AspectRatioGammaTest.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retian certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file AspectRatioGammaTest.cpp
00028  *  \brief unit tests for AspectRatioGammaQualityMetric
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "AspectRatioGammaQualityMetric.hpp"
00034 #include "cppunit/extensions/HelperMacros.h"
00035 #include "QualityMetricTester.hpp"
00036
00037 using namespace MBMesquite;
00038
00039 class AspectRatioGammaTest : public CppUnit::TestFixture
00040 {
00041   private:
00042     CPPUNIT_TEST_SUITE( AspectRatioGammaTest );
00043
00044     CPPUNIT_TEST( test_supported_types );
00045     CPPUNIT_TEST( test_ideal_element_eval );
00046     CPPUNIT_TEST( test_ideal_element_grad );
00047     CPPUNIT_TEST( test_measures_quality );
00048     CPPUNIT_TEST( test_gradient_reflects_quality );
00049     CPPUNIT_TEST( test_inverted_elements );
00050     CPPUNIT_TEST( test_degenerate_elements );
00051     CPPUNIT_TEST( test_get_evaluations );
00052     CPPUNIT_TEST( test_get_element_indices );
00053     CPPUNIT_TEST( test_get_fixed_indices );
00054     CPPUNIT_TEST( test_eval_with_indices );
00055     CPPUNIT_TEST( test_location_invariant );
00056     CPPUNIT_TEST( test_scale_invariant );
00057     CPPUNIT_TEST( test_orient_invariant );
00058
00059     CPPUNIT_TEST_SUITE_END();
00060
00061     AspectRatioGammaQualityMetric mMetric;
00062     QualityMetricTester tester;
00063
00064   public:
00065     AspectRatioGammaTest() : tester( QualityMetricTester::SIMPLICIES ) {}
00066
00067     void test_supported_types()
00068     {
00069         tester.test_supported_element_types( &mMetric );
00070     }
00071
00072     void test_ideal_element_eval()
00073     {
00074         tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 1.0 );
00075         tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 1.0 );
00076     }
00077
00078     void test_ideal_element_grad()
00079     {
00080         tester.test_ideal_element_zero_gradient( &mMetric, false );
00081     }
00082
00083     void test_measures_quality()
00084     {
00085         tester.test_measures_quality( &mMetric );
00086     }
00087
00088     void test_gradient_reflects_quality()
00089     {
00090         tester.test_gradient_reflects_quality( &mMetric );
00091     }
00092
00093     void test_inverted_elements()
00094     {
00095         tester.test_evaluate_inverted_element( &mMetric, false );
00096     }
00097
00098     void test_degenerate_elements()
00099     {
00100         tester.test_evaluate_degenerate_element( &mMetric, false );
00101     }
00102
00103     void test_get_evaluations()
00104     {
00105         tester.test_get_element_evaluations( &mMetric );
00106     }
00107
00108     void test_get_element_indices()
00109     {
00110         tester.test_get_element_indices( &mMetric );
00111     }
00112
00113     void test_get_fixed_indices()
00114     {
00115         tester.test_get_indices_fixed( &mMetric );
00116     }
00117
00118     void test_eval_with_indices()
00119     {
00120         tester.compare_eval_and_eval_with_indices( &mMetric );
00121     }
00122
00123     void test_location_invariant()
00124     {
00125         tester.test_location_invariant( &mMetric );
00126         tester.test_grad_location_invariant( &mMetric );
00127         tester.test_hessian_location_invariant( &mMetric );
00128     }
00129
00130     void test_scale_invariant()
00131     {
00132         tester.test_scale_invariant( &mMetric );
00133     }
00134
00135     void test_orient_invariant()
00136     {
00137         tester.test_orient_invariant( &mMetric );
00138         tester.test_grad_orient_invariant( &mMetric );
00139     }
00140 };
00141
00142 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( AspectRatioGammaTest, "AspectRatioGammaTest" );
00143 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( AspectRatioGammaTest, "Unit" );
