MBTest.cpp File Reference
#include <iostream>
#include <fstream>
#include <algorithm>
#include <cstdio>
#include <ctime>
#include <cassert>
#include <cmath>
#include "moab/Interface.hpp"
#include "MBTagConventions.hpp"
#include "moab/Range.hpp"
#include "moab/Skinner.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/CN.hpp"
#include "moab/OrientedBox.hpp"
#include "moab/CartVect.hpp"
#include "moab/WriteUtilIface.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "SequenceManager.hpp"
#include "EntitySequence.hpp"
#include "RangeSeqIntersectIter.hpp"
#include "moab/Error.hpp"
#include "moab/ScdInterface.hpp"
#include "TestUtil.hpp"
+ Include dependency graph for MBTest.cpp:
Classes
class  OffsetHexCenterNodes
Defines
#define IS_BUILDING_MB
#define TEST_USES_ERR_CODES
#define CHKERR(A)
#define RR   if( result != MB_SUCCESS ) return result
#define VINDEX(i, j, k)   ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
#define ASSERT_EQUAL(A, B)
#define ASSERT_NOT_EQUAL(A, B)
#define TEST_ERROR_CODE(E)
#define RUN_TEST_ERR(A)   _run_test( ( A ), #A )
Typedefs
typedef ErrorCode(* TestFunc )()
Functions
ErrorCode create_some_mesh (Interface *iface)
ErrorCode check_valid_connectivity (Interface *iface)
ErrorCode mb_vertex_coordinate_test ()
ErrorCode mb_vertex_tag_test ()
ErrorCode mb_temporary_test ()
ErrorCode mb_adjacent_vertex_test ()
ErrorCode mb_adjacencies_create_delete_test ()
static ErrorCode create_two_hex_full_mesh (Interface *mb, EntityHandle vertices[12], EntityHandle hexes[2], EntityHandle hex1_faces[6], EntityHandle hex2_faces[6], EntityHandle hex1_edges[12], EntityHandle hex2_edges[12])
ErrorCode mb_upward_adjacencies_test ()
ErrorCode mb_adjacent_create_test ()
ErrorCode nothing_but_type (Range &range, EntityType type)
ErrorCode check_esets (Interface *MB, const int num_sets)
ErrorCode mb_mesh_sets_test (int flags)
static bool compare_lists (std::vector< EntityHandle > vect, const EntityHandle *array, int count, bool ordered=true)
ErrorCode mb_mesh_set_parent_child_test ()
ErrorCode mb_mesh_sets_set_test ()
ErrorCode mb_mesh_sets_list_test ()
ErrorCode mb_mesh_set_appends (int flags)
ErrorCode mb_mesh_set_set_appends ()
ErrorCode mb_mesh_set_list_appends ()
ErrorCode mb_mesh_set_root_appends ()
ErrorCode mb_mesh_set_set_replace_test ()
ErrorCode mb_mesh_set_list_replace_test ()
ErrorCode mb_mesh_set_flag_test ()
static ErrorCode check_list_meshset_internal (const EntityHandle *expected, int num_expected, const EntityHandle *contents, int length)
static ErrorCode check_ranged_meshset_internal (const EntityHandle *expected, int num_expected, const EntityHandle *contents, int length)
static ErrorCode check_meshset_internal (Interface &mb, EntityHandle set, const EntityHandle *expected, int num_expected)
ErrorCode mb_mesh_set_set_add_remove_test ()
ErrorCode mb_higher_order_test ()
ErrorCode mb_bit_tags_test ()
ErrorCode mb_common_tag_test (TagType storage)
ErrorCode mb_dense_tag_test ()
ErrorCode mb_sparse_tag_test ()
ErrorCode mb_forced_adjacencies_test ()
bool points_are_coincident (const double *first, const double *second)
ErrorCode find_coincident_nodes (Interface *gMB, const Range &vertices, std::vector< std::pair< EntityHandle, EntityHandle > > &coin_nodes)
ErrorCode find_coincident_elements (Interface *gMB, const Range &entities, int num_nodes, std::vector< std::pair< EntityHandle, EntityHandle > > &coin)
ErrorCode mb_merge_update_test ()
ErrorCode mb_canon_number_test ()
ErrorCode mb_side_number_test ()
ErrorCode mb_poly_test ()
ErrorCode mb_topo_util_test ()
ErrorCode mb_split_test ()
ErrorCode mb_range_seq_intersect_test ()
template<typename T1 , typename T2 >
bool _assert_equal (T1 a, T2 b, const char *as, const char *bs, int line)
bool _assert_not_equal (T1 a, T2 b, const char *as, const char *bs, int line)
std::ostream & operator<< (std::ostream &s, Range::const_iterator i)
ErrorCode mb_poly_adjacency_test ()
ErrorCode mb_poly_adjacency_test2 ()
ErrorCode mb_memory_use_test ()
ErrorCode mb_skin_curve_test_common (bool use_adj)
ErrorCode mb_skin_curve_test ()
ErrorCode mb_skin_curve_adj_test ()
ErrorCode mb_skin_surface_test_common (bool use_adj)
ErrorCode mb_skin_surface_test ()
ErrorCode mb_skin_surface_adj_test ()
ErrorCode mb_skin_volume_test_common (bool use_adj)
ErrorCode mb_skin_volume_test ()
ErrorCode mb_skin_volume_adj_test ()
ErrorCode mb_skin_scd_test ()
ErrorCode mb_skin_fileset_test ()
ErrorCode mb_read_fail_test ()
ErrorCode mb_enum_string_test ()
ErrorCode mb_skin_verts_common (unsigned dim, bool skin_elems)
ErrorCode mb_skin_surf_verts_test ()
ErrorCode mb_skin_vol_verts_test ()
ErrorCode mb_skin_surf_verts_elems_test ()
ErrorCode mb_skin_vol_verts_elems_test ()
ErrorCode mb_skin_poly_test ()
ErrorCode mb_skin_higher_order_faces_common (bool use_adj)
ErrorCode mb_skin_higher_order_faces_test ()
ErrorCode mb_skin_adj_higher_order_faces_test ()
ErrorCode mb_skin_higher_order_regions_common (bool use_adj)
ErrorCode mb_skin_higher_order_pyramids ()
ErrorCode mb_skin_higher_order_regions_test ()
ErrorCode mb_skin_adj_higher_order_regions_test ()
ErrorCode mb_skin_reversed_common (int dim, bool use_adj)
ErrorCode mb_skin_faces_reversed_test ()
ErrorCode mb_skin_adj_faces_reversed_test ()
ErrorCode mb_skin_regions_reversed_test ()
ErrorCode mb_skin_adj_regions_reversed_test ()
ErrorCode mb_skin_subset_common (int dimension, bool use_adj)
ErrorCode mb_skin_faces_subset_test ()
ErrorCode mb_skin_adj_faces_subset_test ()
ErrorCode mb_skin_regions_subset_test ()
ErrorCode mb_skin_adj_regions_subset_test ()
ErrorCode mb_skin_full_common (int dimension, bool use_adj)
ErrorCode mb_skin_faces_full_test ()
ErrorCode mb_skin_adj_faces_full_test ()
ErrorCode mb_skin_regions_full_test ()
ErrorCode mb_skin_adj_regions_full_test ()
ErrorCode mb_skin_adjacent_surf_patches ()
static ErrorCode get_by_all_types_and_tag (Interface *mb, EntityHandle meshset, const Tag *tag_handles, const void *const *values, int num_tags, Range &result, int condition, bool recursive)
ErrorCode mb_type_is_maxtype_test ()
ErrorCode mb_root_set_test ()
bool contained (const std::vector< EntityHandle > &list, EntityHandle h)
static void usage (const char *exe)
static int _run_test (TestFunc func, const char *func_str)
int main (int argc, char *argv[])
Variables
const char * argv0 = 0
int number_tests = 0
int number_tests_failed = 0
Define Documentation
#define ASSERT_EQUAL (   A,
Value:
do        \
        if( !_assert_equal( ( A ), ( B ), #A, #B, __LINE__ ) ) return MB_FAILURE; \
    } while( false )
Definition at line 5171 of file MBTest.cpp.
#define ASSERT_NOT_EQUAL (   A,
Value:
do        \
        if( !_assert_not_equal( ( A ), ( B ), #A, #B, __LINE__ ) ) return MB_FAILURE; \
    } while( false )
Definition at line 5177 of file MBTest.cpp.
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 70 of file MBTest.cpp.
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
MBTest.cpp Test Harness for MB mesh database system
Definition at line 52 of file MBTest.cpp.
#define RUN_TEST_ERR (   A)    _run_test( ( A ), #A )
Definition at line 7686 of file MBTest.cpp.
Referenced by main().
#define TEST_ERROR_CODE (   E)
Value:
if( mb->get_error_string( E ) != #E )        \
        std::cerr << "Invalid error string from get_error_string for " << #E << ": " << mb->get_error_string( E ) \
                  << std::endl;        \
Definition at line 5805 of file MBTest.cpp.
Referenced by mb_enum_string_test().
Definition at line 64 of file MBTest.cpp.
#define VINDEX (   i,
  j,
#define VINDEX (   i,
  j,
Typedef Documentation
typedef ErrorCode( * TestFunc)()
Definition at line 7688 of file MBTest.cpp.
Function Documentation
bool _assert_equal ( T1  a,
T2  b,
const char *  as,
const char *  bs,
int  line
Definition at line 5184 of file MBTest.cpp.
    if( a == b ) return true;
    std::cout << "Assertion failed at line " << line << std::endl
              << "\t" << as << " == " << bs << std::endl
              << "\t" << as << " = " << a << std::endl
              << "\t" << bs << " = " << b << std::endl;
    return false;
bool _assert_not_equal ( T1  a,
T2  b,
const char *  as,
const char *  bs,
int  line
Definition at line 5196 of file MBTest.cpp.
    if( a != b ) return true;
              << "\t" << as << " != " << bs << std::endl
    return false;
static int _run_test ( TestFunc  func,
const char *  func_str
) [static]
Definition at line 7689 of file MBTest.cpp.
References number_tests, and run_test().
    ++number_tests;
    return run_test( func, func_str );
ErrorCode check_esets ( Interface MB,
const int  num_sets
Definition at line 955 of file MBTest.cpp.
References ErrorCode, moab::Interface::get_number_entities_by_type(), MB_SUCCESS, and MBENTITYSET.
    int entity_sets_size;
    ErrorCode result = MB->get_number_entities_by_type( 0, MBENTITYSET, entity_sets_size );
    if( MB_SUCCESS != result || entity_sets_size != num_sets ) return MB_FAILURE;
    return MB_SUCCESS;
static ErrorCode check_list_meshset_internal ( const EntityHandle expected,
int  num_expected,
const EntityHandle contents,
int  length
) [static]
Definition at line 2379 of file MBTest.cpp.
References length(), and MB_SUCCESS.
Referenced by check_meshset_internal().
    bool okay = true;
    for( int i = 0; i < std::min( num_expected, length ); ++i )
        if( expected[i] != contents[i] )
            std::cerr << "List set contents differ at index " << i << ": expected " << expected[i] << " but got "
                      << contents[i] << std::endl;
            okay = false;
    if( num_expected > length )
        std::cerr << "List set is missing " << num_expected - length << "handles" << std::endl;
        okay = false;
    else if( length > num_expected )
        std::cerr << "List set has " << num_expected - length << " extra handles" << std::endl;
        okay = false;
    if( okay ) return MB_SUCCESS;
    std::cerr << "Expected contents: ";
    if( !num_expected )
        std::cerr << "(empty)";
    else
        std::cerr << expected[0];
    for( int i = 1; i < num_expected; ++i )
        std::cerr << ", " << expected[i];
    std::cerr << std::endl;
    std::cerr << "Actual contents: ";
    if( !length )
    else
        std::cerr << contents[0];
    for( int i = 1; i < length; ++i )
        std::cerr << ", " << contents[i];
    return MB_FAILURE;
static ErrorCode check_meshset_internal ( Interface mb,
EntityHandle  set,
int  num_expected
) [static]
Definition at line 2541 of file MBTest.cpp.
References check_list_meshset_internal(), check_ranged_meshset_internal(), ErrorCode, moab::WriteUtilIface::get_entity_list_pointers(), length(), MB_CHK_ERR, MB_SUCCESS, moab::Interface::query_interface(), and moab::Interface::release_interface().
Referenced by mb_mesh_set_set_add_remove_test().
    ErrorCode rval;
    WriteUtilIface* tool = 0;
    rval                 = mb.query_interface( tool );MB_CHK_ERR( rval );
    const EntityHandle* contents;
    int length;
    unsigned char flags;
    rval = tool->get_entity_list_pointers( &set, 1, &contents, WriteUtilIface::CONTENTS, &length, &flags );MB_CHK_ERR( rval );
    ErrorCode rval1 = mb.release_interface( tool );MB_CHK_ERR( rval1 );
    if( flags & MESHSET_ORDERED )
        rval = check_list_meshset_internal( expected, num_expected, contents, length );
    else
        rval = check_ranged_meshset_internal( expected, num_expected, contents, length );MB_CHK_ERR( rval );
    return MB_SUCCESS;
static ErrorCode check_ranged_meshset_internal ( const EntityHandle expected,
int  num_expected,
int  length
) [static]
Definition at line 2431 of file MBTest.cpp.
    if( length % 2 )
        std::cerr << "Range set is corrupt.  Odd number of handles in content list" << std::endl;
        std::cerr << "Actual contents: " << contents[0];
        return MB_FAILURE;
    bool okay = true;
    // check that all range pairs are valid (first handle less than or
    // equal to second)
    for( int i = 0; i < length; i += 2 )
        if( contents[i] > contents[i + 1] )
            std::cerr << "Range set has invalid range pair at index " << i << ": [" << contents[i] << ','
                      << contents[i + 1] << ']' << std::endl;
            okay = false;
    // check that all range pairs are sorted and non-overlapping
    // (start of a range must be greater than end of previous range)
    for( int i = 2; i < length; i += 2 )
        if( contents[i] < contents[i - 1] )
            std::cerr << "Range set has incorrectly ordered ranges at index " << i << ": [...," << contents[i - 1]
                      << "], [" << contents[i] << ",...]" << std::endl;
            okay = false;
        if( contents[i] == contents[i - 1] + 1 )
            std::cerr << "Range set has pairs that should have been merged at index " << i << ": [...,"
                      << contents[i - 1] << "], [" << contents[i] << ",...]" << std::endl;
            okay = false;
    if( !okay )
        if( !length )
        else
            std::cerr << '[' << contents[0] << ',' << contents[1] << ']';
            std::cerr << ", [" << contents[i] << ',' << contents[i + 1] << ']';
        return MB_FAILURE;
    int j = 0;
        for( ; j < num_expected && expected[j] < contents[i]; ++j )
            std::cerr << "Range set missing expected handle: " << expected[j] << std::endl;
            okay = false;
        int k = j;
        while( k < num_expected && expected[k] <= contents[i + 1] )
            ++k;
        if( (EntityHandle)( k - j ) <= ( contents[i + 1] - contents[i] ) )
            std::cerr << "Handle range [" << contents[i] << ',' << contents[i + 1]
                      << "] contains unexpected handles.  Expected handles: ";
            if( k == j )
                std::cerr << "(none)" << std::endl;
            else
                std::cerr << expected[j];
                for( ++j; j < k; ++j )
                    std::cerr << ", " << expected[j];
            okay = false;
        j = k;
    if( !num_expected )
    else
    if( !length )
    else
    return MB_FAILURE;
Definition at line 7635 of file MBTest.cpp.
References moab::Range::clear(), conn, contained(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), moab::ID_FROM_HANDLE(), MB_CHK_ERR, MB_SUCCESS, MBVERTEX, and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    // get sorted array of vertex handles so that we can
    // check that all vertices in connectivity are valid
    // handles
    std::vector< EntityHandle > vertices, storage;
    rval = iface->get_entities_by_type( 0, MBVERTEX, vertices );MB_CHK_ERR( rval );
    std::sort( vertices.begin(), vertices.end() );
    // get all the elements
    Range elements, tmp;
    for( int d = 1; d < 4; ++d )
        tmp.clear();
        rval = iface->get_entities_by_dimension( 0, d, tmp );MB_CHK_ERR( rval );
        elements.merge( tmp );
    // check that all connectivity handles are valid
    Range::iterator it;
    ErrorCode result = MB_SUCCESS;
    for( it = elements.begin(); it != elements.end(); ++it )
        const EntityHandle* conn;
        int len;
        rval = iface->get_connectivity( *it, conn, len, false, &storage );MB_CHK_ERR( rval );
        for( int i = 0; i < len; ++i )
            if( !contained( vertices, conn[i] ) )
                printf( "Invalid handle (%s %d) in connectivity of %s %d\n",
                        CN::EntityTypeName( TYPE_FROM_HANDLE( conn[i] ) ), (int)ID_FROM_HANDLE( conn[i] ),
                        CN::EntityTypeName( TYPE_FROM_HANDLE( *it ) ), (int)ID_FROM_HANDLE( *it ) );
                result = MB_FAILURE;
    return result;
static bool compare_lists ( std::vector< EntityHandle vect,
const EntityHandle array,
int  count,
bool  ordered = true
) [static]
Definition at line 1365 of file MBTest.cpp.
Referenced by mb_mesh_set_parent_child_test().
    if( vect.size() != (size_t)count ) return false;
    for( int i = 0; i < count; ++i )
        if( ordered )
            if( vect[i] != array[i] ) return false;
        else if( std::find( vect.begin(), vect.end(), array[i] ) == vect.end() )
            return false;
    return true;
bool contained ( const std::vector< EntityHandle > &  list,
EntityHandle  h
) [inline]
Definition at line 7628 of file MBTest.cpp.
Referenced by check_valid_connectivity(), dot_contained(), main(), moab::MeshSetSequence::num_contained_sets(), and set_remove_contained_regression().
    std::vector< EntityHandle >::const_iterator i;
    i = std::lower_bound( list.begin(), list.end(), h );
    return i != list.end() && *i == h;
Definition at line 7592 of file MBTest.cpp.
References conn, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MB_SUCCESS, MBHEX, and u.
Referenced by mb_adjacent_vertex_test(), mb_bit_tags_test(), mb_common_tag_test(), mb_mesh_set_appends(), mb_mesh_sets_test(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), and mb_vertex_tag_test().
    const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0,
                              0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1,
                              0, 0, 2, 1, 0, 2, 2, 0, 2, 0, 1, 2, 1, 1, 2, 2, 1, 2, 0, 2, 2, 1, 2, 2, 2, 2, 2 };
    const size_t num_vtx  = sizeof( coords ) / sizeof( double ) / 3;
    assert( num_vtx == 27u );
    const int conn[]      = { 0,  1,  4,  3,  9,  10, 13, 12, 1,  2,  5,  4,  10, 11, 14, 13, 3,  4,  7,  6,  12, 13,
                         16, 15, 4,  5,  8,  9,  13, 14, 17, 16, 9,  10, 13, 12, 18, 19, 22, 21, 10, 11, 14, 13,
                         19, 20, 23, 22, 12, 13, 16, 15, 21, 22, 25, 24, 13, 14, 17, 18, 22, 23, 26, 25 };
    const size_t num_elem = sizeof( conn ) / sizeof( conn[0] ) / 8;
    assert( num_elem == 8u );
    EntityHandle verts[num_vtx], hexes[num_elem];
    for( size_t i = 0; i < num_vtx; ++i )
        ErrorCode err = iface->create_vertex( coords + 3 * i, verts[i] );
        if( MB_SUCCESS != err ) return err;
    for( size_t i = 0; i < num_elem; ++i )
        EntityHandle c[8];
        for( int j = 0; j < 8; ++j )
            assert( conn[8 * i + j] < (int)num_vtx );
            c[j] = verts[conn[8 * i + j]];
        ErrorCode err = iface->create_element( MBHEX, c, 8, hexes[i] );
    return MB_SUCCESS;
static ErrorCode create_two_hex_full_mesh ( Interface mb,
) [static]
Definition at line 686 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MB_SUCCESS, MBEDGE, MBHEX, and MBQUAD.
Referenced by mb_upward_adjacencies_test().
    ErrorCode rval;
    // create a simple mesh containing 2 hexes
                              0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1 };
    for( int i = 0; i < 12; ++i )
        if( MB_SUCCESS != mb->create_vertex( coords + 3 * i, vertices[i] ) ) return MB_FAILURE;
    EntityHandle hex1_conn[]           = { vertices[6], vertices[7],  vertices[1], vertices[0],
                                 vertices[9], vertices[10], vertices[4], vertices[3] };
    EntityHandle hex2_conn[]           = { vertices[7],  vertices[8],  vertices[2], vertices[1],
                                 vertices[10], vertices[11], vertices[5], vertices[4] };
    EntityHandle shared_quad_conn[]    = { vertices[7], vertices[1], vertices[4], vertices[10] };
    EntityHandle hex1_face_conn[][4]   = { { vertices[6], vertices[7], vertices[10], vertices[9] },
                                         { vertices[7], vertices[6], vertices[0], vertices[1] },
                                         { vertices[1], vertices[0], vertices[3], vertices[4] },
                                         { vertices[9], vertices[10], vertices[4], vertices[3] },
                                         { vertices[3], vertices[0], vertices[6], vertices[9] } };
    EntityHandle hex2_face_conn[][4]   = { { vertices[7], vertices[8], vertices[11], vertices[10] },
                                         { vertices[8], vertices[7], vertices[1], vertices[2] },
                                         { vertices[2], vertices[1], vertices[4], vertices[5] },
                                         { vertices[10], vertices[11], vertices[5], vertices[4] },
                                         { vertices[5], vertices[2], vertices[8], vertices[11] } };
    EntityHandle shared_edge_conn[][2] = { { vertices[1], vertices[7] },
                                           { vertices[7], vertices[10] },
                                           { vertices[10], vertices[4] },
                                           { vertices[4], vertices[1] } };
    EntityHandle hex1_edge_conn[][2]   = { { vertices[6], vertices[7] }, { vertices[9], vertices[10] },
                                         { vertices[3], vertices[4] }, { vertices[0], vertices[1] },
                                         { vertices[6], vertices[9] }, { vertices[9], vertices[3] },
                                         { vertices[3], vertices[0] }, { vertices[0], vertices[6] } };
    EntityHandle hex2_edge_conn[][2]   = { { vertices[7], vertices[8] },  { vertices[10], vertices[11] },
                                         { vertices[4], vertices[5] },  { vertices[1], vertices[2] },
                                         { vertices[8], vertices[11] }, { vertices[11], vertices[5] },
                                         { vertices[5], vertices[2] },  { vertices[2], vertices[8] } };
    rval                               = mb->create_element( MBHEX, hex1_conn, 8, hexes[0] );
    if( MB_SUCCESS != rval ) return rval;
    rval = mb->create_element( MBHEX, hex2_conn, 8, hexes[1] );
    rval = mb->create_element( MBQUAD, shared_quad_conn, 4, hex1_faces[0] );
    hex2_faces[0] = hex1_faces[0];
    for( int i = 0; i < 5; ++i )
        rval = mb->create_element( MBQUAD, hex1_face_conn[i], 4, hex1_faces[i + 1] );
        rval = mb->create_element( MBQUAD, hex2_face_conn[i], 4, hex2_faces[i + 1] );
    for( int i = 0; i < 4; ++i )
        rval = mb->create_element( MBEDGE, shared_edge_conn[i], 2, hex1_edges[i] );
        hex2_edges[i] = hex1_edges[i];
    for( int i = 0; i < 8; ++i )
        rval = mb->create_element( MBEDGE, hex1_edge_conn[i], 2, hex1_edges[i + 4] );
        rval = mb->create_element( MBEDGE, hex2_edge_conn[i], 2, hex2_edges[i + 4] );
    return MB_SUCCESS;
ErrorCode find_coincident_elements ( Interface gMB,
const Range entities,
int  num_nodes,
std::vector< std::pair< EntityHandle, EntityHandle > > &  coin
Definition at line 3690 of file MBTest.cpp.
References moab::Range::begin(), conn, moab::Range::end(), moab::GeomUtil::first(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), MB_SUCCESS, and points_are_coincident().
Referenced by coincident_counts(), merge_2D_elem(), merge_3D_elem(), merge_top_down(), and process_td_auto_merge().
    double coords1[8][3], coords2[8][3];
    Range::iterator iter, jter;
    std::vector< EntityHandle > conn( 8 );
    std::pair< EntityHandle, EntityHandle > coincident_pair;
    int i = 0, /* j = 0,*/ ii = 0;
    for( iter = entities.begin(); iter != entities.end(); ++iter )
        // Get the coordinates for the element corners.
        if( gMB->get_connectivity( &( *iter ), 1, conn ) != MB_SUCCESS ) return MB_FAILURE;
        for( ii = 0; ii < num_nodes; ii++ )
            if( gMB->get_coords( &( conn[ii] ), 1, coords1[ii] ) != MB_SUCCESS ) return MB_FAILURE;
        for( jter = iter; jter != entities.end(); ++jter )
            if( *iter != *jter )
                // Elements should be the same sense to merge.
                if( gMB->get_connectivity( &( *jter ), 1, conn ) != MB_SUCCESS ) return MB_FAILURE;
                for( int tq = 0; tq < num_nodes; tq++ )
                    if( gMB->get_coords( &( conn[tq] ), 1, coords2[tq] ) != MB_SUCCESS ) return MB_FAILURE;
                //        if(gMB->get_coords(&(conn[0]), 1,  coords2[0]) != MB_SUCCESS)
                //          return MB_FAILURE;
                // Find if first node is coincident before testing the rest.
                bool first = false;
                for( i = 0; i < num_nodes; i++ )
                    if( points_are_coincident( coords1[i], coords2[0] ) )
                        /*      cout <<"first("<<i<<",0) - ";
                                        cout <<" coords1["<<i<<"] = ("
                                        <<coords1[i][0]<<","
                                        <<coords1[i][1]<<","
                                        <<coords1[i][2]<<") ";
                                        cout <<" coords2["<<0<<"] = ("
                                        <<coords2[0][0]<<","
                                        <<coords2[0][1]<<","
                                        <<coords2[0][2]<<")\n";*/
                        first = true;
                        break;
                // TEST -- Find if second node is coincident before testing the rest.
                bool second = false;
                for( int t2 = 0; t2 < num_nodes; t2++ )
                    if( points_are_coincident( coords1[t2], coords2[1] ) )
                        /*      cout <<"second("<<t2<<",1) - ";
                                        cout <<" coords1["<<t2<<"] = ("
                                        <<coords1[t2][0]<<","
                                        <<coords1[t2][1]<<","
                                        <<coords1[t2][2]<<") ";
                                        cout <<" coords2["<<1<<"] = ("
                                        <<coords2[1][0]<<","
                                        <<coords2[1][1]<<","
                                        <<coords2[1][2]<<")\n";*/
                        second = true;
                        break;
                bool third = false;
                for( int ti = 0; ti < num_nodes; ti++ )
                    if( points_are_coincident( coords1[ti], coords2[2] ) )
                        /*      cout <<"third("<<ti<<",2) - ";
                                        cout <<" coords1["<<ti<<"] = ("
                                        <<coords1[ti][0]<<","
                                        <<coords1[ti][1]<<","
                                        <<coords1[ti][2]<<") ";
                                        <<coords2[2][0]<<","
                                        <<coords2[2][1]<<","
                                        <<coords2[2][2]<<")\n";*/
                        third = true;
                        break;
                if( ( first ) && ( second ) && ( third ) )
                    cout << "i = " << i << "\n";
                    for( int tii = 0; tii < num_nodes; tii++ )
                        cout << " coords1[" << tii << "] = (" << coords1[tii][0] << "," << coords1[tii][1] << ","
                             << coords1[tii][2] << ") ";
                        cout << " coords2[" << tii << "] = (" << coords2[tii][0] << "," << coords2[tii][1] << ","
                             << coords2[tii][2] << ")\n";
                if( i < num_nodes )
                    for( ii = 1; ii < num_nodes; ii++ )
                        if( gMB->get_coords( &( conn[ii] ), 1, coords2[ii] ) != MB_SUCCESS ) return MB_FAILURE;
                            for(j=1; j<num_nodes; j++)
                            if(!points_are_coincident(coords1[j], coords2[(j+i)%num_nodes]))
                            break;
                            if(j == num_nodes)*/
                        coincident_pair.first  = *iter;
                        coincident_pair.second = *jter;
                        coin.push_back( coincident_pair );
    return MB_SUCCESS;
ErrorCode find_coincident_nodes ( Interface gMB,
const Range vertices,
std::vector< std::pair< EntityHandle, EntityHandle > > &  coin_nodes
Definition at line 3657 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), MB_SUCCESS, and points_are_coincident().
