CoupleMGen.cpp File Reference
+ Include dependency graph for CoupleMGen.cpp:
Functions
double physField (double x, double y, double z)
int main (int argc, char *argv[])
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 54 of file CoupleMGen.cpp.
References moab::MeshGeneration::BrickOpts::A, ProgOptions::addOpt(), moab::MeshGeneration::BrickOpts::adjEnts, moab::MeshGeneration::BrickOpts::B, moab::Range::begin(), moab::MeshGeneration::BrickOpts::blockSize, moab::MeshGeneration::BrickInstance(), moab::MeshGeneration::BrickOpts::C, moab::Interface::create_meshset(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_pstatus_entities(), moab::MeshGeneration::BrickOpts::GL, moab::Coupler::interpolate(), moab::MeshGeneration::BrickOpts::K, moab::MeshGeneration::BrickOpts::keep_skins, moab::Coupler::LINEAR_FE, moab::Coupler::locate_points(), moab::MeshGeneration::BrickOpts::M, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESHSET_SET, moab::MeshGeneration::BrickOpts::N, moab::MeshGeneration::BrickOpts::newMergeMethod, moab::MeshGeneration::BrickOpts::parmerge, ProgOptions::parseCommandLine(), moab::physField(), PSTATUS_NOT_OWNED, moab::MeshGeneration::BrickOpts::quadratic, size, moab::Range::size(), start_time, moab::subtract(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::MeshGeneration::BrickOpts::tetra, moab::MeshGeneration::BrickOpts::ui, moab::MeshGeneration::BrickOpts::uj, moab::MeshGeneration::BrickOpts::uk, moab::Interface::UNION, moab::Interface::write_file(), moab::MeshGeneration::BrickOpts::xsize, moab::MeshGeneration::BrickOpts::ysize, and moab::MeshGeneration::BrickOpts::zsize.
    int proc_id = 0, size = 1;
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    Core mcore;
    Interface* mb = &mcore;
    EntityHandle fileset1, fileset2;  // for 2 different meshes
    MeshGeneration::BrickOpts opts;
    // default options
    opts.A = opts.B = opts.C = 1;
    opts.M = opts.N = opts.K = 1;
    opts.blockSize           = 4;
    opts.xsize = opts.ysize = opts.zsize = 1.;
    opts.ui                              = CartVect( 1., 0, 0. );
    opts.uj                              = CartVect( 0., 1., 0. );
    opts.uk                              = CartVect( 0., 0., 1. );
    opts.newMergeMethod = opts.quadratic = opts.keep_skins = opts.tetra = false;
    opts.adjEnts = opts.parmerge = false;
    opts.GL                      = 0;
    ProgOptions popts;
    popts.addOpt< int >( string( "blockSize,b" ), string( "Block size of mesh (default=4)" ), &opts.blockSize );
    popts.addOpt< int >( string( "xproc,M" ), string( "Number of processors in x dir (default=1)" ), &opts.M );
    popts.addOpt< int >( string( "yproc,N" ), string( "Number of processors in y dir (default=1)" ), &opts.N );
    popts.addOpt< int >( string( "zproc,K" ), string( "Number of processors in z dir (default=1)" ), &opts.K );
    popts.addOpt< int >( string( "xblocks,A" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.A );
    popts.addOpt< int >( string( "yblocks,B" ), string( "Number of blocks on a task in y dir (default=2)" ), &opts.B );
    popts.addOpt< int >( string( "zblocks,C" ), string( "Number of blocks on a task in x dir (default=2)" ), &opts.C );
    popts.addOpt< double >( string( "xsize,x" ), string( "Total size in x direction (default=1.)" ), &opts.xsize );
    popts.addOpt< double >( string( "ysize,y" ), string( "Total size in y direction (default=1.)" ), &opts.ysize );
    popts.addOpt< double >( string( "zsize,z" ), string( "Total size in z direction (default=1.)" ), &opts.zsize );
    popts.addOpt< void >( "newMerge,w", "use new merging method", &opts.newMergeMethod );
    popts.addOpt< void >( "quadratic,q", "use hex 27 elements", &opts.quadratic );
    popts.addOpt< void >( "keep_skins,k", "keep skins with shared entities", &opts.keep_skins );
    popts.addOpt< void >( "tetrahedrons,t", "generate tetrahedrons", &opts.tetra );
    popts.addOpt< void >( "faces_edges,f", "create all faces and edges", &opts.adjEnts );
    popts.addOpt< int >( string( "ghost_layers,g" ), string( "Number of ghost layers (default=0)" ), &opts.GL );
    popts.addOpt< void >( "parallel_merge,p", "use parallel mesh merge, not vertex ID based merge", &opts.parmerge );
    Coupler::Method method = Coupler::LINEAR_FE;
    double toler = 1.e-6;
    popts.addOpt< double >( string( "eps,e" ), string( "tolerance for coupling, used in locating points" ), &toler );
    bool writeMeshes = false;
    popts.addOpt< void >( "print,p", "write meshes", &writeMeshes );
    popts.parseCommandLine( argc, argv );
    double start_time = MPI_Wtime();
    ErrorCode rval = mb->create_meshset( MESHSET_SET, fileset1 );MB_CHK_ERR( rval );
    rval = mb->create_meshset( MESHSET_SET, fileset2 );MB_CHK_ERR( rval );
    ParallelComm* pc1     = new ParallelComm( mb, MPI_COMM_WORLD );
    MeshGeneration* mgen1 = new MeshGeneration( mb, pc1, fileset1 );
    rval = mgen1->BrickInstance( opts );MB_CHK_ERR( rval );  // this will generate first mesh on fileset1
    double instance_time = MPI_Wtime();
    double current       = instance_time;
    if( !proc_id ) std::cout << " instantiate first mesh " << instance_time - start_time << "\n";
    // set an interpolation tag on source mesh, from phys field
    std::string interpTag( "interp_tag" );
    Tag tag;
    rval = mb->tag_get_handle( interpTag.c_str(), 1, MB_TYPE_DOUBLE, tag, MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_ERR( rval );
    Range src_elems;
    rval = pc1->get_part_entities( src_elems, 3 );MB_CHK_ERR( rval );
    Range src_verts;
    rval = mb->get_connectivity( src_elems, src_verts );MB_CHK_ERR( rval );
    for( Range::iterator vit = src_verts.begin(); vit != src_verts.end(); ++vit )
        EntityHandle vert = *vit;  //?
