LaplaceWrapper.hpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2010 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2011) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file LaplaceWrapper.hpp
00028  *  \brief Define LaplaceWrapper class
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #ifndef MSQ_LAPLACE_WRAPPER_HPP
00033 #define MSQ_LAPLACE_WRAPPER_HPP
00034
00035 #include "Wrapper.hpp"
00036
00037 namespace MBMesquite
00038 {
00039
00040 class LaplaceWrapper : public Wrapper
00041 {
00042   public:
00043     MESQUITE_EXPORT
00044     LaplaceWrapper();
00045
00046     /**\brief Specify timeout after which untangler will exit
00047      *
00048      *  Specify a value less than or equal to zero for no limit
00049      */
00050     void set_cpu_time_limit( double seconds )
00051     {
00052         maxTime = seconds;
00053     }
00054     double get_cpu_time_limit() const
00055     {
00056         return maxTime;
00057     }
00058
00059     /**\brief Specify factor by which to minimum distance a vertex must
00060      *        move in an iteration to avoid termination of the untangler
00061      *
00062      *  Specify a value less than or equal to zero for no limit.
00063      *\NOTE Culling cannot be done w/out a limit on vertex movement
00064      */
00065     void set_vertex_movement_limit_factor( double f )
00066     {
00067         movementFactor = f;
00068     }
00069     double get_vertex_movement_limit_factor() const
00070     {
00071         return movementFactor;
00072     }
00073
00074     /**\brief Specify maximum number of iterations.
00075      *
00076      * Specify a value less than or equal to zero for no limit
00077      */
00078     void set_iteration_limit( int limit )
00079     {
00080         iterationLimit = limit;
00081     }
00082     int get_iteration_limit() const
00083     {
00084         return iterationLimit;
00085     }
00086
00087     /**\brief Cull vertices based on movement limit */
00088     inline void enable_culling( bool yesno )
00089     {
00090         doCulling = yesno;
00091     }
00092     inline bool is_culling_enabled() const
00093     {
00094         return doCulling;
00095     }
00096
00097     MESQUITE_EXPORT
00098     ~LaplaceWrapper();
00099
00100   protected:
00101     MESQUITE_EXPORT
00102     void run_wrapper( MeshDomainAssoc* mesh_and_domain,
00103                       ParallelMesh* pmesh,
00104                       Settings* settings,
00105                       QualityAssessor* qa,
00106                       MsqError& err );
00107
00108   private:
00109     double maxTime, movementFactor;
00110     int iterationLimit;
00111     bool doCulling;
00112 };
00113
00114 }  // namespace MBMesquite
00115
00116 #endif
