MeshKit  1.0
test_facetmeshreader_senses.cpp
00001
00007 #include "meshkit/MKCore.hpp"
00008 #include "meshkit/SurfaceFacetMeshReader.hpp"
00009 #include "meshkit/CurveFacetMeshReader.hpp"
00010 #include "meshkit/ModelEnt.hpp"
00011 #include "MBTagConventions.hpp"
00012 #include "moab/GeomTopoTool.hpp"
00013 #include "moab/Types.hpp"
00014
00015 using namespace MeshKit;
00016
00017 #include "TestUtil.hpp"
00018
00019 MKCore *mk = NULL;
00020
00021 #ifdef HAVE_ACIS
00022 std::string extension = ".sat";
00023 #elif HAVE_OCC
00024 std::string extension = ".stp";
00025 #endif
00026
00027
00028 //test functions
00029 void cylcube_curve_senses_test();
00030 void cylcube_surf_senses_test();
00031
00032
00033 //support functions
00034 int geom_id_by_handle( moab::EntityHandle ent );
00035 void load_sat_curve_sense_data( ModelEnt* curve, std::vector<int>& curve_ids_out, std::vector<int>& senses_out );
00036 void load_stp_curve_sense_data( ModelEnt* curve, std::vector<int>& curve_ids_out, std::vector<int>& senses_out );
00037 void load_sat_surf_sense_data( ModelEnt *surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out );
00038 void load_stp_surf_sense_data( ModelEnt *surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out );
00039 void check_sense_data( std::vector<moab::EntityHandle> wrt_ents, std::vector<int> senses,
00040                        std::vector<int> known_wrt_ids, std::vector<int> known_senses );
00041
00042 int main(int argc, char **argv)
00043 {
00044
00045   // start up MK and load the geometry
00046   mk = new MKCore();
00047
00048   std::string filename = "cylcube" ;
00049
00050   filename = TestDir + "/" + filename + extension;
00051
00052   mk->load_geometry(&filename[0]);
00053
00054   MEntVector surfs;
00055   mk->get_entities_by_dimension(2,surfs);
00056   SurfaceFacetMeshReader *sfmr;
00057
00058   sfmr = (SurfaceFacetMeshReader*) mk->construct_meshop("SurfaceFacetMeshReader", surfs);
00059
00060   double facet_tol = 1e-04, geom_resabs = 1e-06;
00061   sfmr->set_mesh_params(facet_tol, geom_resabs);
00062
00063   mk->setup();
00064   mk->execute();
00065
00066
00067   //RUN TESTS
00068   int num_fail = 0;
00069   num_fail += RUN_TEST(cylcube_curve_senses_test);
00070
00071
00072   return num_fail;
00073 }
00074
00075 void cylcube_curve_senses_test()
00076 {
00077
00078   //check that we retrieve the correct number of curves from the model
00079   MEntVector curves;
00080   mk->get_entities_by_dimension( 1, curves);
00081
00082 #ifdef HAVE_OCC
00083   CHECK( 18 == int(curves.size()) );
00084 #else
00085   CHECK( 14 == int(curves.size()) );
00086 #endif
00087
00088     // Establish GeomTopoTool instance needed to get curve data
00089   moab::GeomTopoTool gt( mk->moab_instance() );
00090
00091     // Initialize vectors for sense checking
00092   std::vector<moab::EntityHandle> curve_list;
00093   std::vector<int> senses;
00094   std::vector<int> known_curve_ids;
00095   std::vector<int> known_senses;
00096
00097   //load_sat_curve_sense_data(
00098   //for each curve get the sense data from the model
00099   for(MEntVector::iterator i = curves.begin(); i != curves.end(); i++)
00100     {
00101
00102       ModelEnt *curve = *i;
00103
00104       curve_list.clear();
00105       senses.clear();
00106
00107       //get the senses for this curve
00108       moab::EntityHandle curve_sh = curve->mesh_handle();
00109       moab::ErrorCode result = gt.get_senses( curve_sh,  curve_list, senses);
00110       if( result != moab::MB_SUCCESS ) CHECK(false); // return failed test if this call fails
00111
00112       //clear reference data
00113       known_curve_ids.clear();
00114       known_senses.clear();
00115
00116       //Load known curve-sense data
00117 #ifdef HAVE_OCC
00118       load_stp_curve_sense_data( curve, known_curve_ids, known_senses);
00119 #else
00120       load_sat_curve_sense_data( curve, known_curve_ids, known_senses);
00121 #endif
00122       //check that each surf and sense has a match in our reference data
00123
00124     }
00125 }
00126
00127 void cylcube_surf_senses_test()
00128 {
00129
00130   MEntVector surfs;
00131
00132   mk->get_entities_by_dimension( 2, surfs );
00133
00134   //make sure we've retrieved the right number of surfaces for the model
00135 #ifdef HAVE_OCC
00136   CHECK_EQUAL( 10, int(surfs.size()) );
00137 #else
00138   CHECK_EQUAL( 9, int(surfs.size()) );
00139 #endif
00140
00141   //Create a Geomtopotool and declare containers for sense data
