FindConnectF.F
00001 c FindConnect: Interacting with iMesh
00002 c
00003 c This program shows how to get more information about a mesh, by
00004 c getting connectivity two different ways (as connectivity and as
00005 c adjacent 0-dimensional entities).
00006
00007 c Usage: FindConnect
00008
00009       program findconnect
00010 #include "iMesh_f.h"
00011
00012 c declarations
00013       iMesh_Instance mesh
00014       iBase_EntityHandle  ents
00015       IBASE_HANDLE_T rpverts, rpallverts, ipoffsets
00016       pointer (rpents, ents(0:*))
00017       pointer (rpverts, verts(0:*))
00018       pointer (rpallverts, allverts(0:*))
00019       pointer (ipoffsets, ioffsets(0,*))
00020       integer ierr, ents_alloc, ents_size
00021       integer iverts_alloc, iverts_size
00022       integer allverts_alloc, allverts_size
00023       integer offsets_alloc, offsets_size
00024
00025 c create the Mesh instance
00026       call iMesh_newMesh("MOAB", mesh, ierr)
00027
00028 c load the mesh
00029       call iMesh_load(%VAL(mesh), %VAL(0), "125hex.vtk", "", ierr)
00030
00031 c get all 3d elements
00032       ents_alloc = 0
00033       call iMesh_getEntities(%VAL(mesh), %VAL(0), %VAL(iBase_REGION),
00034      1     %VAL(iMesh_ALL_TOPOLOGIES), rpents, ents_alloc, ents_size,
00035      1     ierr)
00036
00037       ivert_uses = 0
00038
00039 c iterate through them;
00040       do i = 0, ents_size-1
00041 c get connectivity
00042          iverts_alloc = 0
00043          call iMesh_getEntAdj(%VAL(mesh), %VAL(ents(i)),
00044      1        %VAL(iBase_VERTEX), rpverts, iverts_alloc, iverts_size,
00045      1        ierr)
00046 c sum number of vertex uses
00047
00048          vert_uses = vert_uses + iverts_size
00049
00050          call free(rpverts)
00051       end do
00052
00053 c now get adjacencies in one big block
00054       allverts_alloc = 0
00055       offsets_alloc = 0
00056       call iMesh_getEntArrAdj(%VAL(mesh), %VAL(rpents),
00057      1     %VAL(ents_size), %VAL(iBase_VERTEX), rpallverts,
00058      1     allverts_alloc, allverts_size, ipoffsets, offsets_alloc,
00059      1     offsets_size, ierr)
00060
00061       call free(rpallverts);
00062       call free(ipoffsets);
00063       call free(rpents);
00064
00065 c compare results of two calling methods
00066       if (allverts_size .ne. vert_uses) then
00067          write(*,'("Sizes didn''t agree!")')
00068       else
00069          write(*,'("Sizes did agree!")')
00070       endif
00071
00072       call iMesh_dtor(%VAL(mesh), ierr)
00073
00074       end
