MeshKit  1.0
test_extrudemesh.cpp
00001
00007 #include "meshkit/MKCore.hpp"
00008 #include "meshkit/MeshOp.hpp"
00009 #include "meshkit/ExtrudeMesh.hpp"
00010 #include "meshkit/ModelEnt.hpp"
00011
00012 using namespace MeshKit;
00013
00014 #include "TestUtil.hpp"
00015 #define DEFAULT_TEST_FILE "rect_quads.cub"
00016
00017 MKCore *mk;
00018
00019 void test_load_and_extrude();
00020 void test_extrude_quad();
00021 void test_extrude_tri();
00022
00023 void help_test_extrude_face(iMesh_EntityTopology topo, double *coords,
00024                             size_t nverts);
00025
00026 int main(int argc, char **argv)
00027 {
00028   mk = new MKCore();
00029   int num_fail = 0;
00030
00031   num_fail += RUN_TEST(test_load_and_extrude);
00032   num_fail += RUN_TEST(test_extrude_quad);
00033   num_fail += RUN_TEST(test_extrude_tri);
00034
00035   delete mk;
00036   return num_fail;
00037 }
00038
00039 void clear_mesh(MKCore *mk)
00040 {
00041   iMesh *mesh = mk->imesh_instance();
00042   std::vector<iMesh::EntityHandle> ents;
00043   mesh->getEntities(mesh->getRootSet(), iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES,
00044                     ents);
00045   mesh->deleteEntArr(&ents[0], ents.size());
00046 }
00047
00048 void test_load_and_extrude()
00049 {
00050   clear_mesh(mk);
00051   std::string filename = TestDir + "/" + DEFAULT_TEST_FILE;
00052   mk->load_mesh(filename.c_str());
00053
00054   // populate mesh with no attached geometry or relations
00055   mk->populate_model_ents(-1, 0, -1);
00056
00057   // get the hexes
00058   MEntVector vols;
00059   mk->get_entities_by_dimension(2, vols);
00060
00061   ExtrudeMesh *em = (ExtrudeMesh*) mk->construct_meshop("ExtrudeMesh", vols);
00062   em->set_name("extrude_mesh");
00063
00064   // some entity tag types are always copy or expand
00065   em->expand_sets().add_tag("MATERIAL_SET");
00066   em->expand_sets().add_tag("DIRICHLET_SET");
00067   em->copy_sets().add_tag("NEUMANN_SET");
00068   em->copy_faces(true);
00069
00070   Vector<3> dx; dx[0] = 0; dx[1] = 0; dx[2] = 3;
00071   em->set_transform(Extrude::Translate(dx, 1));
00072
00073   // put them in the graph
00074   mk->get_graph().addArc(mk->root_node()->get_node(), em->get_node());
00075   mk->get_graph().addArc(em->get_node(), mk->leaf_node()->get_node());
00076
00077   moab::Tag mattag;
00078   mk->moab_instance()->tag_get_handle( "MATERIAL_SET", 1, moab::MB_TYPE_INTEGER, mattag );
00079   moab::Range matsets;
00080   std::vector <moab::EntityHandle> set_ents;
00081   mk->moab_instance()->get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &mattag, 0, 1, matsets );
00082
00083   moab::Range::iterator set_it;
00084   for (set_it = matsets.begin(); set_it != matsets.end(); set_it++)  {
00085       moab::EntityHandle this_set = *set_it;
00086       em->extrude_sets().add_set((iMesh::EntitySetHandle)this_set);
00087     }
00088
00089   // some entity tag types are always copy or expand
00090   em->extrude_sets().add_tag("MATERIAL_SET");
00091
00092   // mesh embedded boundary mesh, by calling execute
00093   mk->setup_and_execute();
00094
00095   // now delete all the 2D material sets:
00096   matsets.clear();
00097   // doing this again, to get new material sets created by extrude
00098   mk->moab_instance()->get_entities_by_type_and_tag( 0, moab::MBENTITYSET, &mattag, 0, 1, matsets );
00099   for (set_it = matsets.begin(); set_it != matsets.end(); set_it++)  {
00100       moab::EntityHandle this_set = *set_it;
