ExtrudePoly.cpp
Description: read a 2d mesh in plane, extrude to form layers of prisms (polyhedra)
To run: ./ExtrudePoly [meshfile] [outfile] [nlayers] [thickness_layer]
/** @example ExtrudePoly.cpp
 * Description: read a 2d mesh in plane, extrude to form  layers of prisms (polyhedra) \n
 * To run: ./ExtrudePoly [meshfile] [outfile] [nlayers] [thickness_layer] \n
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
#include <iostream>
using namespace moab;
using namespace std;
#ifndef MESH_DIR
#define MESH_DIR "."
#endif
// at most 20 edges per polygon
#define MAXEDGES 20
// Note: change the file name below to test a trivial "No such file or directory" error
string test_file_name = string( MESH_DIR ) + string( "/io/poly8-10.vtk" );
string output         = string( "polyhedra.vtk" );
int layers            = 1;
double layer_thick    = 1.0;
int main( int argc, char** argv )
    // Get MOAB instance
    Interface* mb = new( std::nothrow ) Core;
    if( NULL == mb ) return 1;
    // Need option handling here for input filename
    if( argc > 1 )
        // User has input a mesh file
        test_file_name = argv[1];
    if( argc > 2 ) output = argv[2];
    if( argc > 3 ) layers = atoi( argv[3] );
    if( argc > 4 ) layer_thick = atof( argv[4] );
    std::cout << "Run: " << argv[0] << " " << test_file_name << " " << output << " " << layers << " " << layer_thick
              << "\n";
    // Load the mesh from vtk file
    ErrorCode rval = mb->load_mesh( test_file_name.c_str() );MB_CHK_ERR( rval );
    // Get verts entities, by type
    Range verts;
    rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval );
    // Get faces, by dimension, so we stay generic to entity type
    Range faces;
    rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval );
    cout << "Number of vertices is " << verts.size() << endl;
    cout << "Number of faces is " << faces.size() << endl;
    Range edges;
    // create all edges
    rval = mb->get_adjacencies( faces, 1, true, edges, Interface::UNION );MB_CHK_ERR( rval );
    cout << "Number of edges is " << edges.size() << endl;
    std::vector< double > coords;
    int nvPerLayer = (int)verts.size();
    coords.resize( 3 * nvPerLayer );
    rval = mb->get_coords( verts, &coords[0] );MB_CHK_ERR( rval );
    // create first vertices
    Range* newVerts = new Range[layers + 1];
    newVerts[0]     = verts;  // just for convenience
    for( int ii = 0; ii < layers; ii++ )
        for( int i = 0; i < nvPerLayer; i++ )
            coords[3 * i + 2] += layer_thick;
        rval = mb->create_vertices( &coords[0], nvPerLayer, newVerts[ii + 1] );MB_CHK_ERR( rval );
    // for each edge, we will create layers quads
    int nquads = edges.size() * layers;
    ReadUtilIface* read_iface;
    rval = mb->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" );
    EntityHandle start_elem, *connect;
    // Create quads
    rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" );
    int nedges = (int)edges.size();
    int indexConn = 0;
    for( int j = 0; j < nedges; j++ )
        EntityHandle edge = edges[j];
        const EntityHandle* conn2 = NULL;
        int num_nodes;
        rval = mb->get_connectivity( edge, conn2, num_nodes );MB_CHK_ERR( rval );
        if( 2 != num_nodes ) MB_CHK_ERR( MB_FAILURE );
        int i0 = verts.index( conn2[0] );
        int i1 = verts.index( conn2[1] );
            connect[indexConn++] = newVerts[ii][i0];
            connect[indexConn++] = newVerts[ii][i1];
            connect[indexConn++] = newVerts[ii + 1][i1];
            connect[indexConn++] = newVerts[ii + 1][i0];
    int nfaces                = (int)faces.size();
    EntityHandle* allPolygons = new EntityHandle[nfaces * ( layers + 1 )];
    for( int i = 0; i < nfaces; i++ )
        allPolygons[i] = faces[i];
    // vertices are parallel to the base vertices
    int indexVerts[MAXEDGES]                  = { 0 };  // polygons with at most MAXEDGES edges
    EntityHandle newConn[MAXEDGES]            = { 0 };
    EntityHandle polyhedronConn[MAXEDGES + 2] = { 0 };
    // edges will be used to determine the lateral faces of polyhedra (prisms)
    int indexEdges[MAXEDGES] = { 0 };  // index of edges in base polygon
    for( int j = 0; j < nfaces; j++ )
        EntityHandle polyg = faces[j];
        const EntityHandle* connp = NULL;
        int num_nodes;
        rval = mb->get_connectivity( polyg, connp, num_nodes );MB_CHK_ERR( rval );
        for( int i = 0; i < num_nodes; i++ )
            indexVerts[i]             = verts.index( connp[i] );
            int i1                    = ( i + 1 ) % num_nodes;
            EntityHandle edgeVerts[2] = { connp[i], connp[i1] };
            // get edge adjacent to these vertices
            Range adjEdges;
            rval = mb->get_adjacencies( edgeVerts, 2, 1, false, adjEdges );MB_CHK_ERR( rval );
            if( adjEdges.size() < 1 ) MB_CHK_SET_ERR( MB_FAILURE, " did not find edge " );
            indexEdges[i] = edges.index( adjEdges[0] );
            if( indexEdges[i] < 0 ) MB_CHK_SET_ERR( MB_FAILURE, "did not find edge in range" );
            // create a polygon on each layer
                newConn[i] = newVerts[ii + 1][indexVerts[i]];  // vertices in layer ii+1
            rval = mb->create_element( MBPOLYGON, newConn, num_nodes, allPolygons[nfaces * ( ii + 1 ) + j] );MB_CHK_ERR( rval );
            // now create a polyhedra with top, bottom and lateral swept faces
            // first face is the bottom
            polyhedronConn[0] = allPolygons[nfaces * ii + j];
            // second face is the top
            polyhedronConn[1] = allPolygons[nfaces * ( ii + 1 ) + j];
            // next add lateral quads, in order of edges, using the start_elem
            // first layer of quads has EntityHandle from start_elem to start_elem+nedges-1
            // second layer of quads has EntityHandle from start_elem + nedges to
            // start_elem+2*nedges-1 ,etc
                polyhedronConn[2 + i] = start_elem + ii + layers * indexEdges[i];
            // Create polyhedron
            EntityHandle polyhedron;
            rval = mb->create_element( MBPOLYHEDRON, polyhedronConn, 2 + num_nodes, polyhedron );MB_CHK_ERR( rval );
    rval = mb->write_file( output.c_str() );MB_CHK_ERR( rval );
    delete mb;
    return 0;
