DenseTag.hpp
00001 /** \file   DenseTag.hpp
00002  *  \author Jason Kraftcheck
00003  *  \date   2010-12-14
00004  */
00005
00006 #ifndef DENSE_TAG_HPP
00007 #define DENSE_TAG_HPP
00008
00009 #include "TagInfo.hpp"
00010
00011 namespace moab
00012 {
00013
00014 class EntitySequence;
00015
00016 /**\brief Dense storage of fixed-length tag data
00017  *
00018  * Implement normal dense tag.
00019  */
00020 class DenseTag : public TagInfo
00021 {
00022   private:
00023     int mySequenceArray;  //!< Array index in SequenceManager used to store tag data.
00024
00025     unsigned char* meshValue;
00026
00027     DenseTag( int array_index, const char* name, int size, DataType type, const void* default_value );
00028
00029   public:
00030     static DenseTag* create_tag( SequenceManager* seqman,
00031                                  Error* error,
00032                                  const char* name,
00033                                  int bytes,
00034                                  DataType type,
00035                                  const void* default_value );
00036
00037     virtual ~DenseTag();
00038
00039     virtual TagType get_storage_type() const;
00040
00041     /**\brief Remove/clear tag data for all entities
00042      *
00043      * Remove tag values from entities.
00044      *
00045      *\param delete_pending  If true, then release any global
00046      *          data associated with the tag in preparation for deleting
00047      *          the tag itself.
00048      *
00049      *\Note Invalidates tag if \c tag_delete_pending is true.  The only
00050      *        valid method that can be invoked that is is the destructor.
00051      *
00052      *\param seqman    Pointer to mesh entity database
00053      */
00054     virtual ErrorCode release_all_data( SequenceManager* seqman, Error* error_handler, bool delete_pending );
00055
00056     /**\brief Get tag value for passed entities
00057      *
00058      * Get tag values for specified entities.
00059      *
00060      *\Note Will fail for variable-length data.
00061      *\param seqman Pointer to mesh entity database
00062      *\param entities Entity handles for which to retrieve tag data
00063      *\param num_entities Length of \c entities array
00064      *\param data Pointer to memory in which to store consecutive tag values,
00065      *            one for each passed entity.
00066      */
00067     virtual ErrorCode get_data( const SequenceManager* seqman,
00068                                 Error* error_handler,
00069                                 const EntityHandle* entities,
00070                                 size_t num_entities,
00071                                 void* data ) const;
00072
00073     /**\brief Get tag value for passed entities
00074      *
00075      * Get tag values for specified entities.
00076      *
00077      *\Note Will fail for variable-length data.
00078      *\param seqman Pointer to mesh entity database
00079      *\param entities Entity handles for which to retrieve tag data
00080      *\param data Pointer to memory in which to store consecutive tag values,
00081      *            one for each passed entity.
00082      */
00083     virtual ErrorCode get_data( const SequenceManager* seqman,
00084                                 Error* error_handler,
00085                                 const Range& entities,
00086                                 void* data ) const;
00087
00088     /**\brief Get tag value for passed entities
00089      *
00090      * Get tag values for specified entities.
00091      *
00092      *\param seqman    Pointer to mesh entity database
00093      *\param entities  Entity handles for which to retrieve tag data
00094      *\param num_entities Length of \c entities array
00095      *\param data_ptrs Array of pointers to tag values, one pointer
00096      *                 for each passed entity.
00097      *\param data_lengths One value for each entity specifying the
00098      *                length of the tag value for the corresponding
00099      *                entity.
00100      */
00101     virtual ErrorCode get_data( const SequenceManager* seqman,
00102                                 Error* error_handler,
00103                                 const EntityHandle* entities,
00104                                 size_t num_entities,
00105                                 const void** data_ptrs,
00106                                 int* data_lengths ) const;
00107
00108     /**\brief Get tag value for passed entities
00109      *
00110      * Get tag values for specified entities.
00111      *
00112      *\param seqman    Pointer to mesh entity database
00113      *\param entities  Entity handles for which to retrieve tag data
00114      *\param data_ptrs Array of pointers to tag values, one pointer
00115      *                 for each passed entity.
00116      *\param data_lengths One value for each entity specifying the
00117      *                length of the tag value for the corresponding
00118      *                entity.
00119      */
00120     virtual ErrorCode get_data( const SequenceManager* seqman,
00121                                 Error* error_handler,
00122                                 const Range& entities,
00123                                 const void** data_ptrs,
00124                                 int* data_lengths ) const;
00125
00126     /**\brief Set tag value for passed entities
00127      *
00128      * Store tag data or update stored tag values
00129      *\Note Will fail for variable-length data.
