GenLargeMesh.cpp File Reference
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/MeshGeneration.hpp"
#include <ctime>
#include <iostream>
#include <vector>
+ Include dependency graph for GenLargeMesh.cpp:
Functions
int main (int argc, char **argv)
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 87 of file GenLargeMesh.cpp.
References moab::MeshGeneration::BrickOpts::A, ProgOptions::addOpt(), moab::MeshGeneration::BrickOpts::adjEnts, moab::MeshGeneration::BrickOpts::B, moab::MeshGeneration::BrickOpts::blockSize, moab::MeshGeneration::BrickInstance(), moab::MeshGeneration::BrickOpts::C, moab::Interface::create_meshset(), moab::Core::delete_mesh(), moab::Interface::delete_mesh(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Core::get_entities_by_dimension(), moab::Interface::get_entities_by_dimension(), moab::ParallelComm::get_pcomm(), ProgOptions::getOptAllArgs(), moab::MeshGeneration::BrickOpts::GL, moab::MeshGeneration::BrickOpts::K, moab::MeshGeneration::BrickOpts::keep_skins, moab::Core::load_file(), moab::MeshGeneration::BrickOpts::M, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MESHSET_SET, moab::MeshGeneration::BrickOpts::N, moab::MeshGeneration::BrickOpts::newMergeMethod, moab::MeshGeneration::BrickOpts::parmerge, ProgOptions::parseCommandLine(), PSTATUS_GHOST, PSTATUS_NOT, moab::MeshGeneration::BrickOpts::quadratic, size, moab::Range::size(), moab::MeshGeneration::BrickOpts::tetra, moab::MeshGeneration::BrickOpts::ui, moab::MeshGeneration::BrickOpts::uj, moab::MeshGeneration::BrickOpts::uk, moab::Interface::write_file(), moab::MeshGeneration::BrickOpts::xsize, moab::MeshGeneration::BrickOpts::ysize, and moab::MeshGeneration::BrickOpts::zsize.
    bool nosave = false;
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
#endif
    MeshGeneration::BrickOpts bopts;
    // default options
    bopts.A = bopts.B = bopts.C = 2;
    bopts.M = bopts.N = bopts.K = 1;
    bopts.blockSize             = 4;
    bopts.xsize = bopts.ysize = bopts.zsize = 1.;
    bopts.ui                                = CartVect( 1., 0, 0. );
    bopts.uj                                = CartVect( 0., 1., 0. );
    bopts.uk                                = CartVect( 0., 0., 1. );
    bopts.newMergeMethod = bopts.quadratic = bopts.keep_skins = bopts.tetra = false;
    bopts.adjEnts = bopts.parmerge = false;
    bopts.GL                       = 0;
    ProgOptions opts;
    opts.addOpt< int >( string( "blockSize,b" ), string( "Block size of mesh (default=4)" ), &bopts.blockSize );
    opts.addOpt< int >( string( "xproc,M" ), string( "Number of processors in x dir (default=1)" ), &bopts.M );
    opts.addOpt< int >( string( "yproc,N" ), string( "Number of processors in y dir (default=1)" ), &bopts.N );
    opts.addOpt< int >( string( "zproc,K" ), string( "Number of processors in z dir (default=1)" ), &bopts.K );
    opts.addOpt< int >( string( "xblocks,A" ), string( "Number of blocks on a task in x dir (default=2)" ), &bopts.A );
    opts.addOpt< int >( string( "yblocks,B" ), string( "Number of blocks on a task in y dir (default=2)" ), &bopts.B );
    opts.addOpt< int >( string( "zblocks,C" ), string( "Number of blocks on a task in x dir (default=2)" ), &bopts.C );
    opts.addOpt< double >( string( "xsize,x" ), string( "Total size in x direction (default=1.)" ), &bopts.xsize );
    opts.addOpt< double >( string( "ysize,y" ), string( "Total size in y direction (default=1.)" ), &bopts.ysize );
    opts.addOpt< double >( string( "zsize,z" ), string( "Total size in z direction (default=1.)" ), &bopts.zsize );
    opts.addOpt< void >( "newMerge,w", "use new merging method", &bopts.newMergeMethod );
    opts.addOpt< void >( "quadratic,q", "use hex 27 elements", &bopts.quadratic );
    opts.addOpt< void >( "keep_skins,k", "keep skins with shared entities", &bopts.keep_skins );
    opts.addOpt< void >( "tetrahedrons,t", "generate tetrahedrons", &bopts.tetra );
    opts.addOpt< void >( "faces_edges,f", "create all faces and edges", &bopts.adjEnts );
    opts.addOpt< int >( string( "ghost_layers,g" ), string( "Number of ghost layers (default=0)" ), &bopts.GL );
    vector< string > intTagNames;
    string firstIntTag;
    opts.addOpt< string >( "int_tag_vert,i", "add integer tag on vertices", &firstIntTag );
    vector< string > doubleTagNames;
    string firstDoubleTag;
    opts.addOpt< string >( "double_tag_cell,d", "add double tag on cells", &firstDoubleTag );
    string outFileName = "GenLargeMesh.h5m";
    opts.addOpt< string >( "outFile,o", "Specify the output file name string (default GenLargeMesh.h5m)",
