Coupler.cpp
00001 #include "Coupler.hpp"
00002 #include "moab/ParallelComm.hpp"
00003 #include "moab/AdaptiveKDTree.hpp"
00004 #include "ElemUtil.hpp"
00005 #include "moab/CN.hpp"
00006 #include "moab/gs.hpp"
00007 #include "moab/TupleList.hpp"
00008 #include "moab/Error.hpp"
00009
00010 /* C++ includes */
00011 #include <cstdio>
00012 #include <cassert>
00013 #include <iostream>
00014 #include <algorithm>
00015 #include <sstream>
00016
00017 #define ERROR( a )                                               \
00018     {                                                            \
00019         if( MB_SUCCESS != err ) std::cerr << ( a ) << std::endl; \
00020     }
00021 #define ERRORR( a, b )                       \
00022     {                                        \
00023         if( MB_SUCCESS != ( b ) )            \
00024         {                                    \
00025             std::cerr << ( a ) << std::endl; \
00026             return b;                        \
00027         }                                    \
00028     }
00029 #define ERRORMPI( a, b )                     \
00030     {                                        \
00031         if( MPI_SUCCESS != ( b ) )           \
00032         {                                    \
00033             std::cerr << ( a ) << std::endl; \
00034             return MB_FAILURE;               \
00035         }                                    \
00036     }
00037
00038 #define MASTER_PROC 0
00039
00040 namespace moab
00041 {
00042
00043 bool debug = false;
00044 int pack_tuples( TupleList* tl, void** ptr );
00045 void unpack_tuples( void* ptr, TupleList** tlp );
00046
00047 Coupler::Coupler( Interface* impl,
00048                   ParallelComm* pc,
00049                   Range& local_elems,
00050                   int coupler_id,
00051                   bool init_tree,
00052                   int max_ent_dim )
00053     : mbImpl( impl ), myPc( pc ), myId( coupler_id ), numIts( 3 ), max_dim( max_ent_dim ), _ntot( 0 ),
00054       spherical( false )
00055 {
00056     assert( NULL != impl && ( pc || !local_elems.empty() ) );
00057
00058     // Keep track of the local points, at least for now
00059     myRange = local_elems;
00060     myTree  = NULL;
00061
00062     // Now initialize the tree
00063     if( init_tree ) initialize_tree();
00064
00065     // Initialize tuple lists to indicate not initialized
00066     mappedPts       = NULL;
00067     targetPts       = NULL;
00068     _spectralSource = _spectralTarget = NULL;
00069 }
00070
00071 /* Destructor
00072  */
00073 Coupler::~Coupler()
00074 {
00075     // This will clear the cache
00076     delete(moab::Element::SpectralHex*)_spectralSource;
00077     delete(moab::Element::SpectralHex*)_spectralTarget;
00078     delete myTree;
00079     delete targetPts;
00080     delete mappedPts;
00081 }
00082
00083 ErrorCode Coupler::initialize_tree()
00084 {
00085     Range local_ents;
00086
00087     // Get entities on the local part
00088     ErrorCode result = MB_SUCCESS;
00089     if( myPc )
00090     {
00091         result = myPc->get_part_entities( local_ents, max_dim );
00092         if( local_ents.empty() )
00093         {
00094             max_dim--;
00095             result = myPc->get_part_entities( local_ents, max_dim );  // go one dimension lower
00096             // right now, this is used for spherical meshes only
00097         }
00098     }
00099     else
00100         local_ents = myRange;
00101     if( MB_SUCCESS != result || local_ents.empty() )
00102     {
00103         std::cout << "Problems getting source entities" << std::endl;
00104         return result;
00105     }
00106
00107     // Build the tree for local processor
00108     int max_per_leaf = 6;
00109     for( int i = 0; i < numIts; i++ )
00110     {
00111         std::ostringstream str;
00112         str << "PLANE_SET=0;"
00113             << "MAX_PER_LEAF=" << max_per_leaf << ";";
00114         if( spherical && !local_ents.empty() )
00115         {
00116             // get coordinates of one vertex, and use for radius computation
00117             EntityHandle elem = local_ents[0];
00118             const EntityHandle* conn;
00119             int numn = 0;
00120             mbImpl->get_connectivity( elem, conn, numn );
00121             CartVect pos0;
00122             mbImpl->get_coords( conn, 1, &( pos0[0] ) );
00123             double radius = pos0.length();
00124             str << "SPHERICAL=true;RADIUS=" << radius << ";";
00125         }
00126         FileOptions opts( str.str().c_str() );
00127         myTree = new AdaptiveKDTree( mbImpl );
00128         result = myTree->build_tree( local_ents, &localRoot, &opts );
00129         if( MB_SUCCESS != result )
00130         {
00131             std::cout << "Problems building tree";
00132             if( numIts != i )
00133             {
00134                 delete myTree;
00135                 max_per_leaf *= 2;
00136                 std::cout << "; increasing elements/leaf to " << max_per_leaf << std::endl;
00137             }
00138             else
00139             {
00140                 std::cout << "; exiting" << std::endl;
00141                 return result;
00142             }
00143         }
00144         else
00145             break;  // Get out of tree building
00146     }
00147
00148     // Get the bounding box for local tree
00149     if( myPc )
00150         allBoxes.resize( 6 * myPc->proc_config().proc_size() );
00151     else
00152         allBoxes.resize( 6 );
00153
00154     unsigned int my_rank = ( myPc ? myPc->proc_config().proc_rank() : 0 );
00155     BoundBox box;
00156     result = myTree->get_bounding_box( box, &localRoot );
00157     if( MB_SUCCESS != result ) return result;
00158     box.bMin.get( &allBoxes[6 * my_rank] );
00159     box.bMax.get( &allBoxes[6 * my_rank + 3] );
00160
00161     // Now communicate to get all boxes
00162     if( myPc )
00163     {
00164         int mpi_err;
00165 #if( MPI_VERSION >= 2 )
00166         // Use "in place" option
00167         mpi_err = MPI_Allgather( MPI_IN_PLACE, 0, MPI_DATATYPE_NULL, &allBoxes[0], 6, MPI_DOUBLE,
00168                                  myPc->proc_config().proc_comm() );
00169 #else
00170         {
00171             std::vector< double > allBoxes_tmp( 6 * myPc->proc_config().proc_size() );
00172             mpi_err  = MPI_Allgather( &allBoxes[6 * my_rank], 6, MPI_DOUBLE, &allBoxes_tmp[0], 6, MPI_DOUBLE,
00173                                       myPc->proc_config().proc_comm() );
00174             allBoxes = allBoxes_tmp;
00175         }
00176 #endif
00177         if( MPI_SUCCESS != mpi_err ) return MB_FAILURE;
00178     }
00179
00180     /*  std::ostringstream blah;
00181     for(int i = 0; i < allBoxes.size(); i++)
00182     blah << allBoxes[i] << " ";
00183     std::cout << blah.str() << "\n";*/
00184
00185 #ifdef VERBOSE
00186     double min[3] = { 0, 0, 0 }, max[3] = { 0, 0, 0 };
00187     unsigned int dep;
00188     myTree->get_info( localRoot, min, max, dep );
00189     std::cout << "Proc " << my_rank << ": box min/max, tree depth = (" << min[0] << "," << min[1] << "," << min[2]
00190               << "), (" << max[0] << "," << max[1] << "," << max[2] << "), " << dep << std::endl;
00191 #endif
00192
00193     return result;
00194 }
00195
00196 ErrorCode Coupler::initialize_spectral_elements( EntityHandle rootSource,
00197                                                  EntityHandle rootTarget,
00198                                                  bool& specSou,
00199                                                  bool& specTar )
00200 {
00201     /*void * _spectralSource;
00202       void * _spectralTarget;*/
00203
00204     moab::Range spectral_sets;
00205     moab::Tag sem_tag;
00206     int sem_dims[3];
00207     ErrorCode rval = mbImpl->tag_get_handle( "SEM_DIMS", 3, moab::MB_TYPE_INTEGER, sem_tag );
00208     if( moab::MB_SUCCESS != rval )
00209     {
00210         std::cout << "Can't find tag, no spectral set\n";
00211         return MB_SUCCESS;  // Nothing to do, no spectral elements
00212     }
00213     rval = mbImpl->get_entities_by_type_and_tag( rootSource, moab::MBENTITYSET, &sem_tag, NULL, 1, spectral_sets );
00214     if( moab::MB_SUCCESS != rval || spectral_sets.empty() )
00215         std::cout << "Can't get sem set on source\n";
00216     else
00217     {
00218         moab::EntityHandle firstSemSet = spectral_sets[0];
00219         rval                           = mbImpl->tag_get_data( sem_tag, &firstSemSet, 1, (void*)sem_dims );
00220         if( moab::MB_SUCCESS != rval ) return MB_FAILURE;
00221
00222         if( sem_dims[0] != sem_dims[1] || sem_dims[0] != sem_dims[2] )
00223         {
00224             std::cout << " dimensions are different. bail out\n";
00225             return MB_FAILURE;
00226         }
00227         // Repeat for target sets
00228         spectral_sets.empty();
00229         // Now initialize a source spectral element !
00230         _spectralSource = new moab::Element::SpectralHex( sem_dims[0] );
00231         specSou         = true;
00232     }
00233     // Repeat for target source
00234     rval = mbImpl->get_entities_by_type_and_tag( rootTarget, moab::MBENTITYSET, &sem_tag, NULL, 1, spectral_sets );
00235     if( moab::MB_SUCCESS != rval || spectral_sets.empty() )
00236         std::cout << "Can't get sem set on target\n";
00237     else
00238     {
00239         moab::EntityHandle firstSemSet = spectral_sets[0];
00240         rval                           = mbImpl->tag_get_data( sem_tag, &firstSemSet, 1, (void*)sem_dims );
00241         if( moab::MB_SUCCESS != rval ) return MB_FAILURE;
00242
00243         if( sem_dims[0] != sem_dims[1] || sem_dims[0] != sem_dims[2] )
00244         {
00245             std::cout << " dimensions are different. bail out\n";
00246             return MB_FAILURE;
00247         }
00248         // Repeat for target sets
00249         spectral_sets.empty();
00250         // Now initialize a target spectral element !
