FBGeomAssocPairSide.cpp
00001 #include "FBGeomAssocPairSide.hpp"
00002
00003 #include <cstring>
00004 #include <sstream>
00005 #include <string>
00006
00007 #include "Lasso.hpp"
00008 #include "iRel_Lasso.hpp"
00009
00010 #define PROCESS_ERROR                                             \
00011     do                                                            \
00012     {                                                             \
00013         if( iBase_SUCCESS != result )                             \
00014         {                                                         \
00015             char this_descr[120];                                 \
00016             FBiGeom_getDescription( instance_, this_descr, 120 ); \
00017             ERRORR( result, this_descr );                         \
00018         }                                                         \
00019     } while( false )
00020
00021 // Redefine LASSOI
00022 #undef LASSOI
00023 #define LASSOI lasso_instance( relation )
00024
00025 static const char* GLOBAL_ID_TAG_NAME = "GLOBAL_ID";
00026 static const char* RELATION_TAG_NAME  = "__FBGEOM_ASSOCIATION";
00027
00028 FBGeomAssocPairSide::FBGeomAssocPairSide( iRel_Instance p_relation, iBase_Instance p_instance, int p_id )
00029     : relation( p_relation ), instance_( reinterpret_cast< FBiGeom_Instance >( p_instance ) ), id( p_id )
00030 {
00031     int result;
00032
00033     create_relation_side();
00034
00035     FBiGeom_getTagHandle( instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result, strlen( GLOBAL_ID_TAG_NAME ) );
00036     if( result == iBase_TAG_NOT_FOUND )
00037     {
00038         FBiGeom_createTag( instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER, &gid_tag, &result,
00039                            strlen( GLOBAL_ID_TAG_NAME ) );
00040     }
00041 }
00042
00043 FBGeomAssocPairSide::~FBGeomAssocPairSide()
00044 {
00045     destroy_relation_side();
00046 }
00047
00048 iBase_Instance FBGeomAssocPairSide::instance() const
00049 {
00050     return instance_;
00051 }
00052
00053 iRel_IfaceType FBGeomAssocPairSide::type() const
00054 {
00055     return iRel_FBIGEOM_IFACE;
00056 }
00057
00058 int FBGeomAssocPairSide::create_relation_side()
00059 {
00060     int result;
00061     std::stringstream ss;
00062     ss << RELATION_TAG_NAME << id;
00063     std::string rel_tag_name( ss.str() );
00064
00065     FBiGeom_getTagHandle( instance_, rel_tag_name.c_str(), &relation_tag, &result, rel_tag_name.size() );
00066     if( result == iBase_TAG_NOT_FOUND )
00067     {
00068         FBiGeom_createTag( instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE, &relation_tag, &result,
00069                            rel_tag_name.size() );
00070     }
00071
00072     PROCESS_ERROR;
00073     RETURNR( iBase_SUCCESS );
00074 }
00075
00076 int FBGeomAssocPairSide::destroy_relation_side()
00077 {
00078     if( relation_tag )
00079     {
00080         int result;
00081
00082         FBiGeom_destroyTag( instance_, relation_tag, true, &result );
00083         relation_tag = NULL;
00084
00085         PROCESS_ERROR;
00086     }
00087     RETURNR( iBase_SUCCESS );
00088 }
00089
00090 int FBGeomAssocPairSide::get_all_entities( int dimension,
00091                                            iBase_EntityHandle** entities,
00092                                            int* entities_alloc,
00093                                            int* entities_size )
00094 {
00095     int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension );
00096     int result;
00097
00098     FBiGeom_getEntities( instance_, 0, this_type, entities, entities_alloc, entities_size, &result );
00099     PROCESS_ERROR;
00100     RETURNR( iBase_SUCCESS );
00101 }
00102
00103 int FBGeomAssocPairSide::get_all_sets( iBase_EntitySetHandle** sets, int* sets_alloc, int* sets_size )
00104 {
00105     int result;
00106
00107     FBiGeom_getEntSets( instance_, 0, 0, sets, sets_alloc, sets_size, &result );
00108     PROCESS_ERROR;
00109     RETURNR( iBase_SUCCESS );
00110 }
00111
00112 int FBGeomAssocPairSide::get_entities( int dimension,
00113                                        iBase_EntitySetHandle set_handle,
00114                                        iBase_EntityHandle** entities,
00115                                        int* entities_alloc,
00116                                        int* entities_size )
00117 {
00118     int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension );
00119     int result;
00120
00121     FBiGeom_getEntities( instance_, set_handle, this_type, entities, entities_alloc, entities_size, &result );
00122     PROCESS_ERROR;
00123     RETURNR( iBase_SUCCESS );
00124 }
00125
00126 int FBGeomAssocPairSide::get_ents_dims( iBase_EntityHandle* entities,
00127                                         int entities_size,
00128                                         int** ent_types,
00129                                         int* ent_types_alloc,
00130                                         int* ent_types_size )
00131 {
00132     int result;
00133