        double vertPos[3];
        mb->get_coords( &vert, 1, vertPos );
        double fieldValue = physField( vertPos[0], vertPos[1], vertPos[2] );
        rval = mb->tag_set_data( tag, &vert, 1, &fieldValue );MB_CHK_ERR( rval );
    double setTag_time = MPI_Wtime();
    if( !proc_id ) std::cout << " set tag " << setTag_time - current;
    // change some options, so it is a different mesh
    int tmp1   = opts.K;
    opts.K     = opts.M;
    opts.M     = tmp1;  // swap (opts.K, opts.M)
    opts.tetra = !opts.tetra;
    opts.blockSize++;
    ParallelComm* pc2     = new ParallelComm( mb, MPI_COMM_WORLD );
    MeshGeneration* mgen2 = new MeshGeneration( mb, pc2, fileset2 );
    rval = mgen2->BrickInstance( opts );MB_CHK_ERR( rval );  // this will generate second mesh on fileset2
    double instance_second = MPI_Wtime();
    if( !proc_id ) std::cout << " instance second mesh" << instance_second - current << "\n";
    current = instance_second;
    // test the sets are fine
    if( writeMeshes )
        rval = mb->write_file( "mesh1.h5m", 0, ";;PARALLEL=WRITE_PART;CPUTIME;PARALLEL_COMM=0;", &fileset1, 1 );MB_CHK_SET_ERR( rval, "Can't write in parallel mesh 1" );
        rval = mb->write_file( "mesh2.h5m", 0, ";;PARALLEL=WRITE_PART;CPUTIME;PARALLEL_COMM=1;", &fileset2, 1 );MB_CHK_SET_ERR( rval, "Can't write in parallel mesh 1" );
        double write_files = MPI_Wtime();
        if( !proc_id ) std::cout << " write files " << write_files - current << "\n";
        current = write_files;
    // Instantiate a coupler, which also initializes the tree
    Coupler mbc( mb, pc1, src_elems, 0 );
    double instancecoupler = MPI_Wtime();
    if( !proc_id ) std::cout << " instance coupler " << instancecoupler - current << "\n";
    current = instancecoupler;
    // Get points from the target mesh to interpolate
    // We have to treat differently the case when the target is a spectral mesh
    // In that case, the points of interest are the GL points, not the vertex nodes
    std::vector< double > vpos;  // This will have the positions we are interested in
    int numPointsOfInterest = 0;
    Range targ_elems;
    Range targ_verts;
    // First get all vertices adj to partition entities in target mesh
    rval = pc2->get_part_entities( targ_elems, 3 );MB_CHK_ERR( rval );
    rval = mb->get_adjacencies( targ_elems, 0, false, targ_verts, Interface::UNION );MB_CHK_ERR( rval );
    Range tmp_verts;
    // Then get non-owned verts and subtract
    rval = pc2->get_pstatus_entities( 0, PSTATUS_NOT_OWNED, tmp_verts );MB_CHK_ERR( rval );
    targ_verts = subtract( targ_verts, tmp_verts );
    // get position of these entities; these are the target points
    numPointsOfInterest = (int)targ_verts.size();
    vpos.resize( 3 * targ_verts.size() );
    rval = mb->get_coords( targ_verts, &vpos[0] );MB_CHK_ERR( rval );
    // Locate those points in the source mesh
    // std::cout<<"rank "<< proc_id<< " points of interest: " << numPointsOfInterest << "\n";
    rval = mbc.locate_points( &vpos[0], numPointsOfInterest, 0, toler );MB_CHK_ERR( rval );
    double locatetime = MPI_Wtime();
    if( !proc_id ) std::cout << " locate points: " << locatetime - current << "\n";
    current = locatetime;
    // Now interpolate tag onto target points
    std::vector< double > field( numPointsOfInterest );
    rval = mbc.interpolate( method, interpTag, &field[0] );MB_CHK_ERR( rval );
    // compare with the actual phys field
    double err_max = 0;
    for( int i = 0; i < numPointsOfInterest; i++ )
        double trval = physField( vpos[3 * i], vpos[3 * i + 1], vpos[3 * i + 2] );
        double err2  = fabs( trval - field[i] );
        if( err2 > err_max ) err_max = err2;
    double interpolateTime = MPI_Wtime();
    if( !proc_id ) std::cout << " interpolate points: " << interpolateTime - current << "\n";
    current = interpolateTime;
    double gerr;
    MPI_Allreduce( &err_max, &gerr, 1, MPI_DOUBLE, MPI_MAX, MPI_COMM_WORLD );
    if( 0 == proc_id ) std::cout << "max err  " << gerr << "\n";
    delete mgen1;
    delete mgen2;
    MPI_Finalize();
    return 0;
double physField ( double  x,
double  y,
double  z
Definition at line 46 of file CoupleMGen.cpp.
    double out = sin( M_PI * x ) * cos( M_PI * y ) * sin( M_PI * z );
    return out;