00251         _spectralTarget = new moab::Element::SpectralHex( sem_dims[0] );
00252         specTar         = true;
00253     }
00254
00255     _ntot = sem_dims[0] * sem_dims[1] * sem_dims[2];
00256     rval  = mbImpl->tag_get_handle( "SEM_X", _ntot, moab::MB_TYPE_DOUBLE, _xm1Tag );
00257     if( moab::MB_SUCCESS != rval )
00258     {
00259         std::cout << "Can't get xm1tag \n";
00260         return MB_FAILURE;
00261     }
00262     rval = mbImpl->tag_get_handle( "SEM_Y", _ntot, moab::MB_TYPE_DOUBLE, _ym1Tag );
00263     if( moab::MB_SUCCESS != rval )
00264     {
00265         std::cout << "Can't get ym1tag \n";
00266         return MB_FAILURE;
00267     }
00268     rval = mbImpl->tag_get_handle( "SEM_Z", _ntot, moab::MB_TYPE_DOUBLE, _zm1Tag );
00269     if( moab::MB_SUCCESS != rval )
00270     {
00271         std::cout << "Can't get zm1tag \n";
00272         return MB_FAILURE;
00273     }
00274
00275     return MB_SUCCESS;
00276 }
00277
00278 ErrorCode Coupler::locate_points( Range& targ_ents, double rel_eps, double abs_eps, TupleList* tl, bool store_local )
00279 {
00280     // Get locations
00281     std::vector< double > locs( 3 * targ_ents.size() );
00282     Range verts    = targ_ents.subset_by_type( MBVERTEX );
00283     ErrorCode rval = mbImpl->get_coords( verts, &locs[0] );
00284     if( MB_SUCCESS != rval ) return rval;
00285     // Now get other ents; reuse verts
00286     unsigned int num_verts = verts.size();
00287     verts                  = subtract( targ_ents, verts );
00288     // Compute centroids
00289     std::vector< EntityHandle > dum_conn( CN::MAX_NODES_PER_ELEMENT );
00290     std::vector< double > dum_pos( CN::MAX_NODES_PER_ELEMENT );
00291     const EntityHandle* conn;
00292     int num_conn;
00293     double* coords = &locs[num_verts];
00294     // Do this here instead of a function to allow reuse of dum_pos and dum_conn
00295     for( Range::const_iterator rit = verts.begin(); rit != verts.end(); ++rit )
00296     {
00297         rval = mbImpl->get_connectivity( *rit, conn, num_conn, false, &dum_conn );
00298         if( MB_SUCCESS != rval ) return rval;
00299         rval = mbImpl->get_coords( conn, num_conn, &dum_pos[0] );
00300         if( MB_SUCCESS != rval ) return rval;
00301         coords[0] = coords[1] = coords[2] = 0.0;
00302         for( int i = 0; i < num_conn; i++ )
00303         {
00304             coords[0] += dum_pos[3 * i];
00305             coords[1] += dum_pos[3 * i + 1];
00306             coords[2] += dum_pos[3 * i + 2];
00307         }
00308         coords[0] /= num_conn;
00309         coords[1] /= num_conn;
00310         coords[2] /= num_conn;
00311         coords += 3;
00312     }
00313
00314     if( store_local ) targetEnts = targ_ents;
00315
00316     return locate_points( &locs[0], targ_ents.size(), rel_eps, abs_eps, tl, store_local );
00317 }
00318
00319 ErrorCode Coupler::locate_points( double* xyz,
00320                                   unsigned int num_points,
00321                                   double rel_eps,
00322                                   double abs_eps,
00323                                   TupleList* tl,
00324                                   bool store_local )
00325 {
00326     assert( tl || store_local );
00327
00328     // target_pts: TL(to_proc, tgt_index, x, y, z): tuples sent to source mesh procs representing
00329     // pts to be located source_pts: TL(from_proc, tgt_index, src_index): results of source mesh
00330     // proc point location, ready to send
00331     //             back to tgt procs; src_index of -1 indicates point not located (arguably not
00332     //             useful...)
00333     TupleList target_pts;
00334     target_pts.initialize( 2, 0, 0, 3, num_points );
00335     target_pts.enableWriteAccess();
00336
00337     TupleList source_pts;
00338     mappedPts = new TupleList( 0, 0, 1, 3, target_pts.get_max() );
00339     mappedPts->enableWriteAccess();
00340
00341     source_pts.initialize( 3, 0, 0, 0, target_pts.get_max() );
00342     source_pts.enableWriteAccess();
00343
00344     mappedPts->set_n( 0 );
00345     source_pts.set_n( 0 );
00346     ErrorCode result;
00347
00348     unsigned int my_rank = ( myPc ? myPc->proc_config().proc_rank() : 0 );
00349     bool point_located;
00350
00351     // For each point, find box(es) containing the point,
00352     // appending results to tuple_list;
00353     // keep local points separately, in local_pts, which has pairs
00354     // of <local_index, mapped_index>, where mapped_index is the index
00355     // into the mappedPts tuple list
00356     for( unsigned int i = 0; i < 3 * num_points; i += 3 )
00357     {
00358
00359         std::vector< int > procs_to_send_to;
00360         for( unsigned int j = 0; j < ( myPc ? myPc->proc_config().proc_size() : 0 ); j++ )
00361         {
00362             // Test if point is in proc's box
00363             if( ( allBoxes[6 * j] <= xyz[i] + abs_eps ) && ( xyz[i] <= allBoxes[6 * j + 3] + abs_eps ) &&
00364                 ( allBoxes[6 * j + 1] <= xyz[i + 1] + abs_eps ) && ( xyz[i + 1] <= allBoxes[6 * j + 4] + abs_eps ) &&
00365                 ( allBoxes[6 * j + 2] <= xyz[i + 2] + abs_eps ) && ( xyz[i + 2] <= allBoxes[6 * j + 5] + abs_eps ) )
00366             {
00367                 // If in this proc's box, will send to proc to test further
00368                 procs_to_send_to.push_back( j );
00369             }
00370         }
00371         if( procs_to_send_to.empty() )
00372         {
00373 #ifdef VERBOSE
00374             std::cout << " point index " << i / 3 << ": " << xyz[i] << " " << xyz[i + 1] << " " << xyz[i + 2]
00375                       << " not found in any box\n";
00376 #endif
00377             // try to find the closest box, and put it in that box, anyway
00378             double min_dist = 1.e+20;
00379             int index       = -1;
00380             for( unsigned int j = 0; j < ( myPc ? myPc->proc_config().proc_size() : 0 ); j++ )
00381             {
00382                 BoundBox box( &allBoxes[6 * j] );           // form back the box
00383                 double distance = box.distance( &xyz[i] );  // will compute the distance in 3d, from the box
00384                 if( distance < min_dist )
00385                 {
00386                     index    = j;
00387                     min_dist = distance;
00388                 }
00389             }
00390             if( index == -1 )
00391             {
00392                 // need to abort early, nothing we can do
00393                 assert( "cannot locate any box for some points" );
00394                 // need a better exit strategy
00395             }
00396 #ifdef VERBOSE
00397             std::cout << " point index " << i / 3 << " added to box for proc j:" << index << "\n";
00398 #endif
00399             procs_to_send_to.push_back( index );  // will send to just one proc, that has the closest box
00400         }
00401         // we finally decided to populate the tuple list for a list of processors
00402         for( size_t k = 0; k < procs_to_send_to.size(); k++ )
00403         {
00404             unsigned int j = procs_to_send_to[k];
00405             // Check size of tuple list, grow if we're at max
00406             if( target_pts.get_n() == target_pts.get_max() )
00407                 target_pts.resize( std::max( 10.0, 1.5 * target_pts.get_max() ) );
00408
00409             target_pts.vi_wr[2 * target_pts.get_n()]     = j;
00410             target_pts.vi_wr[2 * target_pts.get_n() + 1] = i / 3;
00411
00412             target_pts.vr_wr[3 * target_pts.get_n()]     = xyz[i];
00413             target_pts.vr_wr[3 * target_pts.get_n() + 1] = xyz[i + 1];
00414             target_pts.vr_wr[3 * target_pts.get_n() + 2] = xyz[i + 2];
00415             target_pts.inc_n();
00416         }
00417
00418     }  // end for (unsigned int i = 0; ..
00419
00420     int num_to_me = 0;
00421     for( unsigned int i = 0; i < target_pts.get_n(); i++ )
00422         if( target_pts.vi_rd[2 * i] == (int)my_rank ) num_to_me++;
00423 #ifdef VERBOSE
00424     printf( "rank: %u local points: %u, nb sent target pts: %u mappedPts: %u num to me: %d \n", my_rank, num_points,
00425             target_pts.get_n(), mappedPts->get_n(), num_to_me );
00426 #endif
00427     // Perform scatter/gather, to gather points to source mesh procs
00428     if( myPc )
00429     {
00430         ( myPc->proc_config().crystal_router() )->gs_transfer( 1, target_pts, 0 );
00431
00432         num_to_me = 0;
00433         for( unsigned int i = 0; i < target_pts.get_n(); i++ )
00434         {
00435             if( target_pts.vi_rd[2 * i] == (int)my_rank ) num_to_me++;
00436         }
00437 #ifdef VERBOSE
00438         printf( "rank: %u after first gs nb received_pts: %u; num_from_me = %d\n", my_rank, target_pts.get_n(),
00439                 num_to_me );
00440 #endif
00441         // After scatter/gather:
00442         // target_pts.set_n(# points local proc has to map);
00443         // target_pts.vi_wr[2*i] = proc sending point i
00444         // target_pts.vi_wr[2*i + 1] = index of point i on sending proc
00445         // target_pts.vr_wr[3*i..3*i + 2] = xyz of point i
00446         //
00447         // Mapping builds the tuple list:
00448         // source_pts.set_n(target_pts.get_n())
00449         // source_pts.vi_wr[3*i] = target_pts.vi_wr[2*i] = sending proc
00450         // source_pts.vi_wr[3*i + 1] = index of point i on sending proc
00451         // source_pts.vi_wr[3*i + 2] = index of mapped point (-1 if not mapped)
00452         //
00453         // Also, mapping builds local tuple_list mappedPts:
00454         // mappedPts->set_n( # mapped points );
00455         // mappedPts->vul_wr[i] = local handle of mapped entity
00456         // mappedPts->vr_wr[3*i..3*i + 2] = natural coordinates in mapped entity
00457
00458         // Test target points against my elements
00459         for( unsigned i = 0; i < target_pts.get_n(); i++ )
00460         {
00461             result = test_local_box( target_pts.vr_wr + 3 * i, target_pts.vi_rd[2 * i], target_pts.vi_rd[2 * i + 1], i,
00462                                      point_located, rel_eps, abs_eps, &source_pts );
00463             if( MB_SUCCESS != result ) return result;
00464         }
00465
00466         // No longer need target_pts
00467         target_pts.reset();
00468 #ifdef VERBOSE
00469         printf( "rank: %u nb sent source pts: %u, mappedPts now: %u\n", my_rank, source_pts.get_n(),
00470                 mappedPts->get_n() );
00471 #endif
00472         // Send target points back to target procs
00473         ( myPc->proc_config().crystal_router() )->gs_transfer( 1, source_pts, 0 );
00474
00475 #ifdef VERBOSE
00476         printf( "rank: %u nb received source pts: %u\n", my_rank, source_pts.get_n() );
00477 #endif
00478     }
00479
00480     // Store proc/index tuples in targetPts, and/or pass back to application;
00481     // the tuple this gets stored to looks like:
00482     // tl.set_n(# mapped points);
00483     // tl.vi_wr[3*i] = remote proc mapping point
00484     // tl.vi_wr[3*i + 1] = local index of mapped point
00485     // tl.vi_wr[3*i + 2] = remote index of mapped point
00486     //
00487     // Local index is mapped into either myRange, holding the handles of
00488     // local mapped entities, or myXyz, holding locations of mapped pts
00489
00490     // Store information about located points
00491     TupleList* tl_tmp;
00492     if( !store_local )
00493         tl_tmp = tl;
00494     else
00495     {
00496         targetPts = new TupleList();
00497         tl_tmp    = targetPts;
00498     }
00499
00500     tl_tmp->initialize( 3, 0, 0, 0, num_points );
00501     tl_tmp->set_n( num_points );  // Automatically sets tl to write_enabled
00502     // Initialize so we know afterwards how many pts weren't located
00503     std::fill( tl_tmp->vi_wr, tl_tmp->vi_wr + 3 * num_points, -1 );
00504
00505     unsigned int local_pts = 0;
00506     for( unsigned int i = 0; i < source_pts.get_n(); i++ )
00507     {
00508         if( -1 != source_pts.vi_rd[3 * i + 2] )
00509         {  // Why bother sending message saying "i don't have the point" if it gets discarded?