Referenced by coincident_counts(), merge_nodes(), process_bu_auto_merge(), process_mo_auto_merge(), and process_td_auto_merge().
    double first_coords[3], second_coords[3];
    Range::const_iterator iter, jter;
    ErrorCode result;
    for( iter = vertices.begin(); iter != vertices.end(); ++iter )
        result = gMB->get_coords( &( *iter ), 1, first_coords );
        if( result != MB_SUCCESS ) return result;
        for( jter = iter; jter != vertices.end(); ++jter )
                result = gMB->get_coords( &( *jter ), 1, second_coords );
                if( points_are_coincident( first_coords, second_coords ) )
                    coin_nodes.push_back( coincident_pair );
    return MB_SUCCESS;
static ErrorCode get_by_all_types_and_tag ( Interface mb,
const Tag tag_handles,
const void *const *  values,
int  num_tags,
Range result,
int  condition,
bool  recursive
) [static]
Definition at line 7177 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_SUCCESS, MBENTITYSET, MBMAXTYPE, MBVERTEX, and t.
Referenced by mb_type_is_maxtype_test().
    ErrorCode rval;
    Range tmp;
    const EntityType LAST = recursive ? MBENTITYSET : MBMAXTYPE;
    for( EntityType t = MBVERTEX; t < LAST; ++t )
        tmp.clear();
        rval = mb->get_entities_by_type_and_tag( meshset, t, tag_handles, values, num_tags, tmp, condition, recursive );
        result.insert( tmp.begin(), tmp.end() );
    return MB_SUCCESS;
int main ( int  argc,
char *  argv[]
main routine for test harness
Definition at line 7698 of file MBTest.cpp.
References fail(), mb_adjacencies_create_delete_test(), mb_adjacent_create_test(), mb_adjacent_vertex_test(), mb_bit_tags_test(), mb_canon_number_test(), mb_dense_tag_test(), mb_enum_string_test(), mb_forced_adjacencies_test(), mb_higher_order_test(), mb_memory_use_test(), mb_merge_update_test(), mb_mesh_set_flag_test(), mb_mesh_set_list_appends(), mb_mesh_set_list_replace_test(), mb_mesh_set_parent_child_test(), mb_mesh_set_root_appends(), mb_mesh_set_set_add_remove_test(), mb_mesh_set_set_appends(), mb_mesh_set_set_replace_test(), mb_mesh_sets_list_test(), mb_mesh_sets_set_test(), mb_poly_adjacency_test(), mb_poly_adjacency_test2(), mb_poly_test(), mb_range_seq_intersect_test(), mb_read_fail_test(), mb_root_set_test(), mb_side_number_test(), mb_skin_adj_faces_full_test(), mb_skin_adj_faces_reversed_test(), mb_skin_adj_faces_subset_test(), mb_skin_adj_higher_order_faces_test(), mb_skin_adj_higher_order_regions_test(), mb_skin_adj_regions_full_test(), mb_skin_adj_regions_reversed_test(), mb_skin_adj_regions_subset_test(), mb_skin_adjacent_surf_patches(), mb_skin_curve_adj_test(), mb_skin_curve_test(), mb_skin_faces_full_test(), mb_skin_faces_reversed_test(), mb_skin_faces_subset_test(), mb_skin_fileset_test(), mb_skin_higher_order_faces_test(), mb_skin_higher_order_regions_test(), mb_skin_poly_test(), mb_skin_regions_full_test(), mb_skin_regions_reversed_test(), mb_skin_regions_subset_test(), mb_skin_scd_test(), mb_skin_surf_verts_elems_test(), mb_skin_surf_verts_test(), mb_skin_surface_adj_test(), mb_skin_surface_test(), mb_skin_vol_verts_elems_test(), mb_skin_vol_verts_test(), mb_skin_volume_adj_test(), mb_skin_volume_test(), mb_sparse_tag_test(), mb_split_test(), mb_temporary_test(), mb_topo_util_test(), mb_type_is_maxtype_test(), mb_upward_adjacencies_test(), mb_vertex_coordinate_test(), mb_vertex_tag_test(), number_tests_failed, RUN_TEST_ERR, and usage.
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#endif
    argv0 = argv[0];
    // Check command line arg to see if we should avoid doing the stress test
#ifdef MOAB_HAVE_NETCDF
    bool stress_test = true;
#endif
    std::cout << "Size of mConnMap = " << sizeof( CN::mConnectivityMap ) << std::endl;
    std::cout << "Size of mUpConnMap = " << sizeof( CN::mUpConnMap ) << std::endl;
    std::cout << "Size of CN = " << sizeof( CN ) << std::endl;
    for( int i = 1; i < argc; ++i )
        if( string( argv[i] ) == "-h" || string( argv[i] ) == "--help" ) usage( argv[0] );
#if MOAB_HAVE_NETCDF
        else if( string( argv[i] ) == "-nostress" )
            stress_test = false;
#endif
        else
            cerr << "Invalid argument: " << argv[i] << endl;
            usage( argv[0] );
    // Print out Header information
    cout << "\n\nMOAB Comprehensive test suite:\n\n";
    number_tests = number_tests_failed = 0;
    number_tests_failed += RUN_TEST_ERR( mb_adjacent_vertex_test );
    number_tests_failed += RUN_TEST_ERR( mb_adjacencies_create_delete_test );
    number_tests_failed += RUN_TEST_ERR( mb_upward_adjacencies_test );
    number_tests_failed += RUN_TEST_ERR( mb_adjacent_create_test );
    number_tests_failed += RUN_TEST_ERR( mb_vertex_coordinate_test );
    number_tests_failed += RUN_TEST_ERR( mb_vertex_tag_test );
    number_tests_failed += RUN_TEST_ERR( mb_temporary_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_sets_set_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_sets_list_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_parent_child_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_set_appends );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_list_appends );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_root_appends );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_set_replace_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_list_replace_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_flag_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_set_add_remove_test );
    number_tests_failed += RUN_TEST_ERR( mb_dense_tag_test );
    number_tests_failed += RUN_TEST_ERR( mb_sparse_tag_test );
    number_tests_failed += RUN_TEST_ERR( mb_higher_order_test );
    number_tests_failed += RUN_TEST_ERR( mb_bit_tags_test );
    number_tests_failed += RUN_TEST_ERR( mb_adjacencies_test );
    number_tests_failed += RUN_TEST_ERR( mb_tags_test );
    number_tests_failed += RUN_TEST_ERR( mb_delete_mesh_test );
    number_tests_failed += RUN_TEST_ERR( mb_entity_conversion_test );
    number_tests_failed += RUN_TEST_ERR( mb_mesh_set_tracking_test );
#endif
    number_tests_failed += RUN_TEST_ERR( mb_forced_adjacencies_test );
    number_tests_failed += RUN_TEST_ERR( mb_canon_number_test );
    number_tests_failed += RUN_TEST_ERR( mb_side_number_test );
    number_tests_failed += RUN_TEST_ERR( mb_poly_test );
    number_tests_failed += RUN_TEST_ERR( mb_topo_util_test );
    number_tests_failed += RUN_TEST_ERR( mb_split_test );
    number_tests_failed += RUN_TEST_ERR( mb_range_seq_intersect_test );
    number_tests_failed += RUN_TEST_ERR( mb_poly_adjacency_test );
    number_tests_failed += RUN_TEST_ERR( mb_poly_adjacency_test2 );
    number_tests_failed += RUN_TEST_ERR( mb_memory_use_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_curve_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_curve_adj_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_surface_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_surface_adj_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_volume_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_volume_adj_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_surf_verts_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_vol_verts_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_surf_verts_elems_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_vol_verts_elems_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_poly_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_higher_order_faces_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_higher_order_regions_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_higher_order_faces_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_higher_order_regions_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_faces_reversed_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_faces_reversed_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_regions_reversed_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_regions_reversed_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_faces_subset_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_faces_subset_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_regions_subset_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_regions_subset_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_faces_full_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_faces_full_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_regions_full_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adj_regions_full_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_adjacent_surf_patches );
    number_tests_failed += RUN_TEST_ERR( mb_skin_scd_test );
    number_tests_failed += RUN_TEST_ERR( mb_skin_fileset_test );
    number_tests_failed += RUN_TEST_ERR( mb_read_fail_test );
    number_tests_failed += RUN_TEST_ERR( mb_enum_string_test );
    number_tests_failed += RUN_TEST_ERR( mb_merge_update_test );
    number_tests_failed += RUN_TEST_ERR( mb_type_is_maxtype_test );
    number_tests_failed += RUN_TEST_ERR( mb_root_set_test );
    number_tests_failed += RUN_TEST_ERR( mb_merge_test );
    if( stress_test ) number_tests_failed += RUN_TEST_ERR( mb_stress_test );
#endif
    // summary
    cout << "\nMB TEST SUMMARY: \n"
         << "   Number Tests:           " << number_tests << "\n"
         << "   Number Successful:      " << number_tests - number_tests_failed << "\n"
         << "   Number Failed:          " << number_tests_failed << "\n\n";
    fail = MPI_Finalize();
#endif
    return number_tests_failed;
Definition at line 615 of file MBTest.cpp.
References moab::Range::begin(), moab::Interface::create_element(), moab::Interface::create_vertices(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, MBEDGE, MBTRI, and moab::Range::size().
    Core moab;
    Interface* mb = &moab;
    ErrorCode rval;
    double coords[] = { 0, 0, 0, 2, 0, 0, 1, 2, 0 };
    Range verts;
    rval = mb->create_vertices( coords, 3, verts );
    if( verts.size() != 3 ) return MB_FAILURE;
    EntityHandle vert_arr[3];
    EntityHandle tri;
    std::copy( verts.begin(), verts.end(), vert_arr );
    rval = mb->create_element( MBTRI, vert_arr, 3, tri );
    vert_arr[2] = vert_arr[0];
    EntityHandle forward_edge, reverse_edge;
    rval = mb->create_element( MBEDGE, vert_arr, 2, forward_edge );
    std::vector< EntityHandle > results;
    rval = mb->get_adjacencies( &forward_edge, 1, 2, false, results );
    if( results.size() != 1 || results.front() != tri )
        std::cerr << "Adjacency query from forward edge to tri failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    results.clear();
    rval = mb->get_adjacencies( &tri, 1, 1, false, results );
    if( results.size() != 1 || results.front() != forward_edge )
        std::cerr << "Adjacency query from tri to forward edge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    rval = mb->delete_entities( &forward_edge, 1 );
    results.clear();
    if( !results.empty() )
        std::cerr << "Adjacency query from tri returned non-existent edge at " << __FILE__ << ":" << __LINE__
                  << std::endl;
        return MB_FAILURE;
    rval = mb->create_element( MBEDGE, vert_arr + 1, 2, reverse_edge );
    results.clear();
    rval = mb->get_adjacencies( &reverse_edge, 1, 2, false, results );
        std::cerr << "Adjacency query from reverse edge to tri failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    results.clear();
    if( results.size() != 1 || results.front() != reverse_edge )
        std::cerr << "Adjacency query from tri to reverse edge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 870 of file MBTest.cpp.
References CHECK, CHECK_EQUAL, conn, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MBMesquite::faces, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), MB_CHK_ERR, MB_SUCCESS, MBHEX, and smoab::UNION.
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    // create vertices
    const double coords[][3] = { { -0.5, -0.5, 0.5 }, { -0.5, -0.5, -0.5 }, { -0.5, 0.5, -0.5 }, { -0.5, 0.5, 0.5 },
                                 { 0.5, -0.5, 0.5 },  { 0.5, -0.5, -0.5 },  { 0.5, 0.5, -0.5 },  { 0.5, 0.5, 0.5 } };
    EntityHandle verts[8]    = { 0 };
        rval = mb.create_vertex( coords[i], verts[i] );MB_CHK_ERR( rval );
    // create a single hex
    const EntityHandle hconn[8] = { verts[0], verts[1], verts[2], verts[3], verts[4], verts[5], verts[6], verts[7] };
    EntityHandle hex;
    rval = mb.create_element( MBHEX, hconn, 8, hex );MB_CHK_ERR( rval );
    // create hex faces
    std::vector< EntityHandle > quads;
    rval = mb.get_adjacencies( &hex, 1, 2, true, quads, Interface::UNION );MB_CHK_ERR( rval );
    CHECK_EQUAL( (size_t)6, quads.size() );
    // check that we got each of the 6 expected faces, with outwards
    // normals assuming CCW order and correct connectivity
    const EntityHandle faces[6][4] = {
        { verts[0], verts[1], verts[5], verts[4] }, { verts[1], verts[2], verts[6], verts[5] },
        { verts[2], verts[3], verts[7], verts[6] }, { verts[3], verts[0], verts[4], verts[7] },
        { verts[3], verts[2], verts[1], verts[0] }, { verts[4], verts[5], verts[6], verts[7] } };
    for( int i = 0; i < 6; ++i )
    {  // for each expected face
        // get sorted list of verts first for easy comparison
        std::vector< EntityHandle > exp_sorted( 4 );
        std::copy( faces[i], faces[i] + 4, exp_sorted.begin() );
        std::sort( exp_sorted.begin(), exp_sorted.end() );
        // search for matching face in output
        int j = 0;
        std::vector< EntityHandle > conn;
        for( ; j < 6; ++j )
            conn.clear();
            rval = mb.get_connectivity( &quads[j], 1, conn );MB_CHK_ERR( rval );
            CHECK_EQUAL( (size_t)4, conn.size() );
            std::vector< EntityHandle > sorted( conn );
            std::sort( sorted.begin(), sorted.end() );
            if( sorted == exp_sorted ) break;
        if( j == 6 )
            std::cerr << "No adjacent face matching hex face " << i << std::endl;
            CHECK( j < 6 );
        // check order
        int k = std::find( conn.begin(), conn.end(), faces[i][0] ) - conn.begin();
        for( j = 1; j < 4; ++j )
            if( faces[i][j] != conn[( j + k ) % 4] ) break;
        if( j != 4 )
            std::cerr << "Incorrect vertex order for hex face " << i << std::endl;
            std::cerr << "Expected: " << faces[i][0] << ", " << faces[i][1] << ", " << faces[i][2] << ", "
                      << faces[i][3] << std::endl;
            std::cerr << "Actual:   " << conn[0] << ", " << conn[1] << ", " << conn[2] << ", " << conn[3] << std::endl;
            CHECK( false );
    return MB_SUCCESS;
Definition at line 418 of file MBTest.cpp.
References moab::Range::begin(), conn, create_some_mesh(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Range::insert(), mb, MB_SUCCESS, MBHEX, n, and smoab::UNION.
    Core moab;
    ErrorCode rval = create_some_mesh( mb );
    Range hexes, expt_vert, got_vert, some_hexes;
    Range::const_iterator i, j;
    int n;
    // get all hexes
    rval = mb->get_entities_by_type( 0, MBHEX, hexes );
    if( rval != MB_SUCCESS ) return rval;
    if( hexes.empty() )  // can't do test if no elements
        return MB_FAILURE;
    // get every third hex and its vertices
    n = 0;
    for( i = hexes.begin(); i != hexes.end(); ++i )
        if( ++n % 3 ) continue;
        some_hexes.insert( *i );
        int len;
        rval = mb->get_connectivity( *i, conn, len );
        for( int k = 0; k < len; ++k )
            expt_vert.insert( conn[k] );
    // use get_adjacencies to get vertices
    rval = mb->get_adjacencies( some_hexes, 0, false, got_vert, Interface::UNION );
        std::cout << "get_adjacencies failed with error code " << rval << std::endl;
        return rval;
    i = expt_vert.begin();
    j = got_vert.begin();
    while( i != expt_vert.end() && j != got_vert.end() )
        if( *i < *j )
            std::cout << "Result missing vertex: " << *i << std::endl;
            return MB_FAILURE;
        else if( *j < *i )
            std::cout << "Result contains extra vertex: " << *j << std::endl;
            return MB_FAILURE;
        ++i;
        ++j;
    if( i != expt_vert.end() )
        return MB_FAILURE;
    else if( j != got_vert.end() )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 2758 of file MBTest.cpp.
References moab::Range::begin(), create_some_mesh(), moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_type(), MB_SUCCESS, MB_TAG_CREAT, MB_TYPE_BIT, MBVERTEX, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    Core moab;
    Interface* MB     = &moab;
    ErrorCode success = create_some_mesh( MB );
    if( MB_SUCCESS != success ) return success;
    Tag bit_tag;
    Range entities;
    MB->get_entities_by_type( 0, MBVERTEX, entities );
    if( MB->tag_get_handle( "bit on vertex", 3, MB_TYPE_BIT, bit_tag, MB_TAG_CREAT ) != MB_SUCCESS )
        cout << "couldn't create bit tag" << endl;
        return MB_FAILURE;
    Range::iterator iter;
    unsigned char bits;
        // tag each vertex with the low 3 bits of the entity handle
        bits    = ( ( *iter ) & 0x7 );
        success = MB->tag_set_data( bit_tag, &( *iter ), 1, &bits );
        if( success != MB_SUCCESS ) return MB_FAILURE;
    bits = 0;
        success = MB->tag_get_data( bit_tag, &( *iter ), 1, &bits );
        if( bits != ( ( *iter ) & 0x7 ) ) return MB_FAILURE;
    // test range-based query for all vertices
    std::vector< unsigned char > data( entities.size() );
    success = MB->tag_get_data( bit_tag, entities, &data[0] );
    std::vector< unsigned char >::iterator i = data.begin();
    for( iter = entities.begin(); iter != entities.end(); ++iter, ++i )
        if( *i != ( ( *iter ) & 0x7 ) ) return MB_FAILURE;
    // test vector-based query for all vertices
    std::vector< EntityHandle > verts( entities.begin(), entities.end() );
    success = MB->tag_get_data( bit_tag, &verts[0], verts.size(), &data[0] );
    i = data.begin();
    // test default value
    const unsigned char default_bits = '\005';  // 0000 0101
    Tag tag2;
    success = MB->tag_get_handle( "bit with default", 4, MB_TYPE_BIT, tag2, MB_TAG_CREAT, &default_bits );
        cout << "Failed to create bit tag with default value" << std::endl;
        return success;
    // set value to zero on a single vertex
    bits            = 0;
    EntityHandle zh = verts[verts.size() / 2];
    success         = MB->tag_set_data( tag2, &zh, 1, &bits );
    // get tag values for all entities
    data.clear();
    data.resize( verts.size(), 0x7A );  // initialize with 0111 1010
    success = MB->tag_get_data( tag2, entities, &data[0] );
    // check values
    i = data.begin();
        if( *iter == zh && *i )  // the one we set to zero
            return MB_FAILURE;
        else if( *iter != zh && *i != default_bits )
            return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 4177 of file MBTest.cpp.
References moab::CN::ConnMap::conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), dim, ErrorCode, moab::Interface::get_connectivity(), moab::MAX_SUB_ENTITY_VERTICES, MB_SUCCESS, MBEDGE, MBKNIFE, MBPOLYGON, and MBPOLYHEDRON.
    Core moab;
    // various tests for canonical ordering
    // CN::AdjacentSubEntities
    std::vector< int > vec1, vec2;
    ErrorCode result;
    EntityType this_type;
    for( this_type = MBEDGE; this_type != MBKNIFE; this_type++ )
        for( int i = 0; i < CN::VerticesPerEntity( this_type ); i++ )
            // test for edges and faces
            for( int dim = 1; dim <= CN::Dimension( this_type ); dim++ )
                // get the sides adjacent to this vertex
                vec1.clear();
                int temp_result = CN::AdjacentSubEntities( this_type, &i, 1, 0, dim, vec1 );
                if( 0 != temp_result || vec1.size() > (unsigned int)CN::NumSubEntities( this_type, dim ) )
                    cout << "failed getting sides for type " << CN::EntityTypeName( this_type ) << " dimension" << dim
                         << endl;
                    return MB_FAILURE;
                // now get the vertices shared by these sides
                vec2.clear();
                temp_result = CN::AdjacentSubEntities( this_type, &vec1[0], vec1.size(), dim, 0, vec2 );
                // vertex side recovered should be i
                    // if dimension is same as DIMENSION(this_type), will get back all the
                    // vertices in the entity
                    ( dim == CN::Dimension( this_type ) &&
                      vec2.size() != (unsigned int)CN::VerticesPerEntity( this_type ) ) ||
                    // otherwise, we should get back only one vertex, and it should be the one
                    // we started with
                    ( dim != CN::Dimension( this_type ) && ( vec2.size() != 1 || vec2[0] != i ) ) )
                    cout << "traversal from verts to sides to verts failed for " << endl
                         << "vertex " << i << " type " << CN::EntityTypeName( this_type ) << " dimension " << dim
                         << endl;
                    return MB_FAILURE;
    // CN::side_number
    // create vertices to use later
    double xyz[3] = { 0.0, 0.0, 0.0 };
    EntityHandle vertex_handles[8];
    for( int i = 0; i < 8; i++ )
        result = MB->create_vertex( xyz, vertex_handles[i] );
        assert( result == MB_SUCCESS );
    int side, sense, offset;
    EntityHandle this_entity;
        // skip remainder of the loop for MBPOLYGONS and POLYHEDRA, which don't follow
        // the standard canonical ordering
        if( this_type == MBPOLYGON || this_type == MBPOLYHEDRON ) continue;
        // make an entity of this type
        result = MB->create_element( this_type, vertex_handles, CN::VerticesPerEntity( this_type ), this_entity );
        if( MB_SUCCESS != result || 0 == this_entity )
            cout << "failed to create entity of type " << CN::EntityTypeName( this_type ) << endl;
            return MB_FAILURE;
        // now get the connectivity vector *
        const EntityHandle* entity_vertices;
        int num_verts;
        result = MB->get_connectivity( this_entity, entity_vertices, num_verts );
        if( MB_SUCCESS != result || num_verts != CN::VerticesPerEntity( this_type ) )
            cout << "failed to get connectivity for entity type " << CN::EntityTypeName( this_type ) << endl;
            return MB_FAILURE;
        // for each dimension
            // for each side of this dimension
            const CN::ConnMap& cm = CN::mConnectivityMap[this_type][dim - 1];
            int tmp_conn[moab::MAX_SUB_ENTITY_VERTICES];
            for( int side_no = 0; side_no < CN::NumSubEntities( this_type, dim ); side_no++ )
                for( int j = 0; j < moab::MAX_SUB_ENTITY_VERTICES; j++ )
                    tmp_conn[j] = cm.conn[side_no][j];
                int temp_result = CN::SideNumber( this_type, tmp_conn,
                                                  CN::VerticesPerEntity( CN::SubEntityType( this_type, dim, side_no ) ),
                                                  dim, side, sense, offset );
                if( 0 != temp_result )
                    cout << "call to CN::side_number failed with non-success result"
                         << " for type " << CN::EntityTypeName( this_type ) << " dimension " << dim << " side no "
                         << side_no << endl;
                    return MB_FAILURE;
                // side number should be the same as side_no, sense should be forward, offset should
                // be zero
                if( side != side_no || sense != 1 || offset != 0 )
                    cout << "call to CN::side_number failed for type " << CN::EntityTypeName( this_type )
                         << " dimension " << dim << " side no " << side_no << endl
                         << "side, sense, offset = " << side << " " << sense << " " << offset << endl;
                    return MB_FAILURE;
        // destroy the entity of this_type
        result = MB->delete_entities( &this_entity, 1 );
        if( MB_SUCCESS != result ) return result;
    return MB_SUCCESS;
Definition at line 3022 of file MBTest.cpp.
References moab::Range::begin(), create_some_mesh(), moab::Range::empty(), moab::Range::end(), entities, ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MB_TAG_EXCL, MB_TYPE_HANDLE, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), tagname, and moab::Interface::type_from_handle().
Referenced by mb_dense_tag_test(), and mb_sparse_tag_test().
    Core moab;
    ErrorCode result = create_some_mesh( mb );
    char tagname[64];
    sprintf( tagname, "t%d", rand() );
    Tag tag;
    const EntityHandle def_val = ~(EntityHandle)0;
    ErrorCode rval             = mb->tag_get_handle( tagname, 1, MB_TYPE_HANDLE, tag, storage | MB_TAG_EXCL, &def_val );
    Range entities;
    mb->get_entities_by_handle( 0, entities );
    if( entities.empty() ) return MB_FAILURE;
    // set tag on every other entity to be the entities handle
    Range::const_iterator i;
    bool odd = true;
    for( i = entities.begin(); i != entities.end(); ++i, odd = !odd )
        if( odd )
            const EntityHandle h = *i;
            rval                 = mb->tag_set_data( tag, &h, 1, &h );
    // check values on every entity -- expect default for every other entity
    odd = true;
        EntityHandle val = 0;
        rval             = mb->tag_get_data( tag, &*i, 1, &val );
        if( odd )
            if( val != *i ) return MB_FAILURE;
        else
            if( val != def_val ) return MB_FAILURE;
    // set tag values on all entities
    std::vector< EntityHandle > values( entities.size() );
    std::copy( entities.begin(), entities.end(), values.begin() );
    rval = mb->tag_set_data( tag, entities, &values[0] );
    for( i = entities.begin(); i != entities.end(); ++i )
    // find each entity by tag value
        const EntityType type        = mb->type_from_handle( h );
        const void* const tag_vals[] = { &h };
        Range range;
        rval = mb->get_entities_by_type_and_tag( 0, type, &tag, tag_vals, 1, range );
        if( range.size() != 1 ) return MB_FAILURE;
        if( range.front() != h ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 3103 of file MBTest.cpp.
References mb_common_tag_test(), and MB_TAG_DENSE.
Build two Quads with two edges shared between them. The edges share the same nodes. We should be able to get adjacencies on the edges and get one (correct) quad. We should be able to get the edge adjacencies of the quads and only get 4 (not 5) edges.
first clean up any existing mesh.
create 6 nodes, 2 quads and 8 edges. Edge 4 is adjacent to quad 1 and edge 5 is adjacent to quad 2.
4 5 6 o--e7---o--e8---o | | | e3 q1 e4 e5 q2 e6 | | | o--e1---o--e2---o 1 2 3
create the first quad
create the second quad
create the edges
Edge 4 and 5 share the same nodes, but should be different entities
Now that the geometry is created start adding the adjacency information
does this (should this) say anything about order of the edges around the quad? Also, does this also build the edge->quad adjacency, or is that does with a separate call?
now get the adjacencies of each quad.
try getting the adjacency of edge1 (should be quad1)
there should be only 1 entity adjacent to edge1
and that entity should be quad1
try getting the adjacency of edge6 (should be one)
there should be only 1 entity adjacent to edge6
Now seal up the "gap" caused by edges 4 and 5. Remove edge5 from the adjacencies of quad2 and add edge 4 to quad2.
get the adjacencies of edge4 and it should return both quads.
there should be 2 entities adjacent to edge4
and they should be quad1 and quad2. Note that we are not saying anything about order in the array.
clean up on exit
Definition at line 3419 of file MBTest.cpp.
