AxisBox.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 /**
00017  * \brief Class representing axis-aligned bounding box
00018  * \author Jason Kraftcheck ([email protected])
00019  * \date August, 2006
00020  */
00021
00022 #include "AxisBox.hpp"
00023 #include "moab/Range.hpp"
00024 #include <cassert>
00025
00026 namespace moab
00027 {
00028
00029 const char* const AXIS_BOX_TAG_NAME = "AXIS_BOX";
00030
00031 ErrorCode AxisBox::get_tag( Tag& tag_out, Interface* interface, const char* tagname )
00032 {
00033     assert( sizeof( AxisBox ) == 6 * sizeof( double ) );
00034
00035     if( !tagname ) tagname = AXIS_BOX_TAG_NAME;
00036
00037     return interface->tag_get_handle( tagname, sizeof( AxisBox ), MB_TYPE_DOUBLE, tag_out,
00038                                       MB_TAG_DENSE | MB_TAG_CREAT | MB_TAG_BYTES );
00039 }
00040
00041 ErrorCode AxisBox::calculate( AxisBox& box, EntityHandle set, Interface* interface )
00042 {
00043     Range range;
00044     ErrorCode rval = interface->get_entities_by_handle( set, range );
00045     if( MB_SUCCESS != rval ) return rval;
00046
00047     return calculate( box, range, interface );
00048 }
00049
00050 ErrorCode AxisBox::calculate( AxisBox& box, const Range& entities, Interface* interface )
00051 {
00052     ErrorCode rval;
00053     Range vertices;
00054     Range elements;
00055
00056     elements.merge( entities.upper_bound( MBVERTEX ), entities.lower_bound( MBENTITYSET ) );
00057     rval = interface->get_adjacencies( elements, 0, false, vertices );
00058     if( MB_SUCCESS != rval ) return rval;
00059
00060     vertices.merge( entities.begin(), entities.upper_bound( MBVERTEX ) );
00061
00062     std::vector< double > coords( 3 * vertices.size() );
00063     rval = interface->get_coords( vertices, &coords[0] );
00064     if( MB_SUCCESS != rval ) return rval;
00065
00066     box                                     = AxisBox();
00067     std::vector< double >::const_iterator i = coords.begin();
00068     for( ; i != coords.end(); i += 3 )
00069         box |= &*i;
00070
00071     return MB_SUCCESS;
00072 }
00073
00074 }  // namespace moab