                           &outFileName );
#ifdef MOAB_HAVE_HDF5_PARALLEL
    bool readb = false;
    opts.addOpt< void >( "readback,r", "read back the generated mesh", &readb );
    bool readAndGhost = false;
    opts.addOpt< void >( "readAndGhost,G", "read back the generated mesh and ghost one layer", &readAndGhost );
#endif
    opts.addOpt< void >( "parallel_merge,p", "use parallel mesh merge, not vertex ID based merge", &bopts.parmerge );
    opts.addOpt< void >( "no_save,n", "do not save the file", &nosave );
    opts.parseCommandLine( argc, argv );
    opts.getOptAllArgs( "int_tag_vert,i", intTagNames );
    opts.getOptAllArgs( "double_tag_cell,d", doubleTagNames );
    if( bopts.adjEnts ) bopts.keep_skins = true;  // Do not delete anything
    Interface* mb = new( std::nothrow ) Core;
    if( NULL == mb )
        MPI_Finalize();
#endif
        return 1;
    int rank = 0, size = 1;
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
#endif
    EntityHandle fileset;
    ErrorCode rval = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( rval );
    ParallelComm* pc     = new ParallelComm( mb, MPI_COMM_WORLD );
    MeshGeneration* mgen = new MeshGeneration( mb, pc, fileset );
#else
    MeshGeneration* mgen = new MeshGeneration( mb, 0, fileset );
#endif
    clock_t tt = clock();
    rval = mgen->BrickInstance( bopts );MB_CHK_ERR( rval );
    Range all3dcells;
    rval = mb->get_entities_by_dimension( fileset, 3, all3dcells );MB_CHK_ERR( rval );
    if( 0 == rank )
        cout << "generate local mesh: " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl;
        tt = clock();
        cout << "number of elements on rank 0: " << all3dcells.size() << endl;
        cout << "Total number of elements " << all3dcells.size() * size << endl;
        cout << "Element type: " << ( bopts.tetra ? "MBTET" : "MBHEX" )
             << " order:" << ( bopts.quadratic ? "quadratic" : "linear" ) << endl;
    Range verts;
    rval = mb->get_entities_by_dimension( 0, 0, verts );MB_CHK_SET_ERR( rval, "Can't get all vertices" );
    if( !nosave )
        rval = mb->write_file( outFileName.c_str(), 0, ";;PARALLEL=WRITE_PART;CPUTIME;", &fileset, 1 );MB_CHK_SET_ERR( rval, "Can't write in parallel" );
#else
        // should be a vtk file, actually, maybe make sure of that
        rval = mb->write_file( outFileName.c_str(), 0, "", &fileset, 1 );MB_CHK_SET_ERR( rval, "Can't write in serial" );
#endif
        if( 0 == rank )
            cout << "write file " << outFileName << " in " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds"
                 << endl;
            tt = clock();
    // delete the mesh that we already have in-memory
    size_t nLocalVerts = verts.size();
    size_t nLocalCells = all3dcells.size();
    mb->delete_mesh();
    if( !nosave && readb )
        // now recreate a core instance and load the file we just wrote out to verify
        Core mb2;
        std::string read_opts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_"
                               "SHARED_ENTS;CPUTIME;" );
        if( readAndGhost ) read_opts += "PARALLEL_GHOSTS=3.0.1;";
        rval = mb2.load_file( outFileName.c_str(), 0, read_opts.c_str() );MB_CHK_SET_ERR( rval, "Can't read in parallel" );
        if( 0 == rank )
            cout << "read back file " << outFileName << " with options: \n"
                 << read_opts << " in " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl;
            tt = clock();
        moab::Range nverts, ncells;
        rval = mb2.get_entities_by_dimension( 0, 0, nverts );MB_CHK_SET_ERR( rval, "Can't get all vertices" );
        rval = mb2.get_entities_by_dimension( 0, 3, ncells );MB_CHK_SET_ERR( rval, "Can't get all 3d cells elements" );
        if( readAndGhost && size > 1 )
            // filter out the ghost nodes and elements, for comparison with original mesh
            // first get the parallel comm
            ParallelComm* pcomm2 = ParallelComm::get_pcomm( &mb2, 0 );
            if( NULL == pcomm2 ) MB_SET_ERR( MB_FAILURE, "can't get parallel comm." );
            rval = pcomm2->filter_pstatus( nverts, PSTATUS_GHOST, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Can't filter ghost vertices" );
            rval = pcomm2->filter_pstatus( ncells, PSTATUS_GHOST, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Can't filter ghost cells" );
        if( nverts.size() != nLocalVerts && ncells.size() != nLocalCells )
            MB_SET_ERR( MB_FAILURE, "Reading back the output file led to inconsistent number of entities." );
        mb2.delete_mesh();
#endif
    MPI_Finalize();
#endif
    return 0;
