GmshUtil.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include "GmshUtil.hpp"
00017
00018 namespace moab
00019 {
00020
00021 // Indexed by position in Gmsh order, containing cooresponding
00022 // position in MOAB order.
00023 const int hex_27_node_order[] = { 0,  1,  2,  3,  4,  5,  6,  7,                   // corners
00024                                   8,  11, 12, 9,  13, 10, 14, 15, 16, 19, 17, 18,  // edges
00025                                   24, 20, 23, 21, 22, 25,                          // faces
00026                                   26 };                                            // volume
00027
00028 const int tet_10_node_order[] = { 0, 1, 2, 3, 4, 5, 6, 7, 9, 8 };
00029
00030 // Indexed by position in MOAB order, containing cooresponding
00031 // position in Gmsh order.
00032 const int pri_15_node_order[] = {
00033     0, 1, 2, 3, 4,  5,              // corners
00034     6, 8, 9, 7, 10, 11, 12, 14, 13  // edges
00035 };
00036 const int pyr_13_node_order[] = {
00037     0, 1, 2, 3, 4,             // corners
00038     5, 8, 9, 6, 10, 7, 11, 12  // edges
00039 };
00040
00041 // List of GmshElemType structs, indexed by the VTK type number.
00042 const GmshElemType GmshUtil::gmshElemTypes[] = {
00043     { 0, 0, MBMAXTYPE, 0, 0 },
00044     { "line", 1, MBEDGE, 2, 0 },
00045     { "triangle", 2, MBTRI, 3, 0 },
00046     { "quadrangle", 3, MBQUAD, 4, 0 },
00047     { "tetrahedron", 4, MBTET, 4, 0 },
00048     { "hexahedron", 5, MBHEX, 8, 0 },
00049     { "prism", 6, MBPRISM, 6, 0 },
00050     { "pyramid", 7, MBPYRAMID, 5, 0 },
00051     { "2nd order line", 8, MBEDGE, 3, 0 },
00052     { "2nd order triangle", 9, MBTRI, 6, 0 },
00053     { "2nd order quadrangle", 10, MBQUAD, 9, 0 },
00054     { "2nd order tetrahedron", 11, MBTET, 10, tet_10_node_order },
00055     { "2nd order hexahedron", 12, MBHEX, 27, hex_27_node_order },
00056     { "2nd order prism", 13, MBMAXTYPE, 0, 0 },    // prism w/ mid-face nodes on quads but not tris
00057     { "2nd order pyramid", 14, MBMAXTYPE, 0, 0 },  // pyramid w/ mid-face nodes on quad but not tris
00058     { "point", 15, MBVERTEX, 1, 0 },               // point element (0-rad sphere element?) // will be skipped
00059     { "2nd order quadrangle", 16, MBQUAD, 8, 0 },
00060     { "2nd order hexahedron", 17, MBHEX, 20, hex_27_node_order },
00061     { "2nd order prism", 18, MBPRISM, 15, pri_15_node_order },
00062     { "2nd order pyramid", 19, MBPYRAMID, 13, pyr_13_node_order },
00063     { "3rd order triangle", 20, MBMAXTYPE, 0, 0 },     // triangle w/ 2 nodes per edge
00064     { "3rd order triangle", 21, MBMAXTYPE, 0, 0 },     //   "       " "   "    "   "   and mid-face node
00065     { "4th order triangle", 22, MBMAXTYPE, 0, 0 },     // triangle w/ 3 nodes per edge
00066     { "4th order triangle", 23, MBMAXTYPE, 0, 0 },     //   "       " "   "    "   "   and 3 mid-face nodes
00067     { "5th order triangle", 24, MBMAXTYPE, 0, 0 },     // triangle w/ 4 nodes per edge
00068     { "5th order triangle", 25, MBMAXTYPE, 0, 0 },     //   "       " "   "    "   "   and 6 mid-face nodes
00069     { "3rd order edge", 26, MBMAXTYPE, 0, 0 },         // 4-node edge
00070     { "4th order edge", 27, MBMAXTYPE, 0, 0 },         // 5-node edge
00071     { "5th order edge", 28, MBMAXTYPE, 0, 0 },         // 6-node edge
00072     { "3rd order tetrahedron", 29, MBMAXTYPE, 0, 0 },  // tet w/ 2 nodes per edge and 1 per face
00073     { "4th order tetrahedron", 30, MBMAXTYPE, 0, 0 },  // tet w/ 3 nodes per edge, 3 per face, and 1 mid-voluem
00074     { "5th order tetrahedron", 31, MBMAXTYPE, 0, 0 },  // tet w/ 4 nodes per edge, 6 per face, and 4 mid-voluem
00075     { 0, 32, MBMAXTYPE, 0, 0 } };
00076
00077 const unsigned GmshUtil::numGmshElemType = sizeof( GmshUtil::gmshElemTypes ) / sizeof( GmshUtil::gmshElemTypes[0] );
00078
00079 // Define an array, indexed by EntityType and number of nodes,
00080 // containing the corresponding Gmsh element type.
00081 #define TWENTYEIGHT_ZEROS        \
00082     {        \
00083         0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 \
00084     }
00085 const int MAX_NODES                    = 28;
00086 const int mb_to_gmsh_type[][MAX_NODES] = {
00087     // 0  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
00088     TWENTYEIGHT_ZEROS,        // MBVERTEX
00089     { 0, 0, 1, 8, 26, 27, 28, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },    // MBEDGE
00090     { 0, 0, 0, 2, 0, 0, 9, 0, 0, 20, 21, 0, 22, 0, 0, 23, 0, 0, 0, 0, 0, 25, 0, 0, 0, 0, 0, 0 },  // MBTRI
00091     { 0, 0, 0, 0, 3, 0, 0, 0, 16, 10, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },     // MBQUAD
00092     TWENTYEIGHT_ZEROS,        // MBPOLYGON
00093     { 0, 0, 0, 0, 4, 0, 0, 0, 0, 0, 11, 0, 0, 0, 0, 0, 0, 0, 0, 0, 29, 0, 0, 0, 0, 0, 0, 0 },     // MBTET
00094     { 0, 0, 0, 0, 0, 7, 0, 0, 0, 0, 0, 0, 0, 19, 14, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },     // MBPYRAMID
00095     { 0, 0, 0, 0, 0, 0, 6, 0, 0, 0, 0, 0, 0, 0, 0, 18, 0, 0, 13, 0, 0, 0, 0, 0, 0, 0, 0, 0 },     // MBWEDGE
00096     TWENTYEIGHT_ZEROS,        // MBKNIFE
00097     { 0, 0, 0, 0, 0, 0, 0, 0, 5, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 17, 0, 0, 0, 0, 0, 0, 12 },     // MBHEX
00098     TWENTYEIGHT_ZEROS,        // MBPOLYHEDRON
00099     TWENTYEIGHT_ZEROS,        // MBENTITYSET
00100     TWENTYEIGHT_ZEROS };        // MBMAXTYPE
00101
00102 int GmshUtil::get_gmsh_type( EntityType type, unsigned num_nodes )
00103 {
00104     if( num_nodes >= (unsigned)MAX_NODES ) return -1;
00105
00106     int idx = mb_to_gmsh_type[type][num_nodes];
00107     if( !idx ) return -1;
00108
00109     return gmshElemTypes[idx].mb_type == MBMAXTYPE ? -1 : idx;
00110 }
00111
00112 }  // namespace moab
