ErrorHandlingSimulation.cpp File Reference
#include "moab/MOABConfig.h"
#include "moab/ErrorHandler.hpp"
#include <iostream>
#include <cstdlib>
+ Include dependency graph for ErrorHandlingSimulation.cpp:
Functions
ErrorCode FunctionC (int test_case_num, int rank)
ErrorCode FunctionB (int test_case_num, int rank)
ErrorCode FunctionA (int test_case_num, int rank)
int main (int argc, char **argv)
Function Documentation
ErrorCode FunctionA ( int  test_case_num,
int  rank
Examples:
ErrorHandlingSimulation.cpp.
Definition at line 68 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionB(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by main().
    ErrorCode err_code = FunctionB( test_case_num, rank );MB_CHK_ERR( err_code );
    return MB_SUCCESS;
ErrorCode FunctionB ( int  test_case_num,
int  rank
Examples:
Definition at line 61 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionC(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by FunctionA().
    ErrorCode err_code = FunctionC( test_case_num, rank );MB_CHK_ERR( err_code );
    return MB_SUCCESS;
ErrorCode FunctionC ( int  test_case_num,
int  rank
Examples:
Definition at line 24 of file ErrorHandlingSimulation.cpp.
References MB_INDEX_OUT_OF_RANGE, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SET_GLB_ERR, MB_SUCCESS, and MB_TYPE_OUT_OF_RANGE.
Referenced by FunctionB().
    switch( test_case_num )
        case 1:
            // Simulate a global fatal error MB_NOT_IMPLEMENTED on all processors
            // Note, it is printed by root processor 0 only
            MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "A contrived global error MB_NOT_IMPLEMENTED" );
            break;
        case 2:
            // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on all processors
            // Note, it is printed by all processors
            MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor " << rank );
            break;
        case 3:
            // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on all processors except
            // root Note, it is printed by all non-root processors
            if( 0 != rank )
                MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor " << rank );
            break;
        case 4:
            // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on processor 1
            // Note, it is printed by processor 1 only
            if( 1 == rank )
                MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor 1" );
            // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on processor 3
            // Note, it is printed by processor 3 only
            if( 3 == rank ) MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor 3" );
            break;
        default:
            break;
    return MB_SUCCESS;
int main ( int  argc,
char **  argv
Definition at line 75 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionA(), MB_CHK_ERR, moab::MBErrorHandler_Finalize(), and moab::MBErrorHandler_Init().
    if( argc < 2 )
        cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl;
        return 0;
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
#endif
    // Initialize error handler, required for this example (not using a moab instance)
    MBErrorHandler_Init();
    int test_case_num = atoi( argv[1] );
    int rank          = 0;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#endif
    ErrorCode rval = FunctionA( test_case_num, rank );MB_CHK_ERR( rval );
    // Finalize error handler, required for this example (not using a moab instance)
    MBErrorHandler_Finalize();
    MPI_Finalize();
#endif
    return 0;