00130      *\param seqman Pointer to mesh entity database
00131      *\param entities Entity handles for which to store tag data
00132      *\param num_entities Length of \c entities array
00133      *\param data Pointer to memory holding consecutive tag values,
00134      *            one for each passed entity.
00135      */
00136     virtual ErrorCode set_data( SequenceManager* seqman,
00137                                 Error* error_handler,
00138                                 const EntityHandle* entities,
00139                                 size_t num_entities,
00140                                 const void* data );
00141
00142     /**\brief Set tag value for passed entities
00143      *
00144      * Store tag data or update stored tag values
00145      *\Note Will fail for variable-length data.
00146      *\param seqman Pointer to mesh entity database
00147      *\param entities Entity handles for which to store tag data
00148      *\param data Pointer to memory holding consecutive tag values,
00149      *            one for each passed entity.
00150      */
00151     virtual ErrorCode set_data( SequenceManager* seqman,
00152                                 Error* error_handler,
00153                                 const Range& entities,
00154                                 const void* data );
00155
00156     /**\brief Set tag value for passed entities
00157      *
00158      * Store tag data or update stored tag values
00159      *
00160      *\param seqman    Pointer to mesh entity database
00161      *\param entities  Entity handles for which to store tag data
00162      *\param num_entities Length of \c entities array
00163      *\param data_ptrs Array of pointers to tag values, one pointer
00164      *                 for each passed entity.
00165      *\param data_lengths One value for each entity specifying the
00166      *                length of the tag value for the corresponding
00167      *                entity.  Array is required for variable-length
00168      *                tags and is ignored for fixed-length tags.
00169      */
00170     virtual ErrorCode set_data( SequenceManager* seqman,
00171                                 Error* error_handler,
00172                                 const EntityHandle* entities,
00173                                 size_t num_entities,
00174                                 void const* const* data_ptrs,
00175                                 const int* data_lengths );
00176
00177     /**\brief Set tag value for passed entities
00178      *
00179      * Store tag data or update stored tag values
00180      *
00181      *\param seqman    Pointer to mesh entity database
00182      *\param entities  Entity handles for which to store tag data
00183      *\param data_ptrs Array of pointers to tag values, one pointer
00184      *                 for each passed entity.
00185      *\param data_lengths One value for each entity specifying the
00186      *                length of the tag value for the corresponding
00187      *                entity.  Array is required for variable-length
00188      *                tags and is ignored for fixed-length tags.
00189      */
00190     virtual ErrorCode set_data( SequenceManager* seqman,
00191                                 Error* error_handler,
00192                                 const Range& entities,
00193                                 void const* const* data_ptrs,
00194                                 const int* data_lengths );
00195
00196     /**\brief Set tag value for passed entities
00197      *
00198      * Store tag data or update stored tag values.
00199      *
00200      *\param seqman    Pointer to mesh entity database
00201      *\param entities  Entity handles for which to store tag data
00202      *\param num_entities Length of \c entities array
00203      *\param value_ptr Pointer to a single tag value which is to be
00204      *                 stored for each of the passed entities.
00205      *\param value_len Length of tag value in bytes.  Ignored for
00206      *                 fixed-length tags.  Required for variable-
00207      *                 length tags.
00208      */
00209     virtual ErrorCode clear_data( SequenceManager* seqman,
00210                                   Error* error_handler,
00211                                   const EntityHandle* entities,
00212                                   size_t num_entities,
00213                                   const void* value_ptr,
00214                                   int value_len = 0 );
00215
00216     /**\brief Set tag value for passed entities
00217      *
00218      * Store tag data or update stored tag values.
00219      *
00220      *\param seqman    Pointer to mesh entity database
00221      *\param entities  Entity handles for which to store tag data
00222      *\param value_ptr Pointer to a single tag value which is to be
00223      *                 stored for each of the passed entities.
00224      *\param value_len Length of tag value in bytes.  Ignored for
00225      *                 fixed-length tags.  Required for variable-
00226      *                 length tags.
00227      */
00228     virtual ErrorCode clear_data( SequenceManager* seqman,
00229                                   Error* error_handler,
00230                                   const Range& entities,
00231                                   const void* value_ptr,
00232                                   int value_len = 0 );
00233
00234     /**\brief Remove/clear tag data for entities
00235      *
00236      * Remove tag values from entities.
00237      *
00238      *\param seqman    Pointer to mesh entity database
00239      *\param entities  Entity handles for which to store tag data
00240      *\param num_entities Length of \c entities array
00241      */
00242     virtual ErrorCode remove_data( SequenceManager* seqman,
00243                                    Error* error_handler,
00244                                    const EntityHandle* entities,
00245                                    size_t num_entities );
00246
00247     /**\brief Remove/clear tag data for entities
00248      *
00249      * Remove tag values from entities.