References moab::Interface::add_adjacencies(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), moab::error(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, MBEDGE, MBQUAD, and moab::Interface::remove_adjacencies().
    //! first clean up any existing mesh.
    ErrorCode error;
    Core moab;
    //! create 6 nodes, 2 quads and 8 edges.  Edge 4 is adjacent
    //! to quad 1 and edge 5 is adjacent to quad 2.
    //!  4       5       6
    //!  o--e7---o--e8---o
    //!  e3 q1 e4 e5 q2  e6
    //!  o--e1---o--e2---o
    //!  1       2       3
    double node_coord1[3] = { 0., 0., 0. };
    double node_coord2[3] = { 1., 0., 0. };
    double node_coord3[3] = { 2., 0., 0. };
    double node_coord4[3] = { 0., 1., 0. };
    double node_coord5[3] = { 1., 1., 0. };
    double node_coord6[3] = { 2., 1., 0. };
    EntityHandle node1, node2, node3, node4, node5, node6;
    error = MB->create_vertex( node_coord1, node1 );
    if( error != MB_SUCCESS ) return error;
    error = MB->create_vertex( node_coord2, node2 );
    error = MB->create_vertex( node_coord3, node3 );
    error = MB->create_vertex( node_coord4, node4 );
    error = MB->create_vertex( node_coord5, node5 );
    error = MB->create_vertex( node_coord6, node6 );
    std::vector< EntityHandle > conn( 4 );
    //! create the first quad
    EntityHandle quad1;
    conn[0] = node1;
    conn[1] = node2;
    conn[2] = node5;
    conn[3] = node4;
    error   = MB->create_element( MBQUAD, &conn[0], 4, quad1 );
    //! create the second quad
    EntityHandle quad2;
    conn[0] = node2;
    conn[1] = node3;
    conn[2] = node6;
    conn[3] = node5;
    error   = MB->create_element( MBQUAD, &conn[0], 4, quad2 );
    //! create the edges
    EntityHandle edge1;
    conn.resize( 2 );
    conn[0] = node1;
    conn[1] = node2;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge1 );
    EntityHandle edge2;
    conn[0] = node2;
    conn[1] = node3;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge2 );
    EntityHandle edge3;
    conn[0] = node1;
    conn[1] = node4;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge3 );
    EntityHandle edge4;
    conn[0] = node2;
    conn[1] = node5;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge4 );
    EntityHandle edge5;
    conn[0] = node2;
    conn[1] = node5;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge5 );
    EntityHandle edge6;
    conn[0] = node3;
    conn[1] = node6;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge6 );
    EntityHandle edge7;
    conn[0] = node4;
    conn[1] = node5;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge7 );
    EntityHandle edge8;
    conn[0] = node5;
    conn[1] = node6;
    error   = MB->create_element( MBEDGE, &conn[0], 2, edge8 );
    //! Edge 4 and 5 share the same nodes, but should be different entities
    if( edge4 == edge5 ) return MB_FAILURE;
    //! Now that the geometry is created start adding the adjacency information
    std::vector< EntityHandle > edge_adjacencies1( 4 );
    edge_adjacencies1[0] = edge1;
    edge_adjacencies1[1] = edge4;
    edge_adjacencies1[2] = edge7;
    edge_adjacencies1[3] = edge3;
    //! does this (should this) say anything about order of the edges around the
    //! quad?  Also, does this also build the edge->quad adjacency, or is that
    //! does with a separate call?
    error = MB->add_adjacencies( quad1, &edge_adjacencies1[0], edge_adjacencies1.size(), true );
    std::vector< EntityHandle > edge_adjacencies2( 4 );
    edge_adjacencies2[0] = edge2;
    edge_adjacencies2[1] = edge6;
    edge_adjacencies2[2] = edge8;
    edge_adjacencies2[3] = edge5;
    error                = MB->add_adjacencies( quad2, &edge_adjacencies2[0], edge_adjacencies2.size(), true );
    //! now get the adjacencies of each quad.
    std::vector< EntityHandle > quad1_adjacencies;
    error = MB->get_adjacencies( &( quad1 ), 1, 1, false, quad1_adjacencies );
    std::sort( quad1_adjacencies.begin(), quad1_adjacencies.end() );
    std::sort( edge_adjacencies1.begin(), edge_adjacencies1.end() );
    if( quad1_adjacencies != edge_adjacencies1 ) return MB_FAILURE;
    std::vector< EntityHandle > quad2_adjacencies;
    error = MB->get_adjacencies( &( quad2 ), 1, 1, false, quad2_adjacencies );
    std::sort( quad2_adjacencies.begin(), quad2_adjacencies.end() );
    std::sort( edge_adjacencies2.begin(), edge_adjacencies2.end() );
    if( quad2_adjacencies != edge_adjacencies2 ) return MB_FAILURE;
    //! try getting the adjacency of edge1 (should be quad1)
    std::vector< EntityHandle > edge1_adjacencies;
    error = MB->get_adjacencies( &( edge1 ), 1, 2, false, edge1_adjacencies );
    //! there should be only 1 entity adjacent to edge1
    if( edge1_adjacencies.size() != 1 ) return MB_FAILURE;
    //! and that entity should be quad1
    if( edge1_adjacencies[0] != quad1 ) return MB_FAILURE;
    //! try getting the adjacency of edge6 (should be one)
    std::vector< EntityHandle > edge6_adjacencies;
    error = MB->get_adjacencies( &( edge6 ), 1, 2, false, edge6_adjacencies );
    //! there should be only 1 entity adjacent to edge6
    if( edge6_adjacencies.size() != 1 ) return MB_FAILURE;
    //! Now seal up the "gap" caused by edges 4 and 5.  Remove edge5
    //! from the adjacencies of quad2 and add edge 4 to quad2.
    std::vector< EntityHandle > edge5_adjacencies( 1, edge5 );
    error = MB->remove_adjacencies( quad2, &edge5_adjacencies[0], edge5_adjacencies.size() );
    std::vector< EntityHandle > edge4_adjacencies( 1, edge4 );
    error = MB->add_adjacencies( quad2, &edge4_adjacencies[0], edge4_adjacencies.size(), true );
    //! get the adjacencies of edge4 and it should return both quads.
    std::vector< EntityHandle > quad_adjacencies;
    error = MB->get_adjacencies( &( edge4 ), 1, 2, false, quad_adjacencies );
    //! there should be 2 entities adjacent to edge4
    if( quad_adjacencies.size() != 2 ) return MB_FAILURE;
    //! and they should be quad1 and quad2.  Note that we are not saying anything
    //! about order in the array.
    if( ( quad_adjacencies[0] != quad1 || quad_adjacencies[1] != quad2 ) &&
        ( quad_adjacencies[0] != quad2 || quad_adjacencies[1] != quad1 ) )
        return MB_FAILURE;
    //! clean up on exit
    error = MB->delete_mesh();
    return MB_SUCCESS;
Definition at line 2636 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::handle_from_id(), moab::Interface::id_from_handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBTRI, MBVERTEX, and test_handle().
    Core moab;
    double nodes_array[7][3];
    nodes_array[0][0] = 0;
    nodes_array[0][1] = 0;
    nodes_array[0][2] = 0;
    nodes_array[1][0] = 2;
    nodes_array[1][1] = 0;
    nodes_array[1][2] = 0;
    nodes_array[2][0] = 1;
    nodes_array[2][1] = 2;
    nodes_array[2][2] = 1;
    nodes_array[3][0] = 1;
    nodes_array[3][1] = 0;
    nodes_array[3][2] = 0;
    nodes_array[4][0] = 1.5;
    nodes_array[4][1] = 0.5;
    nodes_array[4][2] = 0.5;
    nodes_array[5][0] = 0.5;
    nodes_array[5][1] = 0.5;
    nodes_array[5][2] = 0.5;
    nodes_array[6][0] = 1;
    nodes_array[6][1] = 1;
    nodes_array[6][2] = 0.5;
    // create the nodes
    std::vector< EntityHandle > connectivity( 8 );
    EntityHandle node_handle;
    int i;
    for( i = 0; i < 7; i++ )
        if( MB->create_vertex( nodes_array[i], node_handle ) != MB_SUCCESS ) return MB_FAILURE;
        connectivity[i] = node_handle;
    // create the higher order tri
    EntityHandle tri_handle;
    ErrorCode result = MB->create_element( MBTRI, &connectivity[0], 6, tri_handle );
    std::vector< EntityHandle > other_conn( 3 );
    double other_nodes[3][3];
    other_nodes[0][0] = 1.999;
    other_nodes[0][1] = 1.999;
    other_nodes[0][2] = 1.999;
    other_nodes[1][0] = 2.999;
    other_nodes[1][1] = 2.999;
    other_nodes[1][2] = 2.999;
    other_nodes[2][0] = 3.999;
    other_nodes[2][1] = 3.999;
    other_nodes[2][2] = 3.999;
    for( i = 0; i < 3; i++ )
        if( MB->create_vertex( other_nodes[i], node_handle ) != MB_SUCCESS ) return MB_FAILURE;
        other_conn[i] = node_handle;
    EntityHandle other_tri_handle;
    result = MB->create_element( MBTRI, &other_conn[0], 3, other_tri_handle );
    // get the connectivity now
    std::vector< EntityHandle > retrieved_conn;
    result = MB->get_connectivity( &tri_handle, 1, retrieved_conn );
    unsigned int k;
    for( k = 0; k < retrieved_conn.size(); k++ )
        if( connectivity[k] != retrieved_conn[k] ) return MB_FAILURE;
    result = MB->get_connectivity( &other_tri_handle, 1, retrieved_conn );
    for( k = 0; k < other_conn.size(); k++ )
        if( other_conn[k] != retrieved_conn[k] ) return MB_FAILURE;
    // now let's just try getting the topological connectivity (the 3 corner vertices)
    std::vector< EntityHandle > topo_conn;
    result = MB->get_connectivity( &other_tri_handle, 1, topo_conn, true );
    if( topo_conn.size() != 3 ) return MB_FAILURE;
    for( k = 0; k < 3; k++ )
        if( topo_conn[k] != retrieved_conn[k] ) return MB_FAILURE;
    // short check to make sure that Core::handle_from_id() works
    unsigned long handle_id = MB->id_from_handle( node_handle );
    EntityHandle test_handle;
    result = MB->handle_from_id( MBVERTEX, handle_id, test_handle );
    if( test_handle != node_handle ) return MB_FAILURE;
    handle_id = MB->id_from_handle( tri_handle );
    result = MB->handle_from_id( MBTRI, handle_id, test_handle );
    if( test_handle != tri_handle ) return MB_FAILURE;
    // make up some bogus id
    handle_id = 2140824;
    if( result != MB_ENTITY_NOT_FOUND ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 5337 of file MBTest.cpp.
References moab::Range::clear(), moab::Core::create_element(), moab::Core::create_vertex(), moab::Core::estimated_memory_use(), moab::Range::insert(), mb, MB_SUCCESS, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBQUAD, moab::Core::tag_get_handle(), and moab::Core::tag_set_data().
    Core mb;
    unsigned long long init_total, total_with_elem, total_with_tag, total_with_tag_data;
    mb.estimated_memory_use( 0, 0, 0, &init_total );
    double coords[12] = { 1, 2, 0, 3, 4, 0, 5, 6, 0, 7, 8, 0 };
    EntityHandle verts[4];
        if( MB_SUCCESS != mb.create_vertex( coords + 3 * i, verts[i] ) ) return MB_FAILURE;
    EntityHandle elem;
    mb.create_element( MBQUAD, verts, 4, elem );
    mb.estimated_memory_use( 0, 0, 0, &total_with_elem );
    if( total_with_elem <= init_total ) return MB_FAILURE;
    unsigned long long min, am;
    Range r;
    r.insert( elem );
    mb.estimated_memory_use( r, &min, &am );
    if( min != 4 * sizeof( EntityHandle ) ) return MB_FAILURE;
    r.clear();
    r.insert( verts[0] );
    r.insert( verts[1] );
    if( min != 6 * sizeof( double ) ) return MB_FAILURE;
    Tag tag;
    if( MB_SUCCESS != mb.tag_get_handle( "TMP_TAG", 1, MB_TYPE_INTEGER, tag, MB_TAG_SPARSE | MB_TAG_EXCL ) )
        return MB_FAILURE;
    mb.estimated_memory_use( 0, 0, 0, &total_with_tag );
    if( total_with_tag <= total_with_elem ) return MB_FAILURE;
    int tag_data[] = { 0xA, 0xB };
    if( MB_SUCCESS != mb.tag_set_data( tag, r, &tag_data ) ) return MB_FAILURE;
    if( min <= 6 * sizeof( double ) ) return MB_FAILURE;
    mb.estimated_memory_use( 0, 0, 0, &total_with_tag_data );
    if( total_with_tag_data <= total_with_tag ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 3927 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), ErrorCode, moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), MB_SUCCESS, MBEDGE, MBQUAD, moab::Interface::merge_entities(), MESHSET_SET, MESHSET_TRACK_OWNER, and moab::Range::size().
    Core moab;
    ErrorCode rval;
    // create two quads with a coincident edge pair
    double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 1, 1, 0, 1, 0, 0, 2, 0, 0, 2, 1, 0 };
    EntityHandle verts[8];
        mb->create_vertex( coords + 3 * i, verts[i] );
    EntityHandle quad1, quad2, edge1, edge2;
    mb->create_element( MBQUAD, verts, 4, quad1 );
    mb->create_element( MBQUAD, verts + 4, 4, quad2 );
    mb->create_element( MBEDGE, verts + 1, 2, edge1 );
    mb->create_element( MBEDGE, verts + 4, 2, edge2 );
    // create two tracking sets containing the vertices
    // and edge of each quad
    EntityHandle set1, set2;
    mb->create_meshset( MESHSET_TRACK_OWNER | MESHSET_SET, set1 );
    mb->create_meshset( MESHSET_TRACK_OWNER | MESHSET_ORDERED, set2 );
    mb->add_entities( set1, verts, 4 );
    mb->add_entities( set2, verts + 4, 4 );
    mb->add_entities( set1, &edge1, 1 );
    mb->add_entities( set2, &edge2, 1 );
    // now merge the coincident edges
    rval = mb->merge_entities( verts[1], verts[5], false, true );
        std::cerr << "Merge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return rval;
    rval = mb->merge_entities( verts[2], verts[4], false, true );
        return rval;
    rval = mb->merge_entities( edge1, edge2, false, true );
        return rval;
    // check that there is only one edge and that it has the correct connectivity
    Range r;
    mb->get_entities_by_type( 0, MBEDGE, r );
    if( r.size() != 1 || r.front() != edge1 )
        std::cerr << "Edge merge failed at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    std::vector< EntityHandle > exp( verts + 1, verts + 3 ), act;
    mb->get_connectivity( &edge1, 1, act );
    if( exp != act )
        std::cerr << "Incorrect conn for edge at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    // check that quad connectivity is as expected
    exp = std::vector< EntityHandle >( verts, verts + 4 );
    act.clear();
    mb->get_connectivity( &quad1, 1, act );
    if( exp != act )
        std::cerr << "Incorrect conn for quad at " << __FILE__ << ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    exp.resize( 4 );
    exp[0] = verts[2];
    exp[1] = verts[1];
    exp[2] = verts[6];
    exp[3] = verts[7];
    act.clear();
    mb->get_connectivity( &quad2, 1, act );
    if( exp != act )
        return MB_FAILURE;
    // check that set contents are correctly updated
    exp.push_back( edge1 );
    act.clear();
    mb->get_entities_by_handle( set1, act );
    std::sort( exp.begin(), exp.end() );
    std::sort( act.begin(), act.end() );
    if( exp != act )
        std::cerr << "Incorrect set contents at " << __FILE__ << ":" << __LINE__ << std::endl;
        std::cerr << "  Expected: ";
        std::copy( exp.begin(), exp.end(), std::ostream_iterator< EntityHandle >( std::cerr, " " ) );
        std::cerr << std::endl << "  Actual  : ";
        std::copy( act.begin(), act.end(), std::ostream_iterator< EntityHandle >( std::cerr, " " ) );
        return MB_FAILURE;
    exp.resize( 5 );
    exp[0] = verts[2];
    exp[1] = verts[1];
    exp[2] = verts[6];
    exp[3] = verts[7];
    exp[4] = edge1;
    act.clear();
    mb->get_entities_by_handle( set2, act );
    if( exp != act )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 1832 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::create_meshset(), create_some_mesh(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBVERTEX, moab::Range::merge(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), smoab::UNION, and moab::Range::upper_bound().
Referenced by mb_mesh_set_list_appends(), mb_mesh_set_root_appends(), and mb_mesh_set_set_appends().
    Core moab;
    // get all handles and subdivide into vertex and non-vertex ents
    Range all_ents, verts, elems, results;
    rval = mb->get_entities_by_handle( 0, all_ents );
    Range::iterator ve = all_ents.upper_bound( MBVERTEX );
    verts.merge( all_ents.begin(), ve );
    elems.merge( ve, all_ents.end() );
    // If we're not testing queries from the root set,
    // create a set containing all the vertices
    EntityHandle set = 0;
    if( flags != -1 )
        rval = mb->create_meshset( flags, set );
        rval = mb->add_entities( set, verts );
    // Test get_entities_by_handle.  This one doesn't make
    // much sense if we're testing the root set, but it doesn't
    // hurt to test it anyway.
    results = elems;
    rval    = mb->get_entities_by_handle( set, results );
    if( results != all_ents ) return MB_FAILURE;
    // Test get_entities_by_dimension
    results = elems;
    rval    = mb->get_entities_by_dimension( set, 0, results );
    // Test get_entities_by_type
    results = elems;
    rval    = mb->get_entities_by_type( set, MBVERTEX, results );
    // choose a single entity for testing tag queries
    EntityHandle entity = verts.front();
    Range expected( elems );
    expected.insert( entity );
    Tag sparse, dense;
    const int zero = 0, one = 1;
    const void* vals[] = { &one };
    // Test get_entities_by_type_and_tag w/ sparse tag and no value
    rval = mb->tag_get_handle( "mb_mesh_set_appends_sparse", 1, MB_TYPE_INTEGER, sparse, MB_TAG_SPARSE | MB_TAG_EXCL );
    rval = mb->tag_set_data( sparse, &entity, 1, &one );
    results = elems;
    rval =
        mb->get_entities_by_type_and_tag( set, TYPE_FROM_HANDLE( entity ), &sparse, 0, 1, results, Interface::UNION );
    if( results != expected ) return MB_FAILURE;
    // Test again, but specify tag value
    results = elems;
    rval    = mb->get_entities_by_type_and_tag( set, TYPE_FROM_HANDLE( entity ), &sparse, vals, 1, results,
                                                Interface::UNION );
    // Test get_entities_by_type_and_tag w/ dense tag
    rval =
        mb->tag_get_handle( "mb_mesh_set_appends_dense", 1, MB_TYPE_INTEGER, dense, MB_TAG_DENSE | MB_TAG_EXCL, &zero );
    rval = mb->tag_set_data( dense, &entity, 1, &one );
    results = elems;
    rval =
        mb->get_entities_by_type_and_tag( set, TYPE_FROM_HANDLE( entity ), &dense, vals, 1, results, Interface::UNION );
    return MB_SUCCESS;
Definition at line 2041 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::clear(), moab::Interface::clear_meshset(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Range::empty(), entities, ErrorCode, moab::Range::front(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), moab::Interface::get_meshset_options(), moab::Interface::list_entities(), MB_CHK_ERR, MB_SUCCESS, MESHSET_SET, MESHSET_TRACK_OWNER, moab::Interface::set_meshset_options(), and moab::Range::size().
    Core moab;
    ErrorCode rval;
    // create 10 vertices to put in set
    Range verts;
    std::vector< double > coords( 30 );
    rval = mb->create_vertices( &coords[0], 10, verts );MB_CHK_ERR( rval );
    // CHECK SET->TRACKING
    // create a set and add the verts
    EntityHandle set;
    rval = mb->create_meshset( MESHSET_SET, set );MB_CHK_ERR( rval );
    rval = mb->add_entities( set, verts );MB_CHK_ERR( rval );
    // the verts should not be tracking adjacencies
    Range adj_sets;
    rval = mb->get_adjacencies( verts, 4, false, adj_sets );MB_CHK_ERR( rval );
    if( !adj_sets.empty() )
        std::cerr << "range should be empty but contains:" << std::endl;
        rval = mb->list_entities( adj_sets );
        return MB_FAILURE;
    // check to make sure the flags on MESHSET_SET
    unsigned int flags;
    rval = mb->get_meshset_options( set, flags );MB_CHK_ERR( rval );
    if( !( MESHSET_SET & flags ) || ( MESHSET_TRACK_OWNER & flags ) || ( MESHSET_ORDERED & flags ) )
        std::cerr << "set should be MESHSET_SET only, flags=" << flags << std::endl;
        return MB_FAILURE;
    // change to a tracking set and check flags
    rval = mb->set_meshset_options( set, MESHSET_TRACK_OWNER );MB_CHK_ERR( rval );
    if( ( MESHSET_SET & flags ) || !( MESHSET_TRACK_OWNER & flags ) || ( MESHSET_ORDERED & flags ) )
        std::cerr << "set should be MESHSET_TRACK_OWNER only, flags=" << flags << std::endl;
        return MB_FAILURE;
    // check adjacencies
    if( 1 != adj_sets.size() )
        std::cerr << "range should contain a set, adj_sets.size()=" << adj_sets.size() << std::endl;
        return MB_FAILURE;
    // CHECK TRACKING->SET
    // change to a standard set and check flags
    rval = mb->set_meshset_options( set, MESHSET_SET );MB_CHK_ERR( rval );
        return MB_FAILURE;
    // the set should no longer be adjacent to the vertices
    adj_sets.clear();
        return MB_FAILURE;
    // CHECK UNORDERED->ORDERED
    // add a duplicate vert
    rval = mb->add_entities( set, &verts.front(), 1 );MB_CHK_ERR( rval );
    // unordered sets cannot hold duplicates so size shouldn't change
    std::vector< EntityHandle > entities;
    rval = mb->get_entities_by_handle( set, entities );
    if( 10 != entities.size() )
        std::cerr << "set should not hold duplicate entities" << std::endl;
        return MB_FAILURE;
    // change to an ordered set and check flags
    rval = mb->set_meshset_options( set, MESHSET_ORDERED );MB_CHK_ERR( rval );
    if( ( MESHSET_SET & flags ) || ( MESHSET_TRACK_OWNER & flags ) || !( MESHSET_ORDERED & flags ) )
        std::cerr << "set should be MESHSET_ORDERED only, flags=" << flags << std::endl;
        return MB_FAILURE;
    // swap the order with some entities to that the handles aren't ordered
    rval = mb->clear_meshset( &set, 1 );MB_CHK_ERR( rval );
    entities.clear();
    entities.resize( 2 );
    entities[0] = verts[1];
    entities[1] = verts[0];
    rval        = mb->add_entities( set, &entities[0], 2 );MB_CHK_ERR( rval );
    // check to ensure the entities keep their order
    entities.clear();
    if( verts[0] != entities[1] || verts[1] != entities[0] )
        std::cerr << "ordered set did not keep its order" << std::endl;
        return MB_FAILURE;
    // CHECK ORDERED->UNORDERED
    // change to an unordered set and check flags
    if( !( MESHSET_SET & flags ) || ( MESHSET_TRACK_OWNER & flags ) || MESHSET_ORDERED & flags )
        return MB_FAILURE;
    // the entities in the set should now be ordered by handle
    entities.clear();
    if( verts[0] != entities[0] || verts[1] != entities[1] )
        std::cerr << "unordered set is still ordered" << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 1924 of file MBTest.cpp.
References mb_mesh_set_appends().
Referenced by main().
    return mb_mesh_set_appends( MESHSET_ORDERED );
Definition at line 1977 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_CHK_ERR, MB_SUCCESS, moab::Interface::replace_entities(), and moab::Range::size().
    Core moab;
    ErrorCode rval;
    Range r;
    rval = mb->create_vertices( &coords[0], 10, r );MB_CHK_ERR( rval );
    std::vector< EntityHandle > verts( r.size() );
    std::copy( r.begin(), r.end(), verts.begin() );
    r.clear();
    // create a set
    EntityHandle set;
    rval = mb->create_meshset( MESHSET_ORDERED, set );MB_CHK_ERR( rval );
    // put all vertices in set, but add the first one a second time
    std::vector< EntityHandle > list( verts );
    list.push_back( verts.front() );
    rval = mb->add_entities( set, &list[0], list.size() );MB_CHK_ERR( rval );
    // swap 3 of the vertices
    EntityHandle old_ents[3] = { verts[2], verts[4], verts[6] };
    EntityHandle new_ents[3] = { verts[1], verts[9], verts[5] };
    rval                     = mb->replace_entities( set, old_ents, new_ents, 3 );MB_CHK_ERR( rval );
    // check new set contents
    std::vector< EntityHandle > list2;
    rval = mb->get_entities_by_handle( set, list2 );MB_CHK_ERR( rval );
    list[2] = verts[1];
    list[4] = verts[9];
    list[6] = verts[5];
    if( list != list2 )
        std::cerr << "Range does not contain expected values." << std::endl;
        std::copy( list.begin(), list.end(), std::ostream_iterator< EntityHandle >( std::cerr, " " ) );
        std::copy( list2.begin(), list2.end(), std::ostream_iterator< EntityHandle >( std::cerr, " " ) );
        std::cerr << std::endl;
        return MB_FAILURE;
    // now try replacing a repeated value
    rval = mb->replace_entities( set, &verts[0], &verts[3], 1 );MB_CHK_ERR( rval );
    list[0] = list[10] = verts[3];
    list2.clear();
    if( list != list2 )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 1381 of file MBTest.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_parent_child(), moab::Interface::add_parent_meshset(), moab::Range::begin(), compare_lists(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_parent_meshsets(), MB_SUCCESS, MESHSET_SET, moab::Interface::num_child_meshsets(), moab::Interface::num_parent_meshsets(), moab::Interface::remove_child_meshset(), and moab::Interface::remove_parent_meshset().
