Core.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifndef MOAB_IMPL_GENERAL_HPP
00017 #define MOAB_IMPL_GENERAL_HPP
00018
00019 #include "moab/Interface.hpp"
00020 #include "moab/ReaderIface.hpp"
00021 #include <map>
00022 #include <list>
00023
00024 namespace moab
00025 {
00026
00027 class WriteUtil;
00028 class ReadUtil;
00029 class ScdInterface;
00030 class AEntityFactory;
00031 class SequenceManager;
00032 class Error;
00033 class HomCoord;
00034 class ReaderWriterSet;
00035 class EntitySequence;
00036 class FileOptions;
00037 class SetIterator;
00038
00039 #ifdef MOAB_HAVE_AHF
00040 class HalfFacetRep;
00041 #endif
00042
00043 /**\class Core
00044  * \brief Implementation of MOAB Interface
00045  * Implementation of the MOAB Interface class.  You shouldn't call functions directly
00046  * on an object of type Core (use Interface instead), unless you really have to access
00047  * non-API functionality.
00048  */
00049 class Core : public Interface
00050 {
00051
00052   public:
00053     friend class SetIterator;
00054
00055     //! constructor
00056     Core();
00057
00058     //! destructor
00059     ~Core();
00060
00061     //! Get a pointer to an internal MOAB interface
00062     //!\return NULL if not found, iterface pointer otherwise
00063     virtual ErrorCode query_interface_type( const std::type_info& interface_type, void*& ptr );
00064
00065     //! Release reference to MB interface
00066     virtual ErrorCode release_interface_type( const std::type_info& interface_type, void* iface );
00067
00068     virtual int QueryInterface( const MBuuid& uuid, UnknownInterface** iface );
00069
00070     //! Returns the major.minor version number of the implementation
00071     /**
00072        \param iface_name If non-NULL, will be filled in with a string, possibly
00073        containing implementation-specific information
00074     */
00075     virtual float impl_version( std::string* version_string = NULL );
00076
00077     //! get the type from a handle, returns type
00078     virtual EntityType type_from_handle( const EntityHandle handle ) const;
00079
00080     //! get the id from a handle, returns id
00081     virtual EntityID id_from_handle( const EntityHandle handle ) const;
00082
00083     //! get a handle from an id and type
00084     virtual ErrorCode handle_from_id( const EntityType type, const EntityID id, EntityHandle& handle ) const;
00085
00086     virtual int dimension_from_handle( const EntityHandle ) const;
00087
00088     //! load mesh from data in file
00089     //! NOTE: if there is mesh already present, the new mesh will be added
00090     virtual ErrorCode load_mesh( const char* file_name,
00091                                  const int* active_block_id_list = NULL,
00092                                  const int num_blocks            = 0 );
00093
00094     /**Load or import a file. */
00095     virtual ErrorCode load_file( const char* file_name,
00096                                  const EntityHandle* file_set = 0,
00097                                  const char* options          = 0,
00098                                  const char* set_tag_name     = 0,
00099                                  const int* set_tag_vals      = 0,
00100                                  int num_set_tag_vals         = 0 );
00101
00102     /**Load or import a file. */
00103     ErrorCode serial_load_file( const char* file_name,
00104                                 const EntityHandle* file_set,
00105                                 const FileOptions& opts,
00106                                 const ReaderIface::SubsetList* subsets = 0,
00107                                 const Tag* file_id_tag                 = 0 );
00108
00109     ErrorCode serial_read_tag( const char* file_name,
00110                                const char* tag_name,
00111                                const FileOptions& opts,
00112                                std::vector< int >& tag_vals,
00113                                const ReaderIface::SubsetList* subsets = 0 );
00114
00115     virtual ErrorCode write_mesh( const char* file_name,
00116                                   const EntityHandle* output_list = NULL,
00117                                   const int num_sets              = 0 );
00118     /** Write or export a file. */
00119     virtual ErrorCode write_file( const char* file_name,
00120                                   const char* file_type           = 0,
00121                                   const char* options             = 0,
00122                                   const EntityHandle* output_sets = 0,
00123                                   int num_output_sets             = 0,
00124                                   const Tag* tag_list             = 0,
00125                                   int num_tags                    = 0 );
00126
00127     /** Write or export a file */
00128     virtual ErrorCode write_file( const char* file_name,
00129                                   const char* file_type,
00130                                   const char* options,
00131                                   const Range& output_sets,
00132                                   const Tag* tag_list = 0,
00133                                   int num_tags        = 0 );
00134
00135     //! deletes all mesh entities from this datastore
00136     virtual ErrorCode delete_mesh();
00137
00138     //! get overall geometric dimension
00139     virtual ErrorCode get_dimension( int& dim ) const;
00140
00141     //! set overall geometric dimension
00142     /** Returns error if setting to 3 dimensions, mesh has been created, and
00143      *  there are only 2 dimensions on that mesh
00144      */
00145     virtual ErrorCode set_dimension( const int dim );
00146
00147     //! get blocked vertex coordinates for all vertices
00148     /** Blocked = all x, then all y, etc.
00149      */
00150     virtual ErrorCode get_vertex_coordinates( std::vector< double >& coords ) const;
00151
00152     //! get pointers to coordinate data
00153     virtual ErrorCode coords_iterate( Range::const_iterator iter,
00154                                       Range::const_iterator end,
00155                                       double*& xcoords_ptr,
00156                                       double*& ycoords_ptr,
00157                                       double*& zcoords_ptr,
00158                                       int& count );
00159
00160     //! get the coordinate information for this handle if it is of type Vertex
00161     //! otherwise, return an error
00162     virtual ErrorCode get_coords( const Range& entities, double* coords ) const;
00163
00164     virtual ErrorCode get_coords( const EntityHandle* entities, const int num_entities, double* coords ) const;
00165
00166     virtual ErrorCode get_coords( const EntityHandle entity_handle,
00167                                   const double*& x,
00168                                   const double*& y,
00169                                   const double*& z ) const;
00170
00171     virtual ErrorCode get_coords( const Range& entities, double* x_coords, double* y_coords, double* z_coords ) const;
00172
00173     //! set the coordinate information for this handle if it is of type Vertex
00174     //! otherwise, return an error
00175     virtual ErrorCode set_coords( const EntityHandle* entity_handles, const int num_entities, const double* coords );
00176
00177     //! set the coordinate information for this handle if it is of type Vertex
00178     //! otherwise, return an error
00179     virtual ErrorCode set_coords( Range entity_handles, const double* coords );
00180
00181     //! get global connectivity array for specified entity type
00182     /**  Assumes just vertices, no higher order nodes
00183      */
00184     virtual ErrorCode get_connectivity_by_type( const EntityType type, std::vector< EntityHandle >& connect ) const;
00185
00186     //! get pointer to connectivity data
00187     virtual ErrorCode connect_iterate( Range::const_iterator iter,
00188                                        Range::const_iterator end,
00189                                        EntityHandle*& connect,
00190                                        int& verts_per_entity,
00191                                        int& count );
00192
00193     //! Gets the connectivity for an element EntityHandle.
00194     /** For non-element handles (ie, MeshSets),
00195      * returns an error. Connectivity data is copied from the database into the vector
00196      *   <em>connectivity</em>. The nodes in <em>connectivity</em> are properly ordered.
00197      *  \param entity_handle EntityHandle to get connectivity of.
00198      *  \param connectivity Vector in which connectivity of <em>entity_handle</em> is returned.
