Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/ReadUtilIface.hpp"
#include <map>
#include <iostream>
#include <cassert>
Functions | |
ErrorCode | create_mesh_no_holes (Interface *mbImpl, int nquads) |
int | main (int argc, char **argv) |
ErrorCode create_mesh_no_holes | ( | Interface * | mbImpl, |
int | nquads | ||
Definition at line 160 of file DirectAccessNoHoles.cpp.
References moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_CHK_SET_ERR, MB_SUCCESS, MBQUAD, and moab::Interface::query_interface().
{ // First make the mesh, a 1d array of quads with left hand side x = elem_num; vertices are // numbered in layers ReadUtilIface* read_iface; ErrorCode rval = mbImpl->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" ); vector< double* > coords; EntityHandle start_vert, start_elem, *connect; // Create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop // over quads later rval = read_iface->get_node_coords( 3, 2 * ( nquads + 1 ), 0, start_vert, coords );MB_CHK_SET_ERR( rval, "Error in get_node_arrays" ); // Create quads rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" ); for( int i = 0; i < nquads; i++ ) { coords[0][2 * i] = coords[0][2 * i + 1] = (double)i; // x values are all i coords[1][2 * i] = 0.0; coords[1][2 * i + 1] = 1.0; // y coords coords[2][2 * i] = coords[2][2 * i + 1] = (double)0.0; // z values, all zero (2d mesh) EntityHandle quad_v = start_vert + 2 * i; connect[4 * i + 0] = quad_v; connect[4 * i + 1] = quad_v + 2; connect[4 * i + 2] = quad_v + 3; connect[4 * i + 3] = quad_v + 1; } // Last two vertices // Cppcheck warning (false positive): variable coords is assigned a value that is never used coords[0][2 * nquads] = coords[0][2 * nquads + 1] = (double)nquads; coords[1][2 * nquads] = 0.0; coords[1][2 * nquads + 1] = 1.0; // y coords coords[2][2 * nquads] = coords[2][2 * nquads + 1] = (double)0.0; // z values, all zero (2d mesh) // Call a vertex-quad adjacencies function to generate vertex-element adjacencies in MOAB Range dum_range; rval = mbImpl->get_adjacencies( &start_vert, 1, 2, false, dum_range );MB_CHK_SET_ERR( rval, "Error in get_adjacencies" ); assert( !dum_range.empty() ); return MB_SUCCESS; }
int main | ( | int | argc, |
char ** | argv | ||
Definition at line 47 of file DirectAccessNoHoles.cpp.
References ProgOptions::addOpt(), moab::Interface::adjacencies_iterate(), moab::Range::begin(), moab::Interface::connect_iterate(), moab::Interface::coords_iterate(), create_mesh_no_holes(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, ProgOptions::parseCommandLine(), moab::Range::size(), moab::Range::subset_by_dimension(), moab::Interface::tag_get_handle(), and moab::Interface::tag_iterate().
{ // Get MOAB instance Interface* mbImpl = new( std::nothrow ) Core; if( NULL == mbImpl ) return 1; int nquads = 1000; // Parse options ProgOptions opts; opts.addOpt< int >( string( "nquads,n" ), string( "Number of quads in the mesh (default = 1000" ), &nquads ); opts.parseCommandLine( argc, argv ); // Create simple structured mesh with hole, but using unstructured representation ErrorCode rval = create_mesh_no_holes( mbImpl, nquads );MB_CHK_SET_ERR( rval, "Trouble creating mesh" ); // Get all vertices and non-vertex entities Range verts, quads; rval = mbImpl->get_entities_by_handle( 0, quads );MB_CHK_SET_ERR( rval, "Trouble getting all entities" ); verts = quads.subset_by_dimension( 0 ); quads -= verts; // Create tag1 (element-based avg), tag2 (vertex-based avg), tag3 (# connected verts) Tag tag1, tag2, tag3; rval = mbImpl->tag_get_handle( "tag1", 3, MB_TYPE_DOUBLE, tag1, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag1" ); double def_val[3] = { 0.0, 0.0, 0.0 }; // need a default value for tag2 because we sum into it rval = mbImpl->tag_get_handle( "tag2", 3, MB_TYPE_DOUBLE, tag2, MB_TAG_DENSE | MB_TAG_CREAT, def_val );MB_CHK_SET_ERR( rval, "Trouble creating tag2" ); int def_val_int = 0; // need a default value for tag3 because we increment it rval = mbImpl->tag_get_handle( "tag3", 