    Core moab;
    ErrorCode rval;
    std::vector< EntityHandle > list;
    Range range;
    int count;
    // create a few mesh sets
    const int num_sets = 10;
    EntityHandle sets[num_sets];
    for( int i = 0; i < num_sets; ++i )
        rval = MB->create_meshset( i % 2 ? MESHSET_SET : 0, sets[i] );
    // test adding child meshsets
    // add first child
    rval = MB->add_child_meshset( sets[0], sets[1] );
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list );
    if( !compare_lists( list, sets + 1, 1 ) ) return MB_FAILURE;
    // try to add child again
    list.clear();
    // add second child
    rval = MB->add_child_meshset( sets[0], sets[2] );
    list.clear();
    if( !compare_lists( list, sets + 1, 2 ) ) return MB_FAILURE;
    // try adding child again
    list.clear();
    // add third child
    rval = MB->add_child_meshset( sets[0], sets[3] );
    list.clear();
    if( !compare_lists( list, sets + 1, 3 ) ) return MB_FAILURE;
    list.clear();
    // add fourth child
    rval = MB->add_child_meshset( sets[0], sets[4] );
    list.clear();
    if( !compare_lists( list, sets + 1, 4 ) ) return MB_FAILURE;
    // make sure range query returns same result
    std::sort( list.begin(), list.end() );
    rval = MB->get_child_meshsets( sets[0], range );
    iter = range.begin();
    for( unsigned i = 0; i < 4; ++i, ++iter )
        if( *iter != list[i] ) return MB_FAILURE;
    // remove first child
    rval = MB->remove_child_meshset( sets[0], sets[1] );
    list.clear();
    if( !compare_lists( list, sets + 2, 3 ) ) return MB_FAILURE;
    // try removing child again
    // remove second child
    rval = MB->remove_child_meshset( sets[0], sets[2] );
    list.clear();
    if( !compare_lists( list, sets + 3, 2 ) ) return MB_FAILURE;
    // remove third child
    rval = MB->remove_child_meshset( sets[0], sets[3] );
    list.clear();
    if( list.size() != 1 || list[0] != sets[4] ) return MB_FAILURE;
    // remove fourth child
    rval = MB->remove_child_meshset( sets[0], sets[4] );
    list.clear();
    if( !list.empty() ) return MB_FAILURE;
    // test adding parent meshsets
    // add first parent
    rval = MB->add_parent_meshset( sets[0], sets[1] );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list );
    // try to add parent again
    list.clear();
    // add second parent
    rval = MB->add_parent_meshset( sets[0], sets[2] );
    list.clear();
    // try adding parent again
    list.clear();
    // add third parent
    rval = MB->add_parent_meshset( sets[0], sets[3] );
    list.clear();
    list.clear();
    // add fourth parent
    rval = MB->add_parent_meshset( sets[0], sets[4] );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], range );
    // remove first parent
    rval = MB->remove_parent_meshset( sets[0], sets[1] );
    list.clear();
    // try removing parent again
    // remove second parent
    rval = MB->remove_parent_meshset( sets[0], sets[2] );
    list.clear();
    // remove third parent
    rval = MB->remove_parent_meshset( sets[0], sets[3] );
    list.clear();
    // remove fourth parent
    rval = MB->remove_parent_meshset( sets[0], sets[4] );
    list.clear();
    // setup tests of recursive child query
    //              0
    //          1       2
    //      3       4       5
    //          6       7
    rval = MB->add_child_meshset( sets[1], sets[3] );
    rval = MB->add_child_meshset( sets[1], sets[4] );
    rval = MB->add_child_meshset( sets[2], sets[4] );
    rval = MB->add_child_meshset( sets[2], sets[5] );
    rval = MB->add_child_meshset( sets[3], sets[6] );
    rval = MB->add_child_meshset( sets[4], sets[6] );
    rval = MB->add_child_meshset( sets[4], sets[7] );
    rval = MB->add_child_meshset( sets[5], sets[7] );
    // test query at depth of 1
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list, 1 );
    if( list.size() != 2 || list[0] != sets[1] || list[1] != sets[2] ) return MB_FAILURE;
    rval = MB->num_child_meshsets( sets[0], &count, 1 );
    if( count != 2 ) return MB_FAILURE;
    // test query at depth of 2
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list, 2 );
    if( !compare_lists( list, sets + 1, 5, false ) ) return MB_FAILURE;
    rval = MB->num_child_meshsets( sets[0], &count, 2 );
    if( count != 5 ) return MB_FAILURE;
    // test query at depth of 3
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list, 3 );
    if( !compare_lists( list, sets + 1, 7, false ) ) return MB_FAILURE;
    rval = MB->num_child_meshsets( sets[0], &count, 3 );
    if( count != 7 ) return MB_FAILURE;
    // test query at depth of 4
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list, 4 );
    rval = MB->num_child_meshsets( sets[0], &count, 4 );
    // test query at all
    list.clear();
    rval = MB->get_child_meshsets( sets[0], list, 0 );
    rval = MB->num_child_meshsets( sets[0], &count, 0 );
    // clean up child links
    rval = MB->remove_child_meshset( sets[1], sets[3] );
    rval = MB->remove_child_meshset( sets[1], sets[4] );
    rval = MB->remove_child_meshset( sets[2], sets[4] );
    rval = MB->remove_child_meshset( sets[2], sets[5] );
    rval = MB->remove_child_meshset( sets[3], sets[6] );
    rval = MB->remove_child_meshset( sets[4], sets[6] );
    rval = MB->remove_child_meshset( sets[4], sets[7] );
    rval = MB->remove_child_meshset( sets[5], sets[7] );
        if( MB_SUCCESS != MB->num_child_meshsets( sets[i], &count ) || count ) return MB_FAILURE;
    // setup tests of recursive parent query
    //          6       7
    //      3       4       5
    //          1       2
    //              0
    rval = MB->add_parent_meshset( sets[1], sets[3] );
    rval = MB->add_parent_meshset( sets[1], sets[4] );
    rval = MB->add_parent_meshset( sets[2], sets[4] );
    rval = MB->add_parent_meshset( sets[2], sets[5] );
    rval = MB->add_parent_meshset( sets[3], sets[6] );
    rval = MB->add_parent_meshset( sets[4], sets[6] );
    rval = MB->add_parent_meshset( sets[4], sets[7] );
    rval = MB->add_parent_meshset( sets[5], sets[7] );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list, 1 );
    rval = MB->num_parent_meshsets( sets[0], &count, 1 );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list, 2 );
    rval = MB->num_parent_meshsets( sets[0], &count, 2 );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list, 3 );
    rval = MB->num_parent_meshsets( sets[0], &count, 3 );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list, 4 );
    rval = MB->num_parent_meshsets( sets[0], &count, 4 );
    list.clear();
    rval = MB->get_parent_meshsets( sets[0], list, 0 );
    rval = MB->num_parent_meshsets( sets[0], &count, 0 );
    // clean up parent links
    rval = MB->remove_parent_meshset( sets[1], sets[3] );
    rval = MB->remove_parent_meshset( sets[1], sets[4] );
    rval = MB->remove_parent_meshset( sets[2], sets[4] );
    rval = MB->remove_parent_meshset( sets[2], sets[5] );
    rval = MB->remove_parent_meshset( sets[3], sets[6] );
    rval = MB->remove_parent_meshset( sets[4], sets[6] );
    rval = MB->remove_parent_meshset( sets[4], sets[7] );
    rval = MB->remove_parent_meshset( sets[5], sets[7] );
        if( MB_SUCCESS != MB->num_parent_meshsets( sets[i], &count ) || count ) return MB_FAILURE;
    // test combined parent/child links
    // test creation
    rval = MB->add_parent_child( sets[9], sets[8] );
    list.clear();
    rval = MB->get_child_meshsets( sets[9], list );
    if( MB_SUCCESS != rval ) return rval;
    if( list.size() != 1 || list[0] != sets[8] ) return MB_FAILURE;
    list.clear();
    rval = MB->get_parent_meshsets( sets[8], list );
    if( list.size() != 1 || list[0] != sets[9] ) return MB_FAILURE;
    // test deletion of parent/child
    rval = MB->add_parent_child( sets[7], sets[9] );
    rval = MB->delete_entities( &sets[9], 1 );
    list.clear();
    list.clear();
    rval = MB->get_child_meshsets( sets[7], list );
    // clean up remaining sets
    return MB->delete_entities( sets, 9 );
Definition at line 1929 of file MBTest.cpp.
    return mb_mesh_set_appends( -1 );
Definition at line 2563 of file MBTest.cpp.
References moab::Interface::add_entities(), check_meshset_internal(), moab::Interface::create_meshset(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, MESHSET_SET, and moab::Interface::remove_entities().
    Core core;
    Interface& mb = core;
    EntityHandle set;
    ErrorCode rval = mb.create_meshset( MESHSET_SET, set );MB_CHK_ERR( rval );
    EntityHandle list1[] = { 10, 16, 18, 20, 24, 27 };
    size_t len1          = sizeof( list1 ) / sizeof( list1[0] );
    EntityHandle list2[] = { 10, 16, 17, 18, 19, 20, 24, 27 };
    size_t len2          = sizeof( list2 ) / sizeof( list2[0] );
    rval                 = mb.add_entities( set, list1, len1 );MB_CHK_ERR( rval );
    rval = check_meshset_internal( mb, set, list1, len1 );MB_CHK_ERR( rval );
    rval = mb.add_entities( set, list2, len2 );MB_CHK_ERR( rval );
    EntityHandle exp12[] = { 10, 16, 17, 18, 19, 20, 24, 27 };
    size_t len12         = sizeof( exp12 ) / sizeof( exp12[0] );
    rval                 = check_meshset_internal( mb, set, exp12, len12 );MB_CHK_ERR( rval );
    EntityHandle list3[] = { 15, 16, 18, 20, 21, 24, 28 };
    size_t len3          = sizeof( list3 ) / sizeof( list3[0] );
    rval                 = mb.remove_entities( set, list3, len3 );MB_CHK_ERR( rval );
    EntityHandle exp123[] = { 10, 17, 19, 27 };
    size_t len123         = sizeof( exp123 ) / sizeof( exp123[0] );
    rval                  = check_meshset_internal( mb, set, exp123, len123 );MB_CHK_ERR( rval );
    EntityHandle list4[] = { 18, 10, 11, 12, 13, 14, 15, 16 };
    size_t len4          = sizeof( list4 ) / sizeof( list4[0] );
    rval                 = mb.add_entities( set, list4, len4 );MB_CHK_ERR( rval );
    EntityHandle exp14[] = { 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 27 };
    size_t len14         = sizeof( exp14 ) / sizeof( exp14[0] );
    rval                 = check_meshset_internal( mb, set, exp14, len14 );MB_CHK_ERR( rval );
    EntityHandle list5[] = { 9, 10, 12, 13, 14, 15, 19, 20 };
    rval                 = mb.remove_entities( set, list5, sizeof( list5 ) / sizeof( list5[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp5[] = { 11, 16, 17, 18, 27 };
    rval                = check_meshset_internal( mb, set, exp5, sizeof( exp5 ) / sizeof( exp5[0] ) );MB_CHK_ERR( rval );
    EntityHandle list6[] = { 9, 10, 15, 16, 18, 19, 28 };
    rval                 = mb.add_entities( set, list6, sizeof( list6 ) / sizeof( list6[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp6[] = { 9, 10, 11, 15, 16, 17, 18, 19, 27, 28 };
    rval                = check_meshset_internal( mb, set, exp6, sizeof( exp6 ) / sizeof( exp6[0] ) );MB_CHK_ERR( rval );
    EntityHandle list7[] = { 13, 19, 27, 28 };
    rval                 = mb.add_entities( set, list7, sizeof( list7 ) / sizeof( list7[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp7[] = { 9, 10, 11, 13, 15, 16, 17, 18, 19, 27, 28 };
    rval                = check_meshset_internal( mb, set, exp7, sizeof( exp7 ) / sizeof( exp7[0] ) );MB_CHK_ERR( rval );
    EntityHandle list8[] = { 12, 14, 33 };
    rval                 = mb.add_entities( set, list8, sizeof( list8 ) / sizeof( list8[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp8[] = { 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 27, 28, 33 };
    rval                = check_meshset_internal( mb, set, exp8, sizeof( exp8 ) / sizeof( exp8[0] ) );MB_CHK_ERR( rval );
    EntityHandle list9[] = { 29, 30, 31, 32, 34 };
    rval                 = mb.remove_entities( set, list9, sizeof( list9 ) / sizeof( list9[0] ) );MB_CHK_ERR( rval );
    EntityHandle list10[] = { 9, 11, 13, 17, 18, 19, 28, 33, 100 };
    rval                  = mb.remove_entities( set, list10, sizeof( list10 ) / sizeof( list10[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp10[] = { 10, 12, 14, 15, 16, 27 };
    rval                 = check_meshset_internal( mb, set, exp10, sizeof( exp10 ) / sizeof( exp10[0] ) );MB_CHK_ERR( rval );
    EntityHandle list11[] = { 11, 12, 13, 14, 27, 28 };
    rval                  = mb.remove_entities( set, list11, sizeof( list11 ) / sizeof( list11[0] ) );MB_CHK_ERR( rval );
    EntityHandle exp11[] = { 10, 15, 16 };
    rval                 = check_meshset_internal( mb, set, exp11, sizeof( exp11 ) / sizeof( exp11[0] ) );MB_CHK_ERR( rval );
    EntityHandle list12[] = { 1, 10, 15, 16 };
    rval                  = mb.remove_entities( set, list12, sizeof( list12 ) / sizeof( list12[0] ) );MB_CHK_ERR( rval );
    rval = check_meshset_internal( mb, set, 0, 0 );MB_CHK_ERR( rval );
    return MB_SUCCESS;
Definition at line 1919 of file MBTest.cpp.
References mb_mesh_set_appends(), and MESHSET_SET.
Definition at line 1934 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Range::clear(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Range::insert(), MB_CHK_ERR, MB_SUCCESS, MESHSET_SET, moab::Interface::replace_entities(), and moab::Range::size().
    Core moab;
    ErrorCode rval;
    Range r;
    r.clear();
    // create a set
    EntityHandle set;
    // put every other vertex in set
    for( size_t i = 0; i < 10; i += 2 )
        r.insert( verts[i] );
    rval = mb->add_entities( set, r );MB_CHK_ERR( rval );
    r.clear();
    rval = mb->get_entities_by_handle( set, r );MB_CHK_ERR( rval );
    Range r2;
    r2.insert( verts[0] );
    r2.insert( verts[1] );
    r2.insert( verts[9] );
    r2.insert( verts[5] );
    r2.insert( verts[8] );
    if( r != r2 )
                  << "  Expected: " << r2 << std::endl
                  << "  Actual  : " << r << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 1826 of file MBTest.cpp.
References mb_mesh_sets_test().
    return mb_mesh_sets_test( MESHSET_ORDERED );
Definition at line 1821 of file MBTest.cpp.
References mb_mesh_sets_test(), and MESHSET_SET.
ErrorCode mb_mesh_sets_test ( int  flags)
Definition at line 964 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::all_of_dimension(), moab::Range::all_of_type(), moab::Range::begin(), check_esets(), moab::Range::clear(), moab::Interface::clear_meshset(), moab::Interface::create_meshset(), create_some_mesh(), dim, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_dimension(), moab::Interface::get_number_entities_by_handle(), moab::Interface::get_number_entities_by_type(), moab::Interface::intersect_meshset(), MB_SUCCESS, MBEDGE, MBENTITYSET, MBHEX, MBQUAD, MBTET, MBTRI, MBVERTEX, MESHSET_SET, nothing_but_type(), moab::Range::size(), and moab::Interface::subtract_meshset().
Referenced by mb_mesh_sets_list_test(), and mb_mesh_sets_set_test().
    Core moab;
    ErrorCode result = create_some_mesh( MB );
    Range temp_range;
    std::vector< EntityHandle > temp_vector;
    EntityType ent_type;
    EntityHandle ms_array[MBENTITYSET]     = { 0 };
    unsigned int number_array[MBENTITYSET] = { 0 };
    unsigned int num_dim_array[4]          = { 0, 0, 0, 0 };
    int count, start_num_sets;
    result = MB->get_number_entities_by_type( 0, MBENTITYSET, start_num_sets );
    // add entities to meshsets
    for( ent_type = MBEDGE; ent_type != MBENTITYSET; ent_type++ )
        result = MB->create_meshset( flags, ms_array[ent_type] );
        if( result != MB_SUCCESS ) return result;
        temp_range.clear();
        result = MB->get_entities_by_type( 0, ent_type, temp_range );
        result = MB->get_number_entities_by_type( 0, ent_type, count );
        if( (unsigned)count != temp_range.size() ) return MB_FAILURE;
        result = MB->add_entities( ms_array[ent_type], temp_range );
        number_array[ent_type] = temp_range.size();  // KGM
        num_dim_array[CN::Dimension( ent_type )] += count;
        // Check to make sure mesh set really has correct number of entities in it
        temp_range.clear();
        temp_vector.clear();
        result = MB->get_entities_by_handle( ms_array[ent_type], temp_range );
        if( number_array[ent_type] != temp_range.size() )
            cout << "Number of entities in meshset test is not correct" << endl;
            return MB_FAILURE;
        if( !temp_range.all_of_type( ent_type ) ) return MB_FAILURE;
        result = MB->get_entities_by_handle( ms_array[ent_type], temp_vector );
        if( number_array[ent_type] != temp_vector.size() )
            return MB_FAILURE;
        temp_range.clear();
        result = MB->get_entities_by_type( ms_array[ent_type], ent_type, temp_range );
            cout << "Number of entities by type in meshset test is not correct" << endl;
            return MB_FAILURE;
        temp_range.clear();
        result = MB->get_entities_by_type( ms_array[ent_type], MBVERTEX, temp_range );
        if( 0 != temp_range.size() ) return MB_FAILURE;
        temp_range.clear();
        result = MB->get_entities_by_dimension( ms_array[ent_type], CN::Dimension( ent_type ), temp_range );
            cout << "Number of entities by dimension in meshset test is not correct" << endl;
            return MB_FAILURE;
        temp_range.clear();
        result = MB->get_entities_by_dimension( ms_array[ent_type], 0, temp_range );
            return MB_FAILURE;
        result = MB->get_number_entities_by_handle( ms_array[ent_type], count );
        if( (unsigned)count != number_array[ent_type] ) return MB_FAILURE;
        result = MB->get_number_entities_by_type( ms_array[ent_type], ent_type, count );
        result = MB->get_number_entities_by_type( ms_array[ent_type], MBVERTEX, count );
        if( count != 0 ) return MB_FAILURE;
        result = MB->get_number_entities_by_dimension( ms_array[ent_type], CN::Dimension( ent_type ), count );
        result = MB->get_number_entities_by_dimension( ms_array[ent_type], 0, count );
    result = check_esets( MB, start_num_sets + MBENTITYSET - MBEDGE );
    for( int dim = 1; dim < 4; ++dim )
        result = MB->get_number_entities_by_dimension( 0, dim, count );
        if( MB_SUCCESS != result ) return MB_FAILURE;
        if( (unsigned)count != num_dim_array[dim] ) return MB_FAILURE;
    //----------TEST RECURSIVE OPERATIONS----------------//
    EntityHandle recursive1, recursive2;
    result = MB->create_meshset( MESHSET_SET, recursive1 );
    result = MB->create_meshset( 0, recursive2 );
    unsigned num_sets = MBENTITYSET - MBEDGE;
    result            = MB->add_entities( recursive2, ms_array + MBEDGE, num_sets );
    result = MB->add_entities( recursive1, &recursive2, 1 );
    temp_range.clear();
    result = MB->get_entities_by_type( recursive1, MBENTITYSET, temp_range );
    if( temp_range.size() != 1 || *( temp_range.begin() ) != recursive2 ) return MB_FAILURE;
    temp_range.clear();
    result = MB->get_entities_by_type( recursive2, MBENTITYSET, temp_range );
    if( temp_range.size() != num_sets || !temp_range.all_of_type( MBENTITYSET ) ) return MB_FAILURE;
    temp_range.clear();
    result = MB->get_entities_by_handle( recursive1, temp_range );
    temp_range.clear();
    result = MB->get_entities_by_handle( recursive2, temp_range );
    unsigned total = 0;
        total += number_array[ent_type];
        temp_range.clear();
        result = MB->get_entities_by_type( recursive1, ent_type, temp_range, true );
            cout << "Recursive number of entities by type in meshset test is not correct" << endl;
            return MB_FAILURE;
        result = MB->get_number_entities_by_type( recursive1, ent_type, count, true );
        if( number_array[ent_type] != (unsigned)count )
            return MB_FAILURE;
    if( 0 == total )
        cout << "Invalid test input.  No entities!" << endl;
        return MB_FAILURE;
        temp_range.clear();
        result = MB->get_entities_by_dimension( recursive1, dim, temp_range, true );
        if( temp_range.size() != num_dim_array[dim] ) return MB_FAILURE;
        if( !temp_range.all_of_dimension( dim ) ) return MB_FAILURE;
        result = MB->get_number_entities_by_dimension( recursive1, dim, count, true );
    temp_range.clear();
    result = MB->get_entities_by_handle( recursive1, temp_range, true );
    if( total != temp_range.size() )
        cout << "Recursive number of entities in meshset test is not correct" << endl;
        return MB_FAILURE;
    // try circular relation
    result = MB->add_entities( recursive2, &recursive1, 1 );
        std::cout << "Failed to create circular set containment" << std::endl;
        return result;
    temp_range.clear();
        return MB_FAILURE;
    result = check_esets( MB, start_num_sets + MBENTITYSET - MBEDGE + 2 );
    //----------TEST BOOLEAN OPERATIONS----------------//
    EntityHandle temp_ms1, temp_ms2;
    result = MB->create_meshset( flags, temp_ms1 );
    result = MB->create_meshset( flags, temp_ms2 );
    // Subtract
    // add all edges and hexes of ms_array[MBHEX] and ms_array[MBEDGE] to temp_ms1
    // get all Edge entities
    temp_range.clear();
    result = MB->get_entities_by_handle( ms_array[MBEDGE], temp_range );
    // add Edges to ms1
    result = MB->add_entities( temp_ms1, temp_range );
    temp_range.clear();
    result = MB->get_entities_by_handle( ms_array[MBHEX], temp_range );
    // add Hexes to ms1
    // subtract bars meshset out of hex meshset
    result = MB->subtract_meshset( temp_ms1, ms_array[MBEDGE] );
    // Perform the check
    temp_range.clear();
    result = MB->get_entities_by_handle( temp_ms1, temp_range );
    if( number_array[MBHEX] != temp_range.size() )
        cout << "MBset subtraction is bad" << endl;
        return MB_FAILURE;
    // make sure there's nothing but hexes in hex_ms
    if( nothing_but_type( temp_range, MBHEX ) != MB_SUCCESS ) return MB_FAILURE;
    result = check_esets( MB, start_num_sets + MBENTITYSET - MBEDGE + 4 );
    //------------Intersect------------
    // clean out the temp_ms1
    MB->clear_meshset( &temp_ms1, 1 );
    temp_range.clear();
    // get all quad entities
    temp_range.clear();
    result = MB->get_entities_by_handle( ms_array[MBQUAD], temp_range );
    // add tets them to ms1
    // get all tet entities
    temp_range.clear();
    result = MB->get_entities_by_handle( ms_array[MBTET], temp_range );
    // intersect temp_ms1 (which contains all quads and tets) with tet meshset
    // temp_ms1 meshset is altered
    result = MB->intersect_meshset( temp_ms1, ms_array[MBTET] );
    // Perform the check, only tets should be in temp_ms1
    temp_range.clear();
    if( number_array[MBTET] != temp_range.size() )
        cout << "MBset intersection is bad" << endl;
        return MB_FAILURE;
    // make sure there's nothing but tet in range
    if( nothing_but_type( temp_range, MBTET ) != MB_SUCCESS ) return MB_FAILURE;
    //-------------Unite--------------
    // fill temp_ms1 with tets and tris
    // get all tris
    temp_range.clear();
    result = MB->get_entities_by_handle( ms_array[MBTRI], temp_range );
    temp_range.clear();
    // fill temp_ms2 with tris and hexes
    temp_range.clear();
    result = MB->add_entities( temp_ms2, temp_range );
    temp_range.clear();
    // temp_ms1 is now filled with tets and tris
    // temp_ms2 is now filled with quads and tris
    int size1 = 0, size2 = 0;
    result = MB->get_number_entities_by_handle( ms_array[MBTRI], size1 );
    result = MB->intersect_meshset( temp_ms1, temp_ms2 );
    result = MB->get_number_entities_by_handle( temp_ms1, size2 );
    if( size1 != size2 )
        return MB_FAILURE;
    temp_range.clear();
    // make sure there's nothing but tris in temp_range
    if( nothing_but_type( temp_range, MBTRI ) != MB_SUCCESS ) return MB_FAILURE;
    //-------------Misc tests--------------
    EntityHandle temp_ms3;
    result = MB->create_meshset( flags, temp_ms3 );
    EntityHandle handle_array[] = { 1, 2, 3, 4, 5, 7, 8, 9, 10 };
    const int num_handle        = sizeof( handle_array ) / sizeof( handle_array[0] );
    // add ents to set
    result = MB->add_entities( temp_ms3, handle_array, num_handle );
    // try adding again
    int num_ents;
    result = MB->get_number_entities_by_handle( temp_ms3, num_ents );
    int num_expected = ( flags & MESHSET_SET ) ? num_handle : 2 * num_handle;
    if( num_ents != num_expected ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 5212 of file MBTest.cpp.
References moab::Core::check_adjacencies(), moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, MBPOLYGON, and MBPOLYHEDRON.
    ErrorCode rval;
    Core moab;
    Interface* mbImpl = &moab;
    // make a couple polygons and a polyhedron
    double coords[3] = { 0, 1, 2 };
    EntityHandle verts[10], polygons[2], polyhedron;
    for( int i = 0; i < 10; i++ )
        rval = mbImpl->create_vertex( coords, verts[i] );
    for( int i = 0; i < 2; i++ )
        rval = mbImpl->create_element( MBPOLYGON, verts, 5, polygons[i] );
    rval = mbImpl->create_element( MBPOLYHEDRON, polygons, 2, polyhedron );
    // create the aentities
    Range dum_range;
    for( int dim = 0; dim < 3; dim++ )
        dum_range.clear();
        rval = mbImpl->get_adjacencies( &polyhedron, 1, dim, true, dum_range );
    // delete the polyhedron
    rval = mbImpl->delete_entities( &polyhedron, 1 );
    return moab.check_adjacencies();
Definition at line 5253 of file MBTest.cpp.
References moab::Core::check_adjacencies(), moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, MBPOLYGON, MBPOLYHEDRON, and smoab::UNION.
    ErrorCode rval;
    Core moab;
    // make a polyhedra in shape of a cube with a corner cut
     *             7   -------------   8
     *       .                  .      |  initial cube had 8 vertices; box [000 - 222]
     *    5   -------------   6        |   cut a triangle 123 on lower corner
     *    |                   |        |   faces of the polyhedra (pointing outward)
     *    |        |          |        |   (123) (24653) (4 10 8 6)
     *    3                   |        |   (9 10 4 2 1) (7 8 10 9)  (5687)
     *     \       |          |        |   (1 3 5 7 9)
     *             9   -  -  -|  -    10
     *        1,              |  .
     *  (000)      '2 ----    4
    double coords[] = {
        0, 1, 0,                    // vertex 1
        1, 0, 0,                    // vertex 2
        0, 0, 1,                    // vertex 3
        2, 0, 0, 0, 0, 2, 2, 0, 2,  // vertex 6
        0, 2, 2, 2, 2, 2,           // vertex 8
        0, 2, 0,                    // vertex 9
        2, 2, 0                     // vertex 9
    EntityHandle verts[10], polygons[7], polyhedron;
        rval = mbImpl->create_vertex( &coords[3 * i], verts[i] );
    EntityHandle connect[] = {
        1, 2,  3,                                               // poly 1
        2, 4,  6, 5, 3,                                         // poly 2
        4, 10, 8, 6,                                            // polygon 3...
        9, 10, 4, 2, 1, 7, 8, 10, 9, 5, 6, 8, 7, 1, 3, 5, 7, 9  // polygon 7
    };                                                          // we know the handles directly
    int num_verts[7] = { 3, 5, 4, 5, 4, 4, 5 };
    int start_indx[7];
    start_indx[0] = 0;
    for( int i = 0; i < 6; i++ )
        start_indx[i + 1] = start_indx[i] + num_verts[i];
    for( int j = 0; j < 7; j++ )
        rval = mbImpl->create_element( MBPOLYGON, &connect[start_indx[j]], num_verts[j], polygons[j] );
    rval = mbImpl->create_element( MBPOLYHEDRON, polygons, 7, polyhedron );
    Range dum_range;
        dum_range.clear();
        rval = mbImpl->get_adjacencies( &polyhedron, 1, dim, true, dum_range, Interface::UNION );
        // std::cout << "\n dimension:" << dim << " " << dum_range.size() << " entities";
    // std::cout << "\n";
    /*rval=mbImpl->write_mesh("polyhedra.vtk");
    if (MB_SUCCESS != rval)
      return rval;*/
Definition at line 4386 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Range::insert(), MB_SUCCESS, MBPOLYGON, MBPOLYHEDRON, moab::Range::size(), and smoab::UNION.
