MeshKit  1.0
triMeshOp.cpp
00001
00011 // C++
00012 #include <cstddef>
00013 #include <iostream>
00014 #include <string>
00015
00016 // MeshKit
00017 #include "meshkit/MKCore.hpp"
00018 #include "meshkit/AF2DfltTriangleMeshOp.hpp"
00019 #include "meshkit/SizingFunction.hpp"
00020 #include "meshkit/SizingFunctionVar.hpp"
00021 #include "meshkit/ModelEnt.hpp"
00022
00023 // MeshKit testing
00024 #include "TestUtil.hpp"
00025
00026 // define the geometry file extension depending on the geometry model
00027
00028 #if HAVE_OCC
00029 std::string geomExt = ".stp";
00030 #else
00031 std::string geomExt = ".facet";
00032 #define HAVE_FACET
00033 #endif
00034
00035 using namespace MeshKit;
00036
00037 MEntVector constructMeshOp(std::string geomFile);
00038 void testMesh(std::string geomFile,
00039     std::string meshFile, SizingFunction* sfPtr);
00040
00041 void testSquare();
00042 void testHoleySurf();
00043 void testSingleHoleSurf();
00044 void testSingleHoleSurfImprinted();
00045 void testSquareVarSize();
00046 void testPieceOfTorus();
00047 void testSphere();
00048 void testBrick();
00049
00050
00051 // This variable is at global scope because calling deleteAll on
00052 // the MKCore geometry instance appears to cause memory inconsistencies
00053 // with later use of the geometry instance
00054 MKCore* mk = NULL;
00055
00056 // These variables are at global scope because they affect all of
00057 // the tests.  There is no way provided to save only some of the
00058 // meshes
00059 bool saveMesh = false;
00060 std::string meshExt = "";
00061
00062 int main(int argc, char **argv)
00063 {
00064   // This variable is defined and used in main because a new MKCore
00065   // instance cannot be easily constructed after another MKCore
00066   // instance is deleted; there are problems with a tag left behind in
00067   // iGeom.
00068   mk = new MeshKit::MKCore();
00069
00070   int num_fail = 0;
00071
00072   if (argc == 2)
00073   {
00074     meshExt = argv[1];
00075     if (meshExt.size() > 0 && meshExt.at(0) != '.')
00076     {
00077       meshExt.insert(0, ".");
00078     }
00079     saveMesh = true;
00080     std::cout << "Requested meshes saved with file extension "
00081         << meshExt << std::endl;
00082   }
00083   num_fail += RUN_TEST(testSquare);
00084   num_fail += RUN_TEST(testSquareVarSize);
00085   num_fail += RUN_TEST(testPieceOfTorus);
00086 #ifdef HAVE_FACET
00087   num_fail += RUN_TEST(testBrick);
00088 #else
00089   num_fail += RUN_TEST(testHoleySurf);
00090   num_fail += RUN_TEST(testSingleHoleSurf);
00091   num_fail += RUN_TEST(testSingleHoleSurfImprinted);
00092   num_fail += RUN_TEST(testSphere);
00093 #endif
00094   delete mk;
00095
00096   return num_fail;
00097 }
00098
00107 MEntVector constructMeshOp(std::string geomFile)
00108 {
00109   // count the number of surfaces that existing before
00110   MEntVector temp;
00111   mk->get_entities_by_dimension(2, temp);
00112   unsigned int countExisting = temp.size();
00113   temp.clear();
00114
00115   // load the geometry
00116   std::string file_name = TestDir + "/" + geomFile + geomExt;
00117   mk->load_geometry(file_name.c_str());
00118
00119   // extract the new surfaces into an MEntVector
00120   MEntVector newSurfs;
00121   mk->get_entities_by_dimension(2, temp);
00122   unsigned int countAll = temp.size();
00123   unsigned int count = 0u;
00124   MEntVector::reverse_iterator surfItr = temp.rbegin();
00125   while (count < (countAll - countExisting))
00126   {
00127     newSurfs.push_back(*surfItr);
00128     ++count;
00129     ++surfItr;
00130   }
00131
00132   // Construct the AF2DfltTriangleMeshOp on the surfaces
00133   mk->construct_meshop("AF2DfltTriangleMeshOp", newSurfs);
00134
00135   return newSurfs;
00136 }
00137
00149 void testMesh(std::string geomFile,
00150     std::string meshFile, SizingFunction* sfPtr)
00151 {
00152   MEntVector surfs = constructMeshOp(geomFile);
00153
00154   // Set the size on the surfaces and their children edges
00155   // if a size was provided
00156   if (sfPtr != NULL)
00157   {
00158     for (unsigned int si = 0u; si < surfs.size(); ++si)
00159     {
00160       surfs[si]->sizing_function_index(sfPtr->core_index());
00161     }
00162   }
00163
00164   // setup and execute the MeshOp to mesh the surface
00165   mk->setup_and_execute();
00166
00167   // report the number of triangles
00168   moab::Range tris;
00169   moab::ErrorCode rval =
00170       mk->moab_instance()->get_entities_by_dimension(0, 2, tris);
00171   CHECK_EQUAL(moab::MB_SUCCESS, rval);
00172   std::cout << tris.size() << " tris generated." << std::endl;
00173
00174   // save the mesh if directed to do so
00175   if (saveMesh) {
00176     std::string outfile = meshFile + meshExt;
00177     moab::EntityHandle* outputSets = new moab::EntityHandle[surfs.size()];
00178     for (unsigned int si = 0u; si < surfs.size(); ++si)
00179     {
00180       outputSets[si] = surfs[si]->mesh_handle();
00181     }
00182     rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL,
00183         outputSets, surfs.size());
00184     MBERRCHK(rval, mk->moab_instance());
00185     delete[] outputSets;
00186   }
00187
00188   // remove the MeshOp and the rest of the graph
00189   mk->clear_graph();
00190
00191   // delete the triangles from the mesh
00192   mk->moab_instance()->delete_entities(tris);
00193 }
00194
00195 void testSquare()
00196 {
00197   // Provide a sizing function that will become the index 0 sizing function
00198   // and will be used on the edges.  Without this, there will be a failure
00199   // in the edge mesher.