00510             int tgt_index = 3 * source_pts.vi_rd[3 * i + 1];
00511             // Prefer always entities that are local, from the source_pts
00512             // if a local entity was already found to contain the target point, skip
00513             // tl_tmp->vi_wr[tgt_index] is -1 initially, but it could already be set with
00514             // a remote processor
00515             if( tl_tmp->vi_wr[tgt_index] != (int)my_rank )
00516             {
00517                 tl_tmp->vi_wr[tgt_index]     = source_pts.vi_rd[3 * i];
00518                 tl_tmp->vi_wr[tgt_index + 1] = source_pts.vi_rd[3 * i + 1];
00519                 tl_tmp->vi_wr[tgt_index + 2] = source_pts.vi_rd[3 * i + 2];
00520             }
00521         }
00522     }
00523
00524     // Count missing points
00525     unsigned int missing_pts = 0;
00526     for( unsigned int i = 0; i < num_points; i++ )
00527     {
00528         if( tl_tmp->vi_rd[3 * i + 1] == -1 )
00529         {
00530             missing_pts++;
00531 #ifdef VERBOSE
00532             printf( "missing point at index i:  %d -> %15.10f %15.10f %15.10f\n", i, xyz[3 * i], xyz[3 * i + 1],
00533                     xyz[3 * i + 2] );
00534 #endif
00535         }
00536         else if( tl_tmp->vi_rd[3 * i] == (int)my_rank )
00537             local_pts++;
00538     }
00539 #ifdef VERBOSE
00540     printf( "rank: %u point location: wanted %u got %u locally, %u remote, missing %u\n", my_rank, num_points,
00541             local_pts, num_points - missing_pts - local_pts, missing_pts );
00542 #endif
00543     assert( 0 == missing_pts );  // Will likely break on curved geometries
00544
00545     // No longer need source_pts
00546     source_pts.reset();
00547
00548     // Copy into tl if passed in and storing locally
00549     if( tl && store_local )
00550     {
00551         tl->initialize( 3, 0, 0, 0, num_points );
00552         tl->enableWriteAccess();
00553         memcpy( tl->vi_wr, tl_tmp->vi_rd, 3 * tl_tmp->get_n() * sizeof( int ) );
00554         tl->set_n( tl_tmp->get_n() );
00555         tl->disableWriteAccess();
00556     }
00557
00558     tl_tmp->disableWriteAccess();
00559
00560     // Done
00561     return MB_SUCCESS;
00562 }
00563
00564 ErrorCode Coupler::test_local_box( double* xyz,
00565                                    int from_proc,
00566                                    int remote_index,
00567                                    int /*index*/,
00568                                    bool& point_located,
00569                                    double rel_eps,
00570                                    double abs_eps,
00571                                    TupleList* tl )
00572 {
00573     std::vector< EntityHandle > entities;
00574     std::vector< CartVect > nat_coords;
00575     bool canWrite = false;
00576     if( tl )
00577     {
00578         canWrite = tl->get_writeEnabled();
00579         if( !canWrite )
00580         {
00581             tl->enableWriteAccess();
00582             canWrite = true;
00583         }
00584     }
00585
00586     if( rel_eps && !abs_eps )
00587     {
00588         // Relative epsilon given, translate to absolute epsilon using box dimensions
00589         BoundBox box;
00590         myTree->get_bounding_box( box, &localRoot );
00591         abs_eps = rel_eps * box.diagonal_length();
00592     }
00593
00594     ErrorCode result = nat_param( xyz, entities, nat_coords, abs_eps );
00595     if( MB_SUCCESS != result ) return result;
00596
00597     // If we didn't find any ents and we're looking locally, nothing more to do
00598     if( entities.empty() )
00599     {
00600         if( tl->get_n() == tl->get_max() ) tl->resize( std::max( 10.0, 1.5 * tl->get_max() ) );
00601
00602         tl->vi_wr[3 * tl->get_n()]     = from_proc;
00603         tl->vi_wr[3 * tl->get_n() + 1] = remote_index;
00604         tl->vi_wr[3 * tl->get_n() + 2] = -1;
00605         tl->inc_n();
00606
00607         point_located = false;
00608         return MB_SUCCESS;
00609     }
00610
00611     // Grow if we know we'll exceed size
00612     if( mappedPts->get_n() + entities.size() >= mappedPts->get_max() )
00613         mappedPts->resize( std::max( 10.0, 1.5 * mappedPts->get_max() ) );
00614
00615     std::vector< EntityHandle >::iterator eit = entities.begin();
00616     std::vector< CartVect >::iterator ncit    = nat_coords.begin();
00617
00618     mappedPts->enableWriteAccess();
00619     for( ; eit != entities.end(); ++eit, ++ncit )
00620     {
00621         // Store in tuple mappedPts
00622         mappedPts->vr_wr[3 * mappedPts->get_n()]     = ( *ncit )[0];
00623         mappedPts->vr_wr[3 * mappedPts->get_n() + 1] = ( *ncit )[1];
00624         mappedPts->vr_wr[3 * mappedPts->get_n() + 2] = ( *ncit )[2];
00625         mappedPts->vul_wr[mappedPts->get_n()]        = *eit;
00626         mappedPts->inc_n();
00627
00628         // Also store local point, mapped point indices
00629         if( tl->get_n() == tl->get_max() ) tl->resize( std::max( 10.0, 1.5 * tl->get_max() ) );
00630
00631         // Store in tuple source_pts
00632         tl->vi_wr[3 * tl->get_n()]     = from_proc;
00633         tl->vi_wr[3 * tl->get_n() + 1] = remote_index;
00634         tl->vi_wr[3 * tl->get_n() + 2] = mappedPts->get_n() - 1;
00635         tl->inc_n();
00636     }
00637
00638     point_located = true;
00639
00640     if( tl && !canWrite ) tl->disableWriteAccess();
00641
00642     return MB_SUCCESS;
00643 }
00644
00645 ErrorCode Coupler::interpolate( Coupler::Method method,
00646                                 const std::string& interp_tag,
00647                                 double* interp_vals,
00648                                 TupleList* tl,
00649                                 bool normalize )
00650 {
00651     Tag tag;
00652     ErrorCode result;
00653     if( _spectralSource )
00654     {
00655         result = mbImpl->tag_get_handle( interp_tag.c_str(), _ntot, MB_TYPE_DOUBLE, tag );MB_CHK_SET_ERR( result, "Failed to get handle for interpolation tag \"" << interp_tag << "\"" );
00656     }
00657     else
00658     {
00659         result = mbImpl->tag_get_handle( interp_tag.c_str(), 1, MB_TYPE_DOUBLE, tag );MB_CHK_SET_ERR( result, "Failed to get handle for interpolation tag \"" << interp_tag << "\"" );
00660     }
00661
00662     return interpolate( method, tag, interp_vals, tl, normalize );
00663 }
00664
00665 ErrorCode Coupler::interpolate( Coupler::Method* methods,
00666                                 Tag* tags,
00667                                 int* points_per_method,
00668                                 int num_methods,
00669                                 double* interp_vals,
00670                                 TupleList* tl,
00671                                 bool /* normalize */ )
00672 {
00673     // if (!((LINEAR_FE == method) || (CONSTANT == method)))
00674     // return MB_FAILURE;
00675
00676     // remote pts first
00677     TupleList* tl_tmp = ( tl ? tl : targetPts );
00678
00679     ErrorCode result = MB_SUCCESS;
00680
00681     unsigned int pts_total = 0;
00682     for( int i = 0; i < num_methods; i++ )
00683         pts_total += points_per_method[i];
00684
00685     // If tl was passed in non-NULL, just have those points, otherwise have targetPts plus
00686     // locally mapped pts
00687     if( pts_total != tl_tmp->get_n() ) return MB_FAILURE;
00688
00689     TupleList tinterp;
00690     tinterp.initialize( 5, 0, 0, 1, tl_tmp->get_n() );
00691     int t = 0;
00692     tinterp.enableWriteAccess();
00693     for( int i = 0; i < num_methods; i++ )
00694     {
00695         for( int j = 0; j < points_per_method[i]; j++ )
00696         {
00697             tinterp.vi_wr[5 * t]     = tl_tmp->vi_rd[3 * t];
00698             tinterp.vi_wr[5 * t + 1] = tl_tmp->vi_rd[3 * t + 1];
00699             tinterp.vi_wr[5 * t + 2] = tl_tmp->vi_rd[3 * t + 2];
00700             tinterp.vi_wr[5 * t + 3] = methods[i];
00701             tinterp.vi_wr[5 * t + 4] = i;
00702             tinterp.vr_wr[t]         = 0.0;
00703             tinterp.inc_n();
00704             t++;
00705         }
00706     }
00707
00708     // Scatter/gather interpolation points
00709     if( myPc )
00710     {
00711         ( myPc->proc_config().crystal_router() )->gs_transfer( 1, tinterp, 0 );
00712
00713         // Perform interpolation on local source mesh; put results into
00714         // tinterp.vr_wr[i]
00715
00716         mappedPts->enableWriteAccess();
00717         for( unsigned int i = 0; i < tinterp.get_n(); i++ )
00718         {
00719             int mindex    = tinterp.vi_rd[5 * i + 2];
00720             Method method = (Method)tinterp.vi_rd[5 * i + 3];
00721             Tag tag       = tags[tinterp.vi_rd[5 * i + 4]];
00722
00723             result = MB_FAILURE;
00724             if( LINEAR_FE == method || QUADRATIC_FE == method || SPHERICAL == method )
00725             {
00726                 result = interp_field( mappedPts->vul_rd[mindex], CartVect( mappedPts->vr_wr + 3 * mindex ), tag,
00727                                        tinterp.vr_wr[i] );
00728             }
00729             else if( CONSTANT == method )
00730             {
00731                 result = constant_interp( mappedPts->vul_rd[mindex], tag, tinterp.vr_wr[i] );
00732             }
00733
00734             if( MB_SUCCESS != result ) return result;
00735         }
00736
00737         // Scatter/gather interpolation data
00738         myPc->proc_config().crystal_router()->gs_transfer( 1, tinterp, 0 );
00739     }
00740
00741     // Copy the interpolated field as a unit
00742     for( unsigned int i = 0; i < tinterp.get_n(); i++ )
00743         interp_vals[tinterp.vi_rd[5 * i + 1]] = tinterp.vr_rd[i];
00744
00745     // Done
00746     return MB_SUCCESS;
00747 }
00748
00749 ErrorCode Coupler::nat_param( double xyz[3],
00750                               std::vector< EntityHandle >& entities,
00751                               std::vector< CartVect >& nat_coords,
00752                               double epsilon )
00753 {
00754     if( !myTree ) return MB_FAILURE;
00755
00756     AdaptiveKDTreeIter treeiter;
00757     ErrorCode result = myTree->get_tree_iterator( localRoot, treeiter );
00758     if( MB_SUCCESS != result )
00759     {
00760         std::cout << "Problems getting iterator" << std::endl;
00761         return result;
00762     }
00763
00764     EntityHandle closest_leaf;
00765     if( epsilon )
00766     {
00767         std::vector< double > dists;
00768         std::vector< EntityHandle > leaves;
00769
00770         // Two tolerances
00771         result = myTree->distance_search( xyz, epsilon, leaves,
00772                                           /*iter_tol*/ epsilon,
00773                                           /*inside_tol*/ 10 * epsilon, &dists, NULL, &localRoot );
00774         if( leaves.empty() )
00775             // Not found returns success here, with empty list, just like case with no epsilon
