ErrorHandler.hpp
00001 #ifndef MOAB_ERROR_HANDLER_HPP
00002 #define MOAB_ERROR_HANDLER_HPP
00003
00004 #ifdef _WIN32
00005 #define __func__ __FUNCTION__
00006 #endif
00007
00008 #include "moab/Types.hpp"
00009
00010 #include <sstream>
00011 #include <cstring>
00012
00013 namespace moab
00014 {
00015
00016 //! ErrorType - passed to the error handling routines indicating whether this is a new error
00017 //! (globally fatal or per-processor relevant) to be created, or an existing one to be handled
00018 enum ErrorType
00019 {
00020     MB_ERROR_TYPE_NEW_GLOBAL = 0,
00021     MB_ERROR_TYPE_NEW_LOCAL  = 1,
00022     MB_ERROR_TYPE_EXISTING   = 2
00023 };
00024
00025 //! Initialize MOAB error handler (e.g. create a utility object for printing error output)
00026 void MBErrorHandler_Init();
00027
00028 //! Finalize MOAB error handler (e.g. delete the utility object for printing error output)
00029 void MBErrorHandler_Finalize();
00030
00031 //! Indicates whether MBErrorHandler_Init has been called
00032 bool MBErrorHandler_Initialized();
00033
00034 //! Get information about the last error
00035 void MBErrorHandler_GetLastError( std::string& error );
00036
00037 //! Routine that is called to create a new error or handle an existing one
00038 ErrorCode MBError( int line,
00039                    const char* func,
00040                    const char* file,
00041                    const char* dir,
00042                    ErrorCode err_code,
00043                    const char* err_msg,
00044                    ErrorType err_type );
00045
00046 }  // namespace moab
00047
00048 #define __FILENAME__ ( strrchr( __FILE__, '/' ) ? strrchr( __FILE__, '/' ) + 1 : __FILE__ )
00049
00050 #define MBSTRINGIFY_( X ) #X
00051 #define MBSTRINGIFY( X )  MBSTRINGIFY_( X )
00052
00053 #ifdef LOCDIR
00054 #define __MBSDIR__ MBSTRINGIFY( LOCDIR )
00055 #else
00056 #define __MBSDIR__ ""
00057 #endif
00058
00059 //! Set a new error with the given error message (a string or a stream) and return the given error
00060 //! code Used in functions which return ErrorCode
00061 #define MB_SET_ERR( err_code, err_msg )        \
00062     do        \
00063     {        \
00064         std::ostringstream err_ostr;        \
00065         err_ostr << err_msg;        \
00066         return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, err_ostr.str().c_str(), \
00067                               moab::MB_ERROR_TYPE_NEW_LOCAL );                                                \
00068     } while( false )
00069
00070 //! Set a new error with the given error message (a string or a stream) and return
00071 //! Used in functions which return void types (or have no return types at all, e.g. constructors)
00072 #define MB_SET_ERR_RET( err_msg )        \
00073     do        \
00074     {        \
00075         std::ostringstream err_ostr;        \
00076         err_ostr << err_msg;        \
00077         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00078                        moab::MB_ERROR_TYPE_NEW_LOCAL );                                                        \
00079         return;        \
00080     } while( false )
00081
00082 //! Set a new error with the given error message (a string or a stream) and return the given value
00083 //! Used in functions which return any data type
00084 #define MB_SET_ERR_RET_VAL( err_msg, ret_val )        \
00085     do        \
00086     {        \
00087         std::ostringstream err_ostr;        \
00088         err_ostr << err_msg;        \
00089         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00090                        moab::MB_ERROR_TYPE_NEW_LOCAL );                                                        \
00091         return ret_val;        \
00092     } while( false )
00093
00094 //! Set a new error with the given error message (a string or a stream) and continue
00095 //! Used in functions which return any data type
00096 #define MB_SET_ERR_CONT( err_msg )        \
00097     do        \
00098     {        \
00099         std::ostringstream err_ostr;        \
00100         err_ostr << err_msg;        \
00101         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00102                        moab::MB_ERROR_TYPE_NEW_LOCAL );                                                        \
00103     } while( false )
00104
00105 //! Similar to MB_SET_ERR except that the error is considered globally fatal
00106 #define MB_SET_GLB_ERR( err_code, err_msg )        \
00107     do        \
00108     {        \
00109         std::ostringstream err_ostr;        \
00110         err_ostr << err_msg;        \
00111         return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, err_ostr.str().c_str(), \
00112                               moab::MB_ERROR_TYPE_NEW_GLOBAL );                                               \
00113     } while( false )
00114
00115 //! Similar to MB_SET_ERR_RET except that the error is considered globally fatal
00116 #define MB_SET_GLB_ERR_RET( err_msg )        \
00117     do        \
00118     {        \
00119         std::ostringstream err_ostr;        \
00120         err_ostr << ( err_msg );        \