00250      *
00251      *\param seqman    Pointer to mesh entity database
00252      *\param entities  Entity handles for which to store tag data
00253      */
00254     virtual ErrorCode remove_data( SequenceManager* seqman, Error* error_handler, const Range& entities );
00255
00256     /**\brief Access tag data via direct pointer into contiguous blocks
00257      *
00258      * Iteratively obtain direct access to contiguous blocks of tag
00259      * storage.  This function cannot be used with bit tags because
00260      * of the compressed bit storage.  This function cannot be used
00261      * with variable length tags because it does not provide a mechanism
00262      * to determine the length of the value for each entity.  This
00263      * function may be used with sparse tags, but if it is used, it
00264      * will return data for a single entity at a time.
00265      *
00266      *\param iter        As input, the first entity for which to return
00267      *                   data.  As output, one past the last entity for
00268      *                   which data was returned.
00269      *\param end         One past the last entity for which data is desired
00270      *\param data_ptr    Output: pointer to tag storage.
00271      *
00272      *\Note If this function is called for entities for which no tag value
00273      *      has been set, but for which a default value exists, it will
00274      *      force the allocation of explicit storage for each such entity
00275      *      even though MOAB would normally not explicitly store tag values
00276      *      for such entities.
00277      */
00278     virtual ErrorCode tag_iterate( SequenceManager* seqman,
00279                                    Error* error_handler,
00280                                    Range::iterator& iter,
00281                                    const Range::iterator& end,
00282                                    void*& data_ptr,
00283                                    bool allocate = true );
00284
00285     /**\brief Get all tagged entities
00286      *
00287      * Get the list of entities for which the a tag value has been set,
00288      * or a close approximation if the tag storage scheme cannot
00289      * accurately determine exactly which entities have explicit values.
00290      *
00291      *\param seqman   Pointer to entity storage database
00292      *\param output_entities Results *appended* to this range
00293      *\param type     Optional entity type.  If specified, search is
00294      *                limited to entities of specified type.
00295      *\param intersect Optional intersect list.  If specified,
00296      *                search is restricted to entities in this list.
00297      */
00298     virtual ErrorCode get_tagged_entities( const SequenceManager* seqman,
00299                                            Range& output_entities,
00300                                            EntityType type        = MBMAXTYPE,
00301                                            const Range* intersect = 0 ) const;
00302
00303     /**\brief Count all tagged entities
00304      *
00305      * Count the entities for which the a tag value has been set,
00306      * or a close approximation if the tag storage scheme cannot
00307      * accurately determine exactly which entities have explicit values.
00308      *
00309      *\param seqman   Pointer to entity storage database
00310      *\param output_count This is *incremented* for each detected entity.
00311      *\param type     Optional entity type.  If specified, search is
00312      *                limited to entities of specified type.
00313      *\param intersect Optional intersect list.  If specified,
00314      *                search is restricted to entities in this list.
00315      */
00316     virtual ErrorCode num_tagged_entities( const SequenceManager* seqman,
00317                                            size_t& output_count,
00318                                            EntityType type        = MBMAXTYPE,
00319                                            const Range* intersect = 0 ) const;
00320
00321     /**\brief Get all tagged entities with tag value
00322      *
00323      * Get the list of entities which have the specified tag value.
00324      *
00325      *\param seqman   Pointer to entity storage database
00326      *\param output_entities Results *appended* to this range
00327      *\param value    Pointer to tag value
00328      *\param value_bytes Size of tag value in bytes.
00329      *\param type     Optional entity type.  If specified, search is
00330      *                limited to entities of specified type.
00331      *\param intersect_entities Optional intersect list.  If specified,
00332      *                search is restricted to entities in this list.
00333      */
00334     virtual ErrorCode find_entities_with_value( const SequenceManager* seqman,
00335                                                 Error* error_handler,
00336                                                 Range& output_entities,
00337                                                 const void* value,
00338                                                 int value_bytes                 = 0,
00339                                                 EntityType type                 = MBMAXTYPE,
00340                                                 const Range* intersect_entities = 0 ) const;
00341
00342     /**\brief Check if entity is tagged */
00343     virtual bool is_tagged( const SequenceManager*, EntityHandle h ) const;
00344
00345     /**\brief Get memory use for tag data.
00346      *
00347      */
00348     virtual ErrorCode get_memory_use( const SequenceManager* seqman,
00349                                       unsigned long& total,
00350                                       unsigned long& per_entity ) const;
00351
00352     /**\brief Get read-only tag storage
00353      *
00354      *\param seqman  Sequence manager
00355      *\param error   Error object through which to report errors
00356      *\param h       First entity for which to return storage.