00142   moab::GeomTopoTool gt( mk->moab_instance() );
00143   moab::ErrorCode rval;
00144   std::vector<moab::EntityHandle> vols;
00145   std::vector<int> senses;
00146   std::vector<int> known_volume_ids;
00147   std::vector<int> known_senses;
00148
00149   for( unsigned int i = 0; i < surfs.size(); i++)
00150     {
00151       //clear out the old containers from the previous surface
00152       vols.clear();
00153       senses.clear();
00154
00155       moab::EntityHandle sh = surfs[i]->mesh_handle();
00156
00157       rval = gt.get_senses( sh, vols, senses);
00158       CHECK_ERR(rval);
00159
00160       //clear previous reference data
00161       known_volume_ids.clear();
00162       known_senses.clear();
00163       //Load the known surface to volume sense data
00164 #ifdef HAVE_OCC
00165       load_stp_surf_sense_data( surfs[i], known_volume_ids, known_senses);
00166 #else
00167       load_sat_surf_sense_data( surfs[i], known_volume_ids, known_senses);
00168 #endif
00169
00170       check_sense_data( vols, senses, known_volume_ids, known_senses);
00171     }
00172 }
00173
00174
00175 //Loads reference surface to volume sense data into the reference vectors
00176 void load_sat_surf_sense_data( ModelEnt *surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out ){
00177
00178   int surf_id = geom_id_by_handle( surf->mesh_handle() );
00179   switch(surf_id)
00180   {
00181     case 1:
00182           vol_ids_out.push_back(1);
00183           senses_out.push_back(SENSE_FORWARD);
00184           break;
00185
00186     case 2:
00187           vol_ids_out.push_back(1);
00188           senses_out.push_back(SENSE_FORWARD);
00189           break;
00190
00191     case 3:
00192           vol_ids_out.push_back(1);
00193           senses_out.push_back(SENSE_FORWARD);
00194           break;
00195
00196     case 4:
00197           vol_ids_out.push_back(1);
00198           senses_out.push_back(SENSE_FORWARD);
00199           break;
00200
00201     case 5:
00202           vol_ids_out.push_back(1);
00203           senses_out.push_back(SENSE_FORWARD);
00204           break;
00205
00206     case 6:
00207           vol_ids_out.push_back(1);
00208           senses_out.push_back(SENSE_FORWARD);
00209           break;
00210
00211     case 7:
00212           vol_ids_out.push_back(2);
00213           senses_out.push_back(SENSE_FORWARD);
00214           break;
00215
00216     case 8:
00217           vol_ids_out.push_back(2);
00218           senses_out.push_back(SENSE_FORWARD);
00219           break;
00220
00221     case 9:
00222           vol_ids_out.push_back(2);
00223           senses_out.push_back(SENSE_FORWARD);
00224           break;
00225     default:
00226       std::cout << "Could not match the surface id to sense data." << std::endl;
00227       CHECK(false);
00228
00229    }
00230
00231 }
00232
00233 //Loads reference surface to volume sense data into the reference vectors
00234 void load_stp_surf_sense_data( ModelEnt *surf, std::vector<int>& vol_ids_out, std::vector<int>& senses_out ){
00235
00236   int surf_id = geom_id_by_handle( surf->mesh_handle() );
00237   switch(surf_id)
00238   {
00239     case 1:
00240           vol_ids_out.push_back(1);
00241           senses_out.push_back(SENSE_FORWARD);
00242           break;
00243
00244     case 2:
00245           vol_ids_out.push_back(1);
00246           senses_out.push_back(SENSE_FORWARD);
00247           break;
00248
00249     case 3:
00250           vol_ids_out.push_back(1);
00251           senses_out.push_back(SENSE_FORWARD);
00252           break;
00253
00254     case 4:
00255           vol_ids_out.push_back(1);
00256           senses_out.push_back(SENSE_FORWARD);
00257           break;
00258
00259     case 5:
00260           vol_ids_out.push_back(1);
00261           senses_out.push_back(SENSE_FORWARD);
00262           break;
00263
00264     case 6:
00265           vol_ids_out.push_back(1);
00266           senses_out.push_back(SENSE_FORWARD);
00267           break;
00268
00269     case 7:
00270           vol_ids_out.push_back(2);
00271           senses_out.push_back(SENSE_FORWARD);
00272           break;
00273
00274     case 8:
00275           vol_ids_out.push_back(2);
00276           senses_out.push_back(SENSE_FORWARD);
00277           break;
00278
00279     case 9:
00280           vol_ids_out.push_back(2);
00281           senses_out.push_back(SENSE_FORWARD);
00282           break;
00283
00284     case 10:
