MsqDebug.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Sandia Corporation and Argonne National
00005     Laboratory.  Under the terms of Contract DE-AC04-94AL85000
00006     with Sandia Corporation, the U.S. Government retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023   ***************************************************************** */
00024
00025 #include "MsqDebug.hpp"
00026
00027 #include <cstdio>
00028 #include <cstdlib>
00029 #include <cstdarg>
00030 #include <cstring>
00031
00032 namespace MBMesquite
00033 {
00034
00035 /* IMPORTANT: Be careful to initialize the InitializeFlags object
00036  *LAST* as it will access the other static data. */
00037
00038 std::vector< std::ostream* > MsqDebug::streams;
00039 std::vector< bool > MsqDebug::flags;
00040
00041 #ifdef MSQ_ENABLE_DEBUG
00042 static void parse_flag_string( const char* str, bool flag_val )
00043 {
00044     char* s            = strdup( str );
00045     const char delim[] = ";,";
00046     for( const char* p = strtok( s, delim ); p; p = strtok( 0, delim ) )
00047     {
00048         int beg, end;
00049         switch( sscanf( p, "%u - %u", &beg, &end ) )
00050         {
00051             case 1:
00052                 end = beg;
00053                 // fall through
00054             case 2:
00055                 for( ; beg <= end; ++beg )
00056                     MsqDebug::set( beg, flag_val );
00057                 break;
00058         }
00059     }
00060     free( s );
00061 }
00062
00063 MsqDebug::InitializeFlags::InitializeFlags()
00064 {
00065     const unsigned flag_array[] = { MSQ_ENABLE_DEBUG, 0 };
00066     size_t length               = sizeof( flag_array ) / sizeof( unsigned ) - 1;
00067     while( length > 0 )
00068         MsqDebug::set( flag_array[--length], true );
00069
00070     const char* envstr = getenv( "MESQUITE_DEBUG" );
00071     if( envstr ) parse_flag_string( envstr, true );
00072     envstr = getenv( "MESQUITE_NO_DEBUG" );
00073     if( envstr ) parse_flag_string( envstr, false );
00074 }
00075 #else
00076 MsqDebug::InitializeFlags::InitializeFlags() {}
00077 #endif
00078
00079 MsqDebug::InitializeFlags MsqDebug::init;
00080
00081 bool MsqDebug::get( unsigned flag )
00082 {
00083     return flag < flags.size() && flags[flag];
00084 }
00085
00086 void MsqDebug::set( unsigned flag, bool state )
00087 {
00088     if( state )
00089     {
00090         if( flag >= flags.size() )
00091         {
00092             flags.resize( flag + 1 );
00093         }
00094         flags[flag] = true;
00095     }
00096     else
00097     {
00098         if( flag < flags.size() ) flags[flag] = false;
00099     }
00100 }
00101
00102 void MsqDebug::disable_all()
00103 {
00104     flags.clear();
00105 }
00106
00107 std::ostream& MsqDebug::get_stream( unsigned flag )
00108 {
00109     if( flag < streams.size() )
00110         return *streams[flag];
00111     else
00112         return std::cout;
00113 }
00114
00115 void MsqDebug::set_stream( unsigned flag, std::ostream& stream )
00116 {
00117     if( flag >= streams.size() )
00118     {
00119         size_t old_size = streams.size();
00120         streams.resize( flag );
00121         for( unsigned i = old_size; i < flag; ++i )
00122             streams[i] = &std::cout;
00123     }
00124     streams[flag] = &stream;
00125 }
00126
00127 void MsqDebug::FormatPrinter::print( const char* format, ... ) const
00128 {
00129     if( !MsqDebug::get( myFlag ) ) return;
00130
00131     char buffer[512];
00132
00133 #if defined( HAVE_VSNPRINTF )
00134     va_list args;
00135     va_start( args, format );
00136     vsnprintf( buffer, sizeof( buffer ), format, args );
00137     va_end( args );
00138 #elif defined( HAVE__VSNPRINTF )
00139     va_list args;
00140     va_start( args, format );
00141     _vsnprintf( buffer, sizeof( buffer ), format, args );
00142     va_end( args );
00143 #elif defined( HAVE_VSPRINTF )
00144     va_list args;
00145     va_start( args, format );
00146     vsprintf( buffer, format, args );
00147     va_end( args );
00148 #else
00149     strncpy( buffer, format, sizeof( buffer ) );
00150     buffer[sizeof( buffer ) - 1] = '\0';
00151 #endif
00152
00153     MsqDebug::get_stream( myFlag ) << buffer;
00154 }
00155
00156 }  // namespace MBMesquite