00199      *   Should contain MeshVertices.
00200      *  \param corners_only If true, returns only corner vertices, otherwise returns all of them
00201      * (including any higher-order vertices)
00202      *
00203      *   Example: \code
00204      *   std::vector<EntityHandle> conn;
00205      *   get_connectivity( entity_handle, conn ); \endcode
00206      */
00207     virtual ErrorCode get_connectivity( const EntityHandle* entity_handles,
00208                                         const int num_handles,
00209                                         std::vector< EntityHandle >& connectivity,
00210                                         bool corners_only           = false,
00211                                         std::vector< int >* offsets = NULL ) const;
00212
00213     //! Gets the connectivity for a vector of elements
00214     /** Same as vector-based version except range is returned (unordered!)
00215      */
00216     virtual ErrorCode get_connectivity( const EntityHandle* entity_handles,
00217                                         const int num_handles,
00218                                         Range& connectivity,
00219                                         bool corners_only = false ) const;
00220
00221     //! Gets the connectivity for elements
00222     /** Same as vector-based version except range is returned (unordered!)
00223      */
00224     virtual ErrorCode get_connectivity( const Range& from_entities,
00225                                         Range& adj_entities,
00226                                         bool corners_only = false ) const;
00227
00228     //! Gets a pointer to constant connectivity data of <em>entity_handle</em>
00229     /** Sets <em>number_nodes</em> equal to the number of nodes of the <em>
00230         entity_handle </em>.  Faster then the other <em>get_connectivity</em> function.
00231         The nodes in 'connectivity' are properly ordered.
00232         \param entity_handle EntityHandle to get connectivity of.
00233         \param connectivity Array in which connectivity of <em>entity_handle</em> is returned.
00234         Should contain MBVERTEX's.
00235         \param num_nodes Number of MeshVertices in array <em>connectivity</em>.
00236
00237         Example: \code
00238         const EntityHandle* conn;
00239         int number_nodes = 0;
00240         get_connectivity( entity_handle, conn, number_nodes ); \endcode
00241
00242         Example2: \code
00243         std::vector<EntityHandle> sm_storage;
00244         const EntityHandle* conn;
00245         int number_nodes;
00246         get_connectivity( handle, conn, number_nodes, false, &sm_storage );
00247         if (conn == &sm_storage[0])
00248           std::cout << "Structured mesh element" << std::endl;
00249         \endcode
00250       */
00251     virtual ErrorCode get_connectivity( const EntityHandle entity_handle,
00252                                         const EntityHandle*& connectivity,
00253                                         int& number_nodes,
00254                                         bool corners_only                    = false,
00255                                         std::vector< EntityHandle >* storage = 0 ) const;
00256
00257     //! Sets the connectivity for an EntityHandle.  For non-element handles, return an error.
00258     /** Connectivity is stored exactly as it is ordered in vector <em>connectivity</em>.
00259         \param entity_handle EntityHandle to set connectivity of.
00260         \param connect Vector containing new connectivity of <em>entity_handle</em>.
00261         \param num_connect Number of vertices in <em>connect</em>
00262
00263         Example: \code
00264         std::vector<EntityHandle> conn(3);
00265         conn[0] = node1;
00266         conn[1] = node2;
00267         conn[2] = node3;
00268         set_connectivity( entity_handle, conn, 3 ); \endcode */
00269     virtual ErrorCode set_connectivity( const EntityHandle entity_handle,
00270                                         EntityHandle* connect,
00271                                         const int num_connect );
00272
00273     //! get the adjacencies associated with a set of entities
00274     /** \param from_entities vector of EntityHandle to get adjacencies of.
00275         \param to_dimension Dimension of desired adjacency information.
00276         \param adj_entities Vector in which adjacent EntityHandles are returned.
00277         \param operation_type enum of INTERSECT or UNION.  Defines whether to take
00278         the intersection or union of the set of adjacencies recovered for the from_entities.
00279
00280         The adjacent entities in vector <em>adjacencies</em> are not in any particular
00281         order.
00282
00283         Example: \code
00284           // get the set of edges that are adjacent to all entities in the from_entities list
00285           std::vector<EntityHandle> from_entities = {hex1, hex2};
00286           std::vector<EntityHandle> adjacencies;
00287           get_adjacencies( from_entities, MB_1D_ENTITY, adjacencies );
00288           \endcode */
00289
00290     virtual ErrorCode get_adjacencies( const EntityHandle* from_entities,
00291                                        const int num_entities,
00292                                        const int to_dimension,
00293                                        const bool create_if_missing,
00294                                        std::vector< EntityHandle >& adj_entities,
00295                                        const int operation_type = Interface::INTERSECT );
00296
00297     virtual ErrorCode get_adjacencies( const EntityHandle* from_entities,
00298                                        const int num_entities,
00299                                        const int to_dimension,
00300                                        const bool create_if_missing,
00301                                        Range& adj_entities,
00302                                        const int operation_type = Interface::INTERSECT );
00303
00304     virtual ErrorCode get_adjacencies( const Range& from_entities,
00305                                        const int to_dimension,
00306                                        const bool create_if_missing,
00307                                        Range& adj_entities,
00308                                        const int operation_type = Interface::INTERSECT );
00309
00310     /**\brief Get a ptr to adjacency lists
00311      * Get a pointer to adjacency lists.  These lists are std::vector<EntityHandle>, which are
00312      * pointed to by adjs[i].  Adjacencies are not guaranteed to be in order of increasing
00313      * dimension.  Only a const version of this function is given, because adjacency data is managed
00314      * more carefully in MOAB and should be treated as read-only by applications.  If adjacencies
00315      * have not yet been initialized, adjs_ptr will be NULL (i.e. adjs_ptr == NULL).  There may also
00316      * be NULL entries for individual entities, i.e. adjs_ptr[i] == NULL. \param iter Iterator to
00317      * beginning of entity range desired \param end End iterator for which adjacencies are requested
00318      * \param adjs_ptr Pointer to pointer to const std::vector<EntityHandle>; each member of that
00319      * array is the vector of adjacencies for this entity \param count Number of entities in the
00320      * contiguous chunk starting from *iter
00321      */
00322     ErrorCode adjacencies_iterate( Range::const_iterator iter,
00323                                    Range::const_iterator end,
00324                                    const std::vector< EntityHandle >**& adjs_ptr,
00325                                    int& count );
00326
00327     /**\brief Get all vertices for input entities
00328      *
00329      * Special case of get_adjacencies where to_dimension == 0
00330      * and operation_type == Interface::UNION.
00331      *\Note This is not a variation of get_connectivity because
00332      *      the behavior is different for polyhedra.
00333      */
00334     virtual ErrorCode get_vertices( const Range& from_entities, Range& vertices );
00335
00336     //! Adds adjacencies
00337     /** \param from_handle entities
00338         \param both_ways add the adjacency information to both the
00339         to_handle and and the from_from :handle
00340
00341         Example: \code
00342     */
00343     virtual ErrorCode add_adjacencies( const EntityHandle entity_handle,
00344                                        const EntityHandle* adjacencies,
00345                                        const int num_handles,
00346                                        bool both_ways );
00347
00348     //! Adds adjacencies; same as vector-based, but with range instead
00349     virtual ErrorCode add_adjacencies( const EntityHandle entity_handle, Range& adjacencies, bool both_ways );
00350
00351     //! Removes adjacencies
00352     /** \param handle EntityHandle to get adjacencies of.
