MBCN.h
00001 #include "MBEntityType.h"
00002 #include "MBCN_protos.h"
00003
00004 #ifdef __cplusplus
00005 extern "C" {
00006 #endif
00007
00008 void MBCN_GetBasis( int* rval );
00009
00010 void MBCN_SetBasis( const int in_basis );
00011
00012 void MBCN_EntityTypeName( const int this_type, char* rval, int rval_len );
00013
00014 void MBCN_EntityTypeFromName( const char* name, int* rval );
00015
00016 void MBCN_Dimension( const int t, int* rval );
00017
00018 void MBCN_VerticesPerEntity( const int t, int* rval );
00019
00020 void MBCN_NumSubEntities( const int t, const int d, int* rval );
00021
00022 void MBCN_SubEntityType( const int this_type, const int sub_dimension, const int index, int* rval );
00023
00024 void MBCN_SubEntityVertexIndices( const int this_type,
00025                                   const int sub_dimension,
00026                                   const int sub_index,
00027                                   int sub_entity_conn[] );
00028
00029 void MBCN_AdjacentSubEntities( const int this_type,
00030                                const int* source_indices,
00031                                const int num_source_indices,
00032                                const int source_dim,
00033                                const int target_dim,
00034                                int* index_list,
00035                                int* num_indices,
00036                                const int operation_type,
00037                                int* rval );
00038
00039 void MBCN_SideNumberInt( const int* parent_conn,
00040                          const MBEntityType parent_type,
00041                          const int* child_conn,
00042                          const int child_num_verts,
00043                          const int child_dim,
00044                          int* side_no,
00045                          int* sense,
00046                          int* offset );
00047
00048 void MBCN_SideNumberUint( const unsigned int* parent_conn,
00049                           const MBEntityType parent_type,
00050                           const unsigned int* child_conn,
00051                           const int child_num_verts,
00052                           const int child_dim,
00053                           int* side_no,
00054                           int* sense,
00055                           int* offset );
00056
00057 void MBCN_SideNumberLong( const long* parent_conn,
00058                           const MBEntityType parent_type,
00059                           const long* child_conn,
00060                           const int child_num_verts,
00061                           const int child_dim,
00062                           int* side_no,
00063                           int* sense,
00064                           int* offset );
00065
00066 void MBCN_SideNumberUlong( const unsigned long* parent_conn,
00067                            const MBEntityType parent_type,
00068                            const unsigned long* child_conn,
00069                            const int child_num_verts,
00070                            const int child_dim,
00071                            int* side_no,
00072                            int* sense,
00073                            int* offset );
00074
00075 void MBCN_SideNumberVoid( void* const* parent_conn,
00076                           const MBEntityType parent_type,
00077                           void* const* child_conn,
00078                           const int child_num_verts,
00079                           const int child_dim,
00080                           int* side_no,
00081                           int* sense,
00082                           int* offset );
00083
00084 void MBCN_SideNumber( const int parent_type,
00085                       const int* child_conn_indices,
00086                       const int child_num_verts,
00087                       const int child_dim,
00088                       int* side_no,
00089                       int* sense,
00090                       int* offset );
00091
00092 void MBCN_OppositeSide( const int parent_type,
00093                         const int child_index,
00094                         const int child_dim,
00095                         int* opposite_index,
00096                         int* opposite_dim,
00097                         int* rval );
00098
00099 void MBCN_ConnectivityMatchInt( const int* conn1,
00100                                 const int* conn2,
00101                                 const int num_vertices,
00102                                 int* direct,
00103                                 int* offset,
00104                                 int* rval );
00105 void MBCN_ConnectivityMatchUint( const unsigned int* conn1,
00106                                  const unsigned int* conn2,
00107                                  const int num_vertices,
00108                                  int* direct,
00109                                  int* offset,
00110                                  int* rval );
00111 void MBCN_ConnectivityMatchLong( const long* conn1,
00112                                  const long* conn2,
00113                                  const int num_vertices,
00114                                  int* direct,
00115                                  int* offset,
00116                                  int* rval );
00117 void MBCN_ConnectivityMatchUlong( const unsigned long* conn1,
00118                                   const unsigned long* conn2,
00119                                   const int num_vertices,
00120                                   int* direct,
00121                                   int* offset,
00122                                   int* rval );
00123 void MBCN_ConnectivityMatchVoid( void* const* conn1,
00124                                  void* const* conn2,
00125                                  const int num_vertices,
00126                                  int* direct,
00127                                  int* offset,
00128                                  int* rval );
00129
00130 void MBCN_setPermutation( const MBEntityType t, const int dim, int* pvec, const int num_entries, const int is_reverse );
00131
00132 void MBCN_resetPermutation( const MBEntityType t, const int dim );
00133
00134 void MBCN_permuteThisInt( const MBEntityType t,
00135                           const int dim,
00136                           int* pvec,
00137                           const int num_indices,
00138                           const int num_entries,
00139                           int* rval );
00140
00141 void MBCN_permuteThisUint( const MBEntityType t,
00142                            const int dim,
00143                            unsigned int* pvec,
00144                            const int num_indices,
00145                            const int num_entries,
00146                            int* rval );
00147
00148 void MBCN_permuteThisLong( const MBEntityType t,
00149                            const int dim,
00150                            long* pvec,
00151                            const int num_indices,
00152                            const int num_entries,
00153                            int* rval );
00154
00155 void MBCN_permuteThisVoid( const MBEntityType t,
00156                            const int dim,
00157                            void** pvec,
00158                            const int num_indices,
00159                            const int num_entries,
00160                            int* rval );
00161
00162 void MBCN_revPermuteThisInt( const MBEntityType t,
00163                              const int dim,
00164                              int* pvec,
00165                              const int num_indices,
00166                              const int num_entries,
00167                              int* rval );
00168
00169 void MBCN_revPermuteThisUint( const MBEntityType t,
00170                               const int dim,
00171                               unsigned int* pvec,
00172                               const int num_indices,
00173                               const int num_entries,
00174                               int* rval );
00175
00176 void MBCN_revPermuteThisLong( const MBEntityType t,
00177                               const int dim,
00178                               long* pvec,
00179                               const int num_indices,
00180                               const int num_entries,
00181                               int* rval );
00182
00183 void MBCN_revPermuteThisVoid( const MBEntityType t,
00184                               const int dim,
00185                               void** pvec,
00186                               const int num_indices,
00187                               const int num_entries,
00188                               int* rval );
00189
00190 void MBCN_HasMidEdgeNodes( const int this_type, const int num_verts, int* rval );
00191
00192 void MBCN_HasMidFaceNodes( const int this_type, const int num_verts, int* rval );
00193
00194 void MBCN_HasMidRegionNodes( const int this_type, const int num_verts, int* rval );
00195
00196 void MBCN_HasMidNodes( const int this_type, const int num_verts, int mid_nodes[4] );
00197
00198 void MBCN_HONodeParent( int elem_type, int num_nodes, int ho_node_index, int* parent_dim, int* parent_index );
00199
00200 void MBCN_HONodeIndex( const int this_type,
00201                        const int num_verts,
00202                        const int subfacet_dim,
00203                        const int subfacet_index,
00204                        int* rval );
00205
00206 #ifdef __cplusplus
00207 }
00208 #endif
