MeshImplData.hpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected]
00024
00025   ***************************************************************** */
00026
00027 #ifndef MESQUITE_MESH_IMPL_DATA_HPP
00028 #define MESQUITE_MESH_IMPL_DATA_HPP
00029
00030 #include "Mesquite.hpp"
00031 #include "Vector3D.hpp"
00032 #include "MeshInterface.hpp"
00033
00034 #include <vector>
00035 #include <sys/types.h>
00036
00037 namespace MBMesquite
00038 {
00039
00040 class MsqError;
00041
00042 /** Class to store mesh representation for MeshImpl */
00043 class MeshImplData
00044 {
00045
00046   public:
00047     MeshImplData() : haveSlavedFlags( false ) {}
00048
00049     /** Clear all data */
00050     void clear();
00051
00052     /** Get number of vertices, does not include mid-nodes */
00053     size_t num_vertices() const;
00054     /** Get number of elements */
00055     size_t num_elements() const;
00056     /** Get number of vertex uses (sum of connectivity length for all elements)
00057      * Does not count mid-nodes */
00058     size_t num_vertex_uses() const;
00059
00060     size_t max_vertex_index() const
00061     {
00062         return vertexList.size();
00063     }
00064     size_t max_element_index() const
00065     {
00066         return elementList.size();
00067     }
00068
00069     /** Copy internal representation into CSR rep
00070      *  Does not include mid-nodes. */
00071     void copy_mesh( size_t* vertex_handle_array,
00072                     size_t* element_hanlde_array,
00073                     size_t* element_conn_offsets,
00074                     size_t* element_conn_indices );
00075
00076     /** Get all vertices, including mid-nodes */
00077     void all_vertices( std::vector< size_t >& list, MsqError& err ) const;
00078
00079     /** Get all elements */
00080     void all_elements( std::vector< size_t >& list, MsqError& err ) const;
00081
00082     /** Check if passed vertex index is valid */
00083     inline bool is_vertex_valid( size_t index ) const
00084     {
00085         return index < vertexList.size() && vertexList[index].valid;
00086     }
00087
00088     /** Check if passed element index is valid */
00089     inline bool is_element_valid( size_t index ) const
00090     {
00091         return index < elementList.size() && !elementList[index].connectivity.empty();
00092     }
00093
00094     /** Check if the specified node is used as a mid-node on any element */
00095     bool is_mid_node( size_t index ) const;
00096     /** Check if the specified node is used as a corner vertex on any element */
00097     bool is_corner_node( size_t index ) const;
00098
00099     /** Get vertex coordinates */
00100     const Vector3D& get_vertex_coords( size_t index, MsqError& err ) const;
00101
00102     /** Set vertex coordinates */
00103     void set_vertex_coords( size_t index, const Vector3D& coords, MsqError& err );
00104
00105     /** Get vertex fixed flag */
00106     bool vertex_is_fixed( size_t index, MsqError& err ) const;
00107
00108     /** Get vertex slaved flag */
00109     bool vertex_is_slaved( size_t index, MsqError& err ) const;
00110
00111     /** Set vertex fixed flag */
00112     void fix_vertex( size_t index, bool flag, MsqError& err );
00113
00114     /** Set vertex slaved flag */
00115     void slave_vertex( size_t index, bool flag, MsqError& err );
00116
00117     /** Get vertex byte */
00118     unsigned char get_vertex_byte( size_t index, MsqError& err ) const;
00119
00120     /** Set vertex byte */
00121     void set_vertex_byte( size_t index, unsigned char value, MsqError& err );
00122
00123     /** Get element type */
00124     EntityTopology element_topology( size_t index, MsqError& err ) const;
00125
00126     /** Set element type */
00127     void element_topology( size_t index, EntityTopology type, MsqError& err );
00128
00129     /** Get element connectivity list, including mid-nodes */
00130     const std::vector< size_t >& element_connectivity( size_t index, MsqError& err ) const;
00131
00132     /** Get vertex adjacency list */
00133     const std::vector< size_t >& vertex_adjacencies( size_t index, MsqError& err ) const;
00134
00135     /** Allocate space for specified number of vertices */
00136     void allocate_vertices( size_t count, MsqError& err );
00137
00138     /** Allocate space for specified number of elements */
00139     void allocate_elements( size_t count, MsqError& err );
00140
00141     /** Set allocated but unset veretx to specified values */
00142     void reset_vertex( size_t index, const Vector3D& coords, bool fixed, MsqError& err );
00143
00144     /**
00145      *  Clear element at specified index (if any) including
00146      *  connectivity and adjacency data, and re-initialize with
00147      *  passed data.