00134     FBiGeom_getArrType( instance_, entities, entities_size, ent_types, ent_types_alloc, ent_types_size, &result );
00135     PROCESS_ERROR;
00136     RETURNR( iBase_SUCCESS );
00137 }
00138
00139 int FBGeomAssocPairSide::get_related_ents( iBase_EntityHandle** /*entities*/,
00140                                            int* /*entities_alloc*/,
00141                                            int* /*entities_size*/ )
00142 {
00143     RETURNR( iBase_FAILURE );
00144 }
00145
00146 int FBGeomAssocPairSide::get_related_sets( iBase_EntitySetHandle** /*sets*/, int* /*sets_alloc*/, int* /*sets_size*/ )
00147 {
00148     RETURNR( iBase_FAILURE );
00149 }
00150
00151 int FBGeomAssocPairSide::get_relation_side( iBase_EntityHandle* entities, int num_entities, void* values )
00152 {
00153     int values_alloc = num_entities * sizeof( iBase_EntityHandle );
00154     int values_size;
00155     int result;
00156
00157     FBiGeom_getArrData( instance_, entities, num_entities, relation_tag, &values, &values_alloc, &values_size,
00158                         &result );
00159     PROCESS_ERROR;
00160     RETURNR( iBase_SUCCESS );
00161 }
00162
00163 int FBGeomAssocPairSide::get_relation_side( iBase_EntitySetHandle* sets, int num_sets, void* values )
00164 {
00165     char* data       = static_cast< char* >( values );
00166     int values_alloc = sizeof( iBase_EntityHandle );
00167     int values_size;
00168     int result;
00169
00170     for( int i = 0; i < num_sets; i++ )
00171     {
00172         FBiGeom_getEntSetData( instance_, sets[i], relation_tag, reinterpret_cast< void** >( &data ), &values_alloc,
00173                                &values_size, &result );
00174         data += values_size;
00175         PROCESS_ERROR;
00176     }
00177     RETURNR( iBase_SUCCESS );
00178 }
00179
00180 int FBGeomAssocPairSide::set_relation_side( iBase_EntityHandle* entities, int num_entities, const void* values )
00181 {
00182     int result;
00183
00184     FBiGeom_setArrData( instance_, entities, num_entities, relation_tag, static_cast< const char* >( values ),
00185                         num_entities * sizeof( iBase_EntityHandle ), &result );
00186     PROCESS_ERROR;
00187     RETURNR( iBase_SUCCESS );
00188 }
00189
00190 int FBGeomAssocPairSide::set_relation_side( iBase_EntitySetHandle* sets, int num_sets, const void* values )
00191 {
00192     const char* data = static_cast< const char* >( values );
00193     int size         = sizeof( iBase_EntityHandle );
00194     int result;
00195
00196     for( int i = 0; i < num_sets; i++ )
00197     {
00198         FBiGeom_setEntSetData( instance_, sets[i], relation_tag, data, size, &result );
00199         data += size;
00200         PROCESS_ERROR;
00201     }
00202     RETURNR( iBase_SUCCESS );
00203 }
00204
00205 int FBGeomAssocPairSide::rmv_relation_side( iBase_EntityHandle* entities, int num_entities )
00206 {
00207     int result;
00208
00209     FBiGeom_rmvArrTag( instance_, entities, num_entities, relation_tag, &result );
00210     PROCESS_ERROR;
00211     RETURNR( iBase_SUCCESS );
00212 }
00213
00214 int FBGeomAssocPairSide::rmv_relation_side( iBase_EntitySetHandle* sets, int num_sets )
00215 {
00216     int result;
00217
00218     for( int i = 0; i < num_sets; i++ )
00219     {
00220         FBiGeom_rmvEntSetTag( instance_, sets[i], relation_tag, &result );
00221         PROCESS_ERROR;
00222     }
00223
00224     RETURNR( iBase_SUCCESS );
00225 }
00226
00227 int FBGeomAssocPairSide::get_iterator( iBase_EntitySetHandle set, iBase_EntityIterator* iter )
00228 {
00229     int result;
00230     FBiGeom_initEntIter( instance_, set, iBase_ALL_TYPES, iter, &result );
00231     RETURNR( iBase_SUCCESS );
00232 }
00233
00234 int FBGeomAssocPairSide::get_gids( iBase_EntityHandle* entities, int num_entities, int* values )
00235 {
00236     int values_alloc = num_entities * sizeof( int );
00237     int values_size;
00238     int result;
00239
00240     FBiGeom_getArrData( instance_, entities, num_entities, gid_tag, reinterpret_cast< void** >( &values ),
00241                         &values_alloc, &values_size, &result );
00242     PROCESS_ERROR;
00243     RETURNR( iBase_SUCCESS );
00244 }
00245
00246 int FBGeomAssocPairSide::get_gids( iBase_EntitySetHandle* sets, int num_sets, int* values )
00247 {
00248     char* data       = reinterpret_cast< char* >( values );
00249     int values_alloc = sizeof( int );
00250     int values_size;
00251     int result;
00252
00253     for( int i = 0; i < num_sets; i++ )
00254     {
00255         FBiGeom_getEntSetData( instance_, sets[i], gid_tag, reinterpret_cast< void** >( &data ), &values_alloc,
00256                                &values_size, &result );
00257         data += values_size;
00258         PROCESS_ERROR;
00259     }
00260     RETURNR( iBase_SUCCESS );
00261 }
00262
00263 int FBGeomAssocPairSide::get_dims( iBase_EntityHandle* /*entities*/, int /*num_entities*/, int* /*values*/ )
00264 {
00265     RETURNR( iBase_FAILURE );
00266 }
00267
00268 int FBGeomAssocPairSide::get_dims( iBase_EntitySetHandle* /*sets*/, int /*num_sets*/, int* /*values*/ )
00269 {
00270     RETURNR( iBase_FAILURE );
00271 }
