MsqIBase.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected]
00024
00025   ***************************************************************** */
00026
00027 /*!
00028   \file   MsqIBase.cpp
00029   \brief
00030
00031
00032   \author Jason Kraftcheck
00033   \date   2007-08-14
00034 */
00035
00036 #include "iBase.h"
00037 #include "MsqIBase.hpp"
00038 #include "MsqDebug.hpp"
00039
00040 namespace MBMesquite
00041 {
00042
00043 std::string process_itaps_error( int ierr )
00044 {
00045     std::string result( "ITAPS ERROR: " );
00046     switch( ierr )
00047     {
00048         case iBase_MESH_ALREADY_LOADED:
00049             result += "File Already Loaded";
00050             break;
00051         case iBase_FILE_NOT_FOUND:
00052             result += "File Not Found";
00053             break;
00054         case iBase_FILE_WRITE_ERROR:
00055             result += "File Write Error";
00056             break;
00057         case iBase_NIL_ARRAY:
00058             result += "NULL Array";
00059             break;
00060         case iBase_BAD_ARRAY_SIZE:
00061             result += "Bad Array Size";
00062             break;
00063         case iBase_BAD_ARRAY_DIMENSION:
00064             result += "Bad Array Dimension";
00065             break;
00066         case iBase_INVALID_ENTITY_HANDLE:
00067             result += "Invalid Handle";
00068             break;
00069         case iBase_INVALID_ENTITY_COUNT:
00070             result += "Invalid Count";
00071             break;
00072         case iBase_INVALID_ENTITY_TYPE:
00073             result += "Invalid Type";
00074             break;
00075         case iBase_INVALID_ENTITY_TOPOLOGY:
00076             result += "Invalid Topology";
00077             break;
00078         case iBase_BAD_TYPE_AND_TOPO:
00079             result += "Invalid Type";
00080             break;
00081         case iBase_ENTITY_CREATION_ERROR:
00082             result += "Creation Failed";
00083             break;
00084         case iBase_INVALID_TAG_HANDLE:
00085             result += "Invalid Tag";
00086             break;
00087         case iBase_TAG_NOT_FOUND:
00088             result += "Tag Not Found";
00089             break;
00090         case iBase_TAG_ALREADY_EXISTS:
00091             result += "Tag Exists";
00092             break;
00093         case iBase_TAG_IN_USE:
00094             result += "Tag In Use";
00095             break;
00096         case iBase_INVALID_ENTITYSET_HANDLE:
00097             result += "Invalid Handle";
00098             break;
00099         case iBase_INVALID_ITERATOR_HANDLE:
00100             result += "Invalid Iterator";
00101             break;
00102         case iBase_INVALID_ARGUMENT:
00103             result += "Invalid Argument";
00104             break;
00105         case iBase_MEMORY_ALLOCATION_FAILED:
00106             result += "Out of Memory";
00107             break;
00108         case iBase_NOT_SUPPORTED:
00109             result += "Not Supported";
00110             break;
00111         default:
00112             result += "Uknown/Internal Error";
00113             break;
00114     }
00115     MSQ_DBGOUT( 1 ) << result << std::endl;
00116     return result;
00117 }
00118
00119 }  // namespace MBMesquite
