ErrorHandlingSimulation.cpp
Description: This example simulates MOAB's enhanced error handling in parallel.
All of the errors are contrived, used for simulation purpose only.
Note: We do not need a moab instance for this example
To run: mpiexec -np 4 ./ErrorHandlingSimulation <test_case_num(1 to 4)>
/** @example ErrorHandlingSimulation.cpp
 * Description: This example simulates MOAB's enhanced error handling in parallel. \n
 * All of the errors are contrived, used for simulation purpose only. \n
 * Note: We do not need a moab instance for this example
 * <b>To run</b>: mpiexec -np 4 ./ErrorHandlingSimulation <test_case_num(1 to 4)> \n
#include "moab/MOABConfig.h"
#include "moab/ErrorHandler.hpp"
#ifdef MOAB_HAVE_MPI
#include "moab_mpi.h"
#endif
#include <iostream>
#include <cstdlib>
using namespace moab;
using namespace std;
// Functions that create and handle contrived errors
// Call hierarchy: A calls B, and B calls C
ErrorCode FunctionC( int test_case_num, int rank )
    switch( test_case_num )
        case 1:
            // Simulate a global fatal error MB_NOT_IMPLEMENTED on all processors
            // Note, it is printed by root processor 0 only
            MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "A contrived global error MB_NOT_IMPLEMENTED" );
            break;
        case 2:
            // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on all processors
            // Note, it is printed by all processors
            MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor " << rank );
            break;
        case 3:
            // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on all processors except
            // root Note, it is printed by all non-root processors
            if( 0 != rank )
                MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor " << rank );
            break;
        case 4:
            // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on processor 1
            // Note, it is printed by processor 1 only
            if( 1 == rank )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor 1" );
            // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on processor 3
            // Note, it is printed by processor 3 only
            if( 3 == rank ) MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor 3" );
            break;
        default:
            break;
    return MB_SUCCESS;
ErrorCode FunctionB( int test_case_num, int rank )
    ErrorCode err_code = FunctionC( test_case_num, rank );MB_CHK_ERR( err_code );
    return MB_SUCCESS;
ErrorCode FunctionA( int test_case_num, int rank )
    ErrorCode err_code = FunctionB( test_case_num, rank );MB_CHK_ERR( err_code );
    return MB_SUCCESS;
int main( int argc, char** argv )
    if( argc < 2 )
        cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl;
        return 0;
    MPI_Init( &argc, &argv );
#endif
    // Initialize error handler, required for this example (not using a moab instance)
    MBErrorHandler_Init();
    int test_case_num = atoi( argv[1] );
    int rank          = 0;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#endif
    ErrorCode rval = FunctionA( test_case_num, rank );MB_CHK_ERR( rval );
    // Finalize error handler, required for this example (not using a moab instance)
    MBErrorHandler_Finalize();
    MPI_Finalize();
#endif
    return 0;
