MBEntityType.h File Reference
+ This graph shows which files directly or indirectly include this file:
Defines
#define MOAB_ENTITY_TYPE_NAME   MBEntityType
Enumerations
enum  MOAB_ENTITY_TYPE_NAME {
  MBVERTEX = 0, MBEDGE, MBTRI, MBQUAD,
  MBPOLYGON, MBTET, MBPYRAMID, MBPRISM,
  MBKNIFE, MBHEX, MBPOLYHEDRON, MBENTITYSET,
  MBMAXTYPE
Define Documentation
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 61 of file MBEntityType.h.
Enumeration Type Documentation
Entity types defined in MOAB and MBCN The ordering here must ensure that all element types are grouped together and all elements of similar dimension are grouped together.
Enumerator:
MBVERTEX
Mesh Vertex AKA node
MBEDGE
Mesh Edge
MBTRI
Triangular element (including shells)
MBQUAD
Quadrilateral element (including shells)
MBPOLYGON
Polygon
MBTET
Tetrahedral element
MBPYRAMID
Pyramid element (where are the face ids for this defined?)
MBPRISM
Wedge element (Exodus has one, Cubit doesn't. Does Mesh need it?)
MBKNIFE
Knife element
MBHEX
Hexahedral element
MBPOLYHEDRON
Polyhedron
MBENTITYSET
MeshSet
MBMAXTYPE
Just a place keeper - must be the # of entities, for array dimensioning purposes
Definition at line 69 of file MBEntityType.h.
    MBVERTEX = 0, /**< Mesh Vertex AKA node */
    MBEDGE,       /**< Mesh Edge */
    MBTRI,        /**< Triangular element (including shells) */
    MBQUAD,       /**< Quadrilateral element (including shells) */
    MBPOLYGON,    /**< Polygon */
    MBTET,        /**< Tetrahedral element */
    MBPYRAMID,    /**< Pyramid element (where are the face ids for this defined?) */
    MBPRISM,      /**< Wedge element (Exodus has one, Cubit doesn't. Does Mesh need it?) */
    MBKNIFE,      /**< Knife element */
    MBHEX,        /**< Hexahedral element */
    MBPOLYHEDRON, /**< Polyhedron */
    MBENTITYSET,  /**< MeshSet */
    MBMAXTYPE     /**< Just a place keeper - must be the # of entities, for array */
    /**< dimensioning purposes  */
