MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2004 Sandia Corporation and Argonne National 00005 Laboratory. Under the terms of Contract DE-AC04-94AL85000 00006 with Sandia Corporation, the U.S. Government retains certain 00007 rights in this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 [email protected], [email protected], [email protected], 00024 [email protected], [email protected], [email protected] 00025 00026 ***************************************************************** */ 00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3 00028 // -*- 00029 // 00030 // SUMMARY: 00031 // USAGE: 00032 // 00033 // AUTHOR: Thomas Leurent <[email protected]> 00034 // ORG: Argonne National Laboratory 00035 // E-MAIL: [email protected] 00036 // 00037 // ORIG-DATE: 13-Jan-03 at 09:05:56 00038 // LAST-MOD: 9-Apr-03 at 17:17:26 by Thomas Leurent 00039 // 00040 // DESCRIPTION: 00041 // ============ 00042 /*! \file MsqHessianTest.cpp 00043 00044 Unit testing of the MsqHessian class. 00045 00046 */ 00047 // DESCRIP-END. 00048 // 00049 00050 #include "PatchDataInstances.hpp" 00051 #include "MsqHessian.hpp" 00052 00053 #include <cmath> 00054 00055 #include "cppunit/extensions/HelperMacros.h" 00056 00057 using namespace MBMesquite; 00058 using std::cerr; 00059 using std::cout; 00060 using std::endl; 00061 00062 class MsqHessianTest : public CppUnit::TestFixture, public MBMesquite::MsqHessian 00063 { 00064 00065 private: 00066 CPPUNIT_TEST_SUITE( MsqHessianTest ); 00067 CPPUNIT_TEST( test_initialize ); 00068 CPPUNIT_TEST( test_axpy ); 00069 CPPUNIT_TEST( test_cg_solver ); 00070 CPPUNIT_TEST( test_cholesky_preconditioner ); 00071 CPPUNIT_TEST_SUITE_END(); 00072 00073 private: 00074 PatchData twoTriangles; 00075 00076 public: 00077 void setUp() 00078 { 00079 MsqPrintError err( cout ); 00080 create_two_tri_patch( twoTriangles, err ); 00081 CPPUNIT_ASSERT( !err ); 00082 } 00083 00084 void tearDown() 00085 { 00086 destroy_patch_with_domain( twoTriangles ); 00087 } 00088 00089 public: 00090 MsqHessianTest() {} 00091 00092 void accumulate_entries( const PatchData& pd, size_t elem_index, const Matrix3D* mat3d_array, MsqError& err ); 00093 00094 void test_initialize() 00095 { 00096 MsqPrintError err( cout ); 00097 00098 MsqHessian::initialize( twoTriangles, err ); 00099 CPPUNIT_ASSERT( !err ); 00100 00101 // Checks values of mRowStart are correct. 00102 size_t i, row_start[] = { 0, 4, 7, 8, 9 }; 00103 for( i = 0; i < 5; ++i ) 00104 CPPUNIT_ASSERT( mRowStart[i] == row_start[i] ); 00105 00106 // Checks values of mColIndex are correct. 