00776             return MB_SUCCESS;
00777         // Get closest leaf
00778         double min_dist                           = *dists.begin();
00779         closest_leaf                              = *leaves.begin();
00780         std::vector< EntityHandle >::iterator vit = leaves.begin() + 1;
00781         std::vector< double >::iterator dit       = dists.begin() + 1;
00782         for( ; vit != leaves.end() && min_dist; ++vit, ++dit )
00783         {
00784             if( *dit < min_dist )
00785             {
00786                 min_dist     = *dit;
00787                 closest_leaf = *vit;
00788             }
00789         }
00790     }
00791     else
00792     {
00793         result = myTree->point_search( xyz, treeiter, 1.0e-10, 1.0e-6, NULL, &localRoot );
00794         if( MB_ENTITY_NOT_FOUND == result )  // Point is outside of myTree's bounding box
00795             return MB_SUCCESS;
00796         else if( MB_SUCCESS != result )
00797         {
00798             std::cout << "Problems getting leaf \n";
00799             return result;
00800         }
00801         closest_leaf = treeiter.handle();
00802     }
00803
00804     // Find natural coordinates of point in element(s) in that leaf
00805     CartVect tmp_nat_coords;
00806     Range range_leaf;
00807     result = mbImpl->get_entities_by_dimension( closest_leaf, max_dim, range_leaf, false );
00808     if( MB_SUCCESS != result ) std::cout << "Problem getting leaf in a range" << std::endl;
00809
00810     // Loop over the range_leaf
00811     for( Range::iterator iter = range_leaf.begin(); iter != range_leaf.end(); ++iter )
00812     {
00813         // Test to find out in which entity the point is
00814         // Get the EntityType and create the appropriate Element::Map subtype
00815         // If spectral, do not need coordinates, just the GL points
00816         EntityType etype = mbImpl->type_from_handle( *iter );
00817         if( NULL != this->_spectralSource && MBHEX == etype )
00818         {
00819             EntityHandle eh = *iter;
00820             const double* xval;
00821             const double* yval;
00822             const double* zval;
00823             ErrorCode rval = mbImpl->tag_get_by_ptr( _xm1Tag, &eh, 1, (const void**)&xval );
00824             if( moab::MB_SUCCESS != rval )
00825             {
00826                 std::cout << "Can't get xm1 values \n";
00827                 return MB_FAILURE;
00828             }
00829             rval = mbImpl->tag_get_by_ptr( _ym1Tag, &eh, 1, (const void**)&yval );
00830             if( moab::MB_SUCCESS != rval )
00831             {
00832                 std::cout << "Can't get ym1 values \n";
00833                 return MB_FAILURE;
00834             }
00835             rval = mbImpl->tag_get_by_ptr( _zm1Tag, &eh, 1, (const void**)&zval );
00836             if( moab::MB_SUCCESS != rval )
00837             {
00838                 std::cout << "Can't get zm1 values \n";
00839                 return MB_FAILURE;
00840             }
00841             Element::SpectralHex* spcHex = (Element::SpectralHex*)_spectralSource;
00842
00843             spcHex->set_gl_points( (double*)xval, (double*)yval, (double*)zval );
00844             try
00845             {
00846                 tmp_nat_coords = spcHex->ievaluate( CartVect( xyz ), epsilon );  // introduce
00847                 bool inside    = spcHex->inside_nat_space( CartVect( tmp_nat_coords ), epsilon );
00848                 if( !inside )
00849                 {
00850 #ifdef VERBOSE
00851                     std::cout << "point " << xyz[0] << " " << xyz[1] << " " << xyz[2]
00852                               << " is not converging inside hex " << mbImpl->id_from_handle( eh ) << "\n";
00853 #endif
00854                     continue;  // It is possible that the point is outside, so it will not converge
00855                 }
00856             }
00857             catch( Element::Map::EvaluationError& )
00858             {
00859                 continue;
00860             }
00861         }
00862         else
00863         {
00864             const EntityHandle* connect;
00865             int num_connect;
00866
00867             // Get connectivity
00868             result = mbImpl->get_connectivity( *iter, connect, num_connect, true );
00869             if( MB_SUCCESS != result ) return result;
00870
00871             // Get coordinates of the vertices
00872             std::vector< CartVect > coords_vert( num_connect );
00873             result = mbImpl->get_coords( connect, num_connect, &( coords_vert[0][0] ) );
00874             if( MB_SUCCESS != result )
00875             {
00876                 std::cout << "Problems getting coordinates of vertices\n";
00877                 return result;
00878             }
00879             CartVect pos( xyz );
00880             if( MBHEX == etype )
00881             {
00882                 if( 8 == num_connect )
00883                 {
00884                     Element::LinearHex hexmap( coords_vert );
00885                     if( !hexmap.inside_box( pos, epsilon ) ) continue;
00886                     try
00887                     {
00888                         tmp_nat_coords = hexmap.ievaluate( pos, epsilon );
00889                         bool inside    = hexmap.inside_nat_space( tmp_nat_coords, epsilon );
00890                         if( !inside ) continue;
00891                     }
00892                     catch( Element::Map::EvaluationError& )
00893                     {
00894                         continue;
00895                     }
00896                 }
00897                 else if( 27 == num_connect )
00898                 {
00899                     Element::QuadraticHex hexmap( coords_vert );
00900                     if( !hexmap.inside_box( pos, epsilon ) ) continue;
00901                     try
00902                     {
00903                         tmp_nat_coords = hexmap.ievaluate( pos, epsilon );
00904                         bool inside    = hexmap.inside_nat_space( tmp_nat_coords, epsilon );
00905                         if( !inside ) continue;
00906                     }
00907                     catch( Element::Map::EvaluationError& )
00908                     {
00909                         continue;
00910                     }
00911                 }
00912                 else  // TODO this case not treated yet, no interpolation
00913                     continue;
00914             }
00915             else if( MBTET == etype )
00916             {
00917                 Element::LinearTet tetmap( coords_vert );
00918                 // This is just a linear solve; unless degenerate, will not except
00919                 tmp_nat_coords = tetmap.ievaluate( pos );
00920                 bool inside    = tetmap.inside_nat_space( tmp_nat_coords, epsilon );
00921                 if( !inside ) continue;
00922             }
00923             else if( MBQUAD == etype && spherical )
00924             {
00925                 Element::SphericalQuad sphermap( coords_vert );
00926                 /* skip box test, because it can filter out good elements with high curvature
00927                  * if (!sphermap.inside_box(pos, epsilon))
00928                   continue;*/
00929                 try
00930                 {
00931                     tmp_nat_coords = sphermap.ievaluate( pos, epsilon );
00932                     bool inside    = sphermap.inside_nat_space( tmp_nat_coords, epsilon );
00933                     if( !inside ) continue;
00934                 }
00935                 catch( Element::Map::EvaluationError& )
00936                 {
00937                     continue;
00938                 }
00939             }
00940             else if( MBTRI == etype && spherical )
00941             {
00942                 Element::SphericalTri sphermap( coords_vert );
00943                 /* skip box test, because it can filter out good elements with high curvature
00944                  * if (!sphermap.inside_box(pos, epsilon))
00945                     continue;*/
00946                 try
00947                 {
00948                     tmp_nat_coords = sphermap.ievaluate( pos, epsilon );
00949                     bool inside    = sphermap.inside_nat_space( tmp_nat_coords, epsilon );
00950                     if( !inside ) continue;
00951                 }
00952                 catch( Element::Map::EvaluationError& )
00953                 {
00954                     continue;
00955                 }
00956             }
00957
00958             else if( MBQUAD == etype )
00959             {
00960                 Element::LinearQuad quadmap( coords_vert );
00961                 if( !quadmap.inside_box( pos, epsilon ) ) continue;
00962                 try
00963                 {
00964                     tmp_nat_coords = quadmap.ievaluate( pos, epsilon );
00965                     bool inside    = quadmap.inside_nat_space( tmp_nat_coords, epsilon );
00966                     if( !inside ) continue;
00967                 }
00968                 catch( Element::Map::EvaluationError& )
00969                 {
00970                     continue;
00971                 }
00972                 if( !quadmap.inside_nat_space( tmp_nat_coords, epsilon ) ) continue;
00973             }
00974             /*
00975             else if (etype == MBTRI){
00976               Element::LinearTri trimap(coords_vert);
00977               if (!trimap.inside_box( pos, epsilon))
00978                 continue;
00979               try {
00980                 tmp_nat_coords = trimap.ievaluate(pos, epsilon);
00981                 bool inside = trimap.inside_nat_space(tmp_nat_coords, epsilon);
00982                 if (!inside) continue;
00983               }
00984               catch (Element::Map::EvaluationError) {
00985                 continue;
00986               }
00987               if (!trimap.inside_nat_space(tmp_nat_coords, epsilon))
00988                 continue;
00989             }
00990             */
00991             else if( etype == MBEDGE )
00992             {
00993                 Element::LinearEdge edgemap( coords_vert );
00994                 try
00995                 {
00996                     tmp_nat_coords = edgemap.ievaluate( CartVect( xyz ), epsilon );
00997                 }
00998                 catch( Element::Map::EvaluationError )
00999                 {
01000                     continue;
01001                 }
01002                 if( !edgemap.inside_nat_space( tmp_nat_coords, epsilon ) ) continue;
01003             }
01004             else
01005             {
01006                 std::cout << "Entity not Hex/Tet/Quad/Tri/Edge. Please verify." << std::endl;
01007                 continue;
01008             }
01009         }
01010         // If we get here then we've found the coordinates.
