NCHelperGCRM.cpp
00001 #include "NCHelperGCRM.hpp"
00002 #include "moab/ReadUtilIface.hpp"
00003 #include "moab/FileOptions.hpp"
00004 #include "moab/SpectralMeshTool.hpp"
00005 #include "MBTagConventions.hpp"
00006
00007 #ifdef MOAB_HAVE_ZOLTAN
00008 #include "moab/ZoltanPartitioner.hpp"
00009 #endif
00010
00011 #include <cmath>
00012
00013 namespace moab
00014 {
00015
00016 // GCRM cells are either pentagons or hexagons, and pentagons are always padded to hexagons
00017 const int EDGES_PER_CELL = 6;
00018
00019 NCHelperGCRM::NCHelperGCRM( ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet )
00020     : UcdNCHelper( readNC, fileId, opts, fileSet ), createGatherSet( false )
00021 {
00022     // Ignore variables containing topological information
00023     ignoredVarNames.insert( "grid" );
00024     ignoredVarNames.insert( "cell_corners" );
00025     ignoredVarNames.insert( "cell_edges" );
00026     ignoredVarNames.insert( "edge_corners" );
00027     ignoredVarNames.insert( "cell_neighbors" );
00028 }
00029
00030 bool NCHelperGCRM::can_read_file( ReadNC* readNC )
00031 {
00032     std::vector< std::string >& dimNames = readNC->dimNames;
00033
00034     // If dimension name "cells" exists then it should be the GCRM grid
00035     if( std::find( dimNames.begin(), dimNames.end(), std::string( "cells" ) ) != dimNames.end() ) return true;
00036
00037     return false;
00038 }
00039
00040 ErrorCode NCHelperGCRM::init_mesh_vals()
00041 {
00042     std::vector< std::string >& dimNames              = _readNC->dimNames;
00043     std::vector< int >& dimLens                       = _readNC->dimLens;
00044     std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
00045
00046     ErrorCode rval;
00047     unsigned int idx;
00048     std::vector< std::string >::iterator vit;
00049
00050     // Look for time dimension
00051     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() )
00052         idx = vit - dimNames.begin();
00053     else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
00054         idx = vit - dimNames.begin();
00055     else
00056     {
00057         MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" );
00058     }
00059     tDim       = idx;
00060     nTimeSteps = dimLens[idx];
00061
00062     // Get number of cells
00063     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "cells" ) ) != dimNames.end() )
00064         idx = vit - dimNames.begin();
00065     else
00066     {
00067         MB_SET_ERR( MB_FAILURE, "Couldn't find 'cells' dimension" );
00068     }
00069     cDim   = idx;
00070     nCells = dimLens[idx];
00071
00072     // Get number of edges
00073     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "edges" ) ) != dimNames.end() )
00074         idx = vit - dimNames.begin();
00075     else
00076     {
00077         MB_SET_ERR( MB_FAILURE, "Couldn't find 'edges' dimension" );
00078     }
00079     eDim   = idx;
00080     nEdges = dimLens[idx];
00081
00082     // Get number of vertices
00083     vDim = -1;
00084     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "corners" ) ) != dimNames.end() )
00085         idx = vit - dimNames.begin();
00086     else
00087     {
00088         MB_SET_ERR( MB_FAILURE, "Couldn't find 'corners' dimension" );
00089     }
00090     vDim      = idx;
00091     nVertices = dimLens[idx];
00092
00093     // Get number of layers
00094     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "layers" ) ) != dimNames.end() )
00095         idx = vit - dimNames.begin();
00096     else
00097     {
00098         MB_SET_ERR( MB_FAILURE, "Couldn't find 'layers' dimension" );
00099     }
00100     levDim  = idx;
00101     nLevels = dimLens[idx];
00102
00103     // Dimension indices for other optional levels
00104     std::vector< unsigned int > opt_lev_dims;
00105
00106     // Get index of interface levels
00107     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "interfaces" ) ) != dimNames.end() )
00108     {
00109         idx = vit - dimNames.begin();
00110         opt_lev_dims.push_back( idx );
00111     }
00112
00113     std::map< std::string, ReadNC::VarData >::iterator vmit;
00114
00115     // Store time coordinate values in tVals
00116     if( nTimeSteps > 0 )
00117     {
00118         if( ( vmit = varInfo.find( "time" ) ) != varInfo.end() )
00119         {
00120             rval = read_coordinate( "time", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'time' variable" );
00121         }
00122         else if( ( vmit = varInfo.find( "t" ) ) != varInfo.end() )
00123         {
00124             rval = read_coordinate( "t", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 't' variable" );
00125         }
00126         else
00127         {
00128             // If expected time variable is not available, set dummy time coordinate values to tVals
00129             for( int t = 0; t < nTimeSteps; t++ )
00130                 tVals.push_back( (double)t );
00131         }
00132     }
00133
00134     // For each variable, determine the entity location type and number of levels
00135     for( vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit )
00136     {
00137         ReadNC::VarData& vd = ( *vmit ).second;
00138
00139         // Default entLoc is ENTLOCSET
00140         if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
00141         {
00142             if( std::find( vd.varDims.begin(), vd.varDims.end(), vDim ) != vd.varDims.end() )
00143                 vd.entLoc = ReadNC::ENTLOCVERT;
00144             else if( std::find( vd.varDims.begin(), vd.varDims.end(), eDim ) != vd.varDims.end() )
00145                 vd.entLoc = ReadNC::ENTLOCEDGE;
00146             else if( std::find( vd.varDims.begin(), vd.varDims.end(), cDim ) != vd.varDims.end() )
00147                 vd.entLoc = ReadNC::ENTLOCFACE;
00148         }
00149
00150         // Default numLev is 0
00151         if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() )
00152             vd.numLev = nLevels;
00153         else