    Core moab;
    Interface* mb = &moab;
    // test polygon and polyhedron representation
    // create a couple of polygons; vertices first
    const double vert_pos[48] = { -1, 0,  0,  1, 0, 0,  2, 0, 0,  2, 1, 0,  1,  1,   0,  0,
                                  2,  0,  -1, 1, 0, -2, 1, 0, -2, 0, 0, -2, -1, 0,   -1, -1,
                                  0,  -1, -2, 0, 1, -2, 0, 1, -1, 0, 2, -1, 0,  1.5, .5, 1 };
    EntityHandle verts[16];
    ErrorCode result;
    int i;
    for( i = 0; i < 16; i++ )
        result = mb->create_vertex( &vert_pos[3 * i], verts[i] );
            std::cout << "Failed to create vertex " << i << " in mb_poly_test." << std::endl;
            return result;
    // then polygons
    const int connect_idx[] = { 1,  2,  5,  6,  7, 2, 3, 4,  5,  5,  4,  6,  7, 6, 8, 0, 1, 7, 8,  0, 1, 2, 3, 14,
                                13, 12, 11, 10, 9, 0, 9, 10, 11, 12, 13, 14, 3, 4, 6, 8, 2, 3, 15, 5, 3, 4, 5, 15 };
    int num_connect_idx[] = { 5, 4, 3, 3, 4, 10, 11, 4, 4 };
    EntityHandle polygons[9], temp_connect[12];
    int idx = 0, nump = 0;
    ErrorCode tmp_result;
    while( nump < 9 )
        for( i = 0; i < num_connect_idx[nump]; i++ )
            temp_connect[i] = verts[connect_idx[idx + i]];
        tmp_result = mb->create_element( MBPOLYGON, temp_connect, num_connect_idx[nump], polygons[nump] );
        if( MB_SUCCESS != tmp_result )
            std::cout << "mb_poly_test: create_element failed for polygon " << i << "." << std::endl;
            result = tmp_result;
            nump++;
            continue;
        idx += num_connect_idx[nump];
        nump++;
    // ok, made 'em; now get all the vertices and make sure they're the same
    const EntityHandle* connect;
    int num_connect;
    idx = 0;
    int j;
    for( i = 0; i < 9; i++ )
        tmp_result = mb->get_connectivity( polygons[i], connect, num_connect );
        if( MB_SUCCESS != tmp_result || num_connect != num_connect_idx[i] )
            std::cout << "mb_poly_test: get_connectivity test failed for polygon " << i << "." << std::endl;
            result = ( tmp_result != MB_SUCCESS ? tmp_result : MB_FAILURE );
            continue;
        for( j = 0; j < num_connect; j++ )
            if( connect[j] != verts[connect_idx[idx + j]] )
                std::cout << "mb_poly_test: get_connectivity test returned wrong vertices for polygon " << i << "."
                          << std::endl;
                result = MB_FAILURE;
                continue;
        idx += num_connect;
    // check a different way, with ranges
    Range vert_range, poly_range;
        poly_range.insert( polygons[i] );
    result = mb->get_adjacencies( poly_range, 0, false, vert_range, Interface::UNION );
        std::cout << "mb_poly_test: get_adjacencies failed for polygon " << i << "." << std::endl;
        return result;
    else if( vert_range.size() != 16 )
        std::cout << "mb_poly_test: get_adjacencies returned wrong # of vertices for polygon " << i << "." << std::endl;
        return MB_FAILURE;
    // make a couple polyhedra
    EntityHandle polyhedra[2];
    result = mb->create_element( MBPOLYHEDRON, polygons, 7, polyhedra[0] );
        std::cout << "mb_poly_test: create_element failed for polyhedron 1." << std::endl;
        return result;
    temp_connect[0] = polygons[1];
    temp_connect[1] = polygons[7];
    temp_connect[2] = polygons[8];
    result          = mb->create_element( MBPOLYHEDRON, temp_connect, 3, polyhedra[1] );
        std::cout << "mb_poly_test: create_element failed for polyhedron 2." << std::endl;
        return result;
    // now look for vertices common to both
    std::vector< EntityHandle > temp_verts;
    result = mb->get_adjacencies( polyhedra, 2, 0, false, temp_verts );
        std::cout << "mb_poly_test: get_adjacencies failed for polyhedra." << std::endl;
        return result;
    if( 4 != temp_verts.size() )
        std::cout << "mb_poly_test: get_adjacencies for polyhedra returned " << temp_verts.size()
                  << " vertices, should be 4." << std::endl;
        return MB_FAILURE;
    // ok, we're probably fine
    return MB_SUCCESS;
Definition at line 4765 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::SequenceManager::create_entity_sequence(), moab::CREATE_HANDLE(), moab::SequenceManager::delete_entity(), moab::Range::end(), moab::EntitySequence::end_handle(), moab::Range::erase(), ErrorCode, moab::RangeSeqIntersectIter::get_end_handle(), moab::RangeSeqIntersectIter::get_sequence(), moab::RangeSeqIntersectIter::get_start_handle(), moab::RangeSeqIntersectIter::init(), moab::Range::insert(), moab::RangeSeqIntersectIter::is_at_end(), moab::Range::lower_bound(), MB_END_ID, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBQUAD, MBTRI, moab::EntitySequence::start_handle(), moab::RangeSeqIntersectIter::step(), and moab::Range::subset_by_type().
    ErrorCode rval;
    SequenceManager sequences;
    RangeSeqIntersectIter iter( &sequences );
    Range range;
    // create some entity sequences
    EntitySequence *ts1, *ts2, *ts3, *qs1;
    EntityHandle th1, th2, th3, qh1;
    const int nt1 = 100, nt2 = 10, nt3 = 1, nq1 = 20;
    rval = sequences.create_entity_sequence( MBTRI, nt1, 3, 5, th1, ts1, -1 );
    rval = sequences.create_entity_sequence( MBTRI, nt2, 6, 0, th2, ts2, -1 );
    rval = sequences.create_entity_sequence( MBTRI, nt3, 3, MB_END_ID, th3, ts3, -1 );
    rval = sequences.create_entity_sequence( MBQUAD, nq1, 4, 0, qh1, qs1, -1 );
    // we're going to assume this below, so verify it now
    if( th1 > th2 || th2 > th3 || th3 > qh1 ) return MB_FAILURE;
    // construct an Range containing all valid handles;
    range.clear();
    range.insert( ts1->start_handle(), ts1->end_handle() );
    range.insert( ts2->start_handle(), ts2->end_handle() );
    range.insert( ts3->start_handle(), ts3->end_handle() );
    range.insert( qs1->start_handle(), qs1->end_handle() );
    // iterate over all and check results
    rval = iter.init( range.begin(), range.end() );
    if( ts1 != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != ts1->start_handle() ) return MB_FAILURE;
    if( iter.get_end_handle() != ts1->end_handle() ) return MB_FAILURE;
    rval = iter.step();
    if( ts2 != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != ts2->start_handle() ) return MB_FAILURE;
    if( iter.get_end_handle() != ts2->end_handle() ) return MB_FAILURE;
    rval = iter.step();
    if( ts3 != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != ts3->start_handle() ) return MB_FAILURE;
    if( iter.get_end_handle() != ts3->end_handle() ) return MB_FAILURE;
    rval = iter.step();
    if( qs1 != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != qs1->start_handle() ) return MB_FAILURE;
    if( iter.get_end_handle() != qs1->end_handle() ) return MB_FAILURE;
    if( !iter.is_at_end() ) return MB_FAILURE;
    rval = iter.step();
    if( MB_FAILURE != rval ) return MB_FAILURE;
    // iterate over just the quads
    rval = iter.init( range.lower_bound( MBQUAD ), range.end() );
    rval = iter.step();
    // iterate starting one past the beginning of the
    // triangles and stopping one before the end.  The last
    // sequence contains only one tri, so should stop and end
    // of second-to-last sequence
    rval = iter.init( ++( range.begin() ), --( range.lower_bound( MBQUAD ) ) );
    if( iter.get_start_handle() != ts1->start_handle() + 1 ) return MB_FAILURE;
    rval = iter.step();
    rval = iter.step();
    // Iterate over the quad sequence, starting two past the
    // beginning and stopping one before the end
    rval = iter.init( ++( range.lower_bound( MBQUAD ) ), --( range.end() ) );
    if( iter.get_start_handle() != qs1->start_handle() + 1 ) return MB_FAILURE;
    if( iter.get_end_handle() != qs1->end_handle() - 1 ) return MB_FAILURE;
    rval = iter.step();
    // Iterate over two subsets of the quad sequence
    Range quads          = range.subset_by_type( MBQUAD );
    EntityHandle removed = qs1->start_handle() + nq1 / 2;
    if( quads.erase( removed ) == quads.end() ) return MB_FAILURE;
    rval = iter.init( quads.begin(), quads.end() );
    if( iter.get_end_handle() != removed - 1 ) return MB_FAILURE;
    rval = iter.step();
    if( iter.get_start_handle() != removed + 1 ) return MB_FAILURE;
    rval = iter.step();
    // Iterate over everything, including a bunch of
    // invalid handles
    Range big;
    int junk;
    EntityHandle last = CREATE_HANDLE( MBQUAD + 1, 0, junk );
    big.insert( ts1->start_handle() - 1, last );
    // first some invalid handles in the beginning of the range
    rval = iter.init( big.begin(), big.end() );
    if( MB_ENTITY_NOT_FOUND != rval ) return MB_FAILURE;
    if( NULL != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != *big.begin() ) return MB_FAILURE;
    if( iter.get_end_handle() != ts1->start_handle() - 1 ) return MB_FAILURE;
    // next the first triangle sequence
    rval = iter.step();
    // next the the invalid handles between the first two tri sequences
    if( ts1->end_handle() + 1 != ts2->start_handle() )
        rval = iter.step();
        if( iter.get_start_handle() != ts1->end_handle() + 1 ) return MB_FAILURE;
        if( iter.get_end_handle() != ts2->start_handle() - 1 ) return MB_FAILURE;
    // next the second triangle sequence
    rval = iter.step();
    // next the the invalid handles between the 2nd and 3rd tri sequences
    if( ts2->end_handle() + 1 != ts3->start_handle() )
        rval = iter.step();
        if( iter.get_start_handle() != ts2->end_handle() + 1 ) return MB_FAILURE;
        if( iter.get_end_handle() != ts3->start_handle() - 1 ) return MB_FAILURE;
    // next the third triangle sequence
    rval = iter.step();
    // third tri sequence contains the MAX tri handle, so no more
    // invalid triangles.
    // next 1 invalid quad at the before MB_START_ID
    if( ts3->end_handle() + 1 != qs1->start_handle() )
        rval = iter.step();
        if( iter.get_start_handle() != ts3->end_handle() + 1 ) return MB_FAILURE;
        if( iter.get_end_handle() != qs1->start_handle() - 1 ) return MB_FAILURE;
    // next the quad sequence
    rval = iter.step();
    // next remaining invalid quad handles in the range
    rval = iter.step();
    if( 0 != iter.get_sequence() ) return MB_FAILURE;
    if( iter.get_start_handle() != qs1->end_handle() + 1 ) return MB_FAILURE;
    if( iter.get_end_handle() != last - 1 ) return MB_FAILURE;
    // next invalid entity after the last quad in the range
    rval = iter.step();
    if( iter.get_start_handle() != last ) return MB_FAILURE;
    if( iter.get_end_handle() != last ) return MB_FAILURE;
    // now at the end
    rval = iter.step();
    // Create some holes
    Error eh;
    EntityHandle ts1s  = ts1->start_handle();
    EntityHandle dead1 = ts1->start_handle() + 1;
    EntityHandle dead2 = ts1->start_handle() + 2;
    EntityHandle ts1e  = ts1->end_handle();
    EntityHandle dead3 = ts2->start_handle();
    EntityHandle dead4 = ts2->end_handle();
    EntityHandle qs1s  = qs1->start_handle();
    EntityHandle qs1e  = qs1->end_handle();
    EntityHandle dead5 = qs1->start_handle() + nq1 / 2;
    EntityHandle dead6 = dead5 + 1;
    rval               = sequences.delete_entity( &eh, dead1 );
    rval = sequences.delete_entity( &eh, dead2 );
    rval = sequences.delete_entity( &eh, dead3 );
    rval = sequences.delete_entity( &eh, dead4 );
    rval = sequences.delete_entity( &eh, dead5 );
    rval = sequences.delete_entity( &eh, dead6 );
    // Iterate over sequences w/out removing deleted entities
    // from range.
    // first sequence should have one valid handle at beginning
    if( 0 == iter.get_sequence() || ts1s != iter.get_sequence()->start_handle() ||
        dead1 - 1 != iter.get_sequence()->end_handle() )
        return MB_FAILURE;
    if( iter.get_end_handle() != dead1 - 1 ) return MB_FAILURE;
    // next two invalid handles in sequence in first sequence
    rval = iter.step();
    if( iter.get_start_handle() != dead1 ) return MB_FAILURE;
    if( iter.get_end_handle() != dead2 ) return MB_FAILURE;
    // next the remainder of the fist sequence
    rval = iter.step();
    if( 0 == iter.get_sequence() || dead2 + 1 != iter.get_sequence()->start_handle() ||
        ts1e != iter.get_sequence()->end_handle() )
        return MB_FAILURE;
    if( iter.get_start_handle() != dead2 + 1 ) return MB_FAILURE;
    if( iter.get_end_handle() != ts1e ) return MB_FAILURE;
    // next an invalid handle at the start of the second sequence
    rval = iter.step();
    if( iter.get_start_handle() != dead3 ) return MB_FAILURE;
    if( iter.get_end_handle() != dead3 ) return MB_FAILURE;
    // next the second sequence up to the invalid handle at the end
    rval = iter.step();
    if( 0 == iter.get_sequence() || dead3 + 1 != iter.get_sequence()->start_handle() ||
        dead4 - 1 != iter.get_sequence()->end_handle() )
        return MB_FAILURE;
    if( iter.get_start_handle() != dead3 + 1 ) return MB_FAILURE;
    if( iter.get_end_handle() != dead4 - 1 ) return MB_FAILURE;
    // next invaild handle at the end of the second sequence
    rval = iter.step();
    if( iter.get_start_handle() != dead4 ) return MB_FAILURE;
    if( iter.get_end_handle() != dead4 ) return MB_FAILURE;
    // next the third sequence
    rval = iter.step();
    // next the quad sequence up to the invalid handle in the middle
    rval = iter.step();
    if( 0 == iter.get_sequence() || qs1s != iter.get_sequence()->start_handle() ||
        dead5 - 1 != iter.get_sequence()->end_handle() )
        return MB_FAILURE;
    if( iter.get_start_handle() != qs1s ) return MB_FAILURE;
    if( iter.get_end_handle() != dead5 - 1 ) return MB_FAILURE;
    // next the two invalid handles in the middle
    rval = iter.step();
    if( iter.get_start_handle() != dead5 ) return MB_FAILURE;
    if( iter.get_end_handle() != dead6 ) return MB_FAILURE;
    // next the remainder of the quad sequence
    rval = iter.step();
    if( 0 == iter.get_sequence() || dead6 + 1 != iter.get_sequence()->start_handle() ||
        qs1e != iter.get_sequence()->end_handle() )
        return MB_FAILURE;
    if( iter.get_start_handle() != dead6 + 1 ) return MB_FAILURE;
    if( iter.get_end_handle() != qs1e ) return MB_FAILURE;
    // now at the end
    rval = iter.step();
    // now remove the dead entities from the range and iterate again
    if( range.erase( dead1 ) == quads.end() ) return MB_FAILURE;
    if( range.erase( dead2 ) == quads.end() ) return MB_FAILURE;
    if( range.erase( dead3 ) == quads.end() ) return MB_FAILURE;
    if( range.erase( dead4 ) == quads.end() ) return MB_FAILURE;
    if( range.erase( dead5 ) == quads.end() ) return MB_FAILURE;
    if( range.erase( dead6 ) == quads.end() ) return MB_FAILURE;
        return MB_FAILURE;
    if( iter.get_start_handle() != ts1s ) return MB_FAILURE;
    // next the remainder of the fist sequence after the hole
    rval = iter.step();
        return MB_FAILURE;
    // next the second sequence between deleted start and end handles
    rval = iter.step();
        return MB_FAILURE;
    rval = iter.step();
    // next the quad sequence up to the hole in the middle
    rval = iter.step();
        return MB_FAILURE;
    // next the remainder of the quad sequence after the hole
    rval = iter.step();
        return MB_FAILURE;
    // now at the end
    rval = iter.step();
    return MB_SUCCESS;
Definition at line 5775 of file MBTest.cpp.
References ErrorCode, moab::Interface::load_file(), MB_FILE_DOES_NOT_EXIST, and MB_SUCCESS.
    Core moab;
    const char BAD_FILE_NAME[] = "non-existant-file.txt";
    ErrorCode rval;
    FILE* fptr = fopen( BAD_FILE_NAME, "r" );
    if( fptr )
        fclose( fptr );
        std::cout << "Test cannot proceed while file exists: " << BAD_FILE_NAME << std::endl;
        return MB_FAILURE;
    // try reading a non-existant file
    rval = mb->load_file( BAD_FILE_NAME );
    if( MB_FILE_DOES_NOT_EXIST != rval ) return MB_FAILURE;
    // try reading an invalid file
    if( !argv0 )  // not set by main, oops!
        return MB_FAILURE;
    rval = mb->load_file( argv0 );
    if( MB_SUCCESS == rval ) return MB_FAILURE;
    return MB_SUCCESS;
Test behavior of various functions when passed the root set
Definition at line 7485 of file MBTest.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_child_meshsets(), moab::Interface::add_entities(), moab::Interface::add_parent_child(), moab::Interface::add_parent_meshset(), moab::Interface::add_parent_meshsets(), CHECK, moab::Interface::clear_meshset(), moab::Interface::contains_entities(), moab::Interface::create_meshset(), moab::Interface::dimension_from_handle(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_contained_meshsets(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), moab::Interface::get_root_set(), moab::Range::insert(), moab::Interface::intersect_meshset(), MB_CHK_ERR, MB_SUCCESS, MBENTITYSET, MESHSET_SET, MESHSET_TRACK_OWNER, moab::Interface::num_child_meshsets(), moab::Interface::num_contained_meshsets(), moab::Interface::num_parent_meshsets(), moab::Interface::remove_child_meshset(), moab::Interface::remove_entities(), moab::Interface::remove_parent_child(), moab::Interface::remove_parent_meshset(), moab::Interface::replace_entities(), moab::Interface::set_meshset_options(), moab::Range::size(), moab::Interface::subtract_meshset(), moab::Interface::type_from_handle(), and moab::Interface::unite_meshset().
    ErrorCode rval;
    Core moab;
    EntityHandle rs = mb->get_root_set();
    // expect root set to have zero handle
    CHECK( !rs );
    // check type
    EntityType type = mb->type_from_handle( rs );
    CHECK( MBENTITYSET == type );
    // Create a set to test with
    EntityHandle some_set;
    rval = mb->create_meshset( MESHSET_SET, some_set );MB_CHK_ERR( rval );
    Range sets;
    sets.insert( some_set );
    int exp_dim = mb->dimension_from_handle( some_set );
    int dim     = mb->dimension_from_handle( rs );
    CHECK( exp_dim == dim );
    // test some stuff that should fail
    rval = mb->clear_meshset( &rs, 1 );
    CHECK( MB_SUCCESS != rval );
    rval = mb->set_meshset_options( rs, MESHSET_ORDERED );
    rval = mb->subtract_meshset( rs, some_set );
    rval = mb->intersect_meshset( rs, some_set );
    rval = mb->unite_meshset( rs, some_set );
    // add/remove should fail for root set?
    rval = mb->add_entities( rs, &some_set, 1 );
    rval = mb->remove_entities( rs, &some_set, 1 );
    rval = mb->replace_entities( rs, &some_set, &some_set, 1 );
    // check flags
    unsigned flags;
    rval = mb->get_meshset_options( rs, flags );
    CHECK( flags & MESHSET_SET );
    CHECK( !( flags & MESHSET_ORDERED ) );
    CHECK( flags & MESHSET_TRACK_OWNER );
    // contains tests
    bool c = mb->contains_entities( rs, &some_set, 1 );
    CHECK( c );
    Range sets2;
    rval = mb->get_contained_meshsets( rs, sets2 );MB_CHK_ERR( rval );
    CHECK( sets == sets2 );
    int count;
    rval = mb->num_contained_meshsets( rs, &count );MB_CHK_ERR( rval );
    CHECK( count == (int)sets.size() );
    // The expected behavior for parent/child queries on the root set
    // is to return an error.
    rval = mb->get_parent_meshsets( rs, sets2 );
    rval = mb->get_parent_meshsets( rs, sets2, 2 );
    rval = mb->get_child_meshsets( rs, sets2 );
    rval = mb->get_child_meshsets( rs, sets2, 2 );
    rval = mb->num_parent_meshsets( rs, &count );
    rval = mb->num_parent_meshsets( rs, &count, 2 );
    rval = mb->num_child_meshsets( rs, &count );
    rval = mb->num_child_meshsets( rs, &count, 2 );
    rval = mb->add_parent_meshset( rs, some_set );
    rval = mb->add_parent_meshsets( rs, &some_set, 1 );
    rval = mb->add_child_meshset( rs, some_set );
    rval = mb->add_child_meshsets( rs, &some_set, 1 );
    rval = mb->add_parent_child( rs, some_set );
    rval = mb->remove_parent_child( rs, some_set );
    rval = mb->remove_parent_meshset( rs, some_set );
    rval = mb->remove_child_meshset( rs, some_set );
    return MB_SUCCESS;
Definition at line 4313 of file MBTest.cpp.
References CHECK_EQUAL, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, MBEDGE, MBPRISM, MBQUAD, MBTRI, and moab::Interface::side_number().
    ErrorCode rval;
    Core moab;
    /* Create faces of a wedge: */
            4
        /   2   \
       3.../.\...5
       |/       \|      6 // off vertex
       0_________1
    const double coords[][3] = {
        { 0, 0, 0 }, { 2, 0, 0 }, { 1, 0, 1 }, { 0, 2, 0 }, { 2, 2, 0 }, { 1, 2, 1 }, { 3, 1, 0 },
    EntityHandle verts[7];
    for( unsigned i = 0; i < 7; ++i )
        mb->create_vertex( coords[i], verts[i] );
    EntityHandle faces[6];
    EntityHandle tri[]   = { verts[0], verts[1], verts[2] };
    EntityHandle tri2[]  = { verts[3], verts[4], verts[5] };
    EntityHandle quad1[] = { verts[0], verts[1], verts[5], verts[3] };
    EntityHandle quad2[] = { verts[1], verts[5], verts[4], verts[2] };
    EntityHandle quad3[] = { verts[2], verts[4], verts[3], verts[0] };
    rval                 = mb->create_element( MBTRI, tri, 3, faces[0] );MB_CHK_ERR( rval );
    rval = mb->create_element( MBQUAD, quad1, 4, faces[1] );MB_CHK_ERR( rval );
    rval = mb->create_element( MBQUAD, quad2, 4, faces[2] );MB_CHK_ERR( rval );
    rval = mb->create_element( MBQUAD, quad3, 4, faces[3] );MB_CHK_ERR( rval );
    rval = mb->create_element( MBTRI, tri2, 3, faces[4] );MB_CHK_ERR( rval );
    EntityHandle prism;
    rval = mb->create_element( MBPRISM, verts, 6, prism );MB_CHK_ERR( rval );
     * side_number(const EntityHandle parent,
                                    const EntityHandle child,
                                    int &side_number,
                                    int &sense,
                                    int &offset)
    int side_n, sen, ofs;
    rval = mb->side_number( prism, faces[0], side_n, sen, ofs );MB_CHK_ERR( rval );
    CHECK_EQUAL( side_n, 3 );
    CHECK_EQUAL( sen, -1 );
    CHECK_EQUAL( ofs, 0 );
    // this diagonal should not be on the prism (not an edge of the prism)
    EntityHandle diagonal1;
    EntityHandle diag[] = { verts[2], verts[3] };
    rval                = mb->create_element( MBEDGE, diag, 2, diagonal1 );MB_CHK_ERR( rval );
    rval = mb->side_number( prism, diagonal1, side_n, sen, ofs );
    // expected fail
    if( rval != MB_FAILURE ) return MB_FAILURE;
    // create another triangle, connected to the  prism, but not on the side
    EntityHandle tri3[] = { verts[3], verts[4], verts[6] };
    rval                = mb->create_element( MBTRI, tri3, 3, faces[5] );MB_CHK_ERR( rval );
    rval = mb->side_number( prism, faces[5], side_n, sen, ofs );
    // expected fail
    return MB_SUCCESS;
Definition at line 6981 of file MBTest.cpp.
References mb_skin_full_common().
    return mb_skin_full_common( 2, true );
Definition at line 6716 of file MBTest.cpp.
References mb_skin_reversed_common().
    return mb_skin_reversed_common( 2, true );
Definition at line 6861 of file MBTest.cpp.
References mb_skin_subset_common().
    return mb_skin_subset_common( 2, true );
Definition at line 6989 of file MBTest.cpp.
    return mb_skin_full_common( 3, true );
Definition at line 6724 of file MBTest.cpp.
    return mb_skin_reversed_common( 3, true );
Definition at line 6869 of file MBTest.cpp.
    return mb_skin_subset_common( 3, true );
Definition at line 6994 of file MBTest.cpp.
References conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), edges, moab::Range::end(), error_count, ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), MB_SUCCESS, MBEDGE, MBQUAD, run(), skin(), and vtx().
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    Skinner tool( &mb );
    /* Mesh with vertices and quads numbered.