00353
00354     Example: \code
00355     */
00356     virtual ErrorCode remove_adjacencies( const EntityHandle entity_handle,
00357                                           const EntityHandle* adjacencies,
00358                                           const int num_handles );
00359
00360     //! Retrieves all entities in the database of given dimension.
00361     /** \param dimension Dimension of entities desired.
00362         \param entities Range in which entities of dimension <em>dimension</em> are returned.
00363
00364         Example: \code
00365         int dimension = 2;
00366         Range entities;
00367         get_entities_by_dimension( dimension, entities ); //get 2D EntityHandles in the database
00368         \endcode */
00369     virtual ErrorCode get_entities_by_dimension( const EntityHandle meshset,
00370                                                  const int dimension,
00371                                                  Range& entities,
00372                                                  const bool recursive = false ) const;
00373
00374     virtual ErrorCode get_entities_by_dimension( const EntityHandle meshset,
00375                                                  const int dimension,
00376                                                  std::vector< EntityHandle >& entities,
00377                                                  const bool recursive = false ) const;
00378
00379     //! Retrieves all entities in the data base of given type.
00380     /** \param type EntityType of entities desired (ie, MBHEX, MBEDGE, MBTRI, etc )
00381         \param entities Range in which entities of EntityType <em>type</em> are returned.
00382
00383         Example: \code
00384         EntityType type = MBTET;
00385         Range entities;
00386         get_entities_by_dimension( type, entities ); //get MBTET type EntityHandles in the database
00387         \endcode */
00388     virtual ErrorCode get_entities_by_type( const EntityHandle meshset,
00389                                             const EntityType type,
00390                                             Range& entities,
00391                                             const bool recursive = false ) const;
00392
00393     //! Retrieves all entities in the data base of given type.
00394     /** \param type EntityType of entities desired (ie, MBHEX, MBEDGE, MBTRI, etc )
00395         \param entities Range in which entities of EntityType <em>type</em> are returned.
00396
00397         Example: \code
00398         EntityType type = MBTET;
00399         Range entities;
00400         get_entities_by_dimension( type, entities ); //get MBTET type EntityHandles in the database
00401         \endcode */
00402     virtual ErrorCode get_entities_by_type( const EntityHandle meshset,
00403                                             const EntityType type,
00404                                             std::vector< EntityHandle >& entities,
00405                                             const bool recursive = false ) const;
00406
00407     virtual ErrorCode get_entities_by_type_and_tag( const EntityHandle meshset,
00408                                                     const EntityType type,
00409                                                     const Tag* tags,
00410                                                     const void* const* values,
00411                                                     const int num_tags,
00412                                                     Range& entities,
00413                                                     const int condition  = Interface::INTERSECT,
00414                                                     const bool recursive = false ) const;
00415
00416     //! Retrieves all entities in the data base
00417     /** \param entities Range in which entities of EntityType <em>type</em> are returned.
00418
00419     Example: \code
00420     Range entities;
00421     get_entities( entities ); //get MBTET type EntityHandles in the database
00422     \endcode */
00423     virtual ErrorCode get_entities_by_handle( const EntityHandle meshset,
00424                                               Range& entities,
00425                                               const bool recursive = false ) const;
00426
00427     //! Retrieves all entities in the data base
00428     /** \param entities Range in which entities of EntityType <em>type</em> are returned.
00429
00430     Example: \code
00431     Range entities;
00432     get_entities( entities ); //get MBTET type EntityHandles in the database
00433     \endcode */
00434     virtual ErrorCode get_entities_by_handle( const EntityHandle meshset,
00435                                               std::vector< EntityHandle >& entities,
00436                                               const bool recursive = false ) const;
00437
00438     //! Retrieves all entities in the database of given dimension.
00439     /** \param dimension Dimension of entities desired.
00440         \param entities Range in which entities of dimension <em>dimension</em> are returned.
00441
00442         Example: \code
00443         int dimension = 2;
00444         Range entities;
00445         get_entities_by_dimension( dimension, entities ); //get 2D EntityHandles in the database
00446         \endcode */
00447     virtual ErrorCode get_number_entities_by_dimension( const EntityHandle meshset,
00448                                                         const int dimension,
00449                                                         int& number,
00450                                                         const bool recursive = false ) const;
00451
00452     //! Retrieves all entities in the data base of given type.
00453     /** \param type EntityType of entities desired (ie, MBHEX, MBEDGE, MBTRI, etc )
00454         \param entities Range in which entities of EntityType <em>type</em> are returned.
00455
00456         Example: \code
00457         EntityType type = MBTET;
00458         Range entities;
00459         get_entities_by_dimension( type, entities ); //get MBTET type EntityHandles in the database
00460         \endcode */
00461     virtual ErrorCode get_number_entities_by_type( const EntityHandle meshset,
00462                                                    const EntityType type,
00463                                                    int& num_entities,
00464                                                    const bool recursive = false ) const;
00465
00466     virtual ErrorCode get_number_entities_by_type_and_tag( const EntityHandle meshset,
00467                                                            const EntityType type,
00468                                                            const Tag* tag_handles,
00469                                                            const void* const* values,
00470                                                            const int num_tags,
00471                                                            int& num_entities,
00472                                                            const int condition  = Interface::INTERSECT,
00473                                                            const bool recursive = false ) const;
00474
00475     //! Retrieves all entities in the data base
00476     /** \param entities Range in which entities of EntityType <em>type</em> are returned.
00477
00478     Example: \code
00479     Range entities;
00480     get_entities( entities ); //get MBTET type EntityHandles in the database
00481     \endcode */
00482     virtual ErrorCode get_number_entities_by_handle( const EntityHandle meshset,
00483                                                      int& num_entities,
00484                                                      const bool recursive = false ) const;
00485
00486     //! Creates an element based on the type and connectivity.
00487     /** If connectivity vector is not correct for EntityType <em>type</em> (ie, a vector with
00488         3 vertices is passed in to make an MBQUAD), the function returns MB_FAILURE.
00489         \param type Type of element to create. (MBTET, MBTRI, MBKNIFE, etc.)
00490         \param connectivity Vector containing connectivity of element to create.
00491         \param handle EntityHandle representing the newly created element in the database.
00492
00493         Example: \code
00494         EntityType type = MBQUAD;
00495         std::vector<EntityHandle> connectivity(4);
00496         quad_conn[0] = vertex0;
00497         quad_conn[1] = vertex1;
00498         quad_conn[2] = vertex2;
00499         quad_conn[3] = vertex3;
00500         EntityHandle element_handle;
00501         create_element( type, connectivity, element_handle ); \endcode */
00502     virtual ErrorCode create_element( const EntityType type,
00503                                       const EntityHandle* connectivity,
00504                                       const int num_nodes,
00505                                       EntityHandle& element_handle );
00506
00507     //! Creates a vertex based on coordinates.
00508     /**
00509        \param coordinates Array that has 3 doubles in it.
00510        \param entity_handle EntityHandle representing the newly created vertex in the database.
00511
00512        Example: \code
00513        double *coordinates = double[3];
00514        coordinates[0] = 1.034;
00515        coordinates[1] = 23.23;
00516        coordinates[2] = -0.432;
00517        EntityHandle entity_handle = 0;
00518        create_vertex( coordinates, entity_handle ); \endcode */
00519     virtual ErrorCode create_vertex( const double coords[3], EntityHandle& entity_handle );
00520
00521     //! Create a set of vertices with the specified coordinates
00522     /**
00523        \param coordinates Array that has 3*n doubles in it.