00285           vol_ids_out.push_back(2);
00286           senses_out.push_back(SENSE_FORWARD);
00287           break;
00288     default:
00289       std::cout << "Could not match surface id to sense data." << std::endl;
00290       CHECK(false);
00291    }
00292 }
00293
00294 //Loads two vectors with reference curve and curve_sense data
00295 void load_sat_curve_sense_data( ModelEnt* curve, std::vector<int>& surf_ids_out, std::vector<int>& senses_out )
00296 {
00297
00298   int curve_id = geom_id_by_handle( curve->mesh_handle() );
00299   switch(curve_id)
00300   {
00301     case 1:
00302           surf_ids_out.push_back(1); surf_ids_out.push_back(6);
00303           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00304           break;
00305
00306     case 2:
00307           surf_ids_out.push_back(1); surf_ids_out.push_back(5);
00308           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00309           break;
00310
00311     case 3:
00312           surf_ids_out.push_back(1); surf_ids_out.push_back(4);
00313           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00314           break;
00315
00316     case 4:
00317           surf_ids_out.push_back(1); surf_ids_out.push_back(3);
00318           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00319           break;
00320
00321     case 5:
00322           surf_ids_out.push_back(2); surf_ids_out.push_back(6);
00323           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00324           break;
00325
00326     case 6:
00327           surf_ids_out.push_back(2); surf_ids_out.push_back(3);
00328           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00329           break;
00330
00331     case 7:
00332           surf_ids_out.push_back(2); surf_ids_out.push_back(4);
00333           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00334           break;
00335
00336     case 8:
00337           surf_ids_out.push_back(2); surf_ids_out.push_back(5);
00338           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00339           break;
00340
00341     case 9:
00342           surf_ids_out.push_back(3); surf_ids_out.push_back(4);
00343           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00344           break;
00345
00346     case 10:
00347           surf_ids_out.push_back(3); surf_ids_out.push_back(6);
00348           senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00349           break;
00350
00351     case 11:
00352           surf_ids_out.push_back(4); surf_ids_out.push_back(5);
00353           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00354           break;
00355
00356     case 12:
00357           surf_ids_out.push_back(5); surf_ids_out.push_back(6);
00358           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00359           break;
00360
00361     case 13:
00362       surf_ids_out.push_back(7); surf_ids_out.push_back(8);
00363       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00364       break;
00365
00366     case 14:
00367       surf_ids_out.push_back(7); surf_ids_out.push_back(9);
00368       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00369       break;
00370     default:
00371       std::cout << "Could not match curve id to sense data" << std::endl;
00372       CHECK(false);
00373
00374   }
00375
00376 }
00377
00378
00379 //Loads two vectors with reference curve and curve_sense data
00380 void load_stp_curve_sense_data( ModelEnt* curve, std::vector<int>& surf_ids_out, std::vector<int>& senses_out )
00381 {
00382
00383   int curve_id = geom_id_by_handle( curve->mesh_handle() );
00384   switch(curve_id)
00385   {
00386     case 1:
00387           surf_ids_out.push_back(1); surf_ids_out.push_back(6);
00388           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00389           break;
00390
00391     case 2:
00392           surf_ids_out.push_back(1); surf_ids_out.push_back(5);
00393           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00394           break;
00395
00396     case 3:
00397           surf_ids_out.push_back(1); surf_ids_out.push_back(4);
00398           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00399           break;
00400
00401     case 4:
00402           surf_ids_out.push_back(1); surf_ids_out.push_back(3);
00403           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00404           break;
00405
00406     case 5:
00407           surf_ids_out.push_back(2); surf_ids_out.push_back(6);