       Groups are indicated by letters {A,B,C,D}
       0----1----2----3----4----5
       | (0)| (1)| (2)| (3)| (4)|
       |  A |  A |  B |  B |  B |
       6----7----8----9---10---11
       | (5)| (6)| (7)| (8)| (9)|
       |  A |  A |  A |  B |  B |
      12---13---14---15---16---17
       |(10)|(11)|(12)|(13)|(14)|
       |  A |  C |  D |  D |  D |
      18---19---20---21---22---23
       |(15)|(16)|(17)|(18)|(19)|
       |  C |  C |  C |  D |  D |
      24---25---26---27---28---29
    const int num_vtx = 30;
    EntityHandle vtx[num_vtx];
    for( int i = 0; i < 6; ++i )
        for( int j = 0; j < 5; ++j )
            double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), 0 };
            rval             = mb.create_vertex( coords, vtx[6 * j + i] );
    EntityHandle quads[20];
    for( int i = 0; i < 5; ++i )
        for( int j = 0; j < 4; ++j )
            int v                = 6 * j + i;
            EntityHandle conn[4] = { vtx[v + 6], vtx[v + 7], vtx[v + 1], vtx[v + 0] };
            rval                 = mb.create_element( MBQUAD, conn, 4, quads[5 * j + i] );
    // Define four groups of quads (as labeled above)
    const int Aquads[]    = { 0, 1, 5, 6, 7, 10 };
    const int Aquads_size = sizeof( Aquads ) / sizeof( Aquads[0] );
    const int Bquads[]    = { 2, 3, 4, 8, 9 };
    const int Bquads_size = sizeof( Bquads ) / sizeof( Bquads[0] );
    const int Cquads[]    = { 11, 15, 16, 17 };
    const int Cquads_size = sizeof( Cquads ) / sizeof( Cquads[0] );
    const int Dquads[]    = { 12, 13, 14, 18, 19 };
    const int Dquads_size = sizeof( Dquads ) / sizeof( Dquads[0] );
    // Define the results we expect for each group as a loop
    // of vertex indices
    const int Askin[]    = { 0, 1, 2, 8, 9, 15, 14, 13, 19, 18, 12, 6 };
    const int Ashared[]  = { -1, -1, 1, 1, 1, 3, 2, 2, 2, -1, -1, -1 };
    const int Askin_size = sizeof( Askin ) / sizeof( Askin[0] );
    const int Bskin[]    = { 2, 3, 4, 5, 11, 17, 16, 15, 9, 8 };
    const int Bshared[]  = { -1, -1, -1, -1, -1, 3, 3, 0, 0, 0 };
    const int Bskin_size = sizeof( Bskin ) / sizeof( Bskin[0] );
    const int Cskin[]    = { 18, 19, 13, 14, 20, 21, 27, 26, 25, 24 };
    const int Cshared[]  = { 0, 0, 0, 3, 3, 3, -1, -1, -1, -1 };
    const int Cskin_size = sizeof( Cskin ) / sizeof( Cskin[0] );
    const int Dskin[]    = { 14, 15, 16, 17, 23, 29, 28, 27, 21, 20 };
    const int Dshared[]  = { 0, 1, 1, -1, -1, -1, -1, 2, 2, 2 };
    const int Dskin_size = sizeof( Dskin ) / sizeof( Dskin[0] );
    // Make the above stuff indexable for easier looping
    const int* const gquads[4] = { Aquads, Bquads, Cquads, Dquads };
    const int gquads_size[4]   = { Aquads_size, Bquads_size, Cquads_size, Dquads_size };
    const int* const skin[4]   = { Askin, Bskin, Cskin, Dskin };
    const int* const shared[4] = { Ashared, Bshared, Cshared, Dshared };
    const int skin_size[4]     = { Askin_size, Bskin_size, Cskin_size, Dskin_size };
    // Create an Range for each group of quads
    Range ranges[4];
    for( int grp = 0; grp < 4; ++grp )
        for( int i = 0; i < gquads_size[grp]; ++i )
            ranges[grp].insert( quads[gquads[grp][i]] );
    // run test 4 times, one for each of:
    // o no adjacencies, no edges
    // o no adjacencies, edges
    // o adjacencies, edges
    // o adjacencies, no edges
    // Be careful here: once we specify use_adj, we can't
    // unspecify it (the adjacencies will exist so the skinner
    // will use them, regardless of the passed flag.)
    int error_count = 0;
    for( int run = 0; run < 4; ++run )
        const bool use_adj = run > 1;
        if( run == 3 )
            Range dead;
            mb.get_entities_by_type( 0, MBEDGE, dead );
            mb.delete_entities( dead );
        // test each group
        Range edges[4];
            // get the skin edges
            rval = tool.find_skin( 0, ranges[grp], 1, edges[grp], use_adj );
                std::cout << "Skinner failed for run " << run << " group " << grp << std::endl;
                return rval;
            // check that we have the expected result
            std::vector< bool > seen( skin_size[grp], false );
            for( Range::iterator e = edges[grp].begin(); e != edges[grp].end(); ++e )
                const EntityHandle* conn;
                int len;
                rval = mb.get_connectivity( *e, conn, len );
                if( len != 2 ) return MB_FAILURE;
                const int idx1 = std::find( vtx, vtx + num_vtx, conn[0] ) - vtx;
                const int idx2 = std::find( vtx, vtx + num_vtx, conn[1] ) - vtx;
                int pos        = std::find( skin[grp], skin[grp] + skin_size[grp], idx1 ) - skin[grp];
                if( pos == skin_size[grp] )
                    std::cout << "Non-skin vertex in skin for run " << run << " group " << grp << std::endl;
                    std::cout << "idx1 = " << idx1 << ", idx2 = " << idx2 << std::endl;
                    ++error_count;
                    continue;
                if( skin[grp][( pos + skin_size[grp] - 1 ) % skin_size[grp]] == idx2 )
                    pos = ( pos + skin_size[grp] - 1 ) % skin_size[grp];
                else if( skin[grp][( pos + 1 ) % skin_size[grp]] != idx2 )
                    std::cout << "Non-skin edge in skin for run " << run << " group " << grp << std::endl;
                    ++error_count;
                    continue;
                if( seen[pos] )
                    std::cout << "Duplicate edge in skin for run " << run << " group " << grp << std::endl;
                    ++error_count;
                seen[pos] = true;
                int shared_with = shared[grp][pos];
                if( shared_with < 0 )  // not shared with another group
                    continue;
                if( shared_with > grp )  // didn't skin other group yet
                    continue;
                if( edges[shared_with].find( *e ) == edges[shared_with].end() )
                    std::cout << "Skin edge duplicated for run " << run << " group " << grp << std::endl;
                    std::cout << "idx1 = " << idx1 << ", idx2 = " << idx2 << " not in skin for group " << shared_with
                              << std::endl;
                    ++error_count;
            int missing = std::count( seen.begin(), seen.end(), false );
            if( missing )
                std::cout << "Missking " << missing << " skin edges for run " << run << " group " << grp << std::endl;
                error_count += missing;
    return error_count ? MB_FAILURE : MB_SUCCESS;
Definition at line 5393 of file MBTest.cpp.
References mb_skin_curve_test_common().
    return mb_skin_curve_test_common( true );
Definition at line 5388 of file MBTest.cpp.
    return mb_skin_curve_test_common( false );
Definition at line 5422 of file MBTest.cpp.
References moab::Range::back(), moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_vertex(), edges, ErrorCode, moab::Skinner::find_skin(), moab::Range::front(), moab::Interface::get_connectivity(), moab::Range::insert(), MB_SUCCESS, MBEDGE, moab::Range::size(), skin(), and swap().
Referenced by mb_skin_curve_adj_test(), and mb_skin_curve_test().
    ErrorCode rval;
    Core moab;
    std::vector< EntityHandle > verts;
    for( unsigned i = 0; i < 10; ++i )
        double coords[] = { static_cast< double >( i ), 0, 0 };
        EntityHandle h;
        mb->create_vertex( coords, h );
        verts.push_back( h );
    Range edges;
    for( unsigned i = 1; i < verts.size(); ++i )
        EntityHandle conn[] = { verts[i - 1], verts[i] };
        EntityHandle h;
        mb->create_element( MBEDGE, conn, 2, h );
        edges.insert( h );
    Range skin;
    Skinner tool( mb );
    rval = tool.find_skin( 0, edges, 0, skin, use_adj );
        std::cerr << "Skinner failure at " __FILE__ ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    if( skin.size() != 2 )
        std::cerr << "Skinner bad result at " __FILE__ ":" << __LINE__ << std::endl;
        return MB_FAILURE;
    if( verts.front() > verts.back() ) std::swap( verts.front(), verts.back() );
    if( skin.front() != verts.front() || skin.back() != verts.back() )
        return MB_FAILURE;
    // now test again with only one edge
    EntityHandle edge = edges.front();
    Range range( edge, edge );
    skin.clear();
    rval = tool.find_skin( 0, range, 0, skin, use_adj );
        return MB_FAILURE;
        return MB_FAILURE;
    Range verts2;
    mb->get_connectivity( &edge, 1, verts2 );
    if( skin.front() != verts2.front() || skin.back() != verts2.back() )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 6977 of file MBTest.cpp.
    return mb_skin_full_common( 2, false );
Definition at line 6712 of file MBTest.cpp.
    return mb_skin_reversed_common( 2, false );
Definition at line 6857 of file MBTest.cpp.
    return mb_skin_subset_common( 2, false );
Definition at line 5679 of file MBTest.cpp.
References moab::Interface::add_entities(), conn, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::error(), ErrorCode, moab::Interface::get_entities_by_dimension(), MB_CHK_ERR, MB_SUCCESS, MBHEX, MBQUAD, MESHSET_SET, and moab::Range::size().
    Core moab;
    ErrorCode error;
    const double coords[] = { 0, 0, 0, 1, 0, 0, 2, 0, 0, 2, 1, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 2, 0, 1,
                              2, 1, 1, 1, 1, 1, 0, 1, 1, 0, 0, 2, 1, 0, 2, 2, 0, 2, 2, 1, 2, 1, 1, 2, 0, 1, 2 };
    const size_t num_vtx  = sizeof( coords ) / sizeof( double ) / 3;
    const int conn[]       = { 0, 1, 4,  5,  6,  7,  10, 11, 1, 2, 3, 4,  7,  8,  9,  10,
                         6, 7, 10, 11, 12, 13, 16, 17, 7, 8, 9, 10, 13, 14, 15, 16 };
    const size_t num_elems = sizeof( conn ) / sizeof( int ) / 8;
    EntityHandle verts[num_vtx], cells[num_elems];
    for( size_t i = 0; i < num_vtx; ++i )
        error = mb->create_vertex( coords + 3 * i, verts[i] );MB_CHK_ERR( error );
    for( size_t i = 0; i < num_elems; ++i )
        EntityHandle c[8];
        for( int j = 0; j < 8; j++ )
            c[j] = verts[conn[8 * i + j]];
        error = mb->create_element( MBHEX, c, 8, cells[i] );MB_CHK_ERR( error );
    EntityHandle fileset;
    error = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( error );
    error = mb->add_entities( fileset, &verts[0], num_vtx );MB_CHK_ERR( error );
    error = mb->add_entities( fileset, &cells[0], num_elems );MB_CHK_ERR( error );
    Range fverts, fedges, ffaces, fcells;
    error = mb->get_entities_by_dimension( fileset, 0, fverts );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fileset, 1, fedges );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fileset, 2, ffaces );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fileset, 3, fcells );MB_CHK_ERR( error );
    assert( fverts.size() == 18 && fedges.size() == 0 && ffaces.size() == 0 && fcells.size() == 4 );
    Skinner sk( mb );
    Range skin_ents;
    error = sk.find_skin( fileset, fcells, 2, skin_ents, false, true );MB_CHK_ERR( error );
    assert( ffaces.size() == 16 );
    error = sk.find_skin( fileset, fcells, 1, skin_ents, false, true );MB_CHK_ERR( error );
    assert( fedges.size() == 32 );
    const double fcoords[] = { 0, 0, 3, 1, 0, 3, 2, 0, 3, 2, 1, 3, 1, 1, 3, 0, 1, 3 };
    const size_t num_fvtx  = sizeof( fcoords ) / sizeof( double ) / 3;
    const int fconn[]      = { 0, 1, 4, 5, 1, 2, 3, 4 };
    const size_t num_faces = sizeof( fconn ) / sizeof( int ) / 4;
    EntityHandle nwverts[num_fvtx], faces[num_faces];
    for( size_t i = 0; i < num_fvtx; ++i )
        error = mb->create_vertex( fcoords + 3 * i, nwverts[i] );MB_CHK_ERR( error );
    for( size_t i = 0; i < num_faces; ++i )
        EntityHandle c[4];
        for( int j = 0; j < 4; j++ )
            c[j] = nwverts[fconn[4 * i + j]];
        error = mb->create_element( MBQUAD, c, 4, faces[i] );MB_CHK_ERR( error );
    EntityHandle fileset1;
    error = mb->create_meshset( MESHSET_SET, fileset1 );MB_CHK_ERR( error );
    error = mb->add_entities( fileset1, &nwverts[0], num_fvtx );MB_CHK_ERR( error );
    error = mb->add_entities( fileset1, &faces[0], num_faces );MB_CHK_ERR( error );
    Range verts1, edges1, faces1;
    error = mb->get_entities_by_dimension( fileset1, 0, verts1 );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fileset1, 1, edges1 );MB_CHK_ERR( error );
    error = mb->get_entities_by_dimension( fileset1, 2, faces1 );MB_CHK_ERR( error );
    assert( verts1.size() == 6 && edges1.size() == 0 && faces1.size() == 2 );
    //  error = sk.find_skin(fileset1, faces1, 1, skin_ents, false, true);MB_CHK_ERR(error);
    error = sk.find_skin( fileset1, faces1, false, skin_ents, NULL, true, true, false );MB_CHK_ERR( error );
    assert( edges1.size() == 6 );
    return MB_SUCCESS;
ErrorCode mb_skin_full_common ( int  dimension,
bool  use_adj
Definition at line 6874 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_number_entities_by_dimension(), moab::Range::insert(), MB_SUCCESS, MBHEX, MBQUAD, n, moab::Range::size(), and skin().
Referenced by mb_skin_adj_faces_full_test(), mb_skin_adj_regions_full_test(), mb_skin_faces_full_test(), and mb_skin_regions_full_test().
    EntityType type;
    switch( dimension )
        case 2:
            type = MBQUAD;
            break;
        case 3:
            type = MBHEX;
            break;
        default:
            assert( false );
            return MB_FAILURE;
        3----4----5
        0----1----2
    ErrorCode rval;
    Core moab;
    // create vertices
    const double coords2D[6][2] = { { 0, 0 }, { 1, 0 }, { 2, 0 }, { 0, 1 }, { 1, 1 }, { 2, 1 } };
    EntityHandle v[2][6]        = { { 0, 0, 0, 0, 0, 0 }, { 0, 0, 0, 0, 0, 0 } };
    for( int d = 1; d < dimension; ++d )
            double coords[3] = { coords2D[i][0], coords2D[i][1], static_cast< double >( d - 1 ) };
            rval             = mb.create_vertex( coords, v[d - 1][i] );
    // create elements
    Range input;
    EntityHandle elems[2], econn[2][8];
    for( int i = 0; i < 2; ++i )
        EntityHandle conn[8] = { v[0][i], v[0][i + 1], v[0][i + 4], v[0][i + 3],
                                 v[1][i], v[1][i + 1], v[1][i + 4], v[1][i + 3] };
        memcpy( econn[i], conn, sizeof( conn ) );
        rval = mb.create_element( type, conn, CN::VerticesPerEntity( type ), elems[i] );
        input.insert( elems[i] );
    // create sides
    // NOTE: Shared side is element 0 side 1 and element 1 side 3
    Range expected;
    for( int i = 0; i < CN::NumSubEntities( type, dimension - 1 ); ++i )
        EntityType subtype;
        int len;
        const short* indices = CN::SubEntityVertexIndices( type, dimension - 1, i, subtype, len );
        EntityHandle conn[4];
        assert( (size_t)len <= sizeof( conn ) / sizeof( conn[0] ) );
        for( int j = 0; j < 2; ++j )
            if( j == 1 && i == 3 )  // don't create shared face twice
                continue;
            for( int k = 0; k < len; ++k )
                conn[k] = econn[j][indices[k]];
            EntityHandle h;
            rval = mb.create_element( subtype, conn, len, h );
            if( j != 0 || i != 1 )  // don't insert shared face
                expected.insert( h );
    Range skin;
    rval = tool.find_skin( 0, input, false, skin, 0, use_adj, true );
        std::cout << "Skinner failed to find skin elements" << std::endl;
        return MB_FAILURE;
    if( skin != expected )
        std::cout << "Skinner returned incorrect skin elements" << std::endl;
        return MB_FAILURE;
    int n = 0;
    mb.get_number_entities_by_dimension( 0, dimension - 1, n );
    if( (size_t)n != expected.size() + 1 )
        std::cout << "Skinner created extra lower-dimension entities" << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 6243 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, MBMesquite::faces, moab::Skinner::find_skin(), moab::Interface::get_connectivity(), moab::Interface::get_error_string(), moab::Range::insert(), MB_SUCCESS, MBQUAD, MBTRI, moab::Range::size(), skin(), and u.
Referenced by mb_skin_adj_higher_order_faces_test(), and mb_skin_higher_order_faces_test().
    /* Create mesh:
       0---1---2---3---4
       5   6   7  8 9
       10--11--12
    ErrorCode rval;
    Core moab;
    double coords[13][3] = { { 0, 4, 0 }, { 2, 4, 0 }, { 4, 4, 0 }, { 6, 4, 0 }, { 8, 4, 0 }, { 0, 2, 0 }, { 2, 2, 0 },
                             { 4, 2, 0 }, { 5, 2, 0 }, { 6, 2, 0 }, { 0, 0, 0 }, { 2, 0, 0 }, { 4, 0, 0 } };
    EntityHandle verts[13];
    for( int i = 0; i < 13; ++i )
        rval = mb.create_vertex( coords[i], verts[i] );
    EntityHandle qconn[9] = { verts[0], verts[2],  verts[12], verts[10], verts[1],
                              verts[7], verts[11], verts[5],  verts[6] };
    EntityHandle tconn[7] = { verts[2], verts[4], verts[12], verts[3], verts[9], verts[7], verts[8] };
    EntityHandle quad, tri;
    rval = mb.create_element( MBQUAD, qconn, 9, quad );
    rval = mb.create_element( MBTRI, tconn, 7, tri );
    Range faces;
    faces.insert( quad );
    faces.insert( tri );
    Range skin_verts;
    const int skin_vert_idx[] = { 0, 1, 2, 3, 4, 5, 9, 10, 11, 12 };
    for( size_t i = 0; i < sizeof( skin_vert_idx ) / sizeof( skin_vert_idx[0] ); ++i )
        skin_verts.insert( verts[skin_vert_idx[i]] );
    Range skin;
    rval = tool.find_skin( 0, faces, true, skin, 0, use_adj, false );
        std::cout << "Vertex skinning failed with: " << mb.get_error_string( rval ) << std::endl;
        return rval;
    if( skin != skin_verts )
        std::cout << "Skinner returned incorrect vertices." << std::endl;
        return MB_FAILURE;
    const int skin_edges[5][3] = { { 0, 1, 2 }, { 2, 3, 4 }, { 4, 9, 12 }, { 12, 11, 10 }, { 10, 5, 0 } };
    skin.clear();
    rval = tool.find_skin( 0, faces, false, skin, 0, use_adj, true );
        std::cout << "Edge skinning failed with: " << mb.get_error_string( rval ) << std::endl;
        return rval;
    if( skin.size() != 5u )
        std::cout << "Skinner returned " << skin.size() << " vertices.  Expected 5" << std::endl;
        return MB_FAILURE;
    int num_quadratic = 0;
    int len;
    for( Range::iterator i = skin.begin(); i != skin.end(); ++i )
        rval = mb.get_connectivity( *i, conn, len, false );
        if( len == 3 )
            num_quadratic++;
        else if( len != 2 )
            std::cerr << "Skinner created edge with " << len << " vertices" << std::endl;
            return MB_FAILURE;
    if( num_quadratic != 5 )
        std::cerr << num_quadratic << " of 5 created edges were quadratic" << std::endl;
        return MB_FAILURE;
        bool found = false;
        for( Range::iterator j = skin.begin(); j != skin.end(); ++j )
            mb.get_connectivity( *j, conn, len, false );
            if( conn[2] == verts[skin_edges[i][1]] )
                found = true;
                break;
        if( !found )
            std::cerr << "One or more skin edges is incorrect" << std::endl;
            return MB_FAILURE;
        if( ( conn[0] != verts[skin_edges[i][0]] || conn[1] != verts[skin_edges[i][2]] ) &&
            ( conn[0] != verts[skin_edges[i][2]] || conn[1] != verts[skin_edges[i][0]] ) )
            std::cerr << "Invalid skin edge connectivity" << std::endl;
            return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 6363 of file MBTest.cpp.
References mb_skin_higher_order_faces_common().
Referenced by main().
    return mb_skin_higher_order_faces_common( false );
Definition at line 6559 of file MBTest.cpp.
References moab::Range::begin(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, MBMesquite::faces, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Range::insert(), MB_SUCCESS, MBPYRAMID, MBQUAD, MBTRI, moab::Range::subset_by_type(), and smoab::UNION.
    // create mesh containing 13-node pyramid
    ErrorCode rval;
    Core moab;
    Range pyramids;
    // easier to create a 27 node grid, and then pick a 13-node pyramid
    EntityHandle verts[3][3][3];
    for( int i = 0; i < 3; ++i )
        for( int j = 0; j < 3; ++j )
            for( int k = 0; k < 3; ++k )
                double coords[] = { static_cast< double >( i ), static_cast< double >( j ),
                                    static_cast< double >( k ) };
                rval            = mb.create_vertex( coords, verts[i][j][k] );
    EntityHandle piramid1[13] = { 19, 25, 27, 21, 1, 22, 26, 24, 20, 10, 13, 14, 11 };
    EntityHandle h;
    rval = mb.create_element( MBPYRAMID, piramid1, 13, h );
    pyramids.insert( h );
    Range faces;
    rval = mb.get_adjacencies( pyramids, 2, true, faces, Interface::UNION );
    // triangles should have 6 nodes, quads 8 nodes
    Range tris  = faces.subset_by_type( MBTRI );
    Range quads = faces.subset_by_type( MBQUAD );
    for( Range::iterator tit = tris.begin(); tit != tris.end(); tit++ )
        EntityHandle triangle = *tit;
        int num_verts;
        rval = mb.get_connectivity( triangle, conn, num_verts );
        if( 6 != num_verts ) return MB_FAILURE;
    for( Range::iterator qit = quads.begin(); qit != quads.end(); qit++ )
        EntityHandle quad = *qit;
        int num_verts;
        rval = mb.get_connectivity( quad, conn, num_verts );
        if( 8 != num_verts ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 6373 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_connectivity(), moab::Interface::get_error_string(), moab::Interface::get_number_entities_by_dimension(), moab::Range::insert(), moab::intersect(), MB_SUCCESS, MBHEX, MBQUAD, moab::Range::size(), skin(), and u.
Referenced by mb_skin_adj_higher_order_regions_test(), and mb_skin_higher_order_regions_test().
    // create mesh containing two 27-node hexes
       0,2---1,2---2,2---3,2---4,2
       0,1   1,1   2,1   3,1   4,1
       0,0---1,0---2,0---3,0---4,0
    ErrorCode rval;
    Core moab;
    Range hexes;
    EntityHandle verts[5][3][3];
    int hex_conn[][3] = { // corners
                          { 0, 0, 0 },
                          { 2, 0, 0 },
                          { 2, 2, 0 },
                          { 0, 2, 0 },
                          { 0, 0, 2 },
                          { 2, 0, 2 },
                          { 2, 2, 2 },
                          { 0, 2, 2 },
                          // mid-edge
                          { 1, 0, 0 },
                          { 2, 1, 0 },
                          { 1, 2, 0 },
                          { 0, 1, 0 },
                          { 0, 0, 1 },
                          { 2, 0, 1 },
                          { 2, 2, 1 },
                          { 0, 2, 1 },
                          { 1, 0, 2 },
                          { 2, 1, 2 },
                          { 1, 2, 2 },
                          { 0, 1, 2 },
                          // mid-face
                          { 1, 0, 1 },
                          { 2, 1, 1 },
                          { 1, 2, 1 },
                          { 0, 1, 1 },
                          { 1, 1, 0 },
                          { 1, 1, 2 },
                          // mid-volume
                          { 1, 1, 1 } };
    EntityHandle hexverts[2][27];
        EntityHandle h;
        for( int j = 0; j < 27; ++j )
            hexverts[i][j] = verts[2 * i + hex_conn[j][0]][hex_conn[j][1]][hex_conn[j][2]];
        rval = mb.create_element( MBHEX, hexverts[i], 27, h );
        hexes.insert( h );
    Range interior_verts;
    interior_verts.insert( verts[1][1][1] );  // mid-node of hex 1
    interior_verts.insert( verts[3][1][1] );  // mid-node of hex 2
    interior_verts.insert( verts[2][1][1] );  // mid-node of shared face
    Range skin;
    rval = tool.find_skin( 0, hexes, true, skin, 0, use_adj, false );
    if( MB_SUCCESS != rval )
        return rval;
    Range extra = intersect( skin, interior_verts );
    if( !extra.empty() )
        std::cout << "Skinner returned " << extra.size() << " interior vertices" << std::endl;
        std::cout << extra << std::endl;
        return MB_FAILURE;
    int num_vtx;
    mb.get_number_entities_by_dimension( 0, 0, num_vtx );
    size_t num_skin = num_vtx - interior_verts.size();
    if( skin.size() != num_skin )
        std::cout << "Skinner returned " << skin.size() << " of " << num_skin << " skin vertices" << std::endl;
        return MB_FAILURE;
    skin.clear();
    rval = tool.find_skin( 0, hexes, false, skin, 0, use_adj, true );
        std::cout << "Element skinning failed with: " << mb.get_error_string( rval ) << std::endl;
        return rval;
    if( skin.size() > 10u )
        std::cout << "Skinner created too many faces" << std::endl;
        return MB_FAILURE;
    bool all_okay    = true;
    bool faces[2][6] = { { false, false, false, false, false, false }, { false, false, false, false, false, false } };
    int len;
    for( Range::iterator it = skin.begin(); it != skin.end(); ++it )
        rval = mb.get_connectivity( *it, conn, len );
        if( MB_SUCCESS != rval ) return rval;
        if( len != 9 )
            std::cout << "Skinner created face with " << len << " nodes" << std::endl;
            all_okay = false;
            continue;
        int valid, side, sense, offset;
        for( int h = 0; h < 2; ++h )
            valid = CN::SideNumber( MBHEX, hexverts[h], conn, 4, 2, side, sense, offset );
            if( valid != 0 ) continue;
            if( sense != 1 )
                std::cout << "Skinner created reversed face for hex " << h << " side " << side << std::endl;
                all_okay = false;
                continue;
            int idx[9], len2;
            EntityType sidetype;
            CN::SubEntityNodeIndices( MBHEX, 27, 2, side, sidetype, len2, idx );
            assert( sidetype == MBQUAD );
            assert( len2 == 9 );
            if( conn[offset] != hexverts[h][idx[0]] || conn[( offset + 1 ) % 4] != hexverts[h][idx[1]] ||
                conn[( offset + 2 ) % 4] != hexverts[h][idx[2]] || conn[( offset + 3 ) % 4] != hexverts[h][idx[3]] ||
                conn[4 + offset] != hexverts[h][idx[4]] || conn[4 + ( offset + 1 ) % 4] != hexverts[h][idx[5]] ||
                conn[4 + ( offset + 2 ) % 4] != hexverts[h][idx[6]] ||
                conn[4 + ( offset + 3 ) % 4] != hexverts[h][idx[7]] || conn[8] != hexverts[h][idx[8]] )
                std::cout << "Side " << side << " of hex " << h << " has invalid connectivity" << std::endl;
                all_okay = false;
            faces[h][side] = true;
            if( ( h == 0 && i == 1 ) || ( h == 1 && i == 3 ) )
                if( faces[h][i] )
                    std::cout << "Skinner created interior face for side " << i << " of hex " << h << std::endl;
                    all_okay = false;
            else if( !faces[h][i] )
                std::cout << "Skinner failed to create side " << i << " of hex " << h << std::endl;
                all_okay = false;
    return all_okay ? MB_SUCCESS : MB_FAILURE;
Definition at line 6002 of file MBTest.cpp.
References moab::Range::back(), moab::Range::clear(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MBMesquite::faces, moab::Skinner::find_skin(), moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_error_string(), moab::Range::insert(), MB_SUCCESS, MBHEX, MBPOLYGON, MBPOLYHEDRON, MBQUAD, moab::Range::merge(), moab::Range::size(), skin(), and moab::subtract().
    /* Create a mesh composed of 8 hexagonal prisms and
       two hexahedra by extruding the following cross section
       two steps in the Z direction.