00524        \param nverts Number of vertices to create
00525        \param entity_handles Range passed back with new vertex handles
00526     */
00527     virtual ErrorCode create_vertices( const double* coordinates, const int nverts, Range& entity_handles );
00528
00529     //! merges two entities
00530     virtual ErrorCode merge_entities( EntityHandle entity_to_keep,
00531                                       EntityHandle entity_to_remove,
00532                                       bool auto_merge,
00533                                       bool delete_removed_entity );
00534
00535     //! Removes entities in a vector from the data base.
00536     /** If any of the entities are contained in any meshsets, it is removed from those meshsets
00537         which were created with MESHSET_TRACK_OWNER option bit set.  Tags for <em>entity<\em> are
00538         removed as part of this function.
00539         \param entities 1d vector of entities to delete
00540         \param num_entities Number of entities in 1d vector
00541     */
00542     virtual ErrorCode delete_entities( const EntityHandle* entities, const int num_entities );
00543
00544     //! Removes entities in a range from the data base.
00545     /** If any of the entities are contained in any meshsets, it is removed from those meshsets
00546         which were created with MESHSET_TRACK_OWNER option bit set.  Tags for <em>entity<\em> are
00547         removed as part of this function.
00548         \param entities Range of entities to delete
00549     */
00550     virtual ErrorCode delete_entities( const Range& range );
00551
00552     virtual ErrorCode list_entities( const Range& temp_range ) const;
00553
00554     virtual ErrorCode list_entities( const EntityHandle* entities, const int num_entities ) const;
00555
00556     virtual ErrorCode list_entity( const EntityHandle entity ) const;
00557
00558     typedef unsigned long long type_memstorage;
00559
00560     //! function object for recieving events from MB of higher order nodes
00561     //! added to entities
00562     class HONodeAddedRemoved
00563     {
00564       public:
00565         HONodeAddedRemoved() {}
00566         virtual ~HONodeAddedRemoved() {}
00567         //! node_added called when a node was added to an element's connectivity array
00568         //! note: connectivity array of element may be incomplete (corner nodes will exist always)
00569         virtual void node_added( EntityHandle node, EntityHandle element );
00570         virtual void node_removed( EntityHandle node );
00571     };
00572
00573     virtual ErrorCode convert_entities( const EntityHandle meshset,
00574                                         const bool mid_side,
00575                                         const bool mid_face,
00576                                         const bool mid_volume,
00577                                         Interface::HONodeAddedRemoved* function_object = 0 );
00578
00579     //! function to get the side number given two elements; returns
00580     //! MB_FAILURE if child not related to parent; does *not* create adjacencies
00581     //! between parent and child
00582     virtual ErrorCode side_number( const EntityHandle parent,
00583                                    const EntityHandle child,
00584                                    int& sd_number,
00585                                    int& sense,
00586                                    int& offset ) const;
00587
00588     //! given an entity and the connectivity and type of one of its subfacets, find the
00589     //! high order node on that subfacet, if any
00590     virtual ErrorCode high_order_node( const EntityHandle parent_handle,
00591                                        const EntityHandle* subfacet_conn,
00592                                        const EntityType subfacet_type,
00593                                        EntityHandle& hon ) const;
00594
00595     //! given an entity and a target dimension & side number, get that entity
00596     virtual ErrorCode side_element( const EntityHandle source_entity,
00597                                     const int dim,
00598                                     const int sd_number,
00599                                     EntityHandle& target_entity ) const;
00600
00601     //-------------------------Tag Stuff-------------------------------------//
00602
00603     /**\brief Get a tag handle, possibly creating the tag
00604      *
00605      * Get a handle used to associate application-defined values
00606      * with MOAB entities.  If the tag does not already exist then
00607      * \c flags should contain exactly one of \c MB_TAG_SPARSE,
00608      * \c MB_TAG_DENSE, \c MB_TAG_MESH unless \c type is MB_TYPE_BIT,
00609      * which implies \c MB_TAG_BIT storage.
00610      * .
00611      *\param name          The tag name
00612      *\param size          Tag size as number of values of of data type per entity
00613      *                     (or number of bytes if \c MB_TAG_BYTES is passed in flags).  If \c
00614      *MB_TAG_VARLEN is specified, this value is taken to be the size of the default value if one is
00615      *specified and is otherwise ignored. \param type          The type of the data (used for IO)
00616      *\param tag_handle    Output: the resulting tag handle.
00617      *\param flags         Bitwise OR of values from \c TagType
00618      *\param default_value Optional default value for tag.
00619      *\param created       Optional returned boolean indicating that the tag
00620      *                     was created.
00621      *\return - \c MB_ALREADY_ALLOCATED     if tag exists and \c MB_TAG_EXCL is specified, or
00622      *default values do not match (and \c MB_TAG_ANY or \c MB_TAG_DFTOK not specified).
00623      *        - \c MB_TAG_NOT_FOUND         if tag does not exist and \c MB_TAG_CREAT is not
00624      *specified
00625      *        - \c MB_INVALID_SIZE          if tag value size is not a multiple of the size of the
00626      *data type (and \c MB_TAG_ANY not specified).
00627      *        - \c MB_TYPE_OUT_OF_RANGE     invalid or inconsistent parameter
00628      *        - \c MB_VARIABLE_DATA_LENGTH  if \c MB_TAG_VARLEN and \c default_value is non-null and
00629      *                                      \c default_value_size is not specified.
00630      */
00631     virtual ErrorCode tag_get_handle( const char* name,
00632                                       int size,
00633                                       DataType type,
00634                                       Tag& tag_handle,
00635                                       unsigned flags            = 0,
00636                                       const void* default_value = 0,
00637                                       bool* created             = 0 );
00638
00639     /**\brief same as non-const version, except that TAG_CREAT flag is ignored. */
00640     virtual ErrorCode tag_get_handle( const char* name,
00641                                       int size,
00642                                       DataType type,
00643                                       Tag& tag_handle,
00644                                       unsigned flags            = 0,
00645                                       const void* default_value = 0 ) const;
00646
00647     //! Gets the tag name string of the tag_handle.
00648     /** \param tag_handle Tag you want the name of.
00649         \param tag_name Name string of <em>tag_handle</em>.
00650
00651         Example: \code
00652         Tag tag_handle = 0;
00653         std::string tag_name = "my_special_tag";
00654         tag_get_name( tag_handle, tag_name );  //gets the Tag from the tag's name string
00655         \endcode */
00656     virtual ErrorCode tag_get_name( const Tag tag_handle, std::string& tag_name ) const;
00657
00658     /**\brief Gets the tag handle corresponding to a name
00659      *
00660      * If a tag of that name does not exist, returns MB_TAG_NOT_FOUND
00661      *   \param tag_name Name of the desired tag.
00662      *   \param tag_handle Tag handle corresponding to <em>tag_name</em>
00663      */
00664     virtual ErrorCode tag_get_handle( const char* tag_name, Tag& tag_handle ) const;
00665
00666     //! Get handles for all tags defined on this entity
00667     virtual ErrorCode tag_get_tags_on_entity( const EntityHandle entity, std::vector< Tag >& tag_handles ) const;
00668
00669     //! Get the size of the specified tag in bytes
00670     virtual ErrorCode tag_get_bytes( const Tag tag, int& tag_size ) const;
00671
00672     //! Get the array length of a tag
00673     virtual ErrorCode tag_get_length( const Tag tag, int& tag_size ) const;
00674
00675     //! Get the default value of the specified tag
00676     virtual ErrorCode tag_get_default_value( const Tag tag, void* def_val ) const;
00677     virtual ErrorCode tag_get_default_value( Tag tag, const void*& ptr, int& size ) const;
00678
00679     //! get type of tag (sparse, dense, etc.; 0 = dense, 1 = sparse, 2 = bit, 3 = mesh)
00680     virtual ErrorCode tag_get_type( const Tag, TagType& tag_type ) const;
00681
00682     /** \brief Get data type of tag.
