EdgeIterator.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2010 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2010) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file EdgeIterator.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "EdgeIterator.hpp"
00034
00035 #include <algorithm>
00036
00037 namespace MBMesquite
00038 {
00039
00040 EdgeIterator::EdgeIterator( PatchData* p, MsqError& err ) : patchPtr( p ), vertIdx( 0 )
00041 {
00042     p->generate_vertex_to_element_data();
00043     if( patchPtr->num_nodes() )
00044     {
00045         get_adjacent_vertices( err );
00046         if( adjIter == adjList.end() )
00047         {
00048             step( err );MSQ_ERRRTN( err );
00049         }
00050     }
00051     else
00052         adjIter = adjList.end();
00053 }
00054
00055 void EdgeIterator::get_adjacent_vertices( MsqError& err )
00056 {
00057     adjList.clear();
00058
00059     // Get all adjacent elements
00060     size_t num_elem;
00061     const size_t* elems = patchPtr->get_vertex_element_adjacencies( vertIdx, num_elem, err );MSQ_ERRRTN( err );
00062
00063     // Get all adjacent vertices from elements
00064     std::vector< size_t > elem_verts;
00065     for( size_t e = 0; e < num_elem; ++e )
00066     {
00067         MsqMeshEntity& elem = patchPtr->element_by_index( elems[e] );
00068         EntityTopology type = elem.get_element_type();
00069         size_t num_edges    = TopologyInfo::edges( type );
00070
00071         bool mid_edge, mid_face, mid_vol;
00072         TopologyInfo::higher_order( type, elem.node_count(), mid_edge, mid_face, mid_vol, err );MSQ_ERRRTN( err );
00073
00074         // For each edge
00075         for( size_t d = 0; d < num_edges; ++d )
00076         {
00077             const unsigned* edge = TopologyInfo::edge_vertices( type, d, err );MSQ_ERRRTN( err );
00078             size_t vert1 = elem.get_vertex_index( edge[0] );
00079             size_t vert2 = elem.get_vertex_index( edge[1] );
00080
00081             size_t pmid = ~(size_t)0;
00082             if( mid_edge )
00083             {
00084                 int p = TopologyInfo::higher_order_from_side( type, elem.node_count(), 1, d, err );MSQ_ERRRTN( err );
00085                 pmid = elem.get_vertex_index_array()[p];
00086             }
00087
00088             // If this edge contains the input vertex (vert_idx)
00089             // AND the input vertex index is less than the
00090             // other vertex (avoids iterating over this edge twice)
00091             // add it to the list.
00092             if( vert1 > vert2 )
00093             {
00094                 if( vert2 == vertIdx ) adjList.push_back( Edge( vert1, pmid ) );
00095             }
00096             else
00097             {
00098                 if( vert1 == vertIdx ) adjList.push_back( Edge( vert2, pmid ) );
00099             }
00100         }
00101     }
00102
00103     // Remove duplicates
00104     std::sort( adjList.begin(), adjList.end() );
00105     adjIter = std::unique( adjList.begin(), adjList.end() );
00106     adjList.resize( adjIter - adjList.begin() );
00107     adjIter = adjList.begin();
00108 }
00109
00110 }  // namespace MBMesquite
