MeshKit  1.0
vectortemplate.hpp
00001
00006 #ifndef __MESHKIT_VECTORTEMPLATE_H__
00007 #define __MESHKIT_VECTORTEMPLATE_H__
00008
00009 #include <string>
00010 #include <iostream>
00011 #include <cassert>
00012 #include <stdlib.h>
00013
00014 // defines the vector template class
00015 template <class T>
00016 class CVector
00017 {
00018     private:
00019         int m_nRows;      // number of rows in the vector
00020         T   *m_pCells;    // address where the vector of
00021                           // type T is stored
00022         void ErrorHandler (int,int nR=0) const;
00023                           // handles error conditions
00024         void Release ();  // similar to destructor
00025         std::string m_szName;       // vector name
00026
00027     public:
00028         CVector ();                  // default constructor
00029         CVector (int);               // constructor
00030         CVector (const char*);       // constructor
00031         CVector (const char*, int);  // constructor
00032         CVector (const CVector<T>&); // copy constructor
00033         ~CVector ();                 // destructor
00034         void SetSize (int);     // sets the size of the vector
00035                                 // used with the default constructor
00036
00037         // helper functions
00038         // gets the current size of the vector
00039         int GetSize () const;
00040         // gets the vector name
00041         void GetName (std::string& szName) const;
00042
00043         // vector manipulations (mutator)
00044         void Set (T);           // sets the value of all
00045                                 // elements of a vector
00046         void SetName (const std::string&); // sets the name of the vector
00047
00048         // overloaded operators
00049         T& operator() (int);            // row access
00050         const T& operator() (int) const;// row access
00051         CVector<T>& operator= (const CVector<T>&);  // overloaded = operator
00052 };
00053
00054 // =============== definitions ===========================================
00055 template <class T>
00056 CVector<T>::CVector ()
00057 // ---------------------------------------------------------------------------
00058 // Function: default ctor
00059 // Input:    none
00060 // Output:   none
00061 // ---------------------------------------------------------------------------
00062 {
00063     m_pCells = NULL;
00064     m_nRows = 0;
00065 }
00066
00067 template <class T>
00068 CVector<T>::CVector (int n)
00069 // ---------------------------------------------------------------------------
00070 // Function: overloaded ctor
00071 // Input:    size of the vector
00072 // Output:   none
00073 // ---------------------------------------------------------------------------
00074 {
00075     m_pCells = NULL;
00076     m_nRows = 0;
00077     SetSize (n);
00078 }
00079
00080 template <class T>
00081 CVector<T>::CVector (const char* szName)
00082 // ---------------------------------------------------------------------------
00083 // Function: overloaded ctor
00084 // Input:    vector name
00085 // Output:   none
00086 // ---------------------------------------------------------------------------
00087 {
00088     m_pCells = NULL;
00089     m_nRows = 0;
00090         m_szName = szName;
00091 }
00092
00093 template <class T>
00094 CVector<T>::CVector (const char* szName, int n)
00095 // ---------------------------------------------------------------------------
00096 // Function: overloaded ctor
00097 // Input:    vector name and size
00098 // Output:   none
00099 // ---------------------------------------------------------------------------
00100 {
00101     m_pCells = NULL;
00102     m_nRows = 0;
00103         m_szName = szName;
00104     SetSize (n);
00105 }
00106
00107 template <class T>
00108 CVector<T>::CVector (const CVector<T>& A)
00109 // ---------------------------------------------------------------------------
00110 // Function: copy ctor
00111 // Input:    vector
00112 // Output:   none
00113 // ---------------------------------------------------------------------------
00114 {
00115     m_pCells = NULL;
00116     m_nRows = A.GetSize();
00117         m_szName = A.m_szName;
00118     SetSize (m_nRows);
00119     for (int i=1; i <= m_nRows; i++)
00120         m_pCells[i] = A.m_pCells[i];
00121 }
00122
00123 template <class T>
00124 void CVector<T>::SetSize (int nR)
00125 // ---------------------------------------------------------------------------
00126 // Function: dynamically allocates memory
00127 // Input:    vector size
00128 // Output:   none
00129 // ---------------------------------------------------------------------------
00130 {
00131     // check whether NR is legal
00132     if (nR <= 0) ErrorHandler (3);
00133     Release ();
00134     try {m_pCells = new T [nR + 1];}
00135     catch (std::bad_alloc) {ErrorHandler (1);}
00136     m_nRows = nR;
00137 #ifdef __RGGMETER
00138     m_dAllocated += static_cast<double>(sizeof(T)*(nR+1));
00139 #endif
00140 }
00141
00142 template <class T>
00143 CVector<T>::~CVector ()
00144 // ---------------------------------------------------------------------------
00145 // Function: dtor
00146 // Input:    none
00147 // Output:   none
00148 // ---------------------------------------------------------------------------
00149 {
00150     // deallocate storage
00151     Release ();
00152 }
00153
00154 template <class T>
00155 void CVector<T>::Release ()
00156 // ---------------------------------------------------------------------------
00157 // Function: dynamically deallocates memory
00158 // Input:    none
00159 // Output:   none
00160 // ---------------------------------------------------------------------------
00161 {
00162     // deallocate storage
00163     if (m_pCells != NULL)
00164     {
00165         delete [] m_pCells;
00166 #ifdef __RGGMETER
00167         m_dDeAllocated += static_cast<double>(sizeof(T)*(m_nRows+1));
00168 #endif
00169         m_pCells = NULL;
00170         m_nRows = 0;
00171     }
00172 }
00173
00174 // =============== member functions ===========================================