00683      *
00684      * Get the type of the tag data.  The tag is data is assumed to
00685      * be a vector of this type.  If the tag data vetcor contains
00686      * more than one value, then the tag size must be a multiple of
00687      * the size of this type.
00688      * \param tag  The tag
00689      * \param type The type of the specified tag (output).
00690      */
00691     virtual ErrorCode tag_get_data_type( const Tag handle, DataType& type ) const;
00692
00693     //! get handles for all tags defined
00694     virtual ErrorCode tag_get_tags( std::vector< Tag >& tag_handles ) const;
00695
00696     virtual ErrorCode tag_get_data( const Tag tag_handle,
00697                                     const EntityHandle* entity_handles,
00698                                     const int num_entities,
00699                                     void* tag_data ) const;
00700
00701     virtual ErrorCode tag_get_data( const Tag tag_handle, const Range& entity_handles, void* tag_data ) const;
00702
00703     //! Sets the data of a given EntityHandle and Tag.
00704     /** If the <em>tag_handle</em> and the entity type of <em>entity_handle</em> are not
00705         compatible, data of <em>entity_handle</em> never existed and MB_FAILURE
00706         is returned.
00707         \param tag_handle Tag indicating what data is to be set.
00708         \param entity_handle EntityHandle on which to set tag's data.
00709         \param tag_data Data to set the <em>entity_handle</em>'s tag data to.
00710
00711         Example: \code
00712         int tag_data = 1004;
00713         tag_set_data( tag_handle, entity_handle, &tag_data ); \endcode */
00714     virtual ErrorCode tag_set_data( Tag tag_handle,
00715                                     const EntityHandle* entity_handles,
00716                                     int num_entities,
00717                                     const void* tag_data );
00718
00719     virtual ErrorCode tag_set_data( Tag tag_handle, const Range& entity_handles, const void* tag_data );
00720
00721     /**\brief Get pointers to tag data
00722      *
00723      * For a tag, get the values for a list of passed entity handles.
00724      *\note  This function may not be used for bit tags.
00725      *\param tag_handle     The tag
00726      *\param entity_handles An array of entity handles for which to retreive tag values.
00727      *\param num_entities   The length of the 'entity_handles' array.
00728      *\param tag_data       An array of 'const void*'.  Array must be at least
00729      *                      'num_entitities' long.  Array is populated (output)
00730      *                      with pointers to the internal storage for the
00731      *                      tag value corresponding to each entity handle.
00732      *\param tag_sizes      The length of each tag value.  Optional for
00733      *                      fixed-length tags.  Required for variable-length tags.
00734      */
00735     virtual ErrorCode tag_get_by_ptr( const Tag tag_handle,
00736                                       const EntityHandle* entity_handles,
00737                                       int num_entities,
00738                                       const void** tag_data,
00739                                       int* tag_sizes = 0 ) const;
00740
00741     /**\brief Get pointers to tag data
00742      *
00743      * For a tag, get the values for a list of passed entity handles.
00744      *\note  This function may not be used for bit tags.
00745      *\param tag_handle     The tag
00746      *\param entity_handles The entity handles for which to retreive tag values.
00747      *\param tag_data       An array of 'const void*'.  Array is populated (output)
00748      *                      with pointers to the internal storage for the
00749      *                      tag value corresponding to each entity handle.
00750      *\param tag_sizes      The length of each tag value.  Optional for
00751      *                      fixed-length tags.  Required for variable-length tags.
00752      */
00753     virtual ErrorCode tag_get_by_ptr( const Tag tag_handle,
00754                                       const Range& entity_handles,
00755                                       const void** tag_data,
00756                                       int* tag_sizes = 0 ) const;
00757
00758     /**\brief Set tag data given an array of pointers to tag values.
00759      *
00760      * For a tag, set the values for a list of passed entity handles.
00761      *\note  This function may not be used for bit tags.
00762      *\param tag_handle     The tag
00763      *\param entity_handles An array of entity handles for which to set tag values.
00764      *\param num_entities   The length of the 'entity_handles' array.
00765      *\param tag_data       An array of 'const void*'.  Array must be at least
00766      *                      'num_entitities' long.  Array is expected to
00767      *                      contain pointers to tag values for the corresponding
00768      *                      EntityHandle in 'entity_handles'.
00769      *\param tag_sizes      The length of each tag value.  Optional for
00770      *                      fixed-length tags.  Required for variable-length tags.
00771      */
00772     virtual ErrorCode tag_set_by_ptr( Tag tag_handle,
00773                                       const EntityHandle* entity_handles,
00774                                       int num_entities,
00775                                       void const* const* tag_data,
00776                                       const int* tag_sizes = 0 );
00777
00778     /**\brief Set tag data given an array of pointers to tag values.
00779      *
00780      * For a tag, set the values for a list of passed entity handles.
00781      *\note  This function may not be used for bit tags.
00782      *\param tag_handle     The tag
00783      *\param entity_handles The entity handles for which to set tag values.
00784      *\param tag_data       An array of 'const void*'.  Array is expected to
00785      *                      contain pointers to tag values for the corresponding
00786      *                      EntityHandle in 'entity_handles'.
00787      *\param tag_sizes      The length of each tag value.  Optional for
00788      *                      fixed-length tags.  Required for variable-length tags.
00789      */
00790     virtual ErrorCode tag_set_by_ptr( Tag tag_handle,
00791                                       const Range& entity_handles,
00792                                       void const* const* tag_data,
00793                                       const int* tag_sizes = 0 );
00794
00795     /**\brief Set tag data given value.
00796      *
00797      * For a tag, set the values for a list of passed entity handles to
00798      * the same, specified value.
00799      *
00800      *\param tag_handle     The tag
00801      *\param entity_handles The entity handles for which to set tag values.
00802      *\param tag_data       A pointer to the tag value.
00803      *\param tag_sizes      For variable-length tags, the lenght of the
00804      *                      tag value.  This argument will be ignored for
00805      *                      fixed-length tags.
00806      */
00807     virtual ErrorCode tag_clear_data( Tag tag_handle,
00808                                       const Range& entity_handles,
00809                                       const void* tag_data,
00810                                       int tag_size = 0 );
00811
00812     /**\brief Set tag data given value.
00813      *
00814      * For a tag, set the values for a list of passed entity handles to
00815      * the same, specified value.
00816      *
00817      *\param tag_handle     The tag
00818      *\param entity_handles The entity handles for which to set tag values.
00819      *\param tag_data       A pointer to the tag value.
00820      *\param tag_sizes      For variable-length tags, the lenght of the
00821      *                      tag value.  This argument will be ignored for
00822      *                      fixed-length tags.
00823      */
00824     virtual ErrorCode tag_clear_data( Tag tag_handle,
00825                                       const EntityHandle* entity_handles,
00826                                       int num_entities,
00827                                       const void* tag_data,
00828                                       int tag_size = 0 );
00829
00830     //! Delete the data of a vector of entity handles and sparse tag
00831     /** Delete the data of a tag on a vector of entity handles.  Only sparse tag data are deleted
00832        with this function; dense tags are deleted by deleting the tag itself using tag_delete.