00154         {
00155             // If layers dimension is not found, try other optional levels such as interfaces
00156             for( unsigned int i = 0; i < opt_lev_dims.size(); i++ )
00157             {
00158                 if( std::find( vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i] ) != vd.varDims.end() )
00159                 {
00160                     vd.numLev = dimLens[opt_lev_dims[i]];
00161                     break;
00162                 }
00163             }
00164         }
00165     }
00166
00167     // Hack: create dummy variables for dimensions (like cells) with no corresponding coordinate
00168     // variables
00169     rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" );
00170
00171     return MB_SUCCESS;
00172 }
00173
00174 // When noMesh option is used on this read, the old ReadNC class instance for last read can get out
00175 // of scope (and deleted). The old instance initialized some variables properly when the mesh was
00176 // created, but they are now lost. The new instance (will not create the mesh with noMesh option)
00177 // has to restore them based on the existing mesh from last read
00178 ErrorCode NCHelperGCRM::check_existing_mesh()
00179 {
00180     Interface*& mbImpl = _readNC->mbImpl;
00181     Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
00182     bool& noMesh       = _readNC->noMesh;
00183
00184     if( noMesh )
00185     {
00186         ErrorCode rval;
00187
00188         if( localGidVerts.empty() )
00189         {
00190             // Get all vertices from current file set (it is the input set in no_mesh scenario)
00191             Range local_verts;
00192             rval = mbImpl->get_entities_by_dimension( _fileSet, 0, local_verts );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
00193
00194             if( !local_verts.empty() )
00195             {
00196                 std::vector< int > gids( local_verts.size() );
00197
00198                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00199                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
00200
00201                 // Restore localGidVerts
00202                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVerts ) );
00203                 nLocalVertices = localGidVerts.size();
00204             }
00205         }
00206
00207         if( localGidEdges.empty() )
00208         {
00209             // Get all edges from current file set (it is the input set in no_mesh scenario)
00210             Range local_edges;
00211             rval = mbImpl->get_entities_by_dimension( _fileSet, 1, local_edges );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" );
00212
00213             if( !local_edges.empty() )
00214             {
00215                 std::vector< int > gids( local_edges.size() );
00216
00217                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00218                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_edges, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of edges" );
00219
00220                 // Restore localGidEdges
00221                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdges ) );
00222                 nLocalEdges = localGidEdges.size();
00223             }
00224         }
00225
00226         if( localGidCells.empty() )
00227         {
00228             // Get all cells from current file set (it is the input set in no_mesh scenario)
00229             Range local_cells;
00230             rval = mbImpl->get_entities_by_dimension( _fileSet, 2, local_cells );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" );
00231
00232             if( !local_cells.empty() )
00233             {
00234                 std::vector< int > gids( local_cells.size() );
00235
00236                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00237                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_cells, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of cells" );
00238
00239                 // Restore localGidCells
00240                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCells ) );
00241                 nLocalCells = localGidCells.size();
00242             }
00243         }
00244     }
00245
00246     return MB_SUCCESS;
00247 }
00248
00249 ErrorCode NCHelperGCRM::create_mesh( Range& faces )
00250 {
00251     bool& noEdges       = _readNC->noEdges;
00252     DebugOutput& dbgOut = _readNC->dbgOut;
00253
00254 #ifdef MOAB_HAVE_MPI
00255     int rank         = 0;
00256     int procs        = 1;
00257     bool& isParallel = _readNC->isParallel;
00258     ParallelComm* myPcomm = NULL;
00259     if( isParallel )
00260     {
00261         myPcomm = _readNC->myPcomm;
00262         rank                   = myPcomm->proc_config().proc_rank();
00263         procs                  = myPcomm->proc_config().proc_size();
00264     }
00265
00266     // Need to know whether we'll be creating gather mesh
00267     if( rank == _readNC->gatherSetRank ) createGatherSet = true;
00268
00269     if( procs >= 2 )
00270     {
00271         // Shift rank to obtain a rotated trivial partition
00272         int shifted_rank           = rank;
00273         int& trivialPartitionShift = _readNC->trivialPartitionShift;
00274         if( trivialPartitionShift > 0 ) shifted_rank = ( rank + trivialPartitionShift ) % procs;
00275
00276         // Compute the number of local cells on this proc
00277         nLocalCells = int( std::floor( 1.0 * nCells / procs ) );
00278
00279         // The starting global cell index in the GCRM file for this proc
00280         int start_cell_idx = shifted_rank * nLocalCells;
00281
00282         // Number of extra cells after equal split over procs
00283         int iextra = nCells % procs;
00284
00285         // Allocate extra cells over procs
00286         if( shifted_rank < iextra ) nLocalCells++;
00287         start_cell_idx += std::min( shifted_rank, iextra );
00288
00289         start_cell_idx++;  // 0 based -> 1 based
