MeshKit  1.0
test_point_edge_dist.cpp
00001 #include <iostream>
00002 #include <math.h>
00003
00004 double dot_product( double vect0[], double vect1[] ) {
00005   return vect0[0]*vect1[0] + vect0[1]*vect1[1] + vect0[2]*vect1[2];
00006 }
00007
00008 void cross_product( double vect0[], double vect1[], double vect2[] ) {
00009   vect2[0] = vect0[1]*vect1[2] - vect0[2]*vect1[1];
00010   vect2[1] = vect0[2]*vect1[0] - vect0[0]*vect1[2];
00011   vect2[2] = vect0[0]*vect1[1] - vect0[1]*vect1[0];
00012 }
00013
00014 double dist_between_verts( double coords0[], double coords1[] ) {
00015   return sqrt( (coords0[0]-coords1[0])*(coords0[0]-coords1[0]) +
00016                (coords0[1]-coords1[1])*(coords0[1]-coords1[1]) +
00017                (coords0[2]-coords1[2])*(coords0[2]-coords1[2]) );
00018 }
00019
00020 // from http://www.topcoder.com/tc?module=Static&d1=tutorials&d2=geometry1
00021 double point_edge_dist( double a[], double b[], double c[] ) {
00022   double ab[3], bc[3], ba[3], ac[3];
00023   for(int i=0; i<3; i++) {
00024     ab[i] = b[i] - a[i];
00025     bc[i] = c[i] - b[i];
00026     ba[i] = a[i] - b[i];
00027     ac[i] = c[i] - a[i];
00028   }
00029
00030   // find the magnitude of the cross product and test the line
00031   double cross_prod[3];
00032   cross_product(ab, ac, cross_prod);
00033   double dist = sqrt(dot_product(cross_prod,cross_prod)) / dist_between_verts(a,b);
00034
00035   // test endpoint1
00036   double dot1 = dot_product( ab, bc );
00037   if (dot1 > 0) {
00038     std::cout << "point_edge_dist=" << dist_between_verts(b,c) << " at endpt1" << std::endl;
00039     return dist_between_verts(b,c);
00040   }
00041
00042   // test endpoint0
00043   double dot2 = dot_product( ba, ac );
00044   if (dot2 > 0) {
00045     std::cout << "point_edge_dist=" << dist_between_verts(a,c) << " at endpt0" << std::endl;
00046     return dist_between_verts(a,c);
00047   }
00048
00049   std::cout << "point_edge_dist=" << fabs(dist) << " at middle" << std::endl;
00050   return fabs(dist);
00051 }
00052
00053 int main() {
00054   double a[] = { 859.5510374 ,90.1085829 ,1.929114349 };
00055   double b[] = { 859.5571858, 90.1057543, 2.56411115 };
00056   double c[] = { 859.556885,    90.105728,     2.564118 };
00057   std::cout << point_edge_dist( a,b,c) << std::endl;
00058 }
