HigherOrderTest.cpp File Reference
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "ArrayMesh.hpp"
#include "DomainClassifier.hpp"
#include "PlanarDomain.hpp"
#include "MeshDomain1D.hpp"
#include "IdealShapeTarget.hpp"
#include "TInverseMeanRatio.hpp"
#include "TShapeSizeOrientNB1.hpp"
#include "TShapeSizeNB3.hpp"
#include "TQualityMetric.hpp"
#include "PMeanPTemplate.hpp"
#include "LPtoPTemplate.hpp"
#include "SteepestDescent.hpp"
#include "FeasibleNewton.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "HexLagrangeShape.hpp"
#include "UnitUtil.hpp"
#include <iostream>
+ Include dependency graph for HigherOrderTest.cpp:
Classes
class  HigherOrderTest
Defines
#define HAVE_HO_HEX
#define TEST_HO_QUAD
Functions
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HigherOrderTest,"HigherOrderTest")
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (HigherOrderTest,"Regression")
static double dist (double x1, double y1, double x2, double y2)
int tri_mid_edge_nodes_edge_center (double x2, double y2, double x3, double y3, double x4, double y4, double x5, double y5, double epsilon)
int quad_all_in_xy_plane (const Vector3D &p2, const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, double epsilon)
int quad_mid_edge_nodes_edge_center (const Vector3D &p2, const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, double epsilon)
static void get_ideal_quad (Vector3D &p2, Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7)
int tet_mid_edge_nodes_edge_center (const Vector3D &p3, const Vector3D &p4, const Vector3D &p5, const Vector3D &p6, const Vector3D &p7, const Vector3D &p8, const Vector3D &p9, double epsilon)
static void get_ideal_tet (Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7, Vector3D &p8, Vector3D &p9)
Variables
const int MAX_ITERATIONS = 1000
const double QEL = 1.0
const double IDEAL_TRI_SIDE = sqrt( 2.0 / sqrt( 3.0 ) )
const double IDEAL_TRI_HEIGHT = 1 / IDEAL_TRI_SIDE
const double IDEAL_TET_SIDE = 2.0 / pow( 33, 1.0 / 6.0 )
const double IDEAL_TET_BASE = sqrt( 3.0 ) * 0.5 * IDEAL_TET_SIDE
const double IDEAL_TET_HEIGHT = sqrt( 2.0 / 3.0 ) * IDEAL_TET_SIDE
Detailed Description
Author:
Jason Kraftcheck
Definition in file HigherOrderTest.cpp.
Define Documentation
#define HAVE_HO_HEX
Definition at line 32 of file HigherOrderTest.cpp.
Definition at line 33 of file HigherOrderTest.cpp.
Function Documentation
static double dist ( double  x1,
double  y1,
double  x2,
double  y2
) [inline, static]
Definition at line 221 of file HigherOrderTest.cpp.
    return sqrt( ( x1 - x2 ) * ( x1 - x2 ) + ( y1 - y2 ) * ( y1 - y2 ) );
static void get_ideal_tet ( Vector3D p3,
Vector3D p4,
Vector3D p5,
Vector3D p6,
Vector3D p7,
Vector3D p8,
Vector3D p9
) [inline, static]
Definition at line 668 of file HigherOrderTest.cpp.
References IDEAL_TET_BASE, IDEAL_TET_HEIGHT, IDEAL_TET_SIDE, and MBMesquite::Vector3D::set().
Referenced by HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), and HigherOrderTest::test_tet_basic_mid_convex().
    const Vector3D p0( 0.0, 0.0, 0.0 );
    const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 );
    const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 );
    p3.set( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT );
    p4.set( 0.5 * ( p0 + p1 ) );
    p5.set( 0.5 * ( p1 + p2 ) );
    p6.set( 0.5 * ( p2 + p0 ) );
    p7.set( 0.5 * ( p0 + p3 ) );
    p8.set( 0.5 * ( p1 + p3 ) );
    p9.set( 0.5 * ( p2 + p3 ) );
int quad_all_in_xy_plane ( const Vector3D p2,
const Vector3D p3,
const Vector3D p4,
const Vector3D p5,
const Vector3D p6,
const Vector3D p7,
double  epsilon
Definition at line 414 of file HigherOrderTest.cpp.
References epsilon, n, and z.