01011         // Save them and the entity and return success.
01012         entities.push_back( *iter );
01013         nat_coords.push_back( tmp_nat_coords );
01014         return MB_SUCCESS;
01015     }
01016
01017     // Didn't find any elements containing the point
01018     return MB_SUCCESS;
01019 }
01020
01021 ErrorCode Coupler::interp_field( EntityHandle elem, CartVect nat_coord, Tag tag, double& field )
01022 {
01023     if( _spectralSource )
01024     {
01025         // Get tag values at the GL points for some field (Tag)
01026         const double* vx;
01027         ErrorCode rval = mbImpl->tag_get_by_ptr( tag, &elem, 1, (const void**)&vx );
01028         if( moab::MB_SUCCESS != rval )
01029         {
01030             std::cout << "Can't get field values for the tag \n";
01031             return MB_FAILURE;
01032         }
01033         Element::SpectralHex* spcHex = (Element::SpectralHex*)_spectralSource;
01034         field                        = spcHex->evaluate_scalar_field( nat_coord, vx );
01035     }
01036     else
01037     {
01038         double vfields[27];  // Will work for linear hex, quadratic hex or Tets
01039         moab::Element::Map* elemMap = NULL;
01040         int num_verts               = 0;
01041         // Get the EntityType
01042         // Get the tag values at the vertices
01043         const EntityHandle* connect;
01044         int num_connect;
01045         ErrorCode result = mbImpl->get_connectivity( elem, connect, num_connect );
01046         if( MB_SUCCESS != result ) return result;
01047         EntityType etype = mbImpl->type_from_handle( elem );
01048         if( MBHEX == etype )
01049         {
01050             if( 8 == num_connect )
01051             {
01052                 elemMap   = new moab::Element::LinearHex();
01053                 num_verts = 8;
01054             }
01055             else
01056             { /* (MBHEX == etype && 27 == num_connect) */
01057                 elemMap   = new moab::Element::QuadraticHex();
01058                 num_verts = 27;
01059             }
01060         }
01061         else if( MBTET == etype )
01062         {
01063             elemMap   = new moab::Element::LinearTet();
01064             num_verts = 4;
01065         }
01066         else if( MBQUAD == etype )
01067         {
01068             elemMap   = new moab::Element::LinearQuad();
01069             num_verts = 4;
01070         }
01071         else if( MBTRI == etype )
01072         {
01073             elemMap   = new moab::Element::LinearTri();
01074             num_verts = 3;
01075         }
01076         else
01077             return MB_FAILURE;
01078
01079         result = mbImpl->tag_get_data( tag, connect, std::min( num_verts, num_connect ), vfields );
01080         if( MB_SUCCESS != result )
01081         {
01082             delete elemMap;
01083             return result;
01084         }
01085
01086         // Function for the interpolation
01087         field = 0;
01088
01089         // Check the number of vertices
01090         assert( num_connect >= num_verts );
01091
01092         // Calculate the field
01093         try
01094         {
01095             field = elemMap->evaluate_scalar_field( nat_coord, vfields );
01096         }
01097         catch( moab::Element::Map::EvaluationError& )
01098         {
01099             delete elemMap;
01100             return MB_FAILURE;
01101         }
01102
01103         delete elemMap;
01104     }
01105
01106     return MB_SUCCESS;
01107 }
01108
01109 // Simplest "interpolation" for element-based source fields. Set the value of the field
01110 // at the target point to that of the field in the source element it lies in.
01111 ErrorCode Coupler::constant_interp( EntityHandle elem, Tag tag, double& field )
01112 {
01113     double tempField;
01114
01115     // Get the tag values at the vertices
01116     ErrorCode result = mbImpl->tag_get_data( tag, &elem, 1, &tempField );
01117     if( MB_SUCCESS != result ) return result;
01118
01119     field = tempField;
01120
01121     return MB_SUCCESS;
01122 }
01123
01124 // Normalize a field over the entire mesh represented by the root_set.
01125 ErrorCode Coupler::normalize_mesh( EntityHandle root_set,
01126                                    const char* norm_tag,
01127                                    Coupler::IntegType integ_type,
01128                                    int num_integ_pts )
01129 {
01130     ErrorCode err;
01131
01132     // SLAVE START ****************************************************************
01133     // Search for entities based on tag_handles and tag_values
01134     std::vector< std::vector< EntityHandle > > entity_sets;
01135     std::vector< std::vector< EntityHandle > > entity_groups;
01136
01137     // put the root_set into entity_sets
01138     std::vector< EntityHandle > ent_set;
01139     ent_set.push_back( root_set );
01140     entity_sets.push_back( ent_set );
01141
01142     // get all entities from root_set and put into entity_groups
01143     std::vector< EntityHandle > entities;
01144     err = mbImpl->get_entities_by_handle( root_set, entities, true );ERRORR( "Failed to get entities in root_set.", err );
01145
01146     entity_groups.push_back( entities );
01147
01148     // Call do_normalization() to continue common normalization processing
01149     err = do_normalization( norm_tag, entity_sets, entity_groups, integ_type, num_integ_pts );ERRORR( "Failure in do_normalization().", err );
01150     // SLAVE END   ****************************************************************
01151
01152     return err;
01153 }
01154
01155 // Normalize a field over the subset of entities identified by the tags and values passed
01156 ErrorCode Coupler::normalize_subset( EntityHandle root_set,
01157                                      const char* norm_tag,
01158                                      const char** tag_names,
01159                                      int num_tags,
01160                                      const char** tag_values,
01161                                      Coupler::IntegType integ_type,
01162                                      int num_integ_pts )
01163 {
01164     moab::ErrorCode err;
01165     std::vector< Tag > tag_handles;
01166
01167     // Lookup tag handles from tag names
01168     for( int t = 0; t < num_tags; t++ )
01169     {
01170         // get tag handle & size
01171         Tag th;
01172         err = mbImpl->tag_get_handle( tag_names[t], 1, moab::MB_TYPE_DOUBLE, th, moab::MB_TAG_ANY );ERRORR( "Failed to get tag handle.", err );
01173         tag_handles.push_back( th );
01174     }
01175
01176     return normalize_subset( root_set, norm_tag, &tag_handles[0], num_tags, tag_values, integ_type, num_integ_pts );
01177 }
01178
01179 ErrorCode Coupler::normalize_subset( EntityHandle root_set,
01180                                      const char* norm_tag,
01181                                      Tag* tag_handles,
01182                                      int num_tags,
01183                                      const char** tag_values,
01184                                      Coupler::IntegType integ_type,
01185                                      int num_integ_pts )
01186 {
01187     ErrorCode err;
01188
01189     // SLAVE START ****************************************************************
01190     // Search for entities based on tag_handles and tag_values
01191     std::vector< std::vector< EntityHandle > > entity_sets;
01192     std::vector< std::vector< EntityHandle > > entity_groups;
01193
01194     err = get_matching_entities( root_set, tag_handles, tag_values, num_tags, &entity_sets, &entity_groups );ERRORR( "Failed to get matching entities.", err );
01195
01196     // Call do_normalization() to continue common normalization processing
01197     err = do_normalization( norm_tag, entity_sets, entity_groups, integ_type, num_integ_pts );ERRORR( "Failure in do_normalization().", err );
01198     // SLAVE END   ****************************************************************
01199
01200     return err;
01201 }
01202
01203 ErrorCode Coupler::do_normalization( const char* norm_tag,
01204                                      std::vector< std::vector< EntityHandle > >& entity_sets,
01205                                      std::vector< std::vector< EntityHandle > >& entity_groups,
01206                                      Coupler::IntegType integ_type,
01207                                      int num_integ_pts )
01208 {
01209     // SLAVE START ****************************************************************
01210     ErrorCode err;
01211     int ierr = 0;
01212
01213     // Setup data for parallel computing
01214     int nprocs, rank;
01215     ierr = MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
01216     ERRORMPI( "Getting number of procs failed.", ierr );
01217     ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01218     ERRORMPI( "Getting rank failed.", ierr );
01219
01220     // Get the integrated field value for each group(vector) of entities.
01221     // If no entities are in a group then a zero will be put in the list
01222     // of return values.
01223     unsigned int num_ent_grps = entity_groups.size();
01224     std::vector< double > integ_vals( num_ent_grps );
01225
01226     err = get_group_integ_vals( entity_groups, integ_vals, norm_tag, num_integ_pts, integ_type );ERRORR( "Failed to get integrated field values for groups in mesh.", err );
01227     // SLAVE END   ****************************************************************
01228
01229     // SLAVE/MASTER START #########################################################
01230     // Send list of integrated values back to master proc. The ordering of the
01231     // values will match the ordering of the entity groups (i.e. vector of vectors)
01232     // sent from master to slaves earlier.  The values for each entity group will
01233     // be summed during the transfer.
01234     std::vector< double > sum_integ_vals( num_ent_grps );
01235
01236     if( nprocs > 1 )
01237     {
01238         // If parallel then send the values back to the master.
01239         ierr = MPI_Reduce( &integ_vals[0], &sum_integ_vals[0], num_ent_grps, MPI_DOUBLE, MPI_SUM, MASTER_PROC,
01240                            myPc->proc_config().proc_comm() );
01241         ERRORMPI( "Transfer and reduction of integrated values failed.", ierr );
01242     }
01243     else
01244     {
01245         // Otherwise just copy the vector
01246         sum_integ_vals = integ_vals;
01247     }
01248     // SLAVE/MASTER END   #########################################################
01249
01250     // MASTER START ***************************************************************
01251     // Calculate the normalization factor for each group by taking the
01252     // inverse of each integrated field value. Put the normalization factor
01253     // for each group back into the list in the same order.
01254     for( unsigned int i = 0; i < num_ent_grps; i++ )
01255     {
01256         double val = sum_integ_vals[i];
01257         if( fabs( val ) > 1e-8 )
01258             sum_integ_vals[i] = 1.0 / val;
01259         else
01260         {
01261             sum_integ_vals[i] = 0.0; /* VSM: not sure what we should do here ? */
01262             /* commenting out error below since if integral(value)=0.0, then normalization
01263                is probably unnecessary to start with ? */
01264             /* ERRORR("Integrating an invalid field -- integral("<<norm_tag<<") = "<<val<<".", err);
01265              */
01266         }
01267     }
01268     // MASTER END   ***************************************************************
01269
01270     // MASTER/SLAVE START #########################################################
01271     if( nprocs > 1 )
01272     {
01273         // If parallel then broadcast the normalization factors to the procs.
