BSPTree.cpp File Reference
#include "moab/BSPTree.hpp"
#include "moab/GeomUtil.hpp"
#include "moab/Range.hpp"
#include "Internals.hpp"
#include "moab/BSPTreePoly.hpp"
#include "moab/Util.hpp"
#include <cassert>
#include <cstring>
#include <algorithm>
#include <limits>
+ Include dependency graph for BSPTree.cpp:
Classes
class  moab::BoxPlaneIter
class  moab::BSPTreePlaneIter
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Defines
#define MB_BSP_TREE_DEFAULT_TAG_NAME   "BSPTree"
Functions
static void moab::corners_from_box (const double box_min[3], const double box_max[3], double corners[8][3])
static bool moab::point_in_box (const double corners[8][3], const double point[3])
static void moab::copy_coords (const double src[3], double dest[3])
static void moab::plane_cut_edge (double old_coords_out[3], const double keep_end_coords[3], double cut_end_coords[3], const BSPTree::Plane &plane)
 Clip an edge using a plane.
static ErrorCode moab::plane_cut_box (double cut_face_out[4][3], double corners_inout[8][3], const BSPTree::Plane &plane)
static ErrorCode moab::plane_uncut_box (const double cut_face_in[4][3], double corners_inout[8][3], const BSPTree::Plane &plane)
static void moab::subtr (double result[3], const double a[3], const double b[3])
static void moab::sum (double result[3], const double a[3], const double b[3], const double c[3], const double d[3])
static void moab::cross (double result[3], const double a[3], const double b[3])
static double moab::dot (const double a[3], const double b[3])
template<typename PlaneIter >
static bool moab::ray_intersect_halfspaces (const CartVect &ray_pt, const CartVect &ray_dir, const PlaneIter &begin, const PlaneIter &end, double &t_enter, double &t_exit)
Variables
static const int moab::box_face_corners [6][4]
Detailed Description
Author:
Jason Kraftcheck ([email protected])
Date:
2008-05-13
Definition in file BSPTree.cpp.
Define Documentation
Definition at line 37 of file BSPTree.cpp.
Referenced by moab::BSPTree::init_tags().