00290
00291         // Redistribute local cells after trivial partition (e.g. apply Zoltan partition)
00292         ErrorCode rval = redistribute_local_cells( start_cell_idx, myPcomm);MB_CHK_SET_ERR( rval, "Failed to redistribute local cells after trivial partition" );
00293     }
00294     else
00295     {
00296         nLocalCells = nCells;
00297         localGidCells.insert( 1, nLocalCells );
00298     }
00299 #else
00300     nLocalCells = nCells;
00301     localGidCells.insert( 1, nLocalCells );
00302 #endif
00303     dbgOut.tprintf( 1, " localGidCells.psize() = %d\n", (int)localGidCells.psize() );
00304     dbgOut.tprintf( 1, " localGidCells.size() = %d\n", (int)localGidCells.size() );
00305
00306     // Read vertices on each local cell, to get localGidVerts and cell connectivity later
00307     int verticesOnCellVarId;
00308     int success = NCFUNC( inq_varid )( _fileId, "cell_corners", &verticesOnCellVarId );
00309     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of cell_corners" );
00310     std::vector< int > vertices_on_local_cells( nLocalCells * EDGES_PER_CELL );
00311     dbgOut.tprintf( 1, " nLocalCells = %d\n", (int)nLocalCells );
00312     dbgOut.tprintf( 1, " vertices_on_local_cells.size() = %d\n", (int)vertices_on_local_cells.size() );
00313 #ifdef MOAB_HAVE_PNETCDF
00314     size_t nb_reads = localGidCells.psize();
00315     std::vector< int > requests( nb_reads );
00316     std::vector< int > statuss( nb_reads );
00317     size_t idxReq = 0;
00318 #endif
00319     size_t indexInArray = 0;
00320     for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
00321          ++pair_iter )
00322     {
00323         EntityHandle starth = pair_iter->first;
00324         EntityHandle endh   = pair_iter->second;
00325         dbgOut.tprintf( 1, " cell_corners starth = %d\n", (int)starth );
00326         dbgOut.tprintf( 1, " cell_corners   endh = %d\n", (int)endh );
00327         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
00328         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
00329                                      static_cast< NCDF_SIZE >( EDGES_PER_CELL ) };
00330
00331         // Do a partial read in each subrange
00332 #ifdef MOAB_HAVE_PNETCDF
00333         success = NCFUNCREQG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
00334                                            &( vertices_on_local_cells[indexInArray] ), &requests[idxReq++] );
00335 #else
00336         success = NCFUNCAG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
00337                                          &( vertices_on_local_cells[indexInArray] ) );
00338 #endif
00339         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_corners data in a loop" );
00340
00341         // Increment the index for next subrange
00342         indexInArray += ( endh - starth + 1 ) * EDGES_PER_CELL;
00343     }
00344
00345 #ifdef MOAB_HAVE_PNETCDF
00346     // Wait outside the loop
00347     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00348     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00349 #endif
00350
00351     // Correct vertices_on_local_cells array. Pentagons as hexagons should have
00352     // a connectivity like 123455 and not 122345
00353     for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
00354     {
00355         int* pvertex = &vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL];
00356         for( int k = 0; k < EDGES_PER_CELL - 2; k++ )
00357         {
00358             if( *( pvertex + k ) == *( pvertex + k + 1 ) )
00359             {
00360                 // Shift the connectivity
00361                 for( int kk = k + 1; kk < EDGES_PER_CELL - 1; kk++ )
00362                     *( pvertex + kk ) = *( pvertex + kk + 1 );
00363                 // No need to try next k
00364                 break;
00365             }
00366         }
00367     }
00368
00369     // GCRM is 0 based, convert vertex indices from 0 to 1 based
00370     for( std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++ )
00371         vertices_on_local_cells[idx] += 1;
00372
00373     // Create local vertices
00374     EntityHandle start_vertex;
00375     ErrorCode rval = create_local_vertices( vertices_on_local_cells, start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local vertices for GCRM mesh" );
00376
00377     // Create local edges (unless NO_EDGES read option is set)
00378     if( !noEdges )
00379     {
00380         rval = create_local_edges( start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local edges for GCRM mesh" );
00381     }
00382
00383     // Create local cells, padded
00384     rval = create_padded_local_cells( vertices_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create padded local cells for GCRM mesh" );
00385
00386     if( createGatherSet )
00387     {
00388         EntityHandle gather_set;
00389         rval = _readNC->readMeshIface->create_gather_set( gather_set );MB_CHK_SET_ERR( rval, "Failed to create gather set" );
00390
00391         // Create gather set vertices
00392         EntityHandle start_gather_set_vertex;
00393         rval = create_gather_set_vertices( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices for GCRM mesh" );
00394
00395         // Create gather set edges (unless NO_EDGES read option is set)
00396         if( !noEdges )
00397         {
00398             rval = create_gather_set_edges( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set edges for GCRM mesh" );
00399         }
00400
00401         // Create gather set cells with padding
00402         rval = create_padded_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create padded gather set cells for GCRM mesh" );
00403     }
00404
00405     return MB_SUCCESS;
00406 }
00407
00408 ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate( std::vector< ReadNC::VarData >& vdatas,
00409        std::vector< int >& tstep_nums )
00410 {
00411     Interface*& mbImpl          = _readNC->mbImpl;