01274         ierr = MPI_Bcast( &sum_integ_vals[0], num_ent_grps, MPI_DOUBLE, MASTER_PROC, myPc->proc_config().proc_comm() );
01275         ERRORMPI( "Broadcast of normalization factors failed.", ierr );
01276     }
01277     // MASTER/SLAVE END   #########################################################
01278
01279     // SLAVE START ****************************************************************
01280     // Save the normalization factors to a new tag with name of norm_tag's value
01281     // and the string "_normF" appended.  This new tag will be created on the entity
01282     // set that contains all of the entities from a group.
01283
01284     err = apply_group_norm_factor( entity_sets, sum_integ_vals, norm_tag, integ_type );ERRORR( "Failed to set the normalization factor for groups in mesh.", err );
01285     // SLAVE END   ****************************************************************
01286
01287     return err;
01288 }
01289
01290 // Functions supporting the subset normalization function
01291
01292 // Retrieve groups of entities matching tags and values if present
01293 ErrorCode Coupler::get_matching_entities( EntityHandle root_set,
01294                                           const char** tag_names,
01295                                           const char** tag_values,
01296                                           int num_tags,
01297                                           std::vector< std::vector< EntityHandle > >* entity_sets,
01298                                           std::vector< std::vector< EntityHandle > >* entity_groups )
01299 {
01300     ErrorCode err;
01301     std::vector< Tag > tag_handles;
01302
01303     for( int t = 0; t < num_tags; t++ )
01304     {
01305         // Get tag handle & size
01306         Tag th;
01307         err = mbImpl->tag_get_handle( tag_names[t], 1, moab::MB_TYPE_DOUBLE, th, moab::MB_TAG_ANY );ERRORR( "Failed to get tag handle.", err );
01308         tag_handles.push_back( th );
01309     }
01310
01311     return get_matching_entities( root_set, &tag_handles[0], tag_values, num_tags, entity_sets, entity_groups );
01312 }
01313
01314 // Retrieve groups of entities matching tags and values if present
01315 ErrorCode Coupler::get_matching_entities( EntityHandle root_set,
01316                                           Tag* tag_handles,
01317                                           const char** tag_values,
01318                                           int num_tags,
01319                                           std::vector< std::vector< EntityHandle > >* entity_sets,
01320                                           std::vector< std::vector< EntityHandle > >* entity_groups )
01321 {
01322     // SLAVE START ****************************************************************
01323
01324     // Setup data for parallel computing
01325     ErrorCode err;
01326     int ierr = 0;
01327     int nprocs, rank;
01328     ierr = MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
01329     ERRORMPI( "Getting number of procs failed.", ierr );
01330     ierr = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
01331     ERRORMPI( "Getting rank failed.", ierr );
01332
01333     Range ent_sets;
01334     err =
01335         mbImpl->get_entities_by_type_and_tag( root_set, moab::MBENTITYSET, tag_handles, (const void* const*)tag_values,
01336                                               num_tags, ent_sets, Interface::INTERSECT, false );ERRORR( "Core::get_entities_by_type_and_tag failed.", err );
01337
01338     TupleList* tag_list = NULL;
01339     err                 = create_tuples( ent_sets, tag_handles, num_tags, &tag_list );ERRORR( "Failed to create tuples from entity sets.", err );
01340
01341     // Free up range
01342     ent_sets.clear();
01343     // SLAVE END   ****************************************************************
01344
01345     // If we are running in a multi-proc session then send tuple list back to master
01346     // proc for consolidation. Otherwise just copy the pointer to the tuple_list.
01347     TupleList* cons_tuples;
01348     if( nprocs > 1 )
01349     {
01350         // SLAVE/MASTER START #########################################################
01351
01352         // Pack the tuple_list in a buffer.
01353         uint* tuple_buf;
01354         int tuple_buf_len;
01355         tuple_buf_len = pack_tuples( tag_list, (void**)&tuple_buf );
01356
01357         // Free tag_list here as its not used again if nprocs > 1
01358         tag_list->reset();
01359
01360         // Send back the buffer sizes to the master proc
01361         int* recv_cnts       = (int*)malloc( nprocs * sizeof( int ) );
01362         int* offsets         = (int*)malloc( nprocs * sizeof( int ) );
01363         uint* all_tuples_buf = NULL;
01364
01365         MPI_Gather( &tuple_buf_len, 1, MPI_INT, recv_cnts, 1, MPI_INT, MASTER_PROC, myPc->proc_config().proc_comm() );
01366         ERRORMPI( "Gathering buffer sizes failed.", err );
01367
01368         // Allocate a buffer large enough for all the data
01369         if( rank == MASTER_PROC )
01370         {
01371             int all_tuples_len = recv_cnts[0];
01372             offsets[0]         = 0;
01373             for( int i = 1; i < nprocs; i++ )
01374             {
01375                 offsets[i] = offsets[i - 1] + recv_cnts[i - 1];
01376                 all_tuples_len += recv_cnts[i];
01377             }
01378
01379             all_tuples_buf = (uint*)malloc( all_tuples_len * sizeof( uint ) );
01380         }
01381
01382         // Send all buffers to the master proc for consolidation
01383         MPI_Gatherv( (void*)tuple_buf, tuple_buf_len, MPI_INT, (void*)all_tuples_buf, recv_cnts, offsets, MPI_INT,
01384                      MASTER_PROC, myPc->proc_config().proc_comm() );
01385         ERRORMPI( "Gathering tuple_lists failed.", err );
01386         free( tuple_buf );  // malloc'd in pack_tuples
01387
01388         if( rank == MASTER_PROC )
01389         {
01390             // Unpack the tuple_list from the buffer.
01391             TupleList** tl_array = (TupleList**)malloc( nprocs * sizeof( TupleList* ) );
01392             for( int i = 0; i < nprocs; i++ )
01393                 unpack_tuples( (void*)&all_tuples_buf[offsets[i]], &tl_array[i] );
01394
01395             // Free all_tuples_buf here as it is only allocated on the MASTER_PROC
01396             free( all_tuples_buf );
01397             // SLAVE/MASTER END   #########################################################
01398
01399             // MASTER START ***************************************************************
01400             // Consolidate all tuple_lists into one tuple_list with no duplicates.
01401             err = consolidate_tuples( tl_array, nprocs, &cons_tuples );ERRORR( "Failed to consolidate tuples.", err );
01402
01403             for( int i = 0; i < nprocs; i++ )
01404                 tl_array[i]->reset();
01405             free( tl_array );
01406             // MASTER END   ***************************************************************
01407         }
01408
01409         // Free offsets and recv_cnts as they are allocated on all procs
01410         free( offsets );
01411         free( recv_cnts );
01412
01413         // MASTER/SLAVE START #########################################################
01414         // Broadcast condensed tuple list back to all procs.
01415         uint* ctl_buf;
01416         int ctl_buf_sz;
01417         if( rank == MASTER_PROC ) ctl_buf_sz = pack_tuples( cons_tuples, (void**)&ctl_buf );
01418
01419         // Send buffer size
01420         ierr = MPI_Bcast( &ctl_buf_sz, 1, MPI_INT, MASTER_PROC, myPc->proc_config().proc_comm() );
01421         ERRORMPI( "Broadcasting tuple_list size failed.", ierr );
01422
01423         // Allocate a buffer in the other procs
01424         if( rank != MASTER_PROC ) ctl_buf = (uint*)malloc( ctl_buf_sz * sizeof( uint ) );
01425
01426         ierr = MPI_Bcast( (void*)ctl_buf, ctl_buf_sz, MPI_INT, MASTER_PROC, myPc->proc_config().proc_comm() );
01427         ERRORMPI( "Broadcasting tuple_list failed.", ierr );
01428
01429         if( rank != MASTER_PROC ) unpack_tuples( ctl_buf, &cons_tuples );
01430         free( ctl_buf );
01431         // MASTER/SLAVE END   #########################################################
01432     }
01433     else
01434         cons_tuples = tag_list;
01435
01436     // SLAVE START ****************************************************************
01437     // Loop over the tuple list getting the entities with the tags in the tuple_list entry
01438     uint mi, ml, mul, mr;
01439     cons_tuples->getTupleSize( mi, ml, mul, mr );
01440
01441     for( unsigned int i = 0; i < cons_tuples->get_n(); i++ )
01442     {
01443         // Get Entity Sets that match the tags and values.
01444
01445         // Convert the data in the tuple_list to an array of pointers to the data
01446         // in the tuple_list as that is what the iMesh API call is expecting.
01447         int** vals = (int**)malloc( mi * sizeof( int* ) );
01448         for( unsigned int j = 0; j < mi; j++ )
01449             vals[j] = (int*)&( cons_tuples->vi_rd[( i * mi ) + j] );
01450
01451         // Get entities recursively based on type and tag data
01452         err = mbImpl->get_entities_by_type_and_tag( root_set, moab::MBENTITYSET, tag_handles, (const void* const*)vals,
01453                                                     mi, ent_sets, Interface::INTERSECT, false );ERRORR( "Core::get_entities_by_type_and_tag failed.", err );
01454         if( debug ) std::cout << "ent_sets_size=" << ent_sets.size() << std::endl;
01455
01456         // Free up the array of pointers
01457         free( vals );
01458
01459         // Loop over the entity sets and then free the memory for ent_sets.
01460         std::vector< EntityHandle > ent_set_hdls;
01461         std::vector< EntityHandle > ent_hdls;
01462         for( unsigned int j = 0; j < ent_sets.size(); j++ )
01463         {
01464             // Save the entity set
01465             ent_set_hdls.push_back( ent_sets[j] );
01466
01467             // Get all entities for the entity set
01468             Range ents;
01469
01470             /* VSM: do we need to filter out entity sets ? */
01471             err = mbImpl->get_entities_by_handle( ent_sets[j], ents, false );ERRORR( "Core::get_entities_by_handle failed.", err );
01472             if( debug ) std::cout << "ents_size=" << ents.size() << std::endl;
01473
01474             // Save all of the entities from the entity set and free the memory for ents.
01475             for( unsigned int k = 0; k < ents.size(); k++ )
01476             {
01477                 ent_hdls.push_back( ents[k] );
01478             }
01479             ents.clear();
01480             if( debug ) std::cout << "ent_hdls.size=" << ent_hdls.size() << std::endl;
01481         }
01482
01483         // Free the entity set list for next tuple iteration.
01484         ent_sets.clear();
01485
01486         // Push ent_set_hdls onto entity_sets, ent_hdls onto entity_groups
01487         // and clear both ent_set_hdls and ent_hdls.
