Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
#include "moab/CartVect.hpp"
#include <iostream>
#include <fstream>
Functions | |
double | getLat (CartVect p) |
double | getLon (CartVect p) |
int | main (int argc, char **argv) |
Variables | |
string | bd_name = string( MESH_DIR ) + string( "/../examples/earth/boundary_points.dat" ) |
string | loops = string( MESH_DIR ) + string( "/../examples/earth/SaveLoopCounts" ) |
Definition at line 21 of file BoundaryContinents.cpp.
References moab::CartVect::normalize().
Referenced by main().
{ p.normalize(); return asin( p[2] ); }
Definition at line 26 of file BoundaryContinents.cpp.
{ p.normalize(); double lon; lon = atan2( p[1], p[0] ); if( lon < -2.95 ) { // this is Behring Strait :) return 2.0 * M_PI + lon; } else { return lon; } }
int main | ( | int | argc, |
char ** | argv | ||
get loops for boundaries
Definition at line 42 of file BoundaryContinents.cpp.
References moab::Interface::add_entities(), bd_name, moab::Range::begin(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ReadUtilIface::get_element_connect(), getLat(), getLon(), moab::Interface::globalId_tag(), moab::Range::insert(), length_squared(), loops, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MBEDGE, MESHSET_SET, moab::Interface::query_interface(), moab::Interface::set_coords(), moab::Range::size(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
{ // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; if( argc > 1 ) { // User has input file for boundary describing continents bd_name = argv[1]; } if( argc > 2 ) { // User has input file for loops for continents/islands loops = argv[2]; } std::vector< double > coords; ifstream bdFile( bd_name.c_str() ); if( !bdFile ) { cout << endl << "Failed to open file " << bd_name << endl; ; return 1; } coords.resize( 0 ); while( !bdFile.eof() ) { double co; bdFile >> co; coords.push_back( co ); } cout << " number of boundary points:" << coords.size() / 3 << "\n"; /// get loops for boundaries vector< int > loopsindx; ifstream loopFile( loops.c_str() ); while( !loopFile.eof() ) { int indx; loopFile >> indx; loopsindx.push_back( indx ); } cout << "number of loops: " << loopsindx.size() / 2 << "\n"; ReadUtilIface* readMeshIface; mb->query_interface( readMeshIface ); Range verts; ErrorCode rval = mb->create_vertices( &coords[0], coords.size() / 3, verts );MB_CHK_SET_ERR( rval, "do not create boundary vertices" ); Tag gid = mb->globalId_tag(); int num_edges = 0; for( size_t i = 0; i < loopsindx.size() / 2; i++ ) { num_edges += ( loopsindx[2 * i + 1] - loopsindx[2 * i] + 1 ); } EntityHandle handle; EntityHandle* conn_array; rval = readMeshIface->get_element_connect( num_edges, 2, MBEDGE, 1, handle, conn_array );MB_CHK_SET_ERR( rval, "do not elems" ); int i1 = 0; // index in edge connectivity for( size_t i = 0; i < loopsindx.size() / 2; i++ ) { for( int j = loopsindx[2 * i]; j <= loopsindx[2 * i + 1]; j++ ) { int j2; j2 = j; if( j == loopsindx[2 * i + 1] ) j2 = loopsindx[2 * i] - 1; // close the loop conn_array[2 * i1] = verts[j - 1]; // vertices for sure start at 1 conn_array[2 * i1 + 1] = verts[j2]; // vertices for sure start at 1 i1++; } // the last vertex is first one in the loop } Range bedges( handle, handle + num_edges - 1 ); EntityHandle bound_set; rval = mb->create_meshset( MESHSET_SET, bound_set );MB_CHK_SET_ERR( rval, "Can't create boundary edges set" ); rval = mb->add_entities( bound_set, bedges );MB_CHK_SET_ERR( rval, "Can't add edges to boundary set" ); // set global ids for vertices and edges vector< int > gids; gids.resize( verts.size() ); for( int j = 0; j < (int)verts.size(); j++ ) { gids[j] = j + 1; } rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on verts" ); // we have less edges than vertices, we can reuse the array for edges too rval = mb->tag_set_data( gid, bedges, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on edges" ); mb->write_file( "bound.vtk", 0, 0, &bound_set, 1 ); // now project the mesh in 2d plane // get all the vertices coordinates std::vector< CartVect > co3; co3.resize( verts.size() ); rval = mb->get_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't get vertex coords" ); for( size_t i = 0; i < verts.size(); i++ ) { CartVect p = co3[i]; double lat1 = getLat( p ); double lon1 = getLon( p ); co3[i] = CartVect( lon1, lat1, 0. ); } rval = mb->set_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't set new vertex coords" ); // remove edges in 2d that are too long (longer than 6; they are on the other side..., periodic) Range longEdges; for( Range::iterator eit = bedges.begin(); eit != bedges.end(); ++eit ) { EntityHandle eh = *eit; const EntityHandle* conn; int nconn; rval = mb->get_connectivity( eh, conn, nconn );MB_CHK_ERR( rval ); // get coordinates of nodes CartVect c2[2]; rval = mb->get_coords( conn, 2, &( c2[0][0] ) );MB_CHK_ERR( rval ); double dist = ( c2[1] - c2[0] ).length_squared(); if( dist > 36. ) // too long edge in 2d, remove it longEdges.insert( eh ); } rval = mb->delete_entities( longEdges );MB_CHK_ERR( rval ); mb->write_file( "bound2d.vtk" ); delete mb; return 0; }
Definition at line 18 of file BoundaryContinents.cpp.
Definition at line 19 of file BoundaryContinents.cpp.