00175 template <class T>
00176 void CVector<T>::SetName (const std::string& szName)
00177 // ---------------------------------------------------------------------------
00178 // Function: sets the name of the vector
00179 // Input:    vector name
00180 // Output:   none
00181 // ---------------------------------------------------------------------------
00182 {
00183     m_szName = szName;
00184 }
00185
00186 template <class T>
00187 void CVector<T>::GetName (std::string& szName) const
00188 // ---------------------------------------------------------------------------
00189 // Function: gets the name of the vector
00190 // Input:    string to hold vector name
00191 // Output:   vector name
00192 // ---------------------------------------------------------------------------
00193 {
00194     szName = m_szName;
00195 }
00196
00197 template <class T>
00198 void CVector<T>::Set (T dV)
00199 // ---------------------------------------------------------------------------
00200 // Function: sets the value of all the elements in the vector to the
00201 //           specified value
00202 // Input:    specified value
00203 // Output:   none
00204 // ---------------------------------------------------------------------------
00205 {
00206     for (int i=1; i <= m_nRows; i++)
00207         m_pCells[i] = dV;
00208 }
00209
00210 template <class T>
00211 int CVector<T>::GetSize () const
00212 // ---------------------------------------------------------------------------
00213 // Function: gets the size of the vector
00214 // Input:    none
00215 // Output:   returns the size
00216 // ---------------------------------------------------------------------------
00217 {
00218     return m_nRows;
00219 }
00220
00221 // ==================== Overloaded Operators ========================
00222 #ifdef _DEBUG
00223 template <class T>
00224 T& CVector<T>::operator() (int nR)  // T& is reference
00225 // ---------------------------------------------------------------------------
00226 // Function: overloaded () operator to access vector contents
00227 //           carries out bound checking
00228 // Input:    index or location
00229 // Output:   value at the specified index
00230 // ---------------------------------------------------------------------------
00231 {
00232     // row-column reference in bounds?
00233     if (nR <= 0 || nR > m_nRows)
00234     {
00235         ErrorHandler (2,nR);
00236         return m_pCells[1];
00237     }
00238     else
00239         return m_pCells[nR];
00240 }
00241 #else
00242 template <class T>
00243 inline T& CVector<T>::operator() (int nR)
00244 // ---------------------------------------------------------------------------
00245 // Function: overloaded () operator to access vector contents
00246 // Input:    index or location
00247 // Output:   value at the specified index
00248 // ---------------------------------------------------------------------------
00249 {
00250     return m_pCells[nR];
00251 }
00252 #endif
00253
00254 #ifdef _DEBUG
00255 template <class T>
00256 const T& CVector<T>::operator() (int nR) const
00257 // ---------------------------------------------------------------------------
00258 // Function: overloaded () operator to access vector contents
00259 // Input:    index or location
00260 // Output:   value at the specified index
00261 // ---------------------------------------------------------------------------
00262 {
00263     // row-column reference in bounds?
00264     if (nR <= 0 || nR > m_nRows) {
00265         ErrorHandler (2,nR);
00266         return m_pCells[1];
00267     }
00268     else
00269         return m_pCells[nR];
00270 }
00271 #else
00272 template <class T>
00273 inline const T& CVector<T>::operator() (int nR) const
00274 // ---------------------------------------------------------------------------
00275 // Function: overloaded () operator to access vector contents
00276 // Input:    index or location
00277 // Output:   value at the specified index
00278 // ---------------------------------------------------------------------------
00279 {
00280     return m_pCells[nR];
00281 }
00282 #endif
00283
00284 template <class T>
00285 CVector<T>& CVector<T>::operator= (const CVector& matarg)
00286 // ---------------------------------------------------------------------------
00287 // Function: overloaded = operator
00288 // Input:    vector to use as rvalue
00289 // Output:   modified values
00290 // ---------------------------------------------------------------------------
00291 {
00292     // check whether vector is assigned to itself
00293     if (this != &matarg)
00294     {
00295         // compatible vectors?
00296         if (m_nRows != matarg.m_nRows)
00297         {
00298             ErrorHandler (4);
00299             return *this;
00300         }
00301         // now copy
00302         for (int i=1; i <= matarg.m_nRows; i++)
00303             m_pCells[i] = matarg.m_pCells[i];
00304     }
00305
00306     return *this;
00307 }
00308
00309 // ==================== Error Handler ========================
00310 template <class T>
00311 void CVector<T>::ErrorHandler (int nErrorCode, int nR) const
00312 // ---------------------------------------------------------------------------
00313 // Function: channels error message via std:err
00314 // Input:    error code and optional int value
00315 // Output:   none
00316 // ---------------------------------------------------------------------------
00317 {
00318     std::cerr << "CVector::Vector Name: " << m_szName << ".\n";
00319     switch (nErrorCode)
00320     {
00321         case 1:
00322             std::cerr << "Memory allocation failure.\n";
00323         break;
00324         case 2:
00325             std::cerr << "Row index is out of bounds.\n";
00326         break;
00327         case 3:
00328             std::cerr << "Constructor. Invalid number of rows "
00329                          "or columns.\n";
00330         break;
00331         case 4:
00332             std::cerr << "Constructor. Incompatible vectors.\n";
00333         break;
00334     }
00335     std::cerr << "Unable to populate vectors." << std::endl;
00336     exit (1);
00337 }
00338
00339 #endif