01488         entity_sets->push_back( ent_set_hdls );
01489         ent_set_hdls.clear();
01490         entity_groups->push_back( ent_hdls );
01491         ent_hdls.clear();
01492         if( debug )
01493             std::cout << "entity_sets->size=" << entity_sets->size()
01494                       << ", entity_groups->size=" << entity_groups->size() << std::endl;
01495     }
01496
01497     cons_tuples->reset();
01498     // SLAVE END   ****************************************************************
01499
01500     return err;
01501 }
01502
01503 // Return a tuple_list containing  tag values for each Entity Set
01504 // The tuple_list will have a column for each tag and a row for each
01505 // Entity Set. It is assumed all of the tags are integer tags.
01506 ErrorCode Coupler::create_tuples( Range& ent_sets,
01507                                   const char** tag_names,
01508                                   unsigned int num_tags,
01509                                   TupleList** tuple_list )
01510 {
01511     ErrorCode err;
01512     std::vector< Tag > tag_handles;
01513
01514     for( unsigned int t = 0; t < num_tags; t++ )
01515     {
01516         // Get tag handle & size
01517         Tag th;
01518         err = mbImpl->tag_get_handle( tag_names[t], 1, moab::MB_TYPE_DOUBLE, th, moab::MB_TAG_ANY );ERRORR( "Failed to get tag handle.", err );
01519         tag_handles.push_back( th );
01520     }
01521
01522     return create_tuples( ent_sets, &tag_handles[0], num_tags, tuple_list );
01523 }
01524
01525 // Return a tuple_list containing  tag values for each Entity Set
01526 // The tuple_list will have a column for each tag and a row for each
01527 // Entity Set.  It is assumed all of the tags are integer tags.
01528 ErrorCode Coupler::create_tuples( Range& ent_sets, Tag* tag_handles, unsigned int num_tags, TupleList** tuples )
01529 {
01530     // ASSUMPTION: All tags are of type integer.  This may need to be expanded in future.
01531     ErrorCode err;
01532
01533     // Allocate a tuple_list for the number of entity sets passed in
01534     TupleList* tag_tuples = new TupleList( num_tags, 0, 0, 0, (int)ent_sets.size() );
01535     // tag_tuples->initialize(num_tags, 0, 0, 0, num_sets);
01536     uint mi, ml, mul, mr;
01537     tag_tuples->getTupleSize( mi, ml, mul, mr );
01538     tag_tuples->enableWriteAccess();
01539
01540     if( mi == 0 ) ERRORR( "Failed to initialize tuple_list.", MB_FAILURE );
01541
01542     // Loop over the filtered entity sets retrieving each matching tag value one by one.
01543     int val;
01544     for( unsigned int i = 0; i < ent_sets.size(); i++ )
01545     {
01546         for( unsigned int j = 0; j < num_tags; j++ )
01547         {
01548             EntityHandle set_handle = ent_sets[i];
01549             err                     = mbImpl->tag_get_data( tag_handles[j], &set_handle, 1, &val );ERRORR( "Failed to get integer tag data.", err );
01550             tag_tuples->vi_wr[i * mi + j] = val;
01551         }
01552
01553         // If we get here there was no error so increment n in the tuple_list
01554         tag_tuples->inc_n();
01555     }
01556     tag_tuples->disableWriteAccess();
01557     *tuples = tag_tuples;
01558
01559     return MB_SUCCESS;
01560 }
01561
01562 // Consolidate tuple_lists into one list with no duplicates
01563 ErrorCode Coupler::consolidate_tuples( TupleList** all_tuples, unsigned int num_tuples, TupleList** unique_tuples )
01564 {
01565     int total_rcv_tuples = 0;
01566     int offset = 0, copysz = 0;
01567     unsigned num_tags = 0;
01568
01569     uint ml, mul, mr;
01570     uint* mi = (uint*)malloc( sizeof( uint ) * num_tuples );
01571
01572     for( unsigned int i = 0; i < num_tuples; i++ )
01573     {
01574         all_tuples[i]->getTupleSize( mi[i], ml, mul, mr );
01575     }
01576
01577     for( unsigned int i = 0; i < num_tuples; i++ )
01578     {
01579         if( all_tuples[i] != NULL )
01580         {
01581             total_rcv_tuples += all_tuples[i]->get_n();
01582             num_tags = mi[i];
01583         }
01584     }
01585     const unsigned int_size  = sizeof( sint );
01586     const unsigned int_width = num_tags * int_size;
01587
01588     // Get the total size of all of the tuple_lists in all_tuples.
01589     for( unsigned int i = 0; i < num_tuples; i++ )
01590     {
01591         if( all_tuples[i] != NULL ) total_rcv_tuples += all_tuples[i]->get_n();
01592     }
01593
01594     // Copy the tuple_lists into a single tuple_list.
01595     TupleList* all_tuples_list = new TupleList( num_tags, 0, 0, 0, total_rcv_tuples );
01596     all_tuples_list->enableWriteAccess();
01597     // all_tuples_list->initialize(num_tags, 0, 0, 0, total_rcv_tuples);
01598     for( unsigned int i = 0; i < num_tuples; i++ )
01599     {
01600         if( all_tuples[i] != NULL )
01601         {
01602             copysz = all_tuples[i]->get_n() * int_width;
01603             memcpy( all_tuples_list->vi_wr + offset, all_tuples[i]->vi_rd, copysz );
01604             offset = offset + ( all_tuples[i]->get_n() * mi[i] );
01605             all_tuples_list->set_n( all_tuples_list->get_n() + all_tuples[i]->get_n() );
01606         }
01607     }
01608
01609     // Sort the new tuple_list. Use a radix type sort, starting with the last (or least significant)
01610     // tag column in the vi array and working towards the first (or most significant) tag column.
01611     TupleList::buffer sort_buffer;
01612     sort_buffer.buffer_init( 2 * total_rcv_tuples * int_width );
01613     for( int i = num_tags - 1; i >= 0; i-- )
01614     {
01615         all_tuples_list->sort( i, &sort_buffer );
01616     }
01617
01618     // Cycle through the sorted list eliminating duplicates.
01619     // Keep counters to the current end of the tuple_list (w/out dups) and the last tuple examined.
01620     unsigned int end_idx = 0, last_idx = 1;
01621     while( last_idx < all_tuples_list->get_n() )
01622     {
01623         if( memcmp( all_tuples_list->vi_rd + ( end_idx * num_tags ), all_tuples_list->vi_rd + ( last_idx * num_tags ),
01624                     int_width ) == 0 )
01625         {
01626             // Values equal - skip
01627             last_idx += 1;
01628         }
01629         else
01630         {
01631             // Values different - copy
01632             // Move up the end index
01633             end_idx += 1;
01634             memcpy( all_tuples_list->vi_wr + ( end_idx * num_tags ), all_tuples_list->vi_rd + ( last_idx * num_tags ),
01635                     int_width );
01636             last_idx += 1;
01637         }
01638     }
01639     // Update the count in all_tuples_list
01640     all_tuples_list->set_n( end_idx + 1 );
01641
01642     // Resize the tuple_list
01643     all_tuples_list->resize( all_tuples_list->get_n() );
01644
01645     // Set the output parameter
01646     *unique_tuples = all_tuples_list;
01647
01648     return MB_SUCCESS;
01649 }
01650
01651 // Calculate integrated field values for groups of entities
01652 ErrorCode Coupler::get_group_integ_vals( std::vector< std::vector< EntityHandle > >& groups,
01653                                          std::vector< double >& integ_vals,
01654                                          const char* norm_tag,
01655                                          int /*num_integ_vals*/,
01656                                          Coupler::IntegType integ_type )
01657 {
01658     ErrorCode err;
01659
01660     std::vector< std::vector< EntityHandle > >::iterator iter_i;
01661     std::vector< EntityHandle >::iterator iter_j;
01662     double grp_intrgr_val, intgr_val;
01663
01664     // Get the tag handle for norm_tag
01665     Tag norm_hdl;
01666     err =
01667         mbImpl->tag_get_handle( norm_tag, 1, moab::MB_TYPE_DOUBLE, norm_hdl, moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );ERRORR( "Failed to get norm_tag handle.", err );
01668
01669     // Check size of integ_vals vector
01670     if( integ_vals.size() != groups.size() ) integ_vals.resize( groups.size() );
01671
01672     // Loop over the groups(vectors) of entities
01673     unsigned int i;
01674     for( i = 0, iter_i = groups.begin(); iter_i != groups.end(); i++, ++iter_i )
01675     {
01676         grp_intrgr_val = 0;
01677
01678         // Loop over the all the entities in the group, integrating
01679         // the field_fn over the entity in iter_j
01680         for( iter_j = ( *iter_i ).begin(); iter_j != ( *iter_i ).end(); ++iter_j )
01681         {
01682             EntityHandle ehandle = ( *iter_j );
01683
01684             // Check that the entity in iter_j is of the same dimension as the
01685             // integ_type we are performing
01686             EntityType j_type;
01687             j_type = mbImpl->type_from_handle( ehandle );ERRORR( "Failed to get entity type.", err );
01688             // Skip any entities in the group that are not of the type being considered
01689             if( ( integ_type == VOLUME ) && ( j_type < MBTET || j_type >= MBENTITYSET ) ) continue;
01690
01691             intgr_val = 0;
01692
01693             // Retrieve the vertices from the element
01694             const EntityHandle* verts = NULL;
01695             int connectivity_size     = 0;
01696
01697             err = mbImpl->get_connectivity( ehandle, verts, connectivity_size, false );ERRORR( "Failed to get vertices from entity.", err );
01698
01699             // Get the vertex coordinates and the field values at the vertices.
01700             double* coords = (double*)malloc( sizeof( double ) * ( 3 * connectivity_size ) );
01701             /* TODO: VSM: check if this works for lower dimensions also without problems */
01702             /* if (3 == geom_dim) */
01703             err = mbImpl->get_coords( verts, connectivity_size, coords );ERRORR( "Failed to get vertex coordinates.", err );
01704
01705             /* allocate the field data array */
01706             double* vfield = (double*)malloc( sizeof( double ) * ( connectivity_size ) );
01707             err            = mbImpl->tag_get_data( norm_hdl, verts, connectivity_size, vfield );
01708             if( MB_SUCCESS != err )
01709             {
01710                 free( coords );
01711             }
01712             ERRORR( "Failed to get vertex coordinates.", err );
01713
01714             // Get coordinates of all corner vertices (in normal order) and
01715             // put in array of CartVec.