00833         \param tag_handle Handle of the (sparse) tag being deleted from entity
00834         \param entity_handles 1d vector of entity handles from which the tag is being deleted
00835         \param num_handles Number of entity handles in 1d vector
00836     */
00837     virtual ErrorCode tag_delete_data( Tag tag_handle, const EntityHandle* entity_handles, int num_entities );
00838
00839     //! Delete the data of a range of entity handles and sparse tag
00840     /** Delete the data of a tag on a range of entity handles.  Only sparse tag data are deleted
00841        with this function; dense tags are deleted by deleting the tag itself using tag_delete.
00842         \param tag_handle Handle of the (sparse) tag being deleted from entity
00843         \param entity_range Range of entities from which the tag is being deleted
00844     */
00845     virtual ErrorCode tag_delete_data( Tag tag_handle, const Range& entity_handles );
00846
00847     //! Removes the tag from the database and deletes all of its associated data.
00848     virtual ErrorCode tag_delete( Tag tag_handle );
00849
00850     /**\brief Access tag data via direct pointer into contiguous blocks
00851      *
00852      * Iteratively obtain direct access to contiguous blocks of tag
00853      * storage.  This function cannot be used with bit tags because
00854      * of the compressed bit storage.  This function cannot be used
00855      * with variable length tags because it does not provide a mechanism
00856      * to determine the length of the value for each entity.  This
00857      * function may be used with sparse tags, but if it is used, it
00858      * will return data for a single entity at a time.
00859      *
00860      *\param tag_handle  The handle of the tag for which to access data
00861      *\param iter        The first entity for which to return data.
00862      *\param end         One past the last entity for which data is desired.
00863      *\param count       The number of entities for which data was returned
00864      *\param data_ptr    Output: pointer to tag storage.
00865      *\param allocate    If true, space for this tag will be allocated, if not it wont
00866      *
00867      *\Note If this function is called for entities for which no tag value
00868      *      has been set, but for which a default value exists, it will
00869      *      force the allocation of explicit storage for each such entity
00870      *      even though MOAB would normally not explicitly store tag values
00871      *      for such entities.
00872      *
00873      *\Example:
00874      *\code
00875      * Range ents; // range to iterate over
00876      * Tag tag; // tag for which to access data
00877      * int bytes;
00878      * ErrorCode err = mb.tag_get_size( tag, bytes );
00879      * if (err) { ... }
00880      *
00881      * ...
00882      * Range::iterator iter = ents.begin();
00883      * while (iter != ents.end()) {
00884      *   int count;
00885      *    // get contiguous block of tag dat
00886      *   void* ptr;
00887      *   err = mb.tag_iterate( tag, iter, ents.end(), count, ptr );
00888      *   if (err) { ... }
00889      *    // do something with tag data
00890      *   process_Data( ptr, count );
00891      *    // advance to next block of data
00892      *   iter += count;
00893      * }
00894      *\endcode
00895      */
00896     virtual ErrorCode tag_iterate( Tag tag_handle,
00897                                    Range::const_iterator iter,
00898                                    Range::const_iterator end,
00899                                    int& count,
00900                                    void*& data_ptr,
00901                                    bool allocate = true );
00902
00903     //! creates a mesh set
00904     virtual ErrorCode create_meshset( const unsigned int options, EntityHandle& ms_handle, int start_id = 0 );
00905
00906     //! Empty a vector of mesh set
00907     /** Empty a mesh set.
00908         \param ms_handles 1d vector of handles of sets being emptied
00909         \param num_meshsets Number of entities in 1d vector
00910     */
00911     virtual ErrorCode clear_meshset( const EntityHandle* ms_handles, const int num_meshsets );
00912
00913     //! Empty a range of mesh set
00914     /** Empty a mesh set.
00915         \param ms_handles Range of handles of sets being emptied
00916     */
00917     virtual ErrorCode clear_meshset( const Range& ms_handles );
00918
00919     //! get the options of a mesh set
00920     virtual ErrorCode get_meshset_options( const EntityHandle ms_handle, unsigned int& options ) const;
00921
00922     //! set the options of a mesh set
00923     virtual ErrorCode set_meshset_options( const EntityHandle ms_handle, const unsigned int options );
00924
00925     //! subtracts meshset2 from meshset1 - modifies meshset1
00926     virtual ErrorCode subtract_meshset( EntityHandle meshset1, const EntityHandle meshset2 );
00927
00928     //! intersects meshset2 with meshset1 - modifies meshset1
00929     virtual ErrorCode intersect_meshset( EntityHandle meshset1, const EntityHandle meshset2 );
00930
00931     //! unites meshset2 with meshset1 - modifies meshset1
00932     virtual ErrorCode unite_meshset( EntityHandle meshset1, const EntityHandle meshset2 );
00933
00934     //! add entities to meshset
00935     virtual ErrorCode add_entities( EntityHandle meshset, const Range& entities );
00936
00937     //! add entities to meshset
00938     virtual ErrorCode add_entities( EntityHandle meshset, const EntityHandle* entities, const int num_entities );
00939
00940     //! remove entities from meshset
00941     virtual ErrorCode remove_entities( EntityHandle meshset, const Range& entities );
00942
00943     //! remove entities from meshset
00944     virtual ErrorCode remove_entities( EntityHandle meshset, const EntityHandle* entities, const int num_entities );
00945
00946     //! return true if all entities are contained in set
00947     virtual bool contains_entities( EntityHandle meshset,
00948                                     const EntityHandle* entities,
00949                                     int num_entities,
00950                                     const int operation_type = Interface::INTERSECT );
00951
00952     //! replace entities
00953     virtual ErrorCode replace_entities( EntityHandle meshset,
00954                                         const EntityHandle* old_entities,
00955                                         const EntityHandle* new_entities,
00956                                         int num_entities );
00957
00958     //------MeshSet Parent/Child functions------
00959
00960     //! get parent meshsets
00961     virtual ErrorCode get_parent_meshsets( const EntityHandle meshset,
00962                                            std::vector< EntityHandle >& parents,
00963                                            const int num_hops = 1 ) const;
00964
00965     //! get parent meshsets
00966     virtual ErrorCode get_parent_meshsets( const EntityHandle meshset, Range& parents, const int num_hops = 1 ) const;
00967
00968     //! get child meshsets
00969     virtual ErrorCode get_child_meshsets( const EntityHandle meshset,
00970                                           std::vector< EntityHandle >& children,
00971                                           const int num_hops = 1 ) const;
00972
00973     //! get child meshsets
00974     virtual ErrorCode get_child_meshsets( const EntityHandle meshset, Range& children, const int num_hops = 1 ) const;
00975
00976     //! get contained meshsets
00977     virtual ErrorCode get_contained_meshsets( const EntityHandle meshset,
00978                                               std::vector< EntityHandle >& children,
00979                                               const int num_hops = 1 ) const;
00980
00981     //! get contained meshsets
00982     virtual ErrorCode get_contained_meshsets( const EntityHandle meshset,
00983                                               Range& children,
00984                                               const int num_hops = 1 ) const;
00985
00986     //! gets number of parent meshsets
00987     virtual ErrorCode num_parent_meshsets( const EntityHandle meshset, int* number, const int num_hops = 1 ) const;
00988
00989     //! gets number of child meshsets
00990     virtual ErrorCode num_child_meshsets( const EntityHandle meshset, int* number, const int num_hops = 1 ) const;
00991
00992     //! gets number of contained meshsets