00148      */
00149     void reset_element( size_t index, const std::vector< long >& vertices, EntityTopology topology, MsqError& err );
00150     void reset_element( size_t index, const std::vector< size_t >& vertices, EntityTopology topology, MsqError& err );
00151
00152     /** Add a new vertex */
00153     size_t add_vertex( const Vector3D& coords, bool fixed, MsqError& err );
00154     /** Add a new element */
00155     size_t add_element( const std::vector< long >& vertices, EntityTopology topology, MsqError& err );
00156     size_t add_element( const std::vector< size_t >& vertices, EntityTopology topology, MsqError& err );
00157
00158     /** Delete a vertex - may not be referenced by any element */
00159     void delete_vertex( size_t index, MsqError& err );
00160     /** Delete an element */
00161     void delete_element( size_t index, MsqError& err );
00162
00163     /** Get all mid-nodes and their adjacent corner vertices */
00164     void copy_higher_order( std::vector< size_t >& mid_nodes,
00165                             std::vector< size_t >& vertices,
00166                             std::vector< size_t >& vertex_indices,
00167                             std::vector< size_t >& index_offsets,
00168                             MsqError& err );
00169
00170     /** \brief Get elements adjacent to ALL of the passed nodes.
00171      *
00172      * Return the list of elements that is the intersection of the
00173      * adjacency lists of the specified vertices.
00174      */
00175     void get_adjacent_elements( std::vector< size_t >::const_iterator nodes,
00176                                 std::vector< size_t >::const_iterator nodes_end,
00177                                 std::vector< size_t >& elems_out,
00178                                 MsqError& err );
00179
00180     /**\brief Skin mesh
00181      *
00182      * Get the boundary of a mesh as element sides
00183      *
00184      *\param sides Element sides as pairs of values : { elem_index, side_number }
00185      */
00186     void skin( std::vector< size_t >& sides, MsqError& err );
00187
00188     bool have_slaved_flags() const
00189     {
00190         return haveSlavedFlags;
00191     }
00192
00193   private:
00194     /**\brief helper function for skinning
00195      *
00196      * Check if any elements adjacent to a side of an element
00197      * are of the same dimension as the input element.
00198      *\param elem  The element
00199      *\param nodes The nodes composing the side of the element
00200      */
00201     bool has_adjacent_elements( size_t elem, const std::vector< size_t >& nodes, MsqError& err );
00202
00203     /** Clear existing element data */
00204     void clear_element( size_t index, MsqError& err );
00205
00206     /** Set cleared element */
00207     void set_element( size_t index, const std::vector< long >& vertices, EntityTopology topology, MsqError& err );
00208
00209     /** Set cleared element */
00210     void set_element( size_t index, const std::vector< size_t >& vertices, EntityTopology topology, MsqError& err );
00211
00212     /** Struct holding a vertex */
00213     struct Vertex
00214     {
00215         Vertex( const Vector3D& pos, bool is_fixed )
00216             : coords( pos ), midcount( 0 ), fixed( is_fixed ), valid( true ), byte( '\0' )
00217         {
00218         }
00219
00220         Vertex() : midcount( 0 ), valid( false ), byte( '\0' ) {}
00221
00222         Vector3D coords;                   /**< location */
00223         std::vector< size_t > adjacencies; /**< indices of adjacent elements */
00224         unsigned midcount;                 /**< num elements referencing this as a mid-node */
00225         bool fixed;                        /**< is fixed */
00226         bool slaved;
00227         bool valid;         /**< is a valid (initialized) array entry */
00228         unsigned char byte; /**< mark */
00229     };
00230
00231     /** Struct holding an element */
00232     struct Element
00233     {
00234         std::vector< size_t > connectivity; /**< list of vertex indices */
00235         EntityTopology topology;            /**< element type */
00236         Element() : topology( MIXED ) {}
00237     };
00238
00239     std::vector< Vertex > vertexList;   /**< Array of vertices */
00240     std::vector< Element > elementList; /**< Array of elements */
00241
00242     /** List of unused indices in vertex list */
00243     std::vector< size_t > deletedVertexList;
00244     /** List of unused indices in element list */
00245     std::vector< size_t > deletedElementList;
00246
00247     bool haveSlavedFlags;
00248 };
00249
00250 /**\brief VertexIterator for MeshImpl
00251  *
00252  * Iterate over valid vertex indices
00253  */
00254 class MeshImplVertIter : public VertexIterator
00255 {
00256   private:
00257     MeshImplData* mesh;
00258     size_t index;
00259
00260   public:
00261     MeshImplVertIter( MeshImplData* data ) : mesh( data )
00262     {
00263         restart();
00264     }
00265
00266     virtual ~MeshImplVertIter();
00267
00268     virtual void restart();
00269
00270     virtual void operator++();
00271
00272     virtual Mesh::VertexHandle operator*() const;
00273
00274     virtual bool is_at_end() const;
00275 };
00276
00277 /**\brief ElementIterator for MeshImpl
00278  *
00279  * Iterate over valid element indices
00280  */
00281 class MeshImplElemIter : public ElementIterator
00282 {
00283   private:
00284     MeshImplData* mesh;
00285     size_t index;
00286
00287   public:
00288     MeshImplElemIter( MeshImplData* data ) : mesh( data )
00289     {
00290         restart();
00291     }
00292
00293     virtual ~MeshImplElemIter();
00294
00295     virtual void restart();
00296
00297     virtual void operator++();
00298
00299     virtual Mesh::ElementHandle operator*() const;
00300
00301     virtual bool is_at_end() const;
00302 };
00303
00304 }  // namespace MBMesquite
00305
00306 #endif