00412     std::vector< int >& dimLens = _readNC->dimLens;
00413     bool& noEdges               = _readNC->noEdges;
00414     DebugOutput& dbgOut         = _readNC->dbgOut;
00415
00416     Range* range = NULL;
00417
00418     // Get vertices
00419     Range verts;
00420     ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
00421     assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
00422
00423     // Get edges
00424     Range edges;
00425     rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" );
00426
00427     // Get faces
00428     Range faces;
00429     rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" );
00430     assert( "Should only have a single face subrange, since they were read in one shot" && faces.psize() == 1 );
00431
00432 #ifdef MOAB_HAVE_MPI
00433     bool& isParallel = _readNC->isParallel;
00434     if( isParallel )
00435     {
00436         ParallelComm*& myPcomm = _readNC->myPcomm;
00437         rval                   = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &facesOwned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" );
00438     }
00439     else
00440         facesOwned = faces;  // not running in parallel, but still with MPI
00441 #else
00442     facesOwned = faces;
00443 #endif
00444
00445     for( unsigned int i = 0; i < vdatas.size(); i++ )
00446     {
00447         // Skip edge variables, if specified by the read options
00448         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00449
00450         // Support non-set variables with 3 dimensions like (time, cells, layers), or
00451         // 2 dimensions like (time, cells)
00452         assert( 3 == vdatas[i].varDims.size() || 2 == vdatas[i].varDims.size() );
00453
00454         // For a non-set variable, time should be the first dimension
00455         assert( tDim == vdatas[i].varDims[0] );
00456
00457         // Set up readStarts and readCounts
00458         vdatas[i].readStarts.resize( 3 );
00459         vdatas[i].readCounts.resize( 3 );
00460
00461         // First: Time
00462         vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
00463         vdatas[i].readCounts[0] = 1;
00464
00465         // Next: nVertices / nCells / nEdges
00466         switch( vdatas[i].entLoc )
00467         {
00468             case ReadNC::ENTLOCVERT:
00469                 // Vertices
00470                 // Start from the first localGidVerts
00471                 // Actually, this will be reset later on in a loop
00472                 vdatas[i].readStarts[1] = localGidVerts[0] - 1;
00473                 vdatas[i].readCounts[1] = nLocalVertices;
00474                 range                   = &verts;
00475                 break;
00476             case ReadNC::ENTLOCFACE:
00477                 // Faces
00478                 // Start from the first localGidCells
00479                 // Actually, this will be reset later on in a loop
00480                 vdatas[i].readStarts[1] = localGidCells[0] - 1;
00481                 vdatas[i].readCounts[1] = nLocalCells;
00482                 range                   = &facesOwned;
00483                 break;
00484             case ReadNC::ENTLOCEDGE:
00485                 // Edges
00486                 // Start from the first localGidEdges
00487                 // Actually, this will be reset later on in a loop
00488                 vdatas[i].readStarts[1] = localGidEdges[0] - 1;
00489                 vdatas[i].readCounts[1] = nLocalEdges;
00490                 range                   = &edges;
00491                 break;
00492             default:
00493                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00494         }
00495
00496         // Finally: layers or other optional levels, it is possible that there is no
00497         // level dimension (numLev is 0) for this non-set variable
00498         if( vdatas[i].numLev < 1 ) vdatas[i].numLev = 1;
00499         vdatas[i].readStarts[2] = 0;
00500         vdatas[i].readCounts[2] = vdatas[i].numLev;
00501
00502         // Get variable size
00503         vdatas[i].sz = 1;
00504         for( std::size_t idx = 0; idx != 3; idx++ )
00505             vdatas[i].sz *= vdatas[i].readCounts[idx];
00506
00507         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00508         {
00509             dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
00510
00511             if( tstep_nums[t] >= dimLens[tDim] )
00512             {
00513                 MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
00514             }
00515
00516             // Get the tag to read into
00517             if( !vdatas[i].varTags[t] )
00518             {
00519                 rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag for variable " << vdatas[i].varName );
00520             }
00521
00522             // Get ptr to tag space
00523             assert( 1 == range->psize() );
00524             void* data;
00525             int count;
00526             rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for variable " << vdatas[i].varName );
00527             assert( (unsigned)count == range->size() );
00528             vdatas[i].varDatas[t] = data;
00529         }
00530     }
00531
00532     return rval;
00533 }
00534
00535 #ifdef MOAB_HAVE_PNETCDF
00536 ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async( std::vector< ReadNC::VarData >& vdatas,
00537                                                             std::vector< int >& tstep_nums )
00538 {
00539     bool& noEdges       = _readNC->noEdges;
00540     DebugOutput& dbgOut = _readNC->dbgOut;
00541
00542     ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
00543
00544     // Finally, read into that space
00545     int success;
00546     Range* pLocalGid = NULL;
00547
00548     for( unsigned int i = 0; i < vdatas.size(); i++ )
00549     {
00550         // Skip edge variables, if specified by the read options
00551         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00552
00553         switch( vdatas[i].entLoc )
