandle> mloops;
00128   this_surf->boundary(0, mloops, &senses, &loop_sizes);
00129   CHECK_EQUAL(4, (int)mloops.size());
00130
00131     // print the vertex positions
00132   std::vector<double> coords(12);
00133   moab::ErrorCode rval = mk->moab_instance()->get_coords(&mloops[0], mloops.size(), &coords[0]);
00134   MBERRCHK(rval, mk->moab_instance());
00135 //  std::cout << "Vertex positions:" << std::endl;
00136 //  for (unsigned int i = 0; i < 4; i++)
00137 //    std::cout << coords[3*i] << ", " << coords[3*i+1] << ", " << coords[3*i+2] << std::endl;
00138
00139     // compute the cross product vector and print that
00140   double tmp[] = {0.0, 0.0, 1.0};
00141   Vector<3> p0(&coords[0]), p1(&coords[3]), p2(&coords[6]), unitz(tmp);
00142   p0 -= p1;
00143   p2 -= p1;
00144   p1 = vector_product(p2, p0);
00145   double dot = inner_product(unitz, p1);
00146   CHECK_REAL_EQUAL(1.0, dot, 1.0e-6);
00147
00148   mk->clear_graph();
00149 }
00150
00151 void edgemesh_brick()
00152 {
00153   std::string file_name = TestDir + "/brick" + extension;
00154   mk->load_geometry(file_name.c_str());
00155
00156     // get the vol, surfs, curves
00157   MEntVector vols, surfs, curves, loops;
00158   mk->get_entities_by_dimension(3, vols);
00159   ModelEnt *this_vol = (*vols.rbegin());
00160   this_vol->get_adjacencies(2, surfs);
00161   this_vol->get_adjacencies(1, curves);
00162
00163     // mesh all the edges
00164   mk->construct_meshop("EdgeMesher", curves);
00165   SizingFunction esize(mk, 1, 1.0);
00166   this_vol->sizing_function_index(esize.core_index());
00167   mk->setup_and_execute();
00168
00169     // test loop directionality for each surface
00170   for (MEntVector::iterator vit = surfs.begin(); vit != surfs.end(); vit++) {
00171
00172     std::vector<int> senses, loop_sizes;
00173     std::vector<moab::EntityHandle> mloops;
00174     (*vit)->boundary(0, mloops, &senses, &loop_sizes);
00175     CHECK_EQUAL(4, (int)mloops.size());
00176
00177       // get the vertex positions
00178     std::vector<double> coords(12);
00179     moab::ErrorCode rval = mk->moab_instance()->get_coords(&mloops[0], mloops.size(), &coords[0]);
00180     MBERRCHK(rval, mk->moab_instance());
00181
00182
00183       // compute the cross product vector and compare it to the surface normal
00184     Vector<3> p0(&coords[0]), p1(&coords[3]), p2(&coords[6]), p3;
00185     p0 -= p1;
00186     p2 -= p1;
00187     p1 = vector_product(p2, p0);
00188     (*vit)->evaluate(coords[0], coords[1], coords[2], NULL, p3.data());
00189     double dot = inner_product(p3, p1);
00190     CHECK_REAL_EQUAL(1.0, dot, 1.0e-6);
00191
00192   }
00193
00194   mk->clear_graph();
00195 #ifdef HAVE_FACET
00196   mk->save_mesh("brickedges.h5m");
00197 #endif
00198 }
00199 void edgemesh_var()
00200 {
00201   // delete existing mesh
00202   mk->moab_instance()->delete_mesh();
00203
00204   std::string file_name = TestDir + "/squaresurf" + extension;
00205   mk->load_geometry(file_name.c_str());
00206
00207     // get the surface
00208   MEntVector surfs, curves, loops;
00209   mk->get_entities_by_dimension(2, surfs);
00210   ModelEnt *this_surf = (*surfs.rbegin());
00211
00212     // test getting loops
00213   std::vector<int> senses, loop_sizes;
00214   this_surf->boundary(0, loops, &senses, &loop_sizes);
00215   CHECK_EQUAL(1, (int)loop_sizes.size());
00216
00217     // make an edge mesher
00218   this_surf->get_adjacencies(1, curves);
00219   EdgeMesher * emesher = (EdgeMesher *)mk->construct_meshop("EdgeMesher", curves);
00220
00221   emesher->set_edge_scheme(EdgeMesher::VARIABLE);
00222
00223     // make a sizing function and set it on the surface
00224   SizingFunctionVar * svar = new SizingFunctionVar(mk, -1, 0.1);
00225
00226   // these could be read from a file, or something
00227   double point0[3] = {0, 0, 0};
00228   double coeffs[4] = {0.05, 0.05, 0.05, 0.1};
00229   svar->set_linear_coeff(point0, coeffs);
00230
00231   this_surf->sizing_function_index(svar->core_index());
00232
00233   mk->setup_and_execute();
00234
00235   //mk->moab_instance()->write_file("var1.vtk");
00236   mk->clear_graph();
00237
00238 }
00239 void edgemesh_dual()
00240 {
00241   // delete existing mesh
00242   mk->moab_instance()->delete_mesh();
00243
00244   std::string file_name = TestDir + "/squaresurf" + extension;
00245   mk->load_geometry(file_name.c_str());
00246
00247     // get the surface
00248   MEntVector surfs, curves, loops;
00249   mk->get_entities_by_dimension(2, surfs);
00250   ModelEnt *this_surf = (*surfs.rbegin());
00251
00252     // test getting loops
00253   std::vector<int> senses, loop_sizes;
00254   this_surf->boundary(0, loops, &senses, &loop_sizes);
00255   CHECK_EQUAL(1, (int)loop_sizes.size());
00256
00257     // make an edge mesher
00258   this_surf->get_adjacencies(1, curves);
00259   EdgeMesher * emesher = (EdgeMesher *)mk->construct_meshop("EdgeMesher", curves);
00260
00261   emesher->set_edge_scheme(EdgeMesher::DUAL);
00262
00263     // make a sizing function and set it on the surface
00264   SizingFunction * svar = new SizingFunction(mk, 10, -1);
00265
00266   emesher->set_ratio(1.3);
00267
00268   this_surf->sizing_function_index(svar->core_index());
00269
00270   mk->setup_and_execute();
00271
00272   //mk->moab_instance()->write_file("dual1.1.vtk");
00273   mk->clear_graph();
00274
00275 }