00993     virtual ErrorCode num_contained_meshsets( const EntityHandle meshset, int* number, const int num_hops = 1 ) const;
00994
00995     //! add a parent meshset
00996     virtual ErrorCode add_parent_meshset( EntityHandle meshset, const EntityHandle parent_meshset );
00997
00998     //! add parent meshsets
00999     virtual ErrorCode add_parent_meshsets( EntityHandle meshset, const EntityHandle* parents, int count );
01000
01001     //! add a child meshset
01002     virtual ErrorCode add_child_meshset( EntityHandle meshset, const EntityHandle child_meshset );
01003
01004     //! add parent meshsets
01005     virtual ErrorCode add_child_meshsets( EntityHandle meshset, const EntityHandle* children, int count );
01006
01007     //! adds 'parent' to child's parent list and adds 'child' to parent's child list
01008     virtual ErrorCode add_parent_child( EntityHandle parent, EntityHandle child );
01009
01010     //! removes 'parent' to child's parent list and removes 'child' to parent's child list
01011     virtual ErrorCode remove_parent_child( EntityHandle parent, EntityHandle child );
01012
01013     //! remove parent meshset
01014     virtual ErrorCode remove_parent_meshset( EntityHandle meshset, const EntityHandle parent_meshset );
01015
01016     //! remove child meshset
01017     virtual ErrorCode remove_child_meshset( EntityHandle meshset, const EntityHandle child_meshset );
01018
01019     // ************************  tag  information ***************
01020
01021     //! return various specific tag handles
01022     Tag material_tag();
01023     Tag neumannBC_tag();
01024     Tag dirichletBC_tag();
01025     Tag globalId_tag();
01026     Tag geom_dimension_tag();
01027
01028     //! get/set the number of nodes
01029     // int total_num_nodes() const;
01030     // void total_num_nodes(const int val);
01031
01032     //! get/set the number of elements
01033     // int total_num_elements() const;
01034     // void total_num_elements(const int val);
01035
01036     // ************************  structured sequence  information ***************
01037
01038     //! return a reference to the sequence manager
01039     SequenceManager* sequence_manager()
01040     {
01041         return sequenceManager;
01042     }
01043     const SequenceManager* sequence_manager() const
01044     {
01045         return sequenceManager;
01046     }
01047
01048     /// create structured sequence
01049     ErrorCode create_scd_sequence( const HomCoord& coord_min,
01050                                    const HomCoord& coord_max,
01051                                    EntityType type,
01052                                    EntityID start_id_hint,
01053                                    EntityHandle& first_handle_out,
01054                                    EntitySequence*& sequence_out );
01055
01056     ErrorCode add_vsequence( EntitySequence* vert_seq,
01057                              EntitySequence* elem_seq,
01058                              const HomCoord& p1,
01059                              const HomCoord& q1,
01060                              const HomCoord& p2,
01061                              const HomCoord& q2,
01062                              const HomCoord& p3,
01063                              const HomCoord& q3,
01064                              bool bb_input          = false,
01065                              const HomCoord* bb_min = NULL,
01066                              const HomCoord* bb_max = NULL );
01067
01068     //! return the a_entity_factory pointer
01069     AEntityFactory* a_entity_factory()
01070     {
01071         return aEntityFactory;
01072     }
01073     const AEntityFactory* a_entity_factory() const
01074     {
01075         return aEntityFactory;
01076     }
01077
01078 #ifdef MOAB_HAVE_AHF
01079     HalfFacetRep* a_half_facet_rep()
01080     {
01081         return ahfRep;
01082     }
01083     const HalfFacetRep* a_half_facet_rep() const
01084     {
01085         return ahfRep;
01086     }
01087 #endif
01088
01089     //! return set of registered IO tools
01090     ReaderWriterSet* reader_writer_set()
01091     {
01092         return readerWriterSet;
01093     }
01094
01095     //-----------------MeshSet Interface Functions------------------//
01096
01097     void print( const EntityHandle handle, const char* prefix, bool first_call = true ) const;
01098
01099     ErrorCode print_entity_tags( std::string indent_prefix, const EntityHandle handle, TagType tp ) const;
01100
01101     virtual ErrorCode get_last_error( std::string& info ) const;
01102
01103     virtual std::string get_error_string( const ErrorCode code ) const;
01104
01105     //! check all adjacencies for consistency
01106     ErrorCode check_adjacencies();
01107
01108     //! check some adjacencies for consistency
01109     ErrorCode check_adjacencies( const EntityHandle* ents, int num_ents );
01110
01111     //! return whether the input handle is valid or not
01112     bool is_valid( const EntityHandle this_ent ) const;
01113
01114     /** \brief Create an iterator over the set
01115      * Create a new iterator that iterates over entities with the specified type or dimension.
01116      * Only one of ent_type or dim can be set; use dim=-1 or ent_type=MBMAXTYPE for the other.
01117      * Iterators for list-type (ordered) sets are stable over set modification, unless entity
01118      * removed or deleted is the one at the current position of the iterator.  If the check_valid
01119      * parameter is passed as true, entities are checked for validity before being passed back by
01120      * get_next_entities function (checking entity validity can have a non-negligible cost).
01121      *
01122      * Iterators returned by this function can be deleted using the normal C++ delete function.
01123      * After creating the iterator through this function, further interactions are through methods
01124      * on the SetIterator class.
01125      * \param meshset The entity set associated with this iterator (use 0 for whole instance)
01126      * \param ent_type Entity type associated with this iterator
01127      * \param ent_dim Dimension associated with this iterator
01128      * \param chunk_size Chunk size of the iterator
01129      * \param check_valid If true, entities are checked for validity before being returned
01130      */
01131     virtual ErrorCode create_set_iterator( EntityHandle meshset,
01132                                            EntityType ent_type,
01133                                            int ent_dim,
01134                                            int chunk_size,
01135                                            bool check_valid,
01136                                            SetIterator*& set_iter );
01137
01138     /** \brief Remove the set iterator from the instance's list
01139      * \param set_iter Set iterator being removed
01140      */
01141     ErrorCode remove_set_iterator( SetIterator* set_iter );
01142
01143     /** \brief Get all set iterators associated with the set passed in
01144      * \param meshset Meshset for which iterators are requested
01145      * \param set_iters Set iterators for the set
01146      */
01147     ErrorCode get_set_iterators( EntityHandle meshset, std::vector< SetIterator* >& set_iters );
01148
01149     //-----------------Memory Functions------------------//
01150
01151     /**\brief Calculate amount of memory used to store MOAB data
01152      *
01153      * This function calculates the amount of memory used to store
01154      * MOAB data.
01155      *
01156      * There are two possible values for each catagory of memory use.
01157      * The exact value and the amortized value.  The exact value is the
01158      * amount of memory used to store the data for the specified entities.
01159      * The amortized value includes the exact value and an amortized
01160      * estimate of the memory consumed in overhead for storing the values
01161      * (indexing structures, access structures, etc.)
01162      *
01163      * Note: If ent_array is NULL, the total memory used by MOAB for storing
01164      *       data will be returned in the address pointed to by
01165      *       total_amortized_storage, if total_amortized_storage is not NULL.
01166      *
01167      *\param ent_array Array of entities for which to estimate the memory use.
01168      *                 If NULL, estimate is done for all entities.
01169      *\param num_ents The length of ent_array.  Not used if ent_rray is NULL.