00554         {
00555             case ReadNC::ENTLOCVERT:
00556                 pLocalGid = &localGidVerts;
00557                 break;
00558             case ReadNC::ENTLOCFACE:
00559                 pLocalGid = &localGidCells;
00560                 break;
00561             case ReadNC::ENTLOCEDGE:
00562                 pLocalGid = &localGidEdges;
00563                 break;
00564             default:
00565                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00566         }
00567
00568         std::size_t sz = vdatas[i].sz;
00569
00570         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00571         {
00572             // We will synchronize all these reads with the other processors,
00573             // so the wait will be inside this double loop; is it too much?
00574             size_t nb_reads = pLocalGid->psize();
00575             std::vector< int > requests( nb_reads ), statuss( nb_reads );
00576             size_t idxReq = 0;
00577
00578             // Set readStart for each timestep along time dimension
00579             vdatas[i].readStarts[0] = tstep_nums[t];
00580
00581             switch( vdatas[i].varDataType )
00582             {
00583                 case NC_FLOAT:
00584                 case NC_DOUBLE: {
00585                     // Read float as double
00586                     std::vector< double > tmpdoubledata( sz );
00587
00588                     // In the case of ucd mesh, and on multiple proc,
00589                     // we need to read as many times as subranges we have in the
00590                     // localGid range;
00591                     // basically, we have to give a different point
00592                     // for data to start, for every subrange :(
00593                     size_t indexInDoubleArray = 0;
00594                     size_t ic                 = 0;
00595                     for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
00596                          ++pair_iter, ic++ )
00597                     {
00598                         EntityHandle starth     = pair_iter->first;
00599                         EntityHandle endh       = pair_iter->second;  // inclusive
00600                         vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
00601                         vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
00602
00603                         // Do a partial read, in each subrange
00604                         // wait outside this loop
00605                         success =
00606                             NCFUNCREQG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
00607                                                         &( vdatas[i].readCounts[0] ),
00608                                                         &( tmpdoubledata[indexInDoubleArray] ), &requests[idxReq++] );
00609                         if( success )
00610                             MB_SET_ERR( MB_FAILURE,
00611                                         "Failed to read double data in a loop for variable " << vdatas[i].varName );
00612                         // We need to increment the index in double array for the
00613                         // next subrange
00614                         indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
00615                     }
00616                     assert( ic == pLocalGid->psize() );
00617
00618                     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00619                     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00620
00621                     void* data = vdatas[i].varDatas[t];
00622                     for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
00623                         ( (double*)data )[idx] = tmpdoubledata[idx];
00624
00625                     break;
00626                 }
00627                 default:
00628                     MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
00629             }
00630         }
00631     }
00632
00633     // Debug output, if requested
00634     if( 1 == dbgOut.get_verbosity() )
00635     {
00636         dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
00637         for( unsigned int i = 1; i < vdatas.size(); i++ )
00638             dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
00639         dbgOut.tprintf( 1, "\n" );
00640     }
00641
00642     return rval;
00643 }
00644 #else
00645 ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset( std::vector< ReadNC::VarData >& vdatas,
00646                                                       std::vector< int >& tstep_nums )
00647 {
00648     bool& noEdges = _readNC->noEdges;
00649     DebugOutput& dbgOut = _readNC->dbgOut;
00650
00651     ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
00652
00653     // Finally, read into that space
00654     int success;
00655     Range* pLocalGid = NULL;
00656
00657     for( unsigned int i = 0; i < vdatas.size(); i++ )
00658     {
00659         // Skip edge variables, if specified by the read options
00660         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00661
00662         switch( vdatas[i].entLoc )
00663         {
00664             case ReadNC::ENTLOCVERT:
00665                 pLocalGid = &localGidVerts;
00666                 break;
00667             case ReadNC::ENTLOCFACE:
00668                 pLocalGid = &localGidCells;
00669                 break;
00670             case ReadNC::ENTLOCEDGE:
00671                 pLocalGid = &localGidEdges;
00672                 break;
00673             default:
00674                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00675         }
00676
00677         std::size_t sz = vdatas[i].sz;
00678
00679         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00680         {
00681             // Set readStart for each timestep along time dimension
00682             vdatas[i].readStarts[0] = tstep_nums[t];
00683
00684             switch( vdatas[i].varDataType )
00685             {