1, MB_TYPE_INTEGER, tag3, MB_TAG_DENSE | MB_TAG_CREAT, &def_val_int );MB_CHK_SET_ERR( rval, "Trouble creating tag3" ); // Get pointers to connectivity, coordinate, tag, and adjacency arrays; each of these returns a // count, which should be compared to the # entities you expect to verify there's only one chunk // (no holes) int count, vpere; EntityHandle* conn_ptr; rval = mbImpl->connect_iterate( quads.begin(), quads.end(), conn_ptr, vpere, count );MB_CHK_SET_ERR( rval, "Error in connect_iterate" ); assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads double *x_ptr, *y_ptr, *z_ptr; rval = mbImpl->coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );MB_CHK_SET_ERR( rval, "Error in coords_iterate" ); assert( count == (int)verts.size() ); // Should end up with just one contiguous chunk of vertices double *tag1_ptr, *tag2_ptr; int* tag3_ptr; rval = mbImpl->tag_iterate( tag1, quads.begin(), quads.end(), count, (void*&)tag1_ptr );MB_CHK_SET_ERR( rval, "Error in tag1_iterate" ); assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads rval = mbImpl->tag_iterate( tag2, quads.begin(), quads.end(), count, (void*&)tag2_ptr );MB_CHK_SET_ERR( rval, "Error in tag2_iterate" ); assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads rval = mbImpl->tag_iterate( tag3, quads.begin(), quads.end(), count, (void*&)tag3_ptr );MB_CHK_SET_ERR( rval, "Error in tag3_iterate" ); assert( count == (int)quads.size() ); // Should end up with just one contiguous chunk of quads const vector< EntityHandle >** adjs_ptr; rval = mbImpl->adjacencies_iterate( verts.begin(), verts.end(), adjs_ptr, count );MB_CHK_SET_ERR( rval, "Error in adjacencies_iterate" ); assert( count == (int)verts.size() ); // Should end up with just one contiguous chunk of vertices // Start_ handles used to compute indices into vertex/quad arrays; can use direct subtraction // because we know there aren't any holes in the handle spaces for verts or quads EntityHandle start_vert = *verts.begin(), start_quad = *quads.begin(); // Iterate over elements, computing tag1 from coords positions for( int i = 0; i < nquads; i++ ) { tag1_ptr[3 * i + 0] = tag1_ptr[3 * i + 1] = tag1_ptr[3 * i + 2] = 0.0; // Initialize position for this element for( int j = 0; j < vpere; j++ ) { // Loop over vertices in this element int v_index = conn_ptr[vpere * i + j] - start_vert; // vert index is just the offset from start vertex tag1_ptr[3 * i + 0] += x_ptr[v_index]; tag1_ptr[3 * i + 1] += y_ptr[v_index]; // Sum vertex positions into tag1... tag1_ptr[3 * i + 2] += z_ptr[v_index]; } tag1_ptr[3 * i + 0] /= vpere; tag1_ptr[3 * i + 1] /= vpere; // Then normalize tag1_ptr[3 * i + 2] /= vpere; } // Loop over elements in chunk // Iterate through vertices, summing positions into tag2 on connected elements and incrementing // vertex count for( int v = 0; v < count; v++ ) { const vector< EntityHandle >* avec = *( adjs_ptr + v ); for( vector< EntityHandle >::const_iterator ait = avec->begin(); ait != avec->end(); ++ait ) { // *ait is the quad handle, its index is computed by subtracting the start quad handle int a_ind = *ait - start_quad; tag2_ptr[3 * a_ind + 0] += x_ptr[v]; // Tag on each element is 3 doubles, x/y/z tag2_ptr[3 * a_ind + 1] += y_ptr[v]; tag2_ptr[3 * a_ind + 2] += z_ptr[v]; tag3_ptr[a_ind]++; // Increment the vertex count } } // Normalize tag2 by vertex count (tag3); loop over elements using same approach as before // At the same time, compare values of tag1 and tag2 int n_dis = 0; for( Range::iterator q_it = quads.begin(); q_it != quads.end(); ++q_it ) { int i = *q_it - start_quad; for( int j = 0; j < 3; j++ ) tag2_ptr[3 * i + j] /= (double)tag3_ptr[i]; // Normalize by # verts if( tag1_ptr[3 * i] != tag2_ptr[3 * i] || tag1_ptr[3 * i + 1] != tag2_ptr[3 * i + 1] || tag1_ptr[3 * i + 2] != tag2_ptr[3 * i + 2] ) { cout << "Tag1, tag2 disagree for element " << *q_it + i << endl; n_dis++; } } if( !n_dis ) cout << "All tags agree, success!" << endl; // Ok, we're done, shut down MOAB delete mbImpl; return 0; }
