ElemUtil.hpp File Reference
#include "moab/CartVect.hpp"
#include <vector>
#include "moab/Matrix3.hpp"
#include "moab/FindPtFuncs.h"
+ Include dependency graph for ElemUtil.hpp:
+ This graph shows which files directly or indirectly include this file:
Classes
class  moab::Element::Map
 Class representing a map (diffeomorphism) F parameterizing a 3D element by its canonical preimage. More...
class  moab::Element::Map::EvaluationError
class  moab::Element::Map::ArgError
class  moab::Element::LinearHex
 Shape function space for trilinear hexahedron, obtained by a pushforward of the canonical linear (affine) functions. More...
class  moab::Element::QuadraticHex
class  moab::Element::LinearTet
 Shape function space for a linear tetrahedron, obtained by a pushforward of the canonical affine shape functions. More...
class  moab::Element::SpectralHex
class  moab::Element::LinearQuad
 Shape function space for bilinear quadrilateral, obtained from the canonical linear (affine) functions. More...
class  moab::Element::SphericalQuad
 Shape function space for bilinear quadrilateral on sphere, obtained from the canonical linear (affine) functions. It is mapped using gnomonic projection to a plane tangent at the first vertex It works well for edges that are great circle arcs; RLL meshes do not have this property, but HOMME or MPAS meshes do have it. More...
class  moab::Element::LinearTri
 Shape function space for linear triangle, similar to linear tet. More...
class  moab::Element::SphericalTri
 Shape function space for linear triangle on sphere, obtained from the canonical linear (affine) functions. It is mapped using gnomonic projection to a plane tangent at the first vertex It works well for edges that are great circle arcs; RLL meshes do not have this property, but HOMME or MPAS meshes do have it. More...
class  moab::Element::LinearEdge
class  moab::Element::SpectralQuad
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
namespace  moab::ElemUtil
namespace  moab::Element
Functions
bool moab::ElemUtil::nat_coords_trilinear_hex (const CartVect *corner_coords, const CartVect &x, CartVect &xi, double tol)
bool moab::ElemUtil::point_in_trilinear_hex (const CartVect *hex, const CartVect &xyz, double etol)
bool moab::ElemUtil::point_in_trilinear_hex (const CartVect *hex, const CartVect &xyz, const CartVect &box_min, const CartVect &box_max, double etol)
void moab::ElemUtil::nat_coords_trilinear_hex2 (const CartVect *hex_corners, const CartVect &x, CartVect &xi, double til)
void moab::ElemUtil::hex_findpt (realType *xm[3], int n, CartVect xyz, CartVect &rst, double &dist)
void moab::ElemUtil::hex_eval (realType *field, int n, CartVect rstCartVec, double &value)
bool moab::ElemUtil::integrate_trilinear_hex (const CartVect *hex_corners, double *corner_fields, double &field_val, int num_pts)