00686                 case NC_FLOAT:
00687                 case NC_DOUBLE: {
00688                     // Read float as double
00689                     std::vector< double > tmpdoubledata( sz );
00690
00691                     // In the case of ucd mesh, and on multiple proc,
00692                     // we need to read as many times as subranges we have in the
00693                     // localGid range;
00694                     // basically, we have to give a different point
00695                     // for data to start, for every subrange :(
00696                     size_t indexInDoubleArray = 0;
00697                     size_t ic = 0;
00698                     for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
00699                          ++pair_iter, ic++ )
00700                     {
00701                         EntityHandle starth = pair_iter->first;
00702                         EntityHandle endh = pair_iter->second;  // Inclusive
00703                         vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
00704                         vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
00705
00706                         success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
00707                                                             &( vdatas[i].readCounts[0] ),
00708                                                             &( tmpdoubledata[indexInDoubleArray] ) );
00709                         if( success )
00710                             MB_SET_ERR( MB_FAILURE,
00711                                         "Failed to read double data in a loop for variable " << vdatas[i].varName );
00712                         // We need to increment the index in double array for the
00713                         // next subrange
00714                         indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
00715                     }
00716                     assert( ic == pLocalGid->psize() );
00717
00718                     void* data = vdatas[i].varDatas[t];
00719                     for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
00720                         ( (double*)data )[idx] = tmpdoubledata[idx];
00721
00722                     break;
00723                 }
00724                 default:
00725                     MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
00726             }
00727         }
00728     }
00729
00730     // Debug output, if requested
00731     if( 1 == dbgOut.get_verbosity() )
00732     {
00733         dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
00734         for( unsigned int i = 1; i < vdatas.size(); i++ )
00735             dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
00736         dbgOut.tprintf( 1, "\n" );
00737     }
00738
00739     return rval;
00740 }
00741 #endif
00742
00743 #ifdef MOAB_HAVE_MPI
00744 ErrorCode NCHelperGCRM::redistribute_local_cells( int start_cell_idx, ParallelComm * pco )
00745 {
00746     // If possible, apply Zoltan partition
00747 #ifdef MOAB_HAVE_ZOLTAN
00748     if( _readNC->partMethod == ScdParData::RCBZOLTAN )
00749     {
00750         // Read lat/lon coordinates of cell centers, then convert spherical to
00751         // Cartesian, and use them as input to Zoltan partition
00752         int xCellVarId;
00753         int success = NCFUNC( inq_varid )( _fileId, "grid_center_lat", &xCellVarId );
00754         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_center_lat" );
00755         std::vector< double > xCell( nLocalCells );
00756         NCDF_SIZE read_start = static_cast< NCDF_SIZE >( start_cell_idx - 1 );
00757         NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nLocalCells );
00758         success              = NCFUNCAG( _vara_double )( _fileId, xCellVarId, &read_start, &read_count, &xCell[0] );
00759         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_center_lat data" );
00760
00761         // Read y coordinates of cell centers
00762         int yCellVarId;
00763         success = NCFUNC( inq_varid )( _fileId, "grid_center_lon", &yCellVarId );
00764         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_center_lon" );
00765         std::vector< double > yCell( nLocalCells );
00766         success = NCFUNCAG( _vara_double )( _fileId, yCellVarId, &read_start, &read_count, &yCell[0] );
00767         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_center_lon data" );
00768
00769         // Convert lon/lat/rad to x/y/z
00770         std::vector< double > zCell( nLocalCells );
00771         double rad = 8000.0;  // This is just a approximate radius
00772         for( int i = 0; i < nLocalCells; i++ )
00773         {
00774             double cosphi = cos( xCell[i] );
00775             double zmult  = sin( xCell[i] );
00776             double xmult  = cosphi * cos( yCell[i] );
00777             double ymult  = cosphi * sin( yCell[i] );
00778             xCell[i]      = rad * xmult;
00779             yCell[i]      = rad * ymult;
00780             zCell[i]      = rad * zmult;
00781         }
00782
00783         // Zoltan partition using RCB; maybe more studies would be good, as to which partition
00784         // is better
00785         Interface*& mbImpl         = _readNC->mbImpl;
00786         DebugOutput& dbgOut        = _readNC->dbgOut;
00787         ZoltanPartitioner* mbZTool = new ZoltanPartitioner( mbImpl, pco, false, 0, NULL );
00788         ErrorCode rval             = mbZTool->repartition( xCell, yCell, zCell, start_cell_idx, "RCB", localGidCells );MB_CHK_SET_ERR( rval, "Error in Zoltan partitioning" );
00789         delete mbZTool;
00790
00791         dbgOut.tprintf( 1, "After Zoltan partitioning, localGidCells.psize() = %d\n", (int)localGidCells.psize() );
00792         dbgOut.tprintf( 1, "                           localGidCells.size() = %d\n", (int)localGidCells.size() );
00793
00794         // This is important: local cells are now redistributed, so nLocalCells might be different!