00357      *\param ptr     Pointer to dag storage.  This pointer will be set
00358      *               to null and \c MB_SUCCESS will be returned if the handle
00359      *               is valid but no tag storage has been allocated.
00360      *\param count   Number of consecutive entities for which tag storage
00361      *               is returned.  This value will be valid even if null
00362      *               is returned for \c ptr and indicates the number of
00363      *               consecutive entities for which no tag storage has been
00364      *               allocated.
00365      *\return        MB_SUCCESS if handle is valid (regardless of whether
00366      *               or not any tag storage is allocated).
00367      */
00368     ErrorCode get_array( const SequenceManager* seqman,
00369                          Error* error,
00370                          EntityHandle h,
00371                          const unsigned char* const& ptr,
00372                          size_t& count ) const;
00373
00374     /**\brief Get read-only tag storage for entire sequence
00375      *
00376      *\param seq     Sequence
00377      *\param ptr     Pointer to dag storage.  This pointer will be set
00378      *               to null and \c MB_SUCCESS will be returned if no tag storage has been
00379      *allocated. \return        MB_SUCCESS if sequence is valid (regardless of whether or not any
00380      *tag storage is allocated).
00381      */
00382     ErrorCode get_array( const EntitySequence* seq, const unsigned char* const& ptr ) const;
00383
00384   private:
00385     DenseTag( const DenseTag& );
00386     DenseTag& operator=( const DenseTag& );
00387
00388     /**\brief Get or allocated tag storage
00389      *
00390      *\param h       First entity for which to return storage.
00391      *\param ptr     Pointer to dag storage.  This pointer will be set
00392      *               to null and \c MB_SUCCESS will be returned if the handle
00393      *               is valid but no tag storage has been allocated.
00394      *\param count   Number of consecutive entities for which tag storage
00395      *               is returned.  This value will be valid even if null
00396      *               is returned for \c ptr and indicates the number of
00397      *               consecutive entities for which no tag storage has been
00398      *               allocated.
00399      *\param allocate If true storage will be allocated and initialized
00400      *               if it has not already been allocated.
00401      *\return        MB_SUCCESS if handle is valid (regardless of whether
00402      *               or not any tag storage is allocated).
00403      */
00404     inline ErrorCode get_array_private( SequenceManager* seqman,
00405                                         Error* error,
00406                                         EntityHandle h,
00407                                         unsigned char*& ptr,
00408                                         size_t& count,
00409                                         bool allocate );
00410
00411     /**\brief Get tag storage
00412      *
00413      *\param h       First entity for which to return storage.
00414      *\param ptr     Pointer to dag storage.  This pointer will be set
00415      *               to null and \c MB_SUCCESS will be returned if the handle
00416      *               is valid but no tag storage has been allocated.
00417      *\param count   Number of consecutive entities for which tag storage
00418      *               is returned.  This value will be valid even if null
00419      *               is returned for \c ptr and indicates the number of
00420      *               consecutive entities for which no tag storage has been
00421      *               allocated.
00422      *\return        MB_SUCCESS if handle is valid (regardless of whether
00423      *               or not any tag storage is allocated).
00424      */
00425     inline ErrorCode get_array_private( const SequenceManager* seqman,
00426                                         Error* error,
00427                                         EntityHandle h,
00428                                         const unsigned char*& ptr,
00429                                         size_t& count ) const;
00430
00431     /**\brief Get non-read-only tag storage for entire sequence
00432      *
00433      *\param seq     Sequence
00434      *\param ptr     Pointer to dag storage.  This pointer will be set
00435      *               to null and \c MB_SUCCESS will be returned if no tag storage has been
00436      *allocated. \return        MB_SUCCESS if sequence is valid (regardless of whether or not any
00437      *tag storage is allocated).
00438      */
00439     ErrorCode get_array_private( const EntitySequence* seq, const unsigned char*& ptr ) const;
00440
00441     /**\brief Common implementation of public clear_data and remove_data */
00442     ErrorCode clear_data( bool allocate,
00443                           SequenceManager* seqman,
00444                           Error* error,
00445                           const EntityHandle* entities,
00446                           size_t num_entities,
00447                           const void* value_ptr );
00448
00449     /**\brief Common implementation of public clear_data and remove_data */
00450     ErrorCode clear_data( bool allocate,
00451                           SequenceManager* seqman,
00452                           Error* error,
00453                           const Range& entities,
00454                           const void* value_ptr );
00455 };
00456
00457 }  // namespace moab
00458
00459 #endif  // DENSE_TAG_HPP