               0-----1
              /  (0)  \
         (11)/         \(1)
          11             2
          / \     Y     / \
     (10)/   \(12)^(13)/   \(2)
      10      12-----13      3
    (9)|       |  +--|-->X   |(3)
       9      15-----14      4
      (8)\   /(15) (14)\   /(4)
           8             5
          (7)\         /(5)
              \  (6)  /
               7-----6
    const double coords2D[][2] = {
        { -1, 5 },                                                 // 0
        { 1, 5 },  { 3, 3 },   { 5, 1 },   { 5, -1 },  { 3, -3 },  // 5
        { 1, -5 }, { -1, -5 }, { -3, -3 }, { -5, -1 }, { -5, 1 },  // 10
        { -3, 3 }, { -1, 1 },  { 1, 1 },   { 1, -1 },  { -1, -1 }  // 15
    const int polyconn[4][6] = {
        { 0, 1, 2, 13, 12, 11 }, { 2, 3, 4, 5, 14, 13 }, { 5, 6, 7, 8, 15, 14 }, { 8, 9, 10, 11, 12, 15 } };
    const int polyside[4][6] = {
        { 0, 1, 13, 16, 12, 11 }, { 2, 3, 4, 14, 17, 13 }, { 5, 6, 7, 15, 18, 14 }, { 8, 9, 10, 12, 19, 15 } };
    ErrorCode rval;
    Core moab;
    Range regions, faces, interior_faces;
    // create 48 vertices
    EntityHandle verts[3][16];
        for( int j = 0; j < 16; ++j )
            double coords[3] = { coords2D[j][0], coords2D[j][1], static_cast< double >( 2 * i ) };
            rval             = mb.create_vertex( coords, verts[i][j] );
    // create two hexahedra
    EntityHandle hexes[2];
        EntityHandle conn[8] = { verts[i][15],     verts[i][14],     verts[i][13],     verts[i][12],
                                 verts[i + 1][15], verts[i + 1][14], verts[i + 1][13], verts[i + 1][12] };
        rval                 = mb.create_element( MBHEX, conn, 8, hexes[i] );
        regions.insert( hexes[i] );
    // create hexagonal faces
    EntityHandle hexagons[3][4];
            EntityHandle conn[6];
            for( int k = 0; k < 6; ++k )
                conn[k] = verts[i][polyconn[j][k]];
            rval = mb.create_element( MBPOLYGON, conn, 6, hexagons[i][j] );
            faces.insert( hexagons[i][j] );
            if( i == 1 ) interior_faces.insert( hexagons[i][j] );
    // create quadrilateral faces
    EntityHandle quads[2][20];
        for( int j = 0; j < 20; ++j )
            int c1, c2;
            if( j < 12 )
                c1 = j;
                c2 = ( j + 1 ) % 12;
            else if( j < 16 )
                c1 = j;
                c2 = 2 + 3 * ( ( j - 9 ) % 4 );
            else
                c1 = j - 4;
                c2 = 12 + ( j - 15 ) % 4;
            EntityHandle conn[4] = { verts[i][c1], verts[i][c2], verts[i + 1][c2], verts[i + 1][c1] };
            rval                 = mb.create_element( MBQUAD, conn, 4, quads[i][j] );
            faces.insert( quads[i][j] );
            if( j > 11 ) interior_faces.insert( quads[i][j] );
    // create polyhedra
    EntityHandle poly[2][4];
            EntityHandle conn[8];
                conn[k] = quads[i][polyside[j][k]];
            conn[6] = hexagons[i][j];
            conn[7] = hexagons[i + 1][j];
            rval    = mb.create_element( MBPOLYHEDRON, conn, 8, poly[i][j] );
            regions.insert( poly[i][j] );
    interior_verts.insert( verts[1][12] );
    interior_verts.insert( verts[1][13] );
    interior_verts.insert( verts[1][14] );
    interior_verts.insert( verts[1][15] );
    Range skin;
    rval = tool.find_skin( 0, regions, true, skin, 0, true, false );
        return rval;
    Range all_verts, all_faces;
    rval = mb.get_entities_by_dimension( 0, 0, all_verts );
    rval = mb.get_entities_by_dimension( 0, 2, all_faces );
    Range expected = subtract( all_verts, interior_verts );
    if( expected != skin )
        return MB_FAILURE;
    if( all_faces != faces )
        std::cout << "Skinner created/deleted faces for vertex-only skinning" << std::endl;
        return MB_FAILURE;
    skin.clear();
    rval = tool.find_skin( 0, regions, false, skin, 0, true, false );
        std::cout << "Non-create face skinning failed with: " << mb.get_error_string( rval ) << std::endl;
        return rval;
    expected = subtract( all_faces, interior_faces );
        std::cout << "Skinner returned incorrect faces." << std::endl;
        return MB_FAILURE;
        std::cout << "Skinner created/deleted faces for no-create skinning" << std::endl;
        return MB_FAILURE;
    skin.clear();
    rval = tool.find_skin( 0, regions, false, skin, 0, true, true );
        std::cout << "Create face skinning failed with: " << mb.get_error_string( rval ) << std::endl;
        return rval;
    Range all_faces2;
    rval = mb.get_entities_by_dimension( 0, 2, all_faces2 );
    Range difference = subtract( all_faces2, all_faces );
    if( difference.size() != 2 )
    {  // should have created two quads for hex top/bottom
        std::cout << "Skinner failed to create new quads or created to many." << std::endl;
        return MB_FAILURE;
    expected.merge( difference );
        return MB_FAILURE;
    // check that new faces are correct
    EntityHandle expected_conn[2][4] = { { verts[0][12], verts[0][13], verts[0][14], verts[0][15] },
                                         { verts[2][12], verts[2][13], verts[2][14], verts[2][15] } };
    EntityHandle nq[2]               = { difference.front(), difference.back() };
        int len;
        bool found = false;
        for( int j = 0; !found && j < 2; ++j )
            rval = mb.get_connectivity( nq[j], conn, len );
            int idx1 = std::find( conn, conn + len, expected_conn[i][0] ) - conn;
            if( idx1 == len ) continue;
            found = true;
            for( int k = 1; k < 4; ++k )
                if( conn[( idx1 + k ) % 4] != expected_conn[i][k] ) found = false;
            if( !found )
                found = true;
                    if( conn[( idx1 + 4 - k ) % 4] != expected_conn[i][k] ) found = false;
        if( !found )
            std::cerr << "Skinner did not create & return expected quad " << i << std::endl;
            return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 6985 of file MBTest.cpp.
    return mb_skin_full_common( 3, false );
Definition at line 6720 of file MBTest.cpp.
    return mb_skin_reversed_common( 3, false );
Definition at line 6865 of file MBTest.cpp.
    return mb_skin_subset_common( 3, false );
ErrorCode mb_skin_reversed_common ( int  dim,
bool  use_adj
Definition at line 6630 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), dim, ErrorCode, moab::Skinner::find_skin(), moab::Range::front(), moab::Range::insert(), MB_SUCCESS, MBEDGE, MBTET, MBTRI, reverse(), and moab::Range::size().
Referenced by mb_skin_adj_faces_reversed_test(), mb_skin_adj_regions_reversed_test(), mb_skin_faces_reversed_test(), and mb_skin_regions_reversed_test().
    EntityType type, subtype;
    switch( dim )
        case 2:
            type    = MBTRI;
            subtype = MBEDGE;
            break;
        case 3:
            type    = MBTET;
            subtype = MBTRI;
            break;
        default:
            assert( false );
            return MB_FAILURE;
    /*      3
       0----1----2
    ErrorCode rval;
    Core moab;
    Range hexes;
    double coords[][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 2, 0, 0 }, { 1, 2, 0 }, { 1, 2, 2 } };
    EntityHandle verts[5];
    const int nvtx = 2 + dim;
    for( int i = 0; i < nvtx; ++i )
    // NOTE: order connectivity such that side 1 is shared!
    EntityHandle conn[2][4] = { { verts[0], verts[1], verts[3], verts[4] },
                                { verts[2], verts[3], verts[1], verts[4] } };
    const int conn_len      = dim + 1;
    Range elems;
        EntityHandle h;
        rval = mb.create_element( type, conn[i], conn_len, h );
        elems.insert( h );
    // create one reversed side
    EntityHandle side_conn[3];
    int side_indices[3] = { 0, 0, 0 };
    CN::SubEntityVertexIndices( type, dim - 1, 0, side_indices );
    side_conn[0] = conn[0][side_indices[1]];
    side_conn[1] = conn[0][side_indices[0]];
    side_conn[2] = conn[0][side_indices[2]];
    EntityHandle side;
    rval = mb.create_element( subtype, side_conn, dim, side );
    Range forward, reverse;
    rval = tool.find_skin( 0, elems, false, forward, &reverse, use_adj, true );
        std::cout << "Skinner failed." << std::endl;
        return rval;
    // expect all faces created by the skinner to be forward,
    // so the only reversed side should be the one created above.
    if( reverse.size() != 1 || reverse.front() != side )
        std::cout << "Expected 1 reversed side, got: " << reverse.size() << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 5636 of file MBTest.cpp.
References moab::ScdInterface::construct_box(), ErrorCode, moab::Skinner::find_skin(), MB_SUCCESS, MBVERTEX, moab::ScdBox::num_elements(), moab::Interface::query_interface(), and moab::ScdBox::start_element().
    // make a 10x10x5 scd mesh
    Core moab;
    ScdInterface* scdi;
    ErrorCode rval = mb->query_interface( scdi );
    HomCoord low( 0, 0, 0 ), high( 10, 10, 5 );
    ScdBox* this_box;
    rval = scdi->construct_box( low, high, NULL, 0, this_box );
    // now skin it with the structured and original method, and compare results
    Skinner tool( mb );
    Range ents( this_box->start_element(), this_box->start_element() + this_box->num_elements() - 1 ), scd_skin_ents,
        skin_ents;
    rval = tool.find_skin( 0, ents, false, scd_skin_ents, NULL, true, true, true );
    rval = tool.find_skin( 0, ents, false, skin_ents, NULL, true, true, false );
    // should be same number of entities
    if( scd_skin_ents.size() != skin_ents.size() ) return MB_FAILURE;
    skin_ents.clear();
    scd_skin_ents.clear();
    // now test getting faces and vertices, also with existing faces now
    rval = tool.find_skin( 0, ents, true, scd_skin_ents, NULL, true, true, true );
    rval = tool.find_skin( 0, ents, true, skin_ents, NULL, true, true, false );
    // again, should have same numbers
    if( skin_ents.subset_by_type( MBVERTEX ).size() != scd_skin_ents.subset_by_type( MBVERTEX ).size() )
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode mb_skin_subset_common ( int  dimension,
bool  use_adj
Definition at line 6729 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_connectivity(), moab::Interface::get_number_entities_by_dimension(), moab::Range::insert(), MB_SUCCESS, MBPRISM, MBTRI, n, moab::Range::size(), and skin().
Referenced by mb_skin_adj_faces_subset_test(), mb_skin_adj_regions_subset_test(), mb_skin_faces_subset_test(), and mb_skin_regions_subset_test().
    EntityType type;
    switch( dimension )
        case 2:
            type = MBTRI;
            break;
        case 3:
            type = MBPRISM;
            break;
        default:
            assert( false );
            return MB_FAILURE;
    /*      0
         5  |  1
         |  6  |
         4  |  2
            3
    ErrorCode rval;
    Core moab;
    Range expected_verts;
    const double coords2D[7][2] = { { 0, 2 }, { 1, 1 }, { 1, -1 }, { 0, -2 }, { -1, -1 }, { -1, 1 }, { 0, 0 } };
    EntityHandle verts[2][7]    = { { 0, 0, 0, 0, 0, 0, 0 }, { 0, 0, 0, 0, 0, 0, 0 } };
        for( int i = 0; i < 7; ++i )
            rval             = mb.create_vertex( coords, verts[d - 1][i] );
            if( i != 4 && i != 5 ) expected_verts.insert( verts[d - 1][i] );
    EntityHandle elems[6];
        EntityHandle conn[6] = { verts[0][6], verts[0][( i + 1 ) % 6], verts[0][i],
                                 verts[1][6], verts[1][( i + 1 ) % 6], verts[1][i] };
    Range input;
    input.insert( elems[0] );
    input.insert( elems[1] );
    input.insert( elems[2] );
    Range skin;
    rval = tool.find_skin( 0, input, true, skin, 0, use_adj, false );
        std::cout << "Skinner failed to find skin vertices" << std::endl;
        return MB_FAILURE;
    if( skin != expected_verts )
        std::cout << "Skinner returned incorrect skin vertices" << std::endl;
        return MB_FAILURE;
    int n = 0;
    if( n > 0 )
        std::cout << "Skinner created lower-dimension entities for vertex-only skinning" << std::endl;
        return MB_FAILURE;
    std::vector< EntityHandle > sv( skin.begin(), skin.end() );
    std::vector< int > counts( sv.size(), 0 );
    skin.clear();
        return MB_FAILURE;
        int len;
        rval = mb.get_connectivity( *i, conn, len );
        for( int j = 0; j < len; ++j )
            size_t idx = std::find( sv.begin(), sv.end(), conn[j] ) - sv.begin();
            if( idx == sv.size() )
                std::cout << "Skinner returned non-skin element" << std::endl;
                return MB_FAILURE;
            counts[idx]++;
    for( size_t i = 0; i < counts.size(); ++i )
        if( counts[i] < dimension )
        {  // 2 for dim==2, {3,4,5} for dim==3
            std::cout << "Skinner did not return all skin elements" << std::endl;
            return MB_FAILURE;
    if( (size_t)n != skin.size() )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 5852 of file MBTest.cpp.
References mb_skin_verts_common().
    return mb_skin_verts_common( 2, true );
Definition at line 5842 of file MBTest.cpp.
    return mb_skin_verts_common( 2, false );
Definition at line 5405 of file MBTest.cpp.
References mb_skin_surface_test_common().
    return mb_skin_surface_test_common( true );
Definition at line 5400 of file MBTest.cpp.
    return mb_skin_surface_test_common( false );
Definition at line 5493 of file MBTest.cpp.
References moab::Range::all_of_type(), moab::Range::back(), moab::Range::begin(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Skinner::find_skin(), moab::Range::front(), moab::Interface::get_connectivity(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::Range::size(), skin(), and swap().
Referenced by mb_skin_surface_adj_test(), and mb_skin_surface_test().
    ErrorCode rval;
    Core moab;
    /* Create 4 of 5 faces of a wedge: */
            4
        /   2   \
       3.../.\...5
       0_________1
    const double coords[][3] = { { 0, 0, 0 }, { 2, 0, 0 }, { 1, 0, 1 }, { 0, 2, 0 }, { 2, 2, 0 }, { 1, 2, 1 } };
    EntityHandle verts[6];
    for( unsigned i = 0; i < 6; ++i )
    EntityHandle faces[4];
    Range source;
    std::copy( faces, faces + 4, range_inserter( source ) );
    // Now skin the mesh.  The only missing face is the
    // back triangle (verts 3, 4, & 5) so the skin should
    // be the edges bordering that face.
    Range skin;
    Skinner tool( mb );
    rval = tool.find_skin( 0, source, 1, skin, use_adj );
        return MB_FAILURE;
    if( skin.size() != 3 || !skin.all_of_type( MBEDGE ) )
        return MB_FAILURE;
    // Check each edge
    std::vector< EntityHandle > conn[3];
    rval = mb->get_connectivity( &skin.front(), 1, conn[0] );
    rval = mb->get_connectivity( &*++skin.begin(), 1, conn[1] );
    rval = mb->get_connectivity( &skin.back(), 1, conn[2] );
        if( conn[i][0] > conn[i][1] ) std::swap( conn[i][0], conn[i][1] );
        EntityHandle s = verts[i + 3], e = verts[( i + 1 ) % 3 + 3];
        if( s > e ) std::swap( s, e );
        int j = 0;
        for( j = 0; j < 3; ++j )
            if( conn[j][0] == s && conn[j][1] == e ) break;
        if( j == 3 )
            std::cerr << "Skin does not contain edge [" << s << "," << e << "] at " << __FILE__ ":" << __LINE__
                      << std::endl;
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode mb_skin_verts_common ( unsigned  dim,
bool  skin_elems
Definition at line 5862 of file MBTest.cpp.
References MBMesquite::adj(), moab::Range::begin(), moab::Range::clear(), dim, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Range::insert(), INT, moab::Interface::load_file(), MB_SUCCESS, moab::subtract(), and tmp_file.
Referenced by mb_skin_surf_verts_elems_test(), mb_skin_surf_verts_test(), mb_skin_vol_verts_elems_test(), and mb_skin_vol_verts_test().
    const int INT        = 10;  // intervals+1
    const char* tmp_file = "structured.vtk";
    std::ofstream str( tmp_file );
    if( !str )
        std::cerr << tmp_file << ": filed to create temp file" << std::endl;
        return MB_FAILURE;
    str << "#vtk DataFile Version 2.0" << std::endl
        << "mb_skin_verts_common temp file" << std::endl
        << "ASCII" << std::endl
        << "DATASET STRUCTURED_POINTS" << std::endl
        << "DIMENSIONS " << INT << " " << ( dim > 1 ? INT : 1 ) << " " << ( dim > 2 ? INT : 1 ) << std::endl
        << "ORIGIN 0 0 0" << std::endl
        << "SPACING 1 1 1" << std::endl;
    str.close();
    Core moab;
    ErrorCode rval;
    rval = mb.load_file( tmp_file );
    remove( tmp_file );
    Range ents;
    rval = mb.get_entities_by_dimension( 0, dim, ents );
    if( ents.empty() ) return MB_FAILURE;
    // mesh is a structured quad/hex mesh, so we can
    // determine skin vertices from the number of
    // adjacent elements.
    unsigned interior_adj = 1;
    for( unsigned i = 0; i < dim; ++i )
        interior_adj *= 2;
    Range expected, verts;
    rval = mb.get_entities_by_dimension( 0, 0, verts );
    Range::iterator h = expected.begin();
    std::vector< EntityHandle > adj;
    for( Range::iterator v = verts.begin(); v != verts.end(); ++v )
        adj.clear();
        rval = mb.get_adjacencies( &*v, 1, dim, false, adj );
        if( adj.size() < interior_adj ) h = expected.insert( h, *v );
    // Get skin vertices using skinner
    Range actual;
    rval = tool.find_skin( 0, ents, !skin_elems, actual );
    Range extra, missing;
    if( !skin_elems )
        // Check that we got expected result
        extra   = subtract( actual, expected );
        missing = subtract( expected, actual );
        if( !extra.empty() || !missing.empty() )
            std::cout << "Extra vertices returned: " << extra << std::endl
                      << "Missing vertices: " << missing << std::endl;
            return MB_FAILURE;
        return MB_SUCCESS;
    // test that no extra elements we're created
    extra.clear();
    rval = mb.get_entities_by_dimension( 0, dim - 1, extra );
    extra = subtract( extra, actual );
        std::cout << "Extra/non-returned elements created: " << extra << std::endl;
        return MB_FAILURE;
    // check that each skin vertex has the correct number of adjacent quads
    missing.clear();
    extra.clear();
    for( Range::iterator i = expected.begin(); i != expected.end(); ++i )
        std::vector< EntityHandle > elem, side;
        rval = mb.get_adjacencies( &*i, 1, dim, false, elem );
        rval = mb.get_adjacencies( &*i, 1, dim - 1, false, side );
        if( elem.size() == 1 )
            if( side.size() < dim )
                missing.insert( *i );
            else if( side.size() > dim )
                extra.insert( *i );
        else if( elem.size() == interior_adj )
            if( !side.empty() ) extra.insert( *i );
        else
            if( side.size() < interior_adj / 2 )
            else if( side.size() > interior_adj / 2 )
                extra.insert( *i );
    if( !missing.empty() || !extra.empty() )
        std::cout << "Skin elements missing at vertices: " << missing << std::endl
                  << "Extra skin elements at vertices: " << extra << std::endl;
        return MB_FAILURE;
    // check that all returned elements are actually on the skin
    extra.clear();
    for( Range::iterator i = actual.begin(); i != actual.end(); ++i )
        Range verts2;
        rval = mb.get_adjacencies( &*i, 1, 0, false, verts2 );
        verts2 = subtract( verts2, expected );
        if( !verts2.empty() ) extra.insert( *i );
        std::cout << "Skinner returned elements not on skin: " << extra << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 5857 of file MBTest.cpp.
    return mb_skin_verts_common( 3, true );
Definition at line 5847 of file MBTest.cpp.
    return mb_skin_verts_common( 3, false );
Definition at line 5417 of file MBTest.cpp.
References mb_skin_volume_test_common().
    return mb_skin_volume_test_common( true );
Definition at line 5412 of file MBTest.cpp.
    return mb_skin_volume_test_common( false );
Definition at line 5578 of file MBTest.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Range::insert(), INTERSECT, MB_SUCCESS, MBHEX, moab::Range::size(), skin(), moab::subtract(), and smoab::UNION.
Referenced by mb_skin_volume_adj_test(), and mb_skin_volume_test().
    ErrorCode rval;
    Core moab;
    Interface* mb = &moab;
    /* A 2 adjacent hexes hexes */
          9-----10----11
       6-----7-----8..5
       0-----1-----2
    const double coords[][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 2, 0, 0 }, { 0, 1, 0 }, { 1, 1, 0 }, { 2, 1, 0 },
                                 { 0, 0, 1 }, { 1, 0, 1 }, { 2, 0, 1 }, { 0, 1, 1 }, { 1, 1, 1 }, { 2, 1, 1 } };
    EntityHandle verts[12];
    for( unsigned i = 0; i < 12; ++i )
    EntityHandle hex1c[] = { verts[0], verts[1], verts[4], verts[3], verts[6], verts[7], verts[10], verts[9] };
    EntityHandle hex2c[] = { verts[1], verts[2], verts[5], verts[4], verts[7], verts[8], verts[11], verts[10] };
    EntityHandle hex1, hex2;
    mb->create_element( MBHEX, hex1c, 8, hex1 );
    mb->create_element( MBHEX, hex2c, 8, hex2 );
    Range source;
    source.insert( hex1 );
    source.insert( hex2 );
    // get all quads and shared face
    Range tmp, all_faces;
    mb->get_adjacencies( source, 2, true, all_faces, Interface::UNION );
    mb->get_adjacencies( source, 2, true, tmp, Interface::INTERSECT );
    assert( tmp.size() == 1 );
    Range non_shared = subtract( all_faces, tmp );
    Range skin;
    Skinner tool( mb );
    rval = tool.find_skin( 0, source, 2, skin, use_adj );
        return MB_FAILURE;
    if( skin != non_shared )
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 3108 of file MBTest.cpp.
References mb_common_tag_test(), and MB_TAG_SPARSE.
Definition at line 4650 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::MeshTopoUtil::construct_aentities(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_number_entities_by_dimension(), moab::Range::insert(), MB_SUCCESS, MBHEX, RR, moab::Range::size(), moab::MeshTopoUtil::split_entities_manifold(), and VINDEX.
    Core moab;
    Interface* gMB = &moab;
    MeshTopoUtil mtu( gMB );
    // construct a four-hex mesh for testing purposes
    double grid_vert_pos[] = { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 2.0, 0.0, 0.0, 0.0, 1.0, 0.0, 1.0, 1.0, 0.0, 2.0, 1.0, 0.0,
                               0.0, 2.0, 0.0, 1.0, 2.0, 0.0, 2.0, 2.0, 0.0,
                               0.0, 0.0, 1.0, 1.0, 0.0, 1.0, 2.0, 0.0, 1.0, 0.0, 1.0, 1.0, 1.0, 1.0, 1.0, 2.0, 1.0, 1.0,
                               0.0, 2.0, 1.0, 1.0, 2.0, 1.0, 2.0, 2.0, 1.0,
                               0.0, 0.0, 2.0, 1.0, 0.0, 2.0, 2.0, 0.0, 2.0, 0.0, 1.0, 2.0, 1.0, 1.0, 2.0, 2.0, 1.0, 2.0,
                               0.0, 2.0, 2.0, 1.0, 2.0, 2.0, 2.0, 2.0, 2.0 };
    EntityHandle grid_verts[27], grid_elems[8];
    ErrorCode result;
#define RR \
    if( result != MB_SUCCESS ) return result
    int init_edges, init_faces, init_regions;
    result = gMB->get_number_entities_by_dimension( 0, 1, init_edges );RR;
    result = gMB->get_number_entities_by_dimension( 0, 2, init_faces );RR;
    result = gMB->get_number_entities_by_dimension( 0, 3, init_regions );RR;
    // make vertices
    for( int i = 0; i < 27; i++ )
        result = gMB->create_vertex( &grid_vert_pos[3 * i], grid_verts[i] );RR;
    // make hexes
    int numv = 3, numv_sq = 9;
#define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
    EntityHandle connect[8];
    for( int k = 0; k < 2; k++ )
        for( int j = 0; j < 2; j++ )
            for( int i = 0; i < 2; i++ )
                int vijk   = VINDEX( i, j, k );
                connect[0] = grid_verts[vijk];
                connect[1] = grid_verts[vijk + 1];
                connect[2] = grid_verts[vijk + 1 + numv];
                connect[3] = grid_verts[vijk + numv];
                connect[4] = grid_verts[vijk + numv * numv];
                connect[5] = grid_verts[vijk + 1 + numv * numv];
                connect[6] = grid_verts[vijk + 1 + numv + numv * numv];
                connect[7] = grid_verts[vijk + numv + numv * numv];
                result     = gMB->create_element( MBHEX, connect, 8, grid_elems[4 * k + 2 * j + i] );RR;
    Range vert_range;
    std::copy( grid_verts, grid_verts + 27, range_inserter( vert_range ) );
    // generate aentities
    result = mtu.construct_aentities( vert_range );RR;
    int this_edges, this_faces;
    result = gMB->get_number_entities_by_dimension( 0, 1, this_edges );RR;
    result = gMB->get_number_entities_by_dimension( 0, 2, this_faces );RR;
    if( this_edges != init_edges + 54 || this_faces != init_faces + 36 )
        std::cout << "Wrong number of edges or faces in mb_topo_util test." << std::endl;
        return MB_FAILURE;
    // split the faces between the 2 layers
    // first get the faces
    Range split_faces, tmp_ents, tmp_faces;
    for( int i = 0; i < 4; i++ )
        tmp_ents.clear();
        tmp_ents.insert( grid_elems[i] );
        tmp_ents.insert( grid_elems[i + 4] );
        tmp_faces.clear();
        result = gMB->get_adjacencies( tmp_ents, 2, false, tmp_faces );
        if( MB_SUCCESS != result || tmp_faces.size() != 1 )
            std::cout << "mb_split_test failed to get shared quad." << std::endl;
            return MB_FAILURE;
        split_faces.insert( *tmp_faces.begin() );
    Range new_faces, new_regions;
    // NOTE: passing in non-NULL pointer for new_regions requests that region between the
    // split entities be filled with an element; in this case, since we're splitting faces,
    // the new entities are polyhedra
    result = mtu.split_entities_manifold( split_faces, new_faces, &new_regions );
    if( MB_SUCCESS != result || new_faces.size() != 4 || new_regions.size() != 4 )
        std::cout << "mb_split_test failed to split quads." << std::endl;
        return MB_FAILURE;
    int this_regions;
    result = gMB->get_number_entities_by_dimension( 0, 3, this_regions );RR;
    if( this_edges != init_edges + 54 || this_faces != init_faces + 40 || this_regions != init_regions + 12 )
        std::cout << "Wrong number of edges or faces or regions after splitting in mb_topo_util test." << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 381 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), ErrorCode, moab::Interface::get_adjacencies(), gMB, MB_SUCCESS, MESHSET_TRACK_OWNER, moab::Interface::remove_entities(), and u.