00795         nLocalCells = localGidCells.size();
00796
00797         return MB_SUCCESS;
00798     }
00799 #endif
00800
00801     // By default, apply trivial partition
00802     localGidCells.insert( start_cell_idx, start_cell_idx + nLocalCells - 1 );
00803
00804     return MB_SUCCESS;
00805 }
00806 #endif
00807
00808 ErrorCode NCHelperGCRM::create_local_vertices( const std::vector< int >& vertices_on_local_cells,
00809                                                EntityHandle& start_vertex )
00810 {
00811     Interface*& mbImpl                                = _readNC->mbImpl;
00812     Tag& mGlobalIdTag                                 = _readNC->mGlobalIdTag;
00813     const Tag*& mpFileIdTag                           = _readNC->mpFileIdTag;
00814     DebugOutput& dbgOut                               = _readNC->dbgOut;
00815     std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
00816
00817     // Make a copy of vertices_on_local_cells for sorting (keep original one to set cell
00818     // connectivity later)
00819     std::vector< int > vertices_on_local_cells_sorted( vertices_on_local_cells );
00820     std::sort( vertices_on_local_cells_sorted.begin(), vertices_on_local_cells_sorted.end() );
00821     std::copy( vertices_on_local_cells_sorted.rbegin(), vertices_on_local_cells_sorted.rend(),
00822                range_inserter( localGidVerts ) );
00823     nLocalVertices = localGidVerts.size();
00824
00825     dbgOut.tprintf( 1, "   localGidVerts.psize() = %d\n", (int)localGidVerts.psize() );
00826     dbgOut.tprintf( 1, "   localGidVerts.size() = %d\n", (int)localGidVerts.size() );
00827
00828     // Create local vertices
00829     std::vector< double* > arrays;
00830     ErrorCode rval =
00831         _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays,
00832                                                  // Might have to create gather mesh later
00833                                                  ( createGatherSet ? nLocalVertices + nVertices : nLocalVertices ) );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
00834
00835     // Add local vertices to current file set
00836     Range local_verts_range( start_vertex, start_vertex + nLocalVertices - 1 );
00837     rval = _readNC->mbImpl->add_entities( _fileSet, local_verts_range );MB_CHK_SET_ERR( rval, "Failed to add local vertices to current file set" );
00838
00839     // Get ptr to GID memory for local vertices
00840     int count  = 0;
00841     void* data = NULL;
00842     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local vertices" );
00843     assert( count == nLocalVertices );
00844     int* gid_data = (int*)data;
00845     std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
00846
00847     // Duplicate GID data, which will be used to resolve sharing
00848     if( mpFileIdTag )
00849     {
00850         rval = mbImpl->tag_iterate( *mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on local vertices" );
00851         assert( count == nLocalVertices );
00852         int bytes_per_tag = 4;
00853         rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "can't get number of bytes for file id tag" );
00854         if( 4 == bytes_per_tag )
00855         {
00856             gid_data = (int*)data;
00857             std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
00858         }
00859         else if( 8 == bytes_per_tag )
00860         {  // Should be a handle tag on 64 bit machine?
