MeshKit  1.0
test_facetmeshreader_senses.cpp File Reference
#include "meshkit/MKCore.hpp"
#include "meshkit/SurfaceFacetMeshReader.hpp"
#include "meshkit/CurveFacetMeshReader.hpp"
#include "meshkit/ModelEnt.hpp"
#include "MBTagConventions.hpp"
#include "moab/GeomTopoTool.hpp"
#include "moab/Types.hpp"
#include "TestUtil.hpp"
Include dependency graph for test_facetmeshreader_senses.cpp:
Functions
void cylcube_curve_senses_test ()
void cylcube_surf_senses_test ()
int geom_id_by_handle (moab::EntityHandle ent)
void load_sat_curve_sense_data (ModelEnt *curve, std::vector< int > &curve_ids_out, std::vector< int > &senses_out)
void load_stp_curve_sense_data (ModelEnt *curve, std::vector< int > &curve_ids_out, std::vector< int > &senses_out)
void load_sat_surf_sense_data (ModelEnt *surf, std::vector< int > &vol_ids_out, std::vector< int > &senses_out)
void load_stp_surf_sense_data (ModelEnt *surf, std::vector< int > &vol_ids_out, std::vector< int > &senses_out)
void check_sense_data (std::vector< moab::EntityHandle > wrt_ents, std::vector< int > senses, std::vector< int > known_wrt_ids, std::vector< int > known_senses)
int main (int argc, char **argv)
Variables
MKCoremk = NULL
Function Documentation
void check_sense_data ( std::vector< moab::EntityHandle >  wrt_ents,
Definition at line 480 of file test_facetmeshreader_senses.cpp.
Definition at line 75 of file test_facetmeshreader_senses.cpp.
Definition at line 127 of file test_facetmeshreader_senses.cpp.
int geom_id_by_handle ( moab::EntityHandle  ent)
Definition at line 516 of file test_facetmeshreader_senses.cpp.
void load_sat_curve_sense_data ( ModelEnt curve,
std::vector< int > &  curve_ids_out,
std::vector< int > &  senses_out
Definition at line 295 of file test_facetmeshreader_senses.cpp.
void load_sat_surf_sense_data ( ModelEnt surf,
std::vector< int > &  vol_ids_out,
Definition at line 176 of file test_facetmeshreader_senses.cpp.
void load_stp_curve_sense_data ( ModelEnt curve,
Definition at line 380 of file test_facetmeshreader_senses.cpp.
void load_stp_surf_sense_data ( ModelEnt surf,
Definition at line 234 of file test_facetmeshreader_senses.cpp.
int main ( int  argc,
char **  argv
Definition at line 42 of file test_facetmeshreader_senses.cpp.
Variable Documentation
MKCore* mk = NULL
Definition at line 19 of file test_facetmeshreader_senses.cpp.