00200   SizingFunction* sfPtr = new SizingFunction(mk, 5, -1);
00201   // Do not pass a sizing function to the surface, though.  It is not required.
00202   testMesh("squaresurf", "squaresurf", NULL);
00203   delete sfPtr;
00204 }
00205
00206 void testHoleySurf()
00207 {
00208   SizingFunction esize(mk, -1, 0.25);
00209   testMesh("holysurf", "holysurf", &esize);
00210 }
00211
00212 void testSingleHoleSurf()
00213 {
00214   SizingFunction esize(mk, -1, 0.25);
00215   testMesh("singleholesurf", "singleholesurf", &esize);
00216 }
00217
00218 void testSingleHoleSurfImprinted()
00219 {
00220   SizingFunction esize(mk, -1, 0.25);
00221   testMesh("singleholesurfimprinted", "singleholesurfimprinted", &esize);
00222 }
00223
00224
00225 void testSquareVarSize()
00226 {
00227   // make a sizing function and set it on the surface
00228   SizingFunctionVar svar(mk, -1, 0.1);
00229
00230   // these could be read from a file, or something
00231   double point0[3] = {0, 0, 0};
00232   double coeffs[4] = {0.05, 0.05, 0.05, 0.1};
00233   svar.set_linear_coeff(point0, coeffs);
00234
00235   // run the test
00236   testMesh("squaresurf", "squaresurf_var", &svar);
00237 }
00238
00239 void testPieceOfTorus()
00240 {
00241   SizingFunction esize(mk, -1, 0.25);
00242   testMesh("pieceOfTorus01", "pieceOfTorus01", &esize);
00243 }
00244
00245 void testSphere()
00246 {
00247   MEntVector surfs = constructMeshOp("sphere");
00248
00249   // Set the size to 1.0 on all surfaces of the sphere,
00250   // but don't pass the sizing down to the child edges to test
00251   // whether the setup method will do that
00252   SizingFunction esize(mk, -1, 1.0);
00253   for (unsigned int si = 0u; si < surfs.size(); ++si)
00254   {
00255     surfs[si]->sizing_function_index(esize.core_index(), false);
00256   }
00257
00258   // setup and execute the MeshOp to mesh the surface
00259   mk->setup_and_execute();
00260
00261   // report the number of triangles
00262   moab::Range tris;
00263   moab::ErrorCode rval =
00264       mk->moab_instance()->get_entities_by_dimension(0, 2, tris);
00265   CHECK_EQUAL(moab::MB_SUCCESS, rval);
00266   std::cout << tris.size() << " tris generated." << std::endl;
00267
00268   // save the mesh if directed to do so
00269   if (saveMesh) {
00270     std::string outfile = std::string("sphere") + meshExt;
00271     moab::EntityHandle* outputSets = new moab::EntityHandle[surfs.size()];
00272     for (unsigned int si = 0u; si < surfs.size(); ++si)
00273     {
00274       outputSets[si] = surfs[si]->mesh_handle();
00275     }
00276     rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL,
00277         outputSets, surfs.size());
00278     MBERRCHK(rval, mk->moab_instance());
00279     delete[] outputSets;
00280   }
00281
00282   // remove the MeshOp and the rest of the graph
00283   mk->clear_graph();
00284
00285   // delete the triangles from the mesh
00286   mk->moab_instance()->delete_entities(tris);
00287 }
00288
00289 void testBrick()
00290 {
00291   MEntVector surfs = constructMeshOp("brick");
00292
00293     // Set the size to 1.0 on all surfaces of the sphere,
00294     // but don't pass the sizing down to the child edges to test
00295     // whether the setup method will do that
00296     SizingFunction esize(mk, -1, 0.2);
00297     for (unsigned int si = 0u; si < surfs.size(); ++si)
00298     {
00299       surfs[si]->sizing_function_index(esize.core_index(), false);
00300     }
00301
00302     // setup and execute the MeshOp to mesh the surface
00303     mk->setup_and_execute();
00304
00305     // report the number of triangles
00306     moab::Range tris;
00307     moab::ErrorCode rval =
00308         mk->moab_instance()->get_entities_by_dimension(0, 2, tris);
00309     CHECK_EQUAL(moab::MB_SUCCESS, rval);
00310     std::cout << tris.size() << " tris generated." << std::endl;
00311
00312     // save the mesh if directed to do so
00313     if (saveMesh) {
00314       std::string outfile = std::string("brick") + meshExt;
00315       moab::EntityHandle* outputSets = new moab::EntityHandle[surfs.size()];
00316       for (unsigned int si = 0u; si < surfs.size(); ++si)
00317       {
00318         outputSets[si] = surfs[si]->mesh_handle();
00319       }
00320       rval = mk->moab_instance()->write_file(outfile.c_str(), NULL, NULL,
00321           outputSets, surfs.size());
00322       MBERRCHK(rval, mk->moab_instance());
00323       delete[] outputSets;
00324     }
00325
00326     // remove the MeshOp and the rest of the graph
00327     mk->clear_graph();
00328
00329     // delete the triangles from the mesh
00330     mk->moab_instance()->delete_entities(tris);
00331 }