00101       // get material sets with two dimension and delete
00102       std::vector <moab::EntityHandle> set_ents;
00103       mk->moab_instance()->get_entities_by_dimension(this_set, 2, set_ents, true);
00104       if(set_ents.size() > 0)
00105         mk->moab_instance()->delete_entities(&this_set, 1);
00106     }
00107   delete em;
00108 }
00109
00110
00111 void help_test_extrude_face(iMesh_EntityTopology topo, double *coords,
00112                             size_t nverts)
00113 {
00114   clear_mesh(mk);
00115
00116   iMesh *mesh = mk->imesh_instance();
00117
00118   std::vector<iMesh::EntityHandle> verts(nverts);
00119   iMesh::EntityHandle face;
00120   iMesh::EntitySetHandle set;
00121
00122   mesh->createVtxArr(nverts, iBase_INTERLEAVED, coords, &verts[0]);
00123   mesh->createEnt(topo, &verts[0], nverts, face);
00124   mesh->createEntSet(true, set);
00125   mesh->addEntToSet(face, set);
00126
00127   ModelEnt me(mk, iBase_EntitySetHandle(0), /*igeom instance*/0,
00128               (moab::EntityHandle)set);
00129   MEntVector selection;
00130   selection.push_back(&me);
00131
00132   ExtrudeMesh *em = (ExtrudeMesh*) mk->construct_meshop("ExtrudeMesh",
00133                                                         selection);
00134   em->set_name("extrude_mesh");
00135
00136   Vector<3> dx; dx[0] = 0; dx[1] = 0; dx[2] = 10;
00137   em->set_transform(Extrude::Translate(dx, 10));
00138   em->copy_faces(true);
00139
00140   // put them in the graph
00141   mk->get_graph().addArc(mk->root_node()->get_node(), em->get_node());
00142   mk->get_graph().addArc(em->get_node(), mk->leaf_node()->get_node());
00143
00144   em->copy_sets().add_set(set);
00145   em->extrude_sets().add_set(set);
00146
00147   // mesh embedded boundary mesh, by calling execute
00148   mk->setup_and_execute();
00149
00150   std::vector<iMesh::EntityHandle> new_verts;
00151   std::vector<double> new_coords(nverts*3);
00152   std::vector<iMesh::EntityHandle> new_face;
00153   iMesh::EntitySetHandle copy_set;
00154
00155   mesh->getEntSetEHData(set, em->copy_tag(), (iMesh::EntityHandle&)copy_set);
00156
00157   mesh->getEntities(copy_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, new_face);
00158   CHECK_EQUAL(new_face.size(), size_t(1));
00159
00160   mesh->getEntAdj(new_face[0], iBase_VERTEX, new_verts);
00161   CHECK_EQUAL(new_verts.size(), nverts);
00162
00163   mesh->getVtxArrCoords(&new_verts[0], new_verts.size(), iBase_INTERLEAVED,
00164       &new_coords[0]);
00165
00166   for(size_t i=0; i<nverts; i++) {
00167       CHECK_REAL_EQUAL(coords[i*3+0],    new_coords[i*3+0], 0.00001);
00168       CHECK_REAL_EQUAL(coords[i*3+1],    new_coords[i*3+1], 0.00001);
00169       CHECK_REAL_EQUAL(coords[i*3+2]+10, new_coords[i*3+2], 0.00001);
00170     }
00171
00172   iMesh::EntitySetHandle extrude_set;
00173   int n;
00174   mesh->getEntSetEHData(set, em->extrude_tag(),
00175                         (iMesh::EntityHandle&)extrude_set);
00176   mesh->getNumOfType(extrude_set, iBase_ALL_TYPES, n);
00177   CHECK_EQUAL(n, 10);
00178
00179   delete em;
00180 }
00181
00182 void test_extrude_quad()
00183 {
00184   double coords[] = {
00185     0, 0, 0,
00186     1, 0, 0,
00187     1, 1, 0,
00188     0, 1, 0
00189   };
00190
00191   help_test_extrude_face(iMesh_QUADRILATERAL, coords, 4);
00192 }
00193
00194 void test_extrude_tri()
00195 {
00196   double coords[] = {
00197     0, 0, 0,
00198     1, 0, 0,
00199     1, 1, 0
00200   };
00201
00202   help_test_extrude_face(iMesh_TRIANGLE, coords, 3);
00203 }