00107 size_t col_index[] = { 0, 1, 2, 3, 1, 2, 3, 2, 3 }; 00108 for( i = 0; i < 9; ++i ) 00109 CPPUNIT_ASSERT( mColIndex[i] == col_index[i] ); 00110 } 00111 00112 void test_axpy() 00113 { 00114 size_t i; 00115 MsqPrintError err( cout ); 00116 00117 MsqHessian::initialize( twoTriangles, err ); 00118 CPPUNIT_ASSERT( !err ); 00119 00120 size_t hs = MsqHessian::size(); 00121 00122 Vector3D* res = new Vector3D[hs]; 00123 Vector3D* x = new Vector3D[hs]; 00124 Vector3D* y = new Vector3D[hs]; 00125 Vector3D* ans = new Vector3D[hs]; 00126 00127 Matrix3D blocks[6]; // 6 blocks correspond to a triangular element (n+1)n/2 . 00128 00129 blocks[0] = "4 4 7 4 5 7 7 7 3 "; 00130 blocks[1] = "4 8 7 3 5 7 1 2 3 "; 00131 blocks[2] = "4 4 7 6 5 9 1 8 5 "; 00132 blocks[3] = "4 4 2 4 5 3 2 3 3 "; 00133 blocks[4] = "2 4 7 3 2 7 1 4 3 "; 00134 blocks[5] = "8 4 9 4 5 7 9 7 3 "; 00135 00136 accumulate_entries( twoTriangles, 0, blocks, err ); 00137 CPPUNIT_ASSERT( !err ); 00138 00139 blocks[2] += blocks[5]; 00140 blocks[5] = blocks[3]; 00141 00142 accumulate_entries( twoTriangles, 1, blocks, err ); 00143 CPPUNIT_ASSERT( !err ); 00144 00145 Matrix3D entries_6_ans( "2 3 1 4 2 4 7 7 3" ); 00146 CPPUNIT_ASSERT( mEntries[6] == entries_6_ans ); 00147 00148 x[0].set( 4, 5, 6 ); 00149 x[1].set( 2, 5, 9 ); 00150 x[2].set( 1, 2, 6 ); 00151 x[3].set( 1, 5, 9 ); 00152 00153 y[0].set( 0, 0, 0 ); 00154 y[1].set( 0, 0, 0 ); 00155 y[2].set( 0, 0, 0 ); 00156 y[3].set( 0, 0, 0 ); 00157 00158 axpy( res, hs, *this, x, hs, y, hs, err ); 00159 CPPUNIT_ASSERT( !err ); 00160 00161 ans[0].set( 636, 635, 453 ); 00162 ans[1].set( 365, 460, 461 ); 00163 ans[2].set( 150, 199, 220 ); 00164 ans[3].set( 166, 204, 174 ); 00165 00166 for( i = 0; i < hs; ++i ) 00167 CPPUNIT_ASSERT( res[i] == ans[i] ); 00168 00169 y[0].set( 3, 2, 6 ); 00170 y[1].set( 1, 2, 4 ); 00171 y[2].set( 3, 6, 9 ); 00172 y[3].set( 2, 4, 4 ); 00173 00174 ans[0].set( 639, 637, 459 ); 00175 ans[1].set( 366, 462, 465 ); 00176 ans[2].set( 153, 205, 229 ); 00177 ans[3].set( 168, 208, 178 ); 00178 00179 axpy( res, hs, *this, x, hs, y, hs, err ); 00180 CPPUNIT_ASSERT( !err ); 00181 00182 for( i = 0; i < hs; ++i ) 00183 CPPUNIT_ASSERT( res[i] == ans[i] ); 00184 00185 delete[] res; 00186 delete[] x; 00187 delete[] y; 00188 delete[] ans; 00189 } 00190 00191 void test_cg_solver() 00192 { 00193 size_t i; 00194 MsqPrintError err( cout ); 00195 00196 MsqHessian::initialize( twoTriangles, err ); 00197 CPPUNIT_ASSERT( !err ); 00198 00199 size_t hs = MsqHessian::size(); 00200 00201 Vector3D* res = new Vector3D[hs]; 00202 Vector3D* x = new Vector3D[hs]; 00203 Vector3D* y = new Vector3D[hs]; 00204 Vector3D* ans = new Vector3D[hs]; 00205 00206 Matrix3D blocks[6]; // 6 blocks correspond to a triangular element (n+!)n/2 . 