Core.cpp File Reference
#include <iostream>
#include <sstream>
#include <vector>
#include <string>
#include <algorithm>
#include "moab/Core.hpp"
#include "MeshSetSequence.hpp"
#include "ElementSequence.hpp"
#include "VertexSequence.hpp"
#include <cassert>
#include "AEntityFactory.hpp"
#include "ReadUtil.hpp"
#include "WriteUtil.hpp"
#include "moab/CN.hpp"
#include "moab/HigherOrderFactory.hpp"
#include "SequenceManager.hpp"
#include "moab/Error.hpp"
#include "moab/ReaderWriterSet.hpp"
#include "moab/ReaderIface.hpp"
#include "moab/WriterIface.hpp"
#include "moab/ScdInterface.hpp"
#include "moab/SetIterator.hpp"
#include "BitTag.hpp"
#include "DenseTag.hpp"
#include "MeshTag.hpp"
#include "SparseTag.hpp"
#include "VarLenDenseTag.hpp"
#include "VarLenSparseTag.hpp"
#include <sys/stat.h>
#include <cerrno>
#include <cstring>
#include "WriteVtk.hpp"
#include "MBTagConventions.hpp"
#include "ExoIIUtil.hpp"
#include "EntitySequence.hpp"
#include "moab/FileOptions.hpp"
+ Include dependency graph for Core.cpp:
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Defines
#define MOAB_MPE_LOG   "moab.mpe"
#define DefaultWriterName   "WriteVtk"
#define ALLOW_NULL_FOR_MESH_TAG
#define CHECK_MESH_NULL
Typedefs
typedef moab::WriteVtk DefaultWriter
Functions
static void warn_null_array_mesh_tag ()
static const MeshSet * moab::get_mesh_set (const SequenceManager *sm, EntityHandle h)
static MeshSet * moab::get_mesh_set (SequenceManager *sm, EntityHandle h)
template<typename ITER >
static ErrorCode moab::get_adjacencies_union (Core *gMB, ITER begin, ITER end, int to_dimension, bool create_if_missing, Range &adj_entities)
static ErrorCode moab::get_adjacencies_intersection (Core *mb, ITER begin, ITER end, const int to_dimension, const bool create_if_missing, std::vector< EntityHandle > &adj_entities)
static ErrorCode moab::get_adjacencies_intersection (Core *mb, ITER begin, ITER end, const int to_dimension, const bool create_if_missing, Range &adj_entities)
static bool moab::is_zero_bytes (const void *mem, size_t size)
Define Documentation
Definition at line 114 of file Core.cpp.
Value:
EntityHandle root = 0;                            \
    if( NULL == entity_handles && 0 == num_entities ) \
        entity_handles = &root;                       \
        num_entities   = 1;                           \
        warn_null_array_mesh_tag();                   \
Definition at line 131 of file Core.cpp.
Referenced by moab::Core::tag_clear_data(), moab::Core::tag_delete_data(), moab::Core::tag_get_by_ptr(), moab::Core::tag_get_data(), moab::Core::tag_set_by_ptr(), and moab::Core::tag_set_data().
Definition at line 88 of file Core.cpp.
Referenced by moab::Core::write_file().
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 22 of file Core.cpp.
Referenced by moab::Core::deinitialize().
Typedef Documentation
Definition at line 87 of file Core.cpp.
Function Documentation
static void warn_null_array_mesh_tag ( ) [static]
Definition at line 125 of file Core.cpp.
    std::cerr << "WARNING: Accepting empty array to indicate mesh tag" << std::endl;