00408           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00409           break;
00410
00411     case 6:
00412           surf_ids_out.push_back(2); surf_ids_out.push_back(3);
00413           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00414           break;
00415
00416     case 7:
00417           surf_ids_out.push_back(2); surf_ids_out.push_back(4);
00418           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00419           break;
00420
00421     case 8:
00422           surf_ids_out.push_back(2); surf_ids_out.push_back(5);
00423           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00424           break;
00425
00426     case 9:
00427           surf_ids_out.push_back(3); surf_ids_out.push_back(4);
00428           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00429           break;
00430
00431     case 10:
00432           surf_ids_out.push_back(3); surf_ids_out.push_back(6);
00433           senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00434           break;
00435
00436     case 11:
00437           surf_ids_out.push_back(4); surf_ids_out.push_back(5);
00438           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00439           break;
00440
00441     case 12:
00442           surf_ids_out.push_back(5); surf_ids_out.push_back(6);
00443           senses_out.push_back(SENSE_FORWARD); senses_out.push_back(SENSE_REVERSE);
00444           break;
00445
00446     case 13:
00447       surf_ids_out.push_back(7); surf_ids_out.push_back(8);
00448       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00449       break;
00450
00451     case 14:
00452       surf_ids_out.push_back(7); surf_ids_out.push_back(9);
00453       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00454       break;
00455     case 15:
00456       surf_ids_out.push_back(7); surf_ids_out.push_back(8);
00457       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00458       break;
00459     case 16:
00460       surf_ids_out.push_back(7); surf_ids_out.push_back(10);
00461       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00462       break;
00463     case 17:
00464       surf_ids_out.push_back(8); surf_ids_out.push_back(10);
00465       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00466       break;
00467     case 18:
00468       surf_ids_out.push_back(8); surf_ids_out.push_back(9);
00469       senses_out.push_back(SENSE_REVERSE); senses_out.push_back(SENSE_FORWARD);
00470       break;
00471     default:
00472       std::cout << "Could not match curve id to sense data" << std::endl;
00473       CHECK(false);
00474
00475   }
00476
00477 }
00478
00479
00480 void check_sense_data( std::vector<moab::EntityHandle> wrt_ents, std::vector<int> senses,
00481                        std::vector<int> known_wrt_ids, std::vector<int> known_senses )
00482 {
00483
00484   //Get ID's of the wrt entities
00485   std::vector<int> wrt_ent_ids;
00486
00487   for(unsigned int i=0 ; i<wrt_ents.size() ; i++)
00488   {
00489       wrt_ent_ids.push_back( geom_id_by_handle( wrt_ents[i] ) );
00490   }
00491
00492   for(unsigned int i=0; i< wrt_ent_ids.size() ; i++)
00493   {
00494      for(unsigned int j=0; j< known_wrt_ids.size(); j++)
00495      {
00496        if( wrt_ent_ids[i] == known_wrt_ids [j] )
00497          {
00498           // Make sure the senses of the matching wrt entities
00499           // are correct
00500           CHECK_EQUAL( senses[i], known_senses[j] );
00501           //Once a wrt entity is matched with a known entity,
00502           // remove it from the list
00503           wrt_ent_ids.erase( wrt_ent_ids.begin()+i );
00504           senses.erase( senses.begin()+i );
00505          }
00506      }
00507   }
00508
00509   // After both loops are complete, known_wrt_ents should be empty
00510   int leftovers = wrt_ent_ids.size();
00511   CHECK_EQUAL( leftovers, 0 );
00512
00513 }
00514
00515
00516 int geom_id_by_handle( moab::EntityHandle ent )
00517 {
00518
00519   moab::ErrorCode rval;
00520   //Get the id_tag handle
00521   moab::Tag id_tag;
00522   rval = mk->moab_instance()->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, moab::MB_TYPE_INTEGER, id_tag, moab::MB_TAG_DENSE );
00523   CHECK_ERR(rval);
00524
00525   //Load the ID for the EntHandle given to the function
00526   int id;
00527   rval = mk->moab_instance()->tag_get_data( id_tag, &ent, 1, &id );
00528   CHECK_ERR(rval);
00529
00530   return id;
00531
00532  }
00533