00207 00208 blocks[0] = "14 4 7 4 15 7 7 7 13 "; 00209 blocks[1] = "4 8 7 3 5 7 1 2 3 "; 00210 blocks[2] = "4 4 7 6 5 9 1 8 5 "; 00211 blocks[3] = "14 4 2 4 15 3 2 3 13 "; 00212 blocks[4] = "2 4 7 3 2 7 1 4 3 "; 00213 blocks[5] = "18 4 9 4 15 7 9 7 13 "; 00214 00215 accumulate_entries( twoTriangles, 0, blocks, err ); 00216 CPPUNIT_ASSERT( !err ); 00217 00218 blocks[2] -= blocks[5]; 00219 blocks[5] = blocks[3]; 00220 00221 accumulate_entries( twoTriangles, 1, blocks, err ); 00222 CPPUNIT_ASSERT( !err ); 00223 00224 y[0].set( 3, 2, 6 ); 00225 y[1].set( 1, 2, 4 ); 00226 y[2].set( 3, 6, 9 ); 00227 y[3].set( 2, 4, 4 ); 00228 00229 cg_solver( x, y, err ); 00230 CPPUNIT_ASSERT( !err ); 00231 00232 // for (int i=0; i<4; ++i) 00233 // cout << x[i]; 00234 00235 ans[0].set( 3.2338, 7.6431, -7.0735 ); 00236 ans[1].set( -1.0068, 4.5520, -4.6628 ); 00237 ans[2].set( -0.4361, 4.7640, -8.1006 ); 00238 ans[3].set( -0.1218, -0.8817, -4.5571 ); 00239 00240 for( i = 0; i < hs; ++i ) 00241 for( short j = 0; j < 3; ++j ) 00242 CPPUNIT_ASSERT_DOUBLES_EQUAL( x[i][j], ans[i][j], 10e-1 ); 00243 00244 delete[] res; 00245 delete[] x; 00246 delete[] y; 00247 delete[] ans; 00248 } 00249 00250 void test_cholesky_preconditioner() 00251 { 00252 MsqPrintError err( cout ); 00253 00254 MsqHessian::initialize( twoTriangles, err ); 00255 CPPUNIT_ASSERT( !err ); 00256 MsqHessian::zero_out(); 00257 00258 Matrix3D blocks[6]; // 6 blocks correspond to a triangular element (n+1)n/2 . 00259 00260 blocks[0] = " 2 1 1 " 00261 " 1 2.5 0.5 " 00262 " 1 0.5 2.5 "; 00263 blocks[1] = "0 0 0 0 0 0 0 0 0 "; 00264 blocks[2] = "0 0 0 0 0 0 0 0 0 "; 00265 blocks[3] = "0 0 0 0 0 0 0 0 0 "; 00266 blocks[4] = "0 0 0 0 0 0 0 0 0 "; 00267 blocks[5] = "0 0 0 0 0 0 0 0 0 "; 00268 00269 accumulate_entries( twoTriangles, 0, blocks, err ); 00270 CPPUNIT_ASSERT( !err ); 00271 00272 MsqHessian::compute_preconditioner( err ); 00273 CPPUNIT_ASSERT( !err ); 00274 Matrix3D block_0 = mPreconditioner[0]; 00275 00276 Matrix3D correct( " 0.5 0.5 0.5 " 00277 " 0 0.5 0 " 00278 " 0 0 0.5 " ); 00279 00280 for( short i = 0; i < 3; ++i ) 00281 for( short j = 0; j < 3; ++j ) 00282 CPPUNIT_ASSERT_DOUBLES_EQUAL( block_0[i][j], correct[i][j], 10e-10 ); 00283 00284 // cout << "block 0: \n" << block_0 << endl; 00285 // cout << "correct: \n" << correct << endl; 00286 } 00287 }; 00288 00289 void MsqHessianTest::accumulate_entries( const PatchData& pd, 00290 size_t elem_index, 00291 const Matrix3D* mat3d_array, 00292 MsqError& err ) 00293 { 00294 const MsqMeshEntity& elem = pd.element_by_index( elem_index ); 00295 const size_t nv = elem.vertex_count(); 00296 const size_t* v = elem.get_vertex_index_array(); 00297 for( size_t r = 0; r < nv; ++r ) 00298 { 00299 for( size_t c = r; c < nv; ++c ) 00300 { 00301 add( v[r], v[c], *mat3d_array, err ); 00302 CPPUNIT_ASSERT( !err ); 00303 ++mat3d_array; 00304 } 00305 } 00306 } 00307 00308 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqHessianTest, "MsqHessianTest" ); 00309 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqHessianTest, "Unit" );