00121         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00122                        moab::MB_ERROR_TYPE_NEW_GLOBAL );                                                       \
00123         return;        \
00124     } while( false )
00125
00126 //! Similar to MB_SET_ERR_RET_VAL except that the error is considered globally fatal
00127 #define MB_SET_GLB_ERR_RET_VAL( err_msg, ret_val )                                                             \
00128     do        \
00129     {        \
00130         std::ostringstream err_ostr;        \
00131         err_ostr << ( err_msg );        \
00132         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00133                        moab::MB_ERROR_TYPE_NEW_GLOBAL );                                                       \
00134         return ret_val;        \
00135     } while( false )
00136
00137 //! Similar to MB_SET_ERR_CONT except that the error is considered globally fatal
00138 #define MB_SET_GLB_ERR_CONT( err_msg )        \
00139     do        \
00140     {        \
00141         std::ostringstream err_ostr;        \
00142         err_ostr << ( err_msg );        \
00143         moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \
00144                        moab::MB_ERROR_TYPE_NEW_GLOBAL );                                                       \
00145     } while( false )
00146
00147 //! Check error code, if not MB_SUCCESS, call the error handler and return the given error code
00148 //! Used in functions which return ErrorCode
00149 #define MB_CHK_ERR( err_code )        \
00150     do        \
00151     {        \
00152         if( moab::MB_SUCCESS != ( err_code ) )                                                \
00153             return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", \
00154                                   moab::MB_ERROR_TYPE_EXISTING );                             \
00155     } while( false )
00156
00157 //! Check error code, if not MB_SUCCESS, call the error handler and return
00158 //! Used in functions which return void types (or have no return types at all, e.g. constructors)
00159 #define MB_CHK_ERR_RET( err_code )        \
00160     do        \
00161     {        \
00162         if( moab::MB_SUCCESS != ( err_code ) )        \
00163         {        \
00164             moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \
00165             return;        \
00166         }        \
00167     } while( false )
00168
00169 //! Check error code, if not MB_SUCCESS, call the error handler and return the given value
00170 //! Used in functions which return any data type
00171 #define MB_CHK_ERR_RET_VAL( err_code, ret_val )        \
00172     do        \
00173     {        \
00174         if( moab::MB_SUCCESS != ( err_code ) )        \
00175         {        \
00176             moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \
00177             return ret_val;        \
00178         }        \
00179     } while( false )
00180
00181 //! Check error code, if not MB_SUCCESS, call the error handler and continue
00182 //! Used in functions which return any data type
00183 #define MB_CHK_ERR_CONT( err_code )        \
00184     do        \
00185     {        \
00186         if( moab::MB_SUCCESS != ( err_code ) )        \
00187         {        \
00188             moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \
00189         }        \
00190     } while( false )
00191
00192 //! Check error code, if not MB_SUCCESS, set a new error with the given error message and return the
00193 //! given error code Used in functions which return ErrorCode
00194 #define MB_CHK_SET_ERR( err_code, err_msg )                                     \
00195     do        \
00196     {        \
00197         if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR( err_code, err_msg ); \
00198     } while( false )
00199
00200 //! Check error code, if not MB_SUCCESS, set a new error with the given error message and return
00201 //! Used in functions which return void types (or have no return types at all, e.g. constructors)
00202 #define MB_CHK_SET_ERR_RET( err_code, err_msg )                           \
00203     do        \
00204     {        \
00205         if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_RET( err_msg ); \
00206     } while( false )
00207
00208 //! Check error code, if not MB_SUCCESS, set a new error with the given error message and return the
00209 //! given value Used in functions which return any data type
00210 #define MB_CHK_SET_ERR_RET_VAL( err_code, err_msg, ret_val )                           \
00211     do        \
00212     {        \
00213         if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_RET_VAL( err_msg, ret_val ); \
00214     } while( false )
00215
00216 //! Check error code, if not MB_SUCCESS, set a new error with the given error message and continue
00217 //! Used in functions which return any data type
00218 #define MB_CHK_SET_ERR_CONT( err_code, err_msg )                           \
00219     do        \
00220     {        \
00221         if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_CONT( err_msg ); \
00222     } while( false )
00223
00224 #endif