    Core moab;
    double array[3] = { 0.0, 0.0, 0.0 };
    EntityHandle h_node1;
    ErrorCode result = gMB->create_vertex( array, h_node1 );
    if( MB_SUCCESS != result ) return result;
    EntityHandle ordered_meshset1;
    result = gMB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ordered_meshset1 );
    EntityHandle ordered_meshset2;
    result = gMB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ordered_meshset2 );
    result = gMB->add_entities( ordered_meshset1, &h_node1, 1 );
    result = gMB->remove_entities( ordered_meshset1, &h_node1, 1 );
    result = gMB->add_entities( ordered_meshset2, &h_node1, 1 );
    bool create_if_missing = false;
    std::vector< EntityHandle > meshsets;
    result = gMB->get_adjacencies( &h_node1, 1, 4, create_if_missing, meshsets );
    if( 1u != meshsets.size() ) return MB_FAILURE;
    return MB_SUCCESS;
Definition at line 4526 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::MeshTopoUtil::construct_aentities(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::erase(), ErrorCode, moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_average_position(), moab::Interface::get_number_entities_by_dimension(), moab::Range::insert(), MB_SUCCESS, MBHEX, RR, moab::Range::size(), moab::MeshTopoUtil::star_entities(), and VINDEX.
    Core moab;
                               0.0, 2.0, 1.0, 1.0, 2.0, 1.0, 2.0, 2.0, 1.0 };
    EntityHandle grid_verts[18], grid_elems[4];
    ErrorCode result;
#define RR \
    int init_edges, init_faces;
    // make vertices
    for( int i = 0; i < 18; i++ )
    // make hexes
            int vijk   = VINDEX( i, j, 0 );
            result     = gMB->create_element( MBHEX, connect, 8, grid_elems[2 * j + i] );RR;
    Range vert_range;
    std::copy( grid_verts, grid_verts + 18, range_inserter( vert_range ) );
    if( this_edges != init_edges + 33 || this_faces != init_faces + 20 )
        //    return MB_FAILURE;
    // get average position
    double pos[3];
            result = mtu.get_average_position( grid_elems[2 * j + i], pos );RR;
            if( pos[0] != .5 + i || pos[1] != .5 + j || pos[2] != .5 )
                std::cout << "Wrong position at i = " << i << ", j = " << j << std::endl;
                result = MB_FAILURE;
    RR;
    // get star faces
    Range all_hexes, middle_edge;
    std::copy( grid_elems, grid_elems + 4, range_inserter( all_hexes ) );
    // get the shared edge
    result = gMB->get_adjacencies( all_hexes, 1, false, middle_edge );
    if( MB_SUCCESS != result || 1 != middle_edge.size() )
        std::cout << "Bad result getting single shared edge." << std::endl;
        return MB_FAILURE;
    std::vector< EntityHandle > star_faces, star_hexes;
    bool bdy_edge;
    result = mtu.star_entities( *middle_edge.begin(), star_faces, bdy_edge, 0, &star_hexes );
    if( MB_SUCCESS != result || bdy_edge || star_faces.size() != 4 || star_hexes.size() != 4 )
        std::cout << "Bad result from star_faces for non-bdy edge." << std::endl;
        return MB_FAILURE;
    // now try for a different edge, which has to be on the bdy
    Range other_edges;
    all_hexes.clear();
    all_hexes.insert( grid_elems[0] );
    result = gMB->get_adjacencies( all_hexes, 1, false, other_edges );RR;
    other_edges.erase( *middle_edge.begin() );
    if( 11 != other_edges.size() )
        std::cout << "Wrong number of edges in hex." << std::endl;
        return MB_FAILURE;
    star_faces.clear();
    star_hexes.clear();
    result = mtu.star_entities( *other_edges.begin(), star_faces, bdy_edge, 0, &star_hexes );
    if( MB_SUCCESS != result || !bdy_edge || ( star_faces.size() != 2 && star_faces.size() != 3 ) ||
        ( star_hexes.size() != 1 && star_hexes.size() != 2 ) )
        std::cout << "Bad result from star_faces for bdy edge." << std::endl;
        return MB_FAILURE;
    return MB_SUCCESS;
Check that functions which accept a type return the result for all types when passed MBMAXTYPE
Definition at line 7202 of file MBTest.cpp.
References moab::Interface::add_entities(), moab::Range::back(), moab::Range::begin(), CHECK, moab::Range::clear(), moab::Interface::create_meshset(), create_some_mesh(), moab::Range::end(), ErrorCode, moab::Range::front(), get_by_all_types_and_tag(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_handle(), moab::Interface::get_number_entities_by_type(), moab::Interface::get_number_entities_by_type_and_tag(), h1, moab::ID_FROM_HANDLE(), moab::Range::insert(), INTERSECT, MB_CHK_ERR, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBMAXTYPE, MESHSET_SET, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), smoab::UNION, and value().
    Core moab;
    ErrorCode rval = create_some_mesh( mb );
    Range r1, r2;
    rval = mb->get_entities_by_type( 0, MBMAXTYPE, r1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( 0, r2, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    std::vector< EntityHandle > v1, v2;
    rval = mb->get_entities_by_type( 0, MBMAXTYPE, v1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( 0, v2, false );MB_CHK_ERR( rval );
    CHECK( v1 == v2 );
    int c1, c2;
    rval = mb->get_number_entities_by_type( 0, MBMAXTYPE, c1, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_handle( 0, c2, false );MB_CHK_ERR( rval );
    CHECK( c1 == c2 );
    Range h1, h2;
    Range::iterator it = r1.begin() + r1.size() / 2;
    h1.insert( r1.begin(), it );
    if( it != r1.end() ) h2.insert( ++it, r1.end() );
    EntityHandle s1, s2;
    rval = mb->create_meshset( MESHSET_SET, s1 );MB_CHK_ERR( rval );
    rval = mb->create_meshset( MESHSET_ORDERED, s2 );MB_CHK_ERR( rval );
    rval = mb->add_entities( s1, r1 );MB_CHK_ERR( rval );
    rval = mb->add_entities( s2, r2 );MB_CHK_ERR( rval );
    rval = mb->add_entities( s2, &s1, 1 );MB_CHK_ERR( rval );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type( s1, MBMAXTYPE, r1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s1, r2, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type( s2, MBMAXTYPE, r1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s2, r2, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type( s2, MBMAXTYPE, r1, true );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s2, r2, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    v1.clear();
    v2.clear();
    rval = mb->get_entities_by_type( s1, MBMAXTYPE, v1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s1, v2, false );MB_CHK_ERR( rval );
    CHECK( v1 == v2 );
    v1.clear();
    v2.clear();
    rval = mb->get_entities_by_type( s2, MBMAXTYPE, v1, false );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s2, v2, false );MB_CHK_ERR( rval );
    CHECK( v1 == v2 );
    v1.clear();
    v2.clear();
    rval = mb->get_entities_by_type( s2, MBMAXTYPE, v1, true );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_handle( s2, v2, true );MB_CHK_ERR( rval );
    CHECK( v1 == v2 );
    rval = mb->get_number_entities_by_type( s1, MBMAXTYPE, c1, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_handle( s1, c2, false );MB_CHK_ERR( rval );
    CHECK( c1 == c2 );
    rval = mb->get_number_entities_by_type( s2, MBMAXTYPE, c1, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_handle( s2, c2, false );MB_CHK_ERR( rval );
    CHECK( c1 == c2 );
    rval = mb->get_number_entities_by_type( s2, MBMAXTYPE, c1, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_handle( s2, c2, true );MB_CHK_ERR( rval );
    CHECK( c1 == c2 );
    r1.clear();
    rval = mb->get_entities_by_handle( s1, r1 );MB_CHK_ERR( rval );
    Tag t1;
    rval = mb->tag_get_handle( "maxtype1", 1, MB_TYPE_INTEGER, t1, MB_TAG_SPARSE | MB_TAG_EXCL );MB_CHK_ERR( rval );
    std::vector< int > d1( r1.size() );
    Range::iterator ri;
    std::vector< int >::iterator ii = d1.begin();
    for( ri = r1.begin(); ri != r1.end(); ++ri, ++ii )
        *ii = ( (int)ID_FROM_HANDLE( *ri ) ) % 20;
    rval = mb->tag_set_data( t1, r1, &d1[0] );MB_CHK_ERR( rval );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( 0, MBMAXTYPE, &t1, 0, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( 0, MBMAXTYPE, &t1, 0, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, 0, &t1, 0, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    CHECK( (unsigned)c1 == r2.size() );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s1, MBMAXTYPE, &t1, 0, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s1, MBMAXTYPE, &t1, 0, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s1, &t1, 0, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, 0, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, 0, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, &t1, 0, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, 0, 1, r1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, 0, 1, c1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, &t1, 0, 1, r2, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    int value              = 3;
    const void* vallist[2] = { &value, 0 };
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( 0, MBMAXTYPE, &t1, vallist, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( 0, MBMAXTYPE, &t1, vallist, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, 0, &t1, vallist, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s1, MBMAXTYPE, &t1, vallist, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s1, MBMAXTYPE, &t1, vallist, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s1, &t1, vallist, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, vallist, 1, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, vallist, 1, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, &t1, vallist, 1, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, vallist, 1, r1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, &t1, vallist, 1, c1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, &t1, vallist, 1, r2, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    r2.insert( r1.back() );
    r1.clear();
    rval = mb->get_entities_by_handle( s2, r1 );MB_CHK_ERR( rval );
    r2.insert( r1.front() );
    Tag t2;
    rval = mb->tag_get_handle( "maxtype2", 1, MB_TYPE_INTEGER, t2, MB_TAG_DENSE | MB_TAG_EXCL );MB_CHK_ERR( rval );
    d1.resize( r2.size() );
    ii = d1.begin();
    for( ri = r2.begin(); ri != r2.end(); ++ri, ++ii )
        *ii = ( (int)ID_FROM_HANDLE( *ri ) ) % 2;
    rval = mb->tag_set_data( t2, r2, &d1[0] );MB_CHK_ERR( rval );
    Tag tags[] = { t1, t2 };
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( 0, MBMAXTYPE, tags, 0, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( 0, MBMAXTYPE, tags, 0, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, 0, tags, 0, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s1, MBMAXTYPE, tags, 0, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s1, MBMAXTYPE, tags, 0, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s1, tags, 0, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, 0, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, 0, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, 0, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, 0, 2, r1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, 0, 2, c1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, 0, 2, r2, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    int val2   = 1;
    vallist[1] = &val2;
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( 0, MBMAXTYPE, tags, vallist, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( 0, MBMAXTYPE, tags, vallist, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, 0, tags, vallist, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s1, MBMAXTYPE, tags, vallist, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s1, MBMAXTYPE, tags, vallist, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s1, tags, vallist, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, r1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, c1, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, vallist, 2, r2, Interface::INTERSECT, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, r1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, c1, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, vallist, 2, r2, Interface::INTERSECT, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( 0, MBMAXTYPE, tags, vallist, 2, r1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( 0, MBMAXTYPE, tags, vallist, 2, c1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, 0, tags, vallist, 2, r2, Interface::UNION, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s1, MBMAXTYPE, tags, vallist, 2, r1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s1, MBMAXTYPE, tags, vallist, 2, c1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s1, tags, vallist, 2, r2, Interface::UNION, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, r1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, c1, Interface::UNION, false );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, vallist, 2, r2, Interface::UNION, false );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    r1.clear();
    r2.clear();
    rval = mb->get_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, r1, Interface::UNION, true );MB_CHK_ERR( rval );
    rval = mb->get_number_entities_by_type_and_tag( s2, MBMAXTYPE, tags, vallist, 2, c1, Interface::UNION, true );MB_CHK_ERR( rval );
    rval = get_by_all_types_and_tag( mb, s2, tags, vallist, 2, r2, Interface::UNION, true );MB_CHK_ERR( rval );
    CHECK( r1 == r2 );
    return MB_SUCCESS;
Definition at line 757 of file MBTest.cpp.
References MBMesquite::adj(), CHECK, create_two_hex_full_mesh(), dim, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), MB_CHK_ERR, MB_SUCCESS, n, and smoab::UNION.
    ErrorCode rval;
    Core moab;
    // create a simple mesh containing 2 hexes
    EntityHandle vertices[12], hexes[2], hex1_faces[6], hex2_faces[6], hex1_edges[12], hex2_edges[12];
    rval = create_two_hex_full_mesh( mb, vertices, hexes, hex1_faces, hex2_faces, hex1_edges, hex2_edges );MB_CHK_ERR( rval );
    // test adjacences from dim to 3
    for( int dim = 0; dim < 3; ++dim )
        std::vector< EntityHandle > hex1_ent, hex2_ent, shared;
        const EntityHandle *list1, *list2;
        int n;
        switch( dim )
            case 0:
                rval = mb->get_connectivity( hexes[0], list1, n );MB_CHK_ERR( rval );
                rval = mb->get_connectivity( hexes[1], list2, n );MB_CHK_ERR( rval );
                break;
            case 1:
                list1 = hex1_edges;
                list2 = hex2_edges;
                n     = 12;
                break;
            case 2:
                list1 = hex1_faces;
                list2 = hex2_faces;
                n     = 6;
                break;
        // split entities into those uniquely in hex1, those uniquely in hex2
        // and those shared between the two
        for( int i = 0; i < n; ++i )
            if( std::find( list2, list2 + n, list1[i] ) - list2 == n )
                hex1_ent.push_back( list1[i] );
            else
                shared.push_back( list1[i] );
            if( std::find( list1, list1 + n, list2[i] ) - list1 == n ) hex2_ent.push_back( list2[i] );
        // for each shared entity check that get_adjacencies returns both hexes
        for( size_t j = 0; j < shared.size(); ++j )
            rval = mb->get_adjacencies( &shared[j], 1, 3, false, adj );MB_CHK_ERR( rval );
            if( adj.size() != 2 )
                std::cout << "Expected 2 hexes adjacent to " << dim << "D entity " << j << ". Got " << adj.size()
                          << " hexes." << std::endl;
                return MB_FAILURE;
            if( !( adj[0] == hexes[0] && adj[1] == hexes[1] ) && !( adj[0] == hexes[1] && adj[1] == hexes[0] ) )
                std::cout << "Got incorrect hexes adjacent to " << dim << "D entity " << j << std::endl;
                return MB_FAILURE;
        for( size_t j = 0; j < hex1_ent.size(); ++j )
            rval = mb->get_adjacencies( &hex1_ent[j], 1, 3, false, adj );MB_CHK_ERR( rval );
            CHECK( adj.size() == 1 && adj[0] == hexes[0] );
        for( size_t j = 0; j < hex2_ent.size(); ++j )
            rval = mb->get_adjacencies( &hex2_ent[j], 1, 3, false, adj );MB_CHK_ERR( rval );
            CHECK( adj.size() == 1 && adj[0] == hexes[1] );
    // For each edge, get adjacent faces, and for each face
    // get adjacent hexes.  Result should be the same as
    // direct query from edges to hexes
    std::vector< EntityHandle > all_edges( 24 );
    std::copy( hex1_edges, hex1_edges + 12, all_edges.begin() );
    std::copy( hex2_edges, hex2_edges + 12, all_edges.begin() + 12 );
    std::sort( all_edges.begin(), all_edges.end() );
    all_edges.erase( std::unique( all_edges.begin(), all_edges.end() ), all_edges.end() );
    for( size_t j = 0; j < all_edges.size(); ++j )
        std::vector< EntityHandle > edge_hexes, edge_faces, face_hexes;
        rval = mb->get_adjacencies( &all_edges[j], 1, 3, false, edge_hexes );MB_CHK_ERR( rval );
        rval = mb->get_adjacencies( &all_edges[j], 1, 2, false, edge_faces );MB_CHK_ERR( rval );
        rval = mb->get_adjacencies( &edge_faces[0], edge_faces.size(), 3, false, face_hexes, Interface::UNION );MB_CHK_ERR( rval );
        if( edge_hexes.size() != face_hexes.size() )
            std::cout << "Inconsistent adjacency data for edge " << j << ". edge->face->hex resulted in "
                      << face_hexes.size() << "hexes while edge->hex resulted in " << edge_hexes.size() << std::endl;
            return MB_FAILURE;
        switch( edge_hexes.size() )
            case 1:
                CHECK( edge_hexes[0] == face_hexes[0] );
                break;
            case 2:
                CHECK( ( edge_hexes[0] == face_hexes[0] && edge_hexes[1] == face_hexes[1] ) ||
                       ( edge_hexes[0] == face_hexes[1] && edge_hexes[1] == face_hexes[0] ) );
                break;
            default:
                std::cout << "Got " << edge_hexes.size() << " hexes adjacent to edge " << j << std::endl;
                return MB_FAILURE;
    return MB_SUCCESS;
Test:
Vertex Coordinates
  • Get coordinates of vertex 1 correctly
  • Get coordinates of vertex 8 correctly
  • Get coordinates of vertex 6 correctly
Definition at line 108 of file MBTest.cpp.
References moab::Range::back(), moab::Range::begin(), CHECK_EQUAL, CHECK_REAL_EQUAL, create_some_mesh(), moab::E, moab::Range::end(), moab::error(), ErrorCode, moab::Range::front(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Range::insert(), MB_CHK_ERR, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBHEX, MBVERTEX, N, moab::Range::size(), and z.
    Core moab;
    Interface* MB   = &moab;
    ErrorCode error = create_some_mesh( MB );MB_CHK_ERR( error );
    Range vertices;
    error = MB->get_entities_by_type( 0, MBVERTEX, vertices );MB_CHK_ERR( error );
    std::vector< double > all_coords( 3 * vertices.size() );
    double* coord_iter = &all_coords[0];
    for( Range::iterator iter = vertices.begin(); iter != vertices.end(); ++iter )
        error = MB->get_coords( &( *iter ), 1, coord_iter );MB_CHK_ERR( error );
        coord_iter += 3;
    // check blocked coordinates
    const size_t N = vertices.size() + 1;
    std::vector< double > x( N ), y( N ), z( N );
    // set last value so we can check later that nothing wrote past the
    // intended end of an array
    x[vertices.size()] = y[vertices.size()] = z[vertices.size()] = -3.14159;
    error                                                        = MB->get_coords( vertices, &x[0], &y[0], &z[0] );
    for( size_t i = 0; i < vertices.size(); ++i )
        CHECK_REAL_EQUAL( all_coords[3 * i], x[i], 1E-12 );
        CHECK_REAL_EQUAL( all_coords[3 * i + 1], y[i], 1E-12 );
        CHECK_REAL_EQUAL( all_coords[3 * i + 2], z[i], 1E-12 );
    // checkthat get_coords did not write past intended end of arrays
    CHECK_REAL_EQUAL( -3.14159, x[vertices.size()], 1E-12 );
    CHECK_REAL_EQUAL( -3.14159, y[vertices.size()], 1E-12 );
    CHECK_REAL_EQUAL( -3.14159, z[vertices.size()], 1E-12 );
    // add invalid handle to end of range and try query again
    vertices.insert( vertices.back() + 1 );
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, error );
    // Try getting coordinates for a hex (should fail)
    Range hexes;
    error = MB->get_entities_by_type( 0, MBHEX, hexes );MB_CHK_ERR( error );
    EntityHandle handle = hexes.front();
    error               = MB->get_coords( &handle, 1, &x[0] );MB_CHK_ERR( error );
    CHECK_REAL_EQUAL( 0.5, x[0], 1E-12 );
    CHECK_REAL_EQUAL( 0.5, x[1], 1E-12 );
    CHECK_REAL_EQUAL( 0.5, x[2], 1E-12 );
    return MB_SUCCESS;
Test:
MB Vertex Tag Test
  • Add, Set and correctly get an int tag
  • Add, Set and correctly get a boolean tag
  • Add, Set and correctly get a double tag
  • Add, Set and correctly get a struct tag
Definition at line 168 of file MBTest.cpp.
References create_some_mesh(), moab::error(), ErrorCode, moab::Interface::get_entities_by_type(), MB_SUCCESS, MB_TAG_EXCL, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBVERTEX, moab::Interface::tag_delete(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_name(), moab::Interface::tag_get_tags_on_entity(), moab::Interface::tag_set_data(), and TagStruct::test_double.
    Core moab;
    if( MB_SUCCESS != error ) return error;
    // Add an int Vertex Tag to the database
    Tag tag_id;
    // Create a dense tag for all vertices
    error = MB->tag_get_handle( "int_tag", 1, MB_TYPE_INTEGER, tag_id, MB_TAG_SPARSE | MB_TAG_EXCL );
    if( error != MB_SUCCESS ) return error;
    // put a value in vertex 1 and retrieve
    std::vector< EntityHandle > verts;
    error = MB->get_entities_by_type( 0, MBVERTEX, verts );
    EntityHandle handle = verts[0];
    int input_value     = 11;
    error               = MB->tag_set_data( tag_id, &handle, 1, &input_value );
    int output_value;
    error = MB->tag_get_data( tag_id, &handle, 1, &output_value );
        return error;
    else if( output_value != input_value )
        return MB_FAILURE;
    // put a value in vertex 5 and retrieve
    handle      = verts[5];
    input_value = 11;
        return error;
        return MB_FAILURE;
    // put a value in vertex 98088234 which doesn't exist
    handle      = *std::max_element( verts.begin(), verts.end() ) + 1;
    input_value = 11;
    if( error == MB_SUCCESS ) return error;
    if( output_value != input_value ) return MB_FAILURE;
    // Add a bool Vertex Tag to the database
    error = MB->tag_get_handle( "bool_tag", sizeof( bool ), MB_TYPE_OPAQUE, tag_id, MB_TAG_SPARSE | MB_TAG_EXCL );
    handle                 = verts[5];
    bool bool_input_value  = true;
    bool bool_output_value = false;
    error                  = MB->tag_set_data( tag_id, &handle, 1, &bool_input_value );
    error = MB->tag_get_data( tag_id, &handle, 1, &bool_output_value );
        return error;
    else if( bool_output_value != bool_input_value )
        return MB_FAILURE;
    // Add a double Vertex Tag to the database
    error = MB->tag_get_handle( "double_tag", 1, MB_TYPE_DOUBLE, tag_id, MB_TAG_SPARSE | MB_TAG_EXCL );
    // put a value in vertex 8: and retrieve
    handle                     = verts[8];
    double double_input_value  = 1.0;
    double double_output_value = 0.0;
    error                      = MB->tag_set_data( tag_id, &handle, 1, &double_input_value );
    error = MB->tag_get_data( tag_id, &handle, 1, &double_output_value );
        return error;
    else if( double_output_value != double_input_value )
        return MB_FAILURE;
    // Add a struct Vertex Tag to the database
    struct TagStruct
        int test_int;
        double test_double;
    error =
        MB->tag_get_handle( "struct_tag", sizeof( TagStruct ), MB_TYPE_OPAQUE, tag_id, MB_TAG_SPARSE | MB_TAG_EXCL );
    // put a value in vertex 7 and retrieve
    handle = verts[7];
    TagStruct input_tag_struct;
    input_tag_struct.test_int    = 55;
    input_tag_struct.test_double = -1.2345;
    TagStruct output_tag_struct;
    error = MB->tag_set_data( tag_id, &handle, 1, &input_tag_struct );
    error = MB->tag_get_data( tag_id, &handle, 1, &output_tag_struct );
        return error;
    else if( output_tag_struct.test_int != input_tag_struct.test_int ||
             output_tag_struct.test_double != input_tag_struct.test_double )
        return MB_FAILURE;
    // Create sparse tags for 10 random entities including some outside the
    // range of allowable entities.
    error = MB->tag_get_handle( "sparse_int_tag", 1, MB_TYPE_INTEGER, tag_id, MB_TAG_SPARSE | MB_TAG_EXCL );
    // print_yes = true;
    int i;
    for( i = 0; i < 10; i++ )
        // use invalid handles for odd values
        if( i % 2 )
            handle = verts[i] + *std::max_element( verts.begin(), verts.end() );
        else
            handle = verts[i];
        input_value = 11;
        // should fail on odd values of i
        if( !( i % 2 ) )
            if( error != MB_SUCCESS )  // even case and if failed
                return error;
        else
            if( error == MB_SUCCESS )  // odd case and it says it worked!
                return MB_FAILURE;
        if( ( i % 2 ) && error != MB_FAILURE && error != MB_TAG_NOT_FOUND ) return error;
        if( ( i % 2 ) && output_value != input_value ) return MB_FAILURE;
    // get the tag_name of the last tag created above
    std::string int_tag_name;
    error = MB->tag_get_name( tag_id, int_tag_name );
    if( int_tag_name != "sparse_int_tag" ) return MB_FAILURE;
    // get the tag handle of the last tag created above
    Tag int_tag_handle;
    error = MB->tag_get_handle( int_tag_name.c_str(), 1, MB_TYPE_INTEGER, int_tag_handle );
    if( int_tag_handle != tag_id ) return MB_FAILURE;
    // test tag_get_tags_on_entity and tag_delete_data
    std::vector< Tag > all_tags;
    handle = verts[0];
    error  = MB->tag_get_tags_on_entity( handle, all_tags );
    if( !all_tags.empty() )
        error = MB->tag_delete_data( all_tags[0], &handle, 1 );
        error = MB->tag_delete( all_tags[0] );
    // delete tags test
    // delete 2 of the sparse tags that were created above.
    handle = verts[2];
    error  = MB->tag_delete_data( tag_id, &handle, 1 );
    handle = verts[6];
    // delete all the rest of the sparse tags.
    error = MB->tag_delete( tag_id );
    // delete the dense tag named bool_tag
    Tag bool_tag_handle;
    error = MB->tag_get_handle( "bool_tag", sizeof( bool ), MB_TYPE_OPAQUE, bool_tag_handle );
    error = MB->tag_delete( bool_tag_handle );
    return error;
ErrorCode nothing_but_type ( Range range,
EntityType  type
Definition at line 937 of file MBTest.cpp.
References moab::Range::begin(), moab::Range::end(), MB_SUCCESS, and moab::TYPE_FROM_HANDLE().
Referenced by mb_mesh_sets_test().
    // make sure there's nothing but hexes in hex_ms
    Range::iterator iter, end_iter;
    iter     = range.begin();
    end_iter = range.end();
    for( ; iter != end_iter; ++iter )
        if( TYPE_FROM_HANDLE( *iter ) != type )
            return MB_FAILURE;
    return MB_SUCCESS;
std::ostream& operator<< ( std::ostream &  s,
Range::const_iterator  i
Definition at line 5207 of file MBTest.cpp.
    return s << *i;
bool points_are_coincident ( const double *  first,
const double *  second
Definition at line 3643 of file MBTest.cpp.
References length().
Referenced by find_coincident_edges(), find_coincident_elements(), and find_coincident_nodes().
    double diff[3];
    diff[2] = first[2] - second[2];
    //  if (diff[2] > 0.001) return false;
    diff[0] = first[0] - second[0];
    diff[1] = first[1] - second[1];
    double length = diff[0] * diff[0] + diff[1] * diff[1] + diff[2] * diff[2];
    if( fabs( length ) < .001 ) return true;
    return false;
static void usage ( const char *  exe) [static]
Definition at line 7678 of file MBTest.cpp.
    cerr << "Usage: " << exe << " [-nostress] [-d input_file_dir]\n";
    exit( 1 );
Variable Documentation
const char* argv0 = 0
Definition at line 5774 of file MBTest.cpp.
Referenced by usage().
int number_tests = 0
Definition at line 7684 of file MBTest.cpp.
Definition at line 7685 of file MBTest.cpp.