Referenced by HigherOrderTest::test_quad_basic_ideal(), HigherOrderTest::test_quad_basic_left_down(), HigherOrderTest::test_quad_basic_left_over(), HigherOrderTest::test_quad_basic_mid_convex(), HigherOrderTest::test_quad_basic_mid_spin(), HigherOrderTest::test_quad_basic_right_up(), and HigherOrderTest::test_quad_basic_top_down().
    Vector3D list[] = { p2, p3, p4, p5, p6, p7 };
    const int n     = sizeof( list ) / sizeof( list[0] );
    int result      = 0;
    for( int i = 0; i < n; ++i )
        if( fabs( list[i].z() ) > epsilon ) result |= ( 1 << i );
    return result;
int quad_mid_edge_nodes_edge_center ( const Vector3D p2,
const Vector3D p3,
const Vector3D p4,
const Vector3D p5,
const Vector3D p6,
const Vector3D p7,
double  epsilon
Definition at line 430 of file HigherOrderTest.cpp.
References epsilon, and QEL.
    const Vector3D p1( QEL, 0.0, 0.0 );
    const Vector3D e0 = 0.5 * ( p0 + p1 );
    const Vector3D e1 = 0.5 * ( p1 + p2 );
    const Vector3D e2 = 0.5 * ( p2 + p3 );
    const Vector3D e3 = 0.5 * ( p3 + p0 );
    int result = 0;
    if( ( p4 - e0 ).length() > epsilon ) result |= 1;
    if( ( p5 - e1 ).length() > epsilon ) result |= 2;
    if( ( p6 - e2 ).length() > epsilon ) result |= 4;
    if( ( p7 - e3 ).length() > epsilon ) result |= 8;
    return result;
int tet_mid_edge_nodes_edge_center ( const Vector3D p3,
const Vector3D p4,
const Vector3D p5,
const Vector3D p6,
const Vector3D p7,
const Vector3D p8,
const Vector3D p9,
double  epsilon
Definition at line 638 of file HigherOrderTest.cpp.
References epsilon, IDEAL_TET_BASE, and IDEAL_TET_SIDE.
Referenced by HigherOrderTest::test_tet_basic_apex_down(), HigherOrderTest::test_tet_basic_apex_over(), HigherOrderTest::test_tet_basic_apex_up(), HigherOrderTest::test_tet_basic_ideal(), HigherOrderTest::test_tet_basic_mid_convex(), and HigherOrderTest::test_tet_basic_mid_spin().
    const Vector3D e2 = 0.5 * ( p2 + p0 );
    const Vector3D e3 = 0.5 * ( p0 + p3 );
    const Vector3D e4 = 0.5 * ( p1 + p3 );
    const Vector3D e5 = 0.5 * ( p2 + p3 );
    int result = 0;
    if( ( p8 - e4 ).length() > epsilon ) result |= 16;
    if( ( p9 - e5 ).length() > epsilon ) result |= 32;
    return result;
int tri_mid_edge_nodes_edge_center ( double  x2,
double  y2,
double  x3,
double  y3,
double  x4,
double  y4,
double  x5,
double  y5,
double  epsilon
Definition at line 230 of file HigherOrderTest.cpp.
References dist(), epsilon, and IDEAL_TRI_SIDE.
Referenced by HigherOrderTest::test_tri_basic_ideal(), HigherOrderTest::test_tri_basic_mid_convex(), HigherOrderTest::test_tri_basic_mid_spin(), HigherOrderTest::test_tri_basic_peak_down(), HigherOrderTest::test_tri_basic_peak_over(), and HigherOrderTest::test_tri_basic_peak_up().
    double x0 = 0.0, y0 = 0.0;
    double x1 = IDEAL_TRI_SIDE, y1 = 0.0;
    double x01 = 0.5 * ( x0 + x1 );
    double x12 = 0.5 * ( x1 + x2 );
    double x20 = 0.5 * ( x2 + x0 );
    double y01 = 0.5 * ( y0 + y1 );
    double y12 = 0.5 * ( y1 + y2 );
    double y20 = 0.5 * ( y2 + y0 );
    int result = 0;
    if( dist( x3, y3, x01, y01 ) > epsilon ) result |= 1;
    if( dist( x4, y4, x12, y12 ) > epsilon ) result |= 2;
    if( dist( x5, y5, x20, y20 ) > epsilon ) result |= 4;
    return result;
Variable Documentation
