MsqIGeom.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected]
00024
00025   ***************************************************************** */
00026
00027 /*!
00028   \file   MsqIGeom.cpp
00029   \brief
00030
00031
00032   \author Jason Kraftcheck
00033   \date   2007-08-14
00034 */
00035
00036 #include "MsqIGeom.hpp"
00037 #include "MsqDebug.hpp"
00038 #include "MsqVertex.hpp"
00039 #include "MsqError.hpp"
00040 #include "MsqIBase.hpp"
00041
00042 namespace MBMesquite
00043 {
00044
00045 /***************** MsqIGeom class methods *********************/
00046
00047 MsqIGeom::MsqIGeom( iGeom_Instance geom, iBase_EntityHandle geom_ent_handle )
00048     : MsqCommonIGeom( geom ), geomEntHandle( geom_ent_handle )
00049 {
00050 }
00051
00052 MsqIGeom::~MsqIGeom() {}
00053
00054 void MsqIGeom::snap_to( Mesh::VertexHandle, Vector3D& coordinate ) const
00055 {
00056     int ierr = move_to( geomEntHandle, coordinate );
00057     if( iBase_SUCCESS != ierr ) process_itaps_error( ierr );
00058 }
00059
00060 void MsqIGeom::vertex_normal_at( Mesh::VertexHandle, Vector3D& coordinate ) const
00061 {
00062     int ierr = normal( geomEntHandle, coordinate );
00063     if( iBase_SUCCESS != ierr ) process_itaps_error( ierr );
00064 }
00065
00066 void MsqIGeom::element_normal_at( Mesh::ElementHandle, Vector3D& coordinate ) const
00067 {
00068     int ierr = normal( geomEntHandle, coordinate );
00069     if( iBase_SUCCESS != ierr ) process_itaps_error( ierr );
00070 }
00071
00072 void MsqIGeom::vertex_normal_at( const Mesh::VertexHandle*,
00073                                  Vector3D coordinates[],
00074                                  unsigned count,
00075                                  MsqError& err ) const
00076 {
00077     int ierr = normal( geomEntHandle, coordinates, count );
00078     if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR );
00079 }
00080
00081 void MsqIGeom::closest_point( Mesh::VertexHandle /*handle*/,
00082                               const Vector3D& position,
00083                               Vector3D& closest,
00084                               Vector3D& p_normal,
00085                               MsqError& err ) const
00086 {
00087     int ierr = closest_and_normal( geomEntHandle, position, closest, p_normal );
00088     if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR );
00089 }
00090
00091 void MsqIGeom::domain_DoF( const Mesh::VertexHandle*,
00092                            unsigned short* dof_array,
00093                            size_t num_vertices,
00094                            MsqError& err ) const
00095 {
00096     unsigned short dim;
00097     int ierr = get_dimension( &geomEntHandle, &dim, 1 );
00098     if( iBase_SUCCESS != ierr ) MSQ_SETERR( err )( process_itaps_error( ierr ), MsqError::INTERNAL_ERROR );
00099     std::fill( dof_array, dof_array + num_vertices, dim );
00100 }
00101
00102 /***************** GeomTSTTCommon class methods *********************/
00103
00104 MsqCommonIGeom::MsqCommonIGeom( iGeom_Instance geom ) : geomIFace( geom ) {}
00105
00106 MsqCommonIGeom::~MsqCommonIGeom() {}
00107
00108 int MsqCommonIGeom::move_to( iBase_EntityHandle geom, Vector3D& coord ) const
00109 {
00110     double x, y, z;
00111     int ierr;
00112     iGeom_getEntClosestPt( geomIFace, geom, coord[0], coord[1], coord[2], &x, &y, &z, &ierr );
00113     coord.set( x, y, z );
00114     return ierr;
00115 }
00116
00117 int MsqCommonIGeom::normal( iBase_EntityHandle geom, Vector3D& coord ) const
00118 {
00119     double i, j, k;
00120     int ierr;
00121     iGeom_getEntNrmlXYZ( geomIFace, geom, coord[0], coord[1], coord[2], &i, &j, &k, &ierr );
00122     coord.set( i, j, k );
00123     return ierr;
00124 }
00125
00126 int MsqCommonIGeom::normal( iBase_EntityHandle geom, Vector3D coords[], unsigned count ) const
00127 {
00128     geomHandles.resize( count, geom );
00129     return normal( arrptr( geomHandles ), coords, count );
00130 }
00131
00132 int MsqCommonIGeom::normal( const iBase_EntityHandle* geom_handles, Vector3D coords[], unsigned count ) const
00133 {
00134     // going to assume this in the following reinterpret_cast, so
00135     // check to make sure it is true
00136     assert( sizeof( Vector3D ) == 3 * sizeof( double ) );
00137
00138     // copy input coordinates into array
00139     coordArray.clear();
00140     coordArray.insert( coordArray.begin(), &coords[0][0], &coords[0][0] + 3 * count );
00141
00142     // define junk variables required for ITAPS "consistancy"
00143     int junk_1 = count * 3, junk_2 = count * 3;
00144     double* norm_ptr = &coords[0][0];
00145
00146     // get the normals
00147     int ierr;
00148     iGeom_getArrNrmlXYZ( geomIFace, geom_handles, count, iBase_INTERLEAVED, arrptr( coordArray ), count * 3, &norm_ptr,
00149                          &junk_1, &junk_2, &ierr );
00150
00151     return ierr;
00152 }
00153
00154 int MsqCommonIGeom::closest_and_normal( iBase_EntityHandle geom,
00155                                         const Vector3D& position,
00156                                         Vector3D& closest,
00157                                         Vector3D& p_normal ) const
00158 {
00159     int ierr;
00160     iGeom_getEntNrmlPlXYZ( geomIFace, geom, position[0], position[1], position[2], &closest[0], &closest[1],
00161                            &closest[2], &p_normal[0], &p_normal[1], &p_normal[2], &ierr );
00162     return ierr;
00163 }
00164
00165 int MsqCommonIGeom::get_dimension( const iBase_EntityHandle* geom_handle, unsigned short* dof_out, size_t count ) const
00166 {
00167     int ierr;
00168     typeArray.resize( count );
00169
00170     // define junk variables required for ITAPS "consistancy"
00171     int junk_1 = count, junk_2 = count;
00172     int* type_ptr = arrptr( typeArray );
00173
00174     // get the types
00175     iGeom_getArrType( geomIFace, geom_handle, count, &type_ptr, &junk_1, &junk_2, &ierr );
00176
00177     // convert from int to unsigned short
00178     std::copy( typeArray.begin(), typeArray.end(), dof_out );
00179     return ierr;
00180 }
00181
00182 }  // namespace MBMesquite