01170      *\param total_(amortized_)storage The sum of the memory entity, adjacency, and all tag storage.
01171      *\param (amortized_)entity_storage The storage for the entity definitions
01172      *                 (connectivity arrays for elements, coordinates for vertices,
01173      *                  list storage within sets, etc.)
01174      *\param (amortized_)adjacency_storage The storage for adjacency data.
01175      *\param tag_array  An array of tags for which to calculate the memory use.
01176      *\param num_tags   The lenght of tag_array
01177      *\param (amortized_)tag_storage If tag_array is not NULL, then one value
01178      *                   for each tag specifying the memory used for storing that
01179      *                   tag.  If tag_array is NULL and this value is not, the
01180      *                   location at which to store the total memory used for
01181      *                   all tags.
01182      */
01183     void estimated_memory_use( const EntityHandle* ent_array                   = 0,
01184                                unsigned long num_ents                          = 0,
01185                                unsigned long long* total_storage               = 0,
01186                                unsigned long long* total_amortized_storage     = 0,
01187                                unsigned long long* entity_storage              = 0,
01188                                unsigned long long* amortized_entity_storage    = 0,
01189                                unsigned long long* adjacency_storage           = 0,
01190                                unsigned long long* amortized_adjacency_storage = 0,
01191                                const Tag* tag_array                            = 0,
01192                                unsigned num_tags                               = 0,
01193                                unsigned long long* tag_storage                 = 0,
01194                                unsigned long long* amortized_tag_storage       = 0 );
01195
01196     /**\brief Calculate amount of memory used to store MOAB data
01197      *
01198      * This function calculates the amount of memory used to store
01199      * MOAB data.
01200      *
01201      * There are two possible values for each catagory of memory use.
01202      * The exact value and the amortized value.  The exact value is the
01203      * amount of memory used to store the data for the specified entities.
01204      * The amortized value includes the exact value and an amortized
01205      * estimate of the memory consumed in overhead for storing the values
01206      * (indexing structures, access structures, etc.)
01207      *
01208      *\param ents      Entities for which to estimate the memory use.
01209      *\param total_(amortized_)storage The sum of the memory entity, adjacency, and all tag storage.
01210      *\param (amortized_)entity_storage The storage for the entity definitions
01211      *                 (connectivity arrays for elements, coordinates for vertices,
01212      *                  list storage within sets, etc.)
01213      *\param (amortized_)adjacency_storage The storage for adjacency data.
01214      *\param tag_array  An array of tags for which to calculate the memory use.
01215      *\param num_tags   The lenght of tag_array
01216      *\param (amortized_)tag_storage If tag_array is not NULL, then one value
01217      *                   for each tag specifying the memory used for storing that
01218      *                   tag.  If tag_array is NULL and this value is not, the
01219      *                   location at which to store the total memory used for
01220      *                   all tags.
01221      */
01222     void estimated_memory_use( const Range& ents,
01223                                unsigned long long* total_storage               = 0,
01224                                unsigned long long* total_amortized_storage     = 0,
01225                                unsigned long long* entity_storage              = 0,
01226                                unsigned long long* amortized_entity_storage    = 0,
01227                                unsigned long long* adjacency_storage           = 0,
01228                                unsigned long long* amortized_adjacency_storage = 0,
01229                                const Tag* tag_array                            = 0,
01230                                unsigned num_tags                               = 0,
01231                                unsigned long long* tag_storage                 = 0,
01232                                unsigned long long* amortized_tag_storage       = 0 );
01233
01234     void print_database() const;
01235
01236     /** \name Sequence Option controllers */
01237
01238     /**@{*/
01239
01240     /** \brief Interface to control memory allocation for sequences
01241      * Provide a factor that controls the size of the sequence that gets allocated.
01242      * This is typically useful in the parallel setting when a-priori, the number of ghost entities
01243      * and the memory required for them within the same sequence as the owned entities are unknown.
01244      * The default factor is 1.0 but this can be appropriately updated at runtime so that we do not
01245      * have broken sequences.
01246      */
01247     virtual double get_sequence_multiplier() const;
01248
01249     /** \brief Interface to control memory allocation for sequences
01250      * Provide a factor that controls the size of the sequence that gets allocated.
01251      * This is typically useful in the parallel setting when a-priori, the number of ghost entities
01252      * and the memory required for them within the same sequence as the owned entities are unknown.
01253      * The default factor is 1.0 but this can be appropriately updated at runtime so that we do not
01254      * have broken sequences.
01255      *
01256      * \param meshset User specified multiplier (should be greater than 1.0)
01257      */
01258     virtual void set_sequence_multiplier( double factor );
01259
01260     /**@}*/
01261
01262   private:
01263     /**\brief Do not allow copying */
01264     Core( const Core& copy );
01265     /**\brief Do not allow copying */
01266     Core& operator=( const Core& copy );
01267
01268     void estimated_memory_use_internal( const Range* ents,
01269                                         unsigned long long* total_storage,
01270                                         unsigned long long* total_amortized_storage,
01271                                         unsigned long long* entity_storage,
01272                                         unsigned long long* amortized_entity_storage,
01273                                         unsigned long long* adjacency_storage,
01274                                         unsigned long long* amortized_adjacency_storage,
01275                                         const Tag* tag_array,
01276                                         unsigned num_tags,
01277                                         unsigned long long* tag_storage,
01278                                         unsigned long long* amortized_tag_storage );
01279
01280     //! database init and de-init routines
01281     ErrorCode initialize();
01282     void deinitialize();
01283
01284     //! return the entity set representing the whole mesh
01285     EntityHandle get_root_set();
01286
01287     //!\brief Clean up after a file reader returns failure.
01288     //!
01289     //! Delete all entities not contained in initial_entities
01290     //! and all tags not contained in initial_tags.
01291     void clean_up_failed_read( const Range& initial_ents, std::vector< Tag > initial_tags );
01292
01293     // other interfaces for MB
01294     WriteUtil* mMBWriteUtil;
01295     ReadUtil* mMBReadUtil;
01296     ScdInterface* scdInterface;
01297
01298     //! store the total number of elements defined in this interface
01299     // int totalNumElements;
01300
01301     //! store the total number of nodes defined in this interface
01302     // int totalNumNodes;
01303
01304     //! the overall geometric dimension of this mesh
01305     int geometricDimension;
01306
01307     Tag materialTag;
01308     Tag neumannBCTag;
01309     Tag dirichletBCTag;
01310     Tag geomDimensionTag;
01311     Tag globalIdTag;
01312
01313     //! tag server for this interface
01314     std::list< TagInfo* > tagList;
01315     inline bool valid_tag_handle( const TagInfo* t ) const
01316     {
01317         return std::find( tagList.begin(), tagList.end(), t ) != tagList.end();
01318     }
01319
01320     SequenceManager* sequenceManager;
01321
01322     AEntityFactory* aEntityFactory;
01323
01324     ReaderWriterSet* readerWriterSet;
01325
01326     Error* mError;
01327     bool mpiFinalize;
01328     int writeMPELog;
01329     bool initErrorHandlerInCore;
01330
01331     //! list of iterators
01332     std::vector< SetIterator* > setIterators;
01333
01334 #ifdef MOAB_HAVE_AHF
01335     HalfFacetRep* ahfRep;
01336     bool mesh_modified;
01337 #endif
01338 };
01339
01340 }  // namespace moab
01341
01342 #endif  // MOAB_IMPL_GENERAL_HPP
