MeshTopoUtil.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifndef MOAB_MESH_TOPO_UTIL_HPP
00017 #define MOAB_MESH_TOPO_UTIL_HPP
00018
00019 #include "moab/Forward.hpp"
00020
00021 namespace moab
00022 {
00023
00024 /*!
00025  *  \authors Tim Tautges
00026  *  \date    2/04
00027  *  \brief   MeshTopoUtil contains general mesh utility functions
00028  *
00029  */
00030 class MeshTopoUtil
00031 {
00032   public:
00033     MeshTopoUtil( Interface* impl ) : mbImpl( impl ) {}
00034
00035     ~MeshTopoUtil() {}
00036
00037     //! generate all the AEntities bounding the vertices
00038     ErrorCode construct_aentities( const Range& vertices );
00039
00040     //! given an entity, get its average position (avg vertex locations)
00041     ErrorCode get_average_position( Range& entities, double* avg_position );
00042
00043     //! given an entity, get its average position (avg vertex locations)
00044     ErrorCode get_average_position( const EntityHandle entity, double* avg_position );
00045
00046     //! given a set of entities, get their average position (avg vertex locations)
00047     ErrorCode get_average_position( const EntityHandle* entities, const int num_entities, double* avg_position );
00048
00049     //! get (target_dim)-dimensional manifold entities connected to star_entity; that is,
00050     //! the entities with <= 1 connected (target_dim+2)-dimensional adjacent entities;
00051     //! for target_dim=3, just return all of them
00052     //! just insert into the list, w/o clearing manifold list first
00053     ErrorCode get_manifold( const EntityHandle star_entity, const int target_dim, Range& manifold );
00054
00055     //! given an entity, find the entities of next higher dimension around
00056     //! that entity, ordered by connection through next higher dimension entities;
00057     //! if any of the star entities is in only entity of next higher dimension,
00058     //! on_boundary is returned true
00059     ErrorCode star_entities( const EntityHandle star_center,
00060                              std::vector< EntityHandle >& star_entities,
00061                              bool& bdy_entity,
00062                              const EntityHandle starting_star_entity        = 0,
00063                              std::vector< EntityHandle >* star_entities_dp1 = NULL,
00064                              Range* star_entities_candidates_dp1            = NULL );
00065
00066     //! Get a series of (d+1)-dimensional stars around a d-dimensional entity, such that
00067     //! each star is on a (d+2)-manifold containing the d-dimensional entity; each star
00068     //! is either open or closed, and also defines a (d+2)-star whose entities are bounded by
00069     //! (d+1)-entities on the star and on the (d+2)-manifold
00070     ErrorCode star_entities_nonmanifold( const EntityHandle star_entity,
00071                                          std::vector< std::vector< EntityHandle > >& stars,
00072                                          std::vector< bool >* bdy_flags                        = NULL,
00073                                          std::vector< std::vector< EntityHandle > >* dp2_stars = NULL );
00074
00075     //! given a star_center, a last_entity (whose dimension should be 1 greater than center)
00076     //! and last_dp1 (dimension 2 higher than center), returns the next star entity across
00077     //! last_dp1, and the next dp1 entity sharing next_entity; if star_candidates is non-empty,
00078     //! star must come from those
00079     ErrorCode star_next_entity( const EntityHandle star_center,
00080                                 const EntityHandle last_entity,
00081                                 const EntityHandle last_dp1,
00082                                 Range* star_candidates_dp1,
00083                                 EntityHandle& next_entity,
00084                                 EntityHandle& next_dp1 );
00085
00086     //! get "bridge" or "2nd order" adjacencies, going through dimension bridge_dim
00087     ErrorCode get_bridge_adjacencies( Range& from_entities,
00088                                       int bridge_dim,
00089                                       int to_dim,
00090                                       Range& to_ents,
00091                                       int num_layers = 1 );
00092
00093     //! get "bridge" or "2nd order" adjacencies, going through dimension bridge_dim
00094     ErrorCode get_bridge_adjacencies( const EntityHandle from_entity,
00095                                       const int bridge_dim,
00096                                       const int to_dim,
00097                                       Range& to_adjs );
00098
00099     //! return a common entity of the specified dimension, or 0 if there isn't one
00100     EntityHandle common_entity( const EntityHandle ent1, const EntityHandle ent2, const int dim );
00101
00102     //! return the opposite side entity given a parent and bounding entity.
00103     //! This function is only defined for certain types of parent/child types;
00104     //! See MBCN.hpp::OppositeSide for details.
00105     //!
00106     //! \param parent The parent element
00107     //! \param child The child element
00108     //! \param opposite_element The index of the opposite element
00109     ErrorCode opposite_entity( const EntityHandle parent, const EntityHandle child, EntityHandle& opposite_element );
00110
00111     //! split entity which is non-manifold, that is, which has > 2 connected entities
00112     //! of next higher dimension; assumes that there are >= 2 connected regions of
00113     //! (d+2)-dimensional entities; a new d-entity is created for each region after the
00114     //! first, and it's made explicitly-adjacent to the region to which it corresponds
00115     ErrorCode split_entity_nonmanifold( EntityHandle split_ent,
00116                                         Range& old_adjs,
00117                                         Range& new_adjs,
00118                                         EntityHandle& new_entity );
00119
00120     //! split entities that are manifold (shared by two or less entities of each higher dimension),
00121     //! optionally creating an entity of next higher dimension to fill the gap
00122     /**
00123        \param entities The entities to be split
00124        \param new_entities New entities, in order of correspondence to that of entities
00125        \param fill_entities If non-NULL, create an entity of next higher dimension to fill the gap,
00126                        passing it back in *fill_entities
00127     */
00128     ErrorCode split_entities_manifold( Range& entities, Range& new_entities, Range* fill_entities );
00129
00130     //! split entities that are manifold (shared by two or less entities of each higher dimension),
00131     //! optionally creating an entity of next higher dimension to fill the gap
00132     /**
00133        \param entities The entities to be split
00134        \param new_entities New entities, in order of correspondence to that of entities
00135        \param fill_entities If non-NULL, create an entity of next higher dimension to fill the gap,
00136                        passing it back in *fill_entities
00137        \param gowith_ents If non-NULL, each of the new entities will adj to the
00138                        corresponding gowith entities after the split; this parameter is
00139                        ignored for boundary split entities; in that case, the split entity
00140                        remains on the boundary (i.e. not adj to any entity of higher
00141                        dimension).  Dimension of gowith_ents must be the same as entities.
00142     */
00143     ErrorCode split_entities_manifold( EntityHandle* entities,
00144                                        const int num_entities,
00145                                        EntityHandle* new_entities,
00146                                        Range* fill_entities,
00147                                        EntityHandle* gowith_ents = NULL );
00148
00149     //! return whether entity is equivalent to any other of same type and same vertices;
00150     //! if equivalent entity is found, it's returned in equiv_ents and return value is true,
00151     //! false otherwise.
00152     bool equivalent_entities( const EntityHandle entity, Range* equiv_ents = NULL );
00153
00154   private:
00155     Interface* mbImpl;
00156 };
00157
00158 }  // namespace moab
00159
00160 #endif