01716             std::vector< CartVect > vertices( connectivity_size );
01717
01718             // Put the vertices into a CartVect vector
01719             double* x = coords;
01720             for( int j = 0; j < connectivity_size; j++, x += 3 )
01721             {
01722                 vertices[j] = CartVect( x );
01723             }
01724             free( coords );
01725
01726             moab::Element::Map* elemMap;
01727             if( j_type == MBHEX )
01728             {
01729                 if( connectivity_size == 8 )
01730                     elemMap = new moab::Element::LinearHex( vertices );
01731                 else
01732                     elemMap = new moab::Element::QuadraticHex( vertices );
01733             }
01734             else if( j_type == MBTET )
01735             {
01736                 elemMap = new moab::Element::LinearTet( vertices );
01737             }
01738             else if( j_type == MBQUAD )
01739             {
01740                 elemMap = new moab::Element::LinearQuad( vertices );
01741             }
01742             /*
01743             else if (j_type == MBTRI) {
01744               elemMap = new moab::Element::LinearTri(vertices);
01745             }
01746             */
01747             else if( j_type == MBEDGE )
01748             {
01749                 elemMap = new moab::Element::LinearEdge( vertices );
01750             }
01751             else
01752                 ERRORR( "Unknown topology type.", MB_UNSUPPORTED_OPERATION );
01753
01754             // Set the vertices in the Map and perform the integration
01755             try
01756             {
01757                 /* VSM: Do we need this call ?? */
01758                 // elemMap->set_vertices(vertices);
01759
01760                 // Perform the actual integration over the element
01761                 intgr_val = elemMap->integrate_scalar_field( vfield );
01762
01763                 // Combine the result with those of the group
01764                 grp_intrgr_val += intgr_val;
01765             }
01766             catch( moab::Element::Map::ArgError& )
01767             {
01768                 std::cerr << "Failed to set vertices on Element::Map." << std::endl;
01769             }
01770             catch( moab::Element::Map::EvaluationError& )
01771             {
01772                 std::cerr << "Failed to get inverse evaluation of coordinate on Element::Map." << std::endl;
01773             }
01774
01775             delete( elemMap );
01776             free( vfield );
01777         }
01778
01779         // Set the group integrated value in the vector
01780         integ_vals[i] = grp_intrgr_val;
01781     }
01782
01783     return err;
01784 }
01785
01786 // Apply a normalization factor to group of entities
01787 ErrorCode Coupler::apply_group_norm_factor( std::vector< std::vector< EntityHandle > >& entity_sets,
01788                                             std::vector< double >& norm_factors,
01789                                             const char* norm_tag,
01790                                             Coupler::IntegType /*integ_type*/ )
01791 {
01792     ErrorCode err;
01793
01794     // Construct the new tag for the normalization factor from the norm_tag name
01795     // and "_normf".
01796     int norm_tag_len       = strlen( norm_tag );
01797     const char* normf_appd = "_normf";
01798     int normf_appd_len     = strlen( normf_appd );
01799
01800     char* normf_tag = (char*)malloc( norm_tag_len + normf_appd_len + 1 );
01801     char* tmp_ptr   = normf_tag;
01802
01803     memcpy( tmp_ptr, norm_tag, norm_tag_len );
01804     tmp_ptr += norm_tag_len;
01805     memcpy( tmp_ptr, normf_appd, normf_appd_len );
01806     tmp_ptr += normf_appd_len;
01807     *tmp_ptr = '\0';
01808
01809     Tag normf_hdl;
01810     // Check to see if the tag exists.  If not then create it and get the handle.
01811     err = mbImpl->tag_get_handle( normf_tag, 1, moab::MB_TYPE_DOUBLE, normf_hdl,
01812                                   moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );ERRORR( "Failed to create normalization factor tag.", err );
01813     if( normf_hdl == NULL )
01814     {
01815         std::string msg( "Failed to create normalization factor tag named '" );
01816         msg += std::string( normf_tag ) + std::string( "'" );ERRORR( msg.c_str(), MB_FAILURE );
01817     }
01818     free( normf_tag );
01819
01820     std::vector< std::vector< EntityHandle > >::iterator iter_i;
01821     std::vector< EntityHandle >::iterator iter_j;
01822     std::vector< double >::iterator iter_f;
01823     double grp_norm_factor = 0.0;
01824
01825     // Loop over the entity sets
01826     for( iter_i = entity_sets.begin(), iter_f = norm_factors.begin();
01827          ( iter_i != entity_sets.end() ) && ( iter_f != norm_factors.end() ); ++iter_i, ++iter_f )
01828     {
01829         grp_norm_factor = *iter_f;
01830
01831         // Loop over the all the entity sets in iter_i and set the
01832         // new normf_tag with the norm factor value on each
01833         for( iter_j = ( *iter_i ).begin(); iter_j != ( *iter_i ).end(); ++iter_j )
01834         {
01835             EntityHandle entset = *iter_j;
01836
01837             std::cout << "Coupler: applying normalization for entity set=" << entset
01838                       << ",  normalization_factor=" << grp_norm_factor << std::endl;
01839
01840             err = mbImpl->tag_set_data( normf_hdl, &entset, 1, &grp_norm_factor );ERRORR( "Failed to set normalization factor on entity set.", err );
01841         }
01842     }
01843
01844     return MB_SUCCESS;
01845 }
01846
01847 #define UINT_PER_X( X )   ( ( sizeof( X ) + sizeof( uint ) - 1 ) / sizeof( uint ) )
01848 #define UINT_PER_REAL     UINT_PER_X( realType )
01849 #define UINT_PER_LONG     UINT_PER_X( slong )
01850 #define UINT_PER_UNSIGNED UINT_PER_X( unsigned )
01851
01852 // Function for packing tuple_list.  Returns number of uints copied into buffer.
01853 int pack_tuples( TupleList* tl, void** ptr )
01854 {
01855     uint mi, ml, mul, mr;
01856     tl->getTupleSize( mi, ml, mul, mr );
01857
01858     uint n = tl->get_n();
01859
01860     int sz_buf = 1 + 4 * UINT_PER_UNSIGNED +
01861                  tl->get_n() * ( mi + ml * UINT_PER_LONG + mul * UINT_PER_LONG + mr * UINT_PER_REAL );
01862
01863     uint* buf = (uint*)malloc( sz_buf * sizeof( uint ) );
01864     *ptr      = (void*)buf;
01865
01866     // Copy n
01867     memcpy( buf, &n, sizeof( uint ) ), buf += 1;
01868     // Copy mi
01869     memcpy( buf, &mi, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01870     // Copy ml
01871     memcpy( buf, &ml, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01872     // Copy mul
01873     memcpy( buf, &mul, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01874     // Copy mr
01875     memcpy( buf, &mr, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01876     // Copy vi_wr
01877     memcpy( buf, tl->vi_rd, tl->get_n() * mi * sizeof( sint ) ), buf += tl->get_n() * mi;
01878     // Copy vl_wr
01879     memcpy( buf, tl->vl_rd, tl->get_n() * ml * sizeof( slong ) ), buf += tl->get_n() * ml * UINT_PER_LONG;
01880     // Copy vul_wr
01881     memcpy( buf, tl->vul_rd, tl->get_n() * mul * sizeof( ulong ) ), buf += tl->get_n() * mul * UINT_PER_LONG;
01882     // Copy vr_wr
01883     memcpy( buf, tl->vr_rd, tl->get_n() * mr * sizeof( realType ) ), buf += tl->get_n() * mr * UINT_PER_REAL;
01884
01885     return sz_buf;
01886 }
01887
01888 // Function for packing tuple_list
01889 void unpack_tuples( void* ptr, TupleList** tlp )
01890 {
01891     TupleList* tl = new TupleList();
01892     *tlp          = tl;
01893
01894     uint nt;
01895     unsigned mit, mlt, mult, mrt;
01896     uint* buf = (uint*)ptr;
01897
01898     // Get n
01899     memcpy( &nt, buf, sizeof( uint ) ), buf += 1;
01900     // Get mi
01901     memcpy( &mit, buf, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01902     // Get ml
01903     memcpy( &mlt, buf, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01904     // Get mul
01905     memcpy( &mult, buf, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01906     // Get mr
01907     memcpy( &mrt, buf, sizeof( unsigned ) ), buf += UINT_PER_UNSIGNED;
01908
01909     // Initialize tl
01910     tl->initialize( mit, mlt, mult, mrt, nt );
01911     tl->enableWriteAccess();
01912     tl->set_n( nt );
01913
01914     uint mi, ml, mul, mr;
01915     tl->getTupleSize( mi, ml, mul, mr );
01916
01917     // Get vi_rd
01918     memcpy( tl->vi_wr, buf, tl->get_n() * mi * sizeof( sint ) ), buf += tl->get_n() * mi;
01919     // Get vl_rd
01920     memcpy( tl->vl_wr, buf, tl->get_n() * ml * sizeof( slong ) ), buf += tl->get_n() * ml * UINT_PER_LONG;
01921     // Get vul_rd
01922     memcpy( tl->vul_wr, buf, tl->get_n() * mul * sizeof( ulong ) ), buf += tl->get_n() * mul * UINT_PER_LONG;
01923     // Get vr_rd
01924     memcpy( tl->vr_wr, buf, tl->get_n() * mr * sizeof( realType ) ), buf += tl->get_n() * mr * UINT_PER_REAL;
01925
01926     tl->disableWriteAccess();
01927     return;
01928 }
01929
01930 ErrorCode Coupler::get_gl_points_on_elements( Range& targ_elems, std::vector< double >& vpos, int& numPointsOfInterest )
01931 {
01932     numPointsOfInterest = targ_elems.size() * _ntot;
01933     vpos.resize( 3 * numPointsOfInterest );
01934     int ielem = 0;
01935     for( Range::iterator eit = targ_elems.begin(); eit != targ_elems.end(); ++eit, ielem += _ntot * 3 )
01936     {
01937         EntityHandle eh = *eit;
01938         const double* xval;
01939         const double* yval;
01940         const double* zval;
01941         ErrorCode rval = mbImpl->tag_get_by_ptr( _xm1Tag, &eh, 1, (const void**)&xval );
01942         if( moab::MB_SUCCESS != rval )
01943         {
01944             std::cout << "Can't get xm1 values \n";
01945             return MB_FAILURE;
01946         }
01947         rval = mbImpl->tag_get_by_ptr( _ym1Tag, &eh, 1, (const void**)&yval );
01948         if( moab::MB_SUCCESS != rval )
01949         {
01950             std::cout << "Can't get ym1 values \n";
01951             return MB_FAILURE;
01952         }
01953         rval = mbImpl->tag_get_by_ptr( _zm1Tag, &eh, 1, (const void**)&zval );
01954         if( moab::MB_SUCCESS != rval )
01955         {
01956             std::cout << "Can't get zm1 values \n";
01957             return MB_FAILURE;
01958         }
01959         // Now, in a stride, populate vpos
01960         for( int i = 0; i < _ntot; i++ )
01961         {
01962             vpos[ielem + 3 * i]     = xval[i];
01963             vpos[ielem + 3 * i + 1] = yval[i];
01964             vpos[ielem + 3 * i + 2] = zval[i];
01965         }
01966     }
01967
01968     return MB_SUCCESS;
01969 }
01970
01971 }  // namespace moab