00861             long* handle_tag_data = (long*)data;
00862             std::copy( localGidVerts.begin(), localGidVerts.end(), handle_tag_data );
00863         }
00864     }
00865
00866 #ifdef MOAB_HAVE_PNETCDF
00867     size_t nb_reads = localGidVerts.psize();
00868     std::vector< int > requests( nb_reads );
00869     std::vector< int > statuss( nb_reads );
00870     size_t idxReq = 0;
00871 #endif
00872
00873     // Store lev values in levVals
00874     std::map< std::string, ReadNC::VarData >::iterator vmit;
00875     if( ( vmit = varInfo.find( "layers" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
00876     {
00877         rval = read_coordinate( "layers", 0, nLevels - 1, levVals );MB_CHK_SET_ERR( rval, "Trouble reading 'layers' variable" );
00878     }
00879     else if( ( vmit = varInfo.find( "interfaces" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
00880     {
00881         rval = read_coordinate( "interfaces", 0, nLevels - 1, levVals );MB_CHK_SET_ERR( rval, "Trouble reading 'interfaces' variable" );
00882     }
00883     else
00884     {
00885         MB_SET_ERR( MB_FAILURE, "Couldn't find 'layers' or 'interfaces' variable" );
00886     }
00887
00888     // Decide whether down is positive
00889     char posval[10] = { 0 };
00890     int success     = NCFUNC( get_att_text )( _fileId, ( *vmit ).second.varId, "positive", posval );
00891     if( 0 == success && !strncmp( posval, "down", 4 ) )
00892     {
00893         for( std::vector< double >::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit )
00894             ( *dvit ) *= -1.0;
00895     }
00896
00897     // Read x coordinates for local vertices
00898     double* xptr = arrays[0];
00899     int xVertexVarId;
00900     success = NCFUNC( inq_varid )( _fileId, "grid_corner_lon", &xVertexVarId );
00901     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lon" );
00902     size_t indexInArray = 0;
00903     for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
00904          ++pair_iter )
00905     {
00906         EntityHandle starth  = pair_iter->first;
00907         EntityHandle endh    = pair_iter->second;
00908         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
00909         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
00910
00911         // Do a partial read in each subrange
00912 #ifdef MOAB_HAVE_PNETCDF
00913         success = NCFUNCREQG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ),
00914                                               &requests[idxReq++] );
00915 #else
00916         success = NCFUNCAG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ) );
00917 #endif
00918         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lon data in a loop" );
00919
00920         // Increment the index for next subrange
00921         indexInArray += ( endh - starth + 1 );
00922     }
00923
00924 #ifdef MOAB_HAVE_PNETCDF
00925     // Wait outside the loop
00926     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00927     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00928 #endif
00929
00930     // Read y coordinates for local vertices
00931     double* yptr = arrays[1];
00932     int yVertexVarId;
00933     success = NCFUNC( inq_varid )( _fileId, "grid_corner_lat", &yVertexVarId );
00934     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lat" );
00935 #ifdef MOAB_HAVE_PNETCDF
00936     idxReq = 0;
00937 #endif
00938     indexInArray = 0;
00939     for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
00940          ++pair_iter )
00941     {
00942         EntityHandle starth  = pair_iter->first;
00943         EntityHandle endh    = pair_iter->second;
00944         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
00945         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
00946
00947         // Do a partial read in each subrange
00948 #ifdef MOAB_HAVE_PNETCDF
00949         success = NCFUNCREQG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ),
00950                                               &requests[idxReq++] );
00951 #else
00952         success = NCFUNCAG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ) );
00953 #endif
00954         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lat data in a loop" );
00955
00956         // Increment the index for next subrange
00957         indexInArray += ( endh - starth + 1 );
00958     }
00959
00960 #ifdef MOAB_HAVE_PNETCDF
00961     // Wait outside the loop
00962     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00963     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00964 #endif
00965
00966     // Convert lon/lat/rad to x/y/z
00967     double* zptr = arrays[2];
00968     double rad   = 8000.0 + levVals[0];
00969     for( int i = 0; i < nLocalVertices; i++ )
00970     {
00971         double cosphi = cos( yptr[i] );
00972         double zmult  = sin( yptr[i] );
00973         double xmult  = cosphi * cos( xptr[i] );
00974         double ymult  = cosphi * sin( xptr[i] );
00975         xptr[i]       = rad * xmult;
00976         yptr[i]       = rad * ymult;
00977         zptr[i]       = rad * zmult;
00978     }
00979
00980     return MB_SUCCESS;
00981 }
00982
00983 ErrorCode NCHelperGCRM::create_local_edges( EntityHandle start_vertex )
00984 {
00985     Interface*& mbImpl  = _readNC->mbImpl;
00986     Tag& mGlobalIdTag   = _readNC->mGlobalIdTag;
00987     DebugOutput& dbgOut = _readNC->dbgOut;
00988
00989     // Read edges on each local cell, to get localGidEdges
00990     int edgesOnCellVarId;
00991     int success = NCFUNC( inq_varid )( _fileId, "cell_edges", &edgesOnCellVarId );
00992     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of cell_edges" );
00993
00994     std::vector< int > edges_on_local_cells( nLocalCells * EDGES_PER_CELL );
00995     dbgOut.tprintf( 1, "   edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size() );
00996
00997 #ifdef MOAB_HAVE_PNETCDF
00998     size_t nb_reads = localGidCells.psize();
00999     std::vector< int > requests( nb_reads );
01000     std::vector< int > statuss( nb_reads );
01001     size_t idxReq = 0;
01002 #endif
01003     size_t indexInArray = 0;
01004     for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
01005          ++pair_iter )
01006     {
01007         EntityHandle starth = pair_iter->first;
01008         EntityHandle endh   = pair_iter->second;
01009         dbgOut.tprintf( 1, "   starth = %d\n", (int)starth );
01010         dbgOut.tprintf( 1, "   endh = %d\n", (int)endh );
01011         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
01012         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
01013                                      static_cast< NCDF_SIZE >( EDGES_PER_CELL ) };
01014
01015         // Do a partial read in each subrange
01016 #ifdef MOAB_HAVE_PNETCDF
01017         success = NCFUNCREQG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
01018                                            &( edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
01019 #else
01020         success = NCFUNCAG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
01021                                          &( edges_on_local_cells[indexInArray] ) );
01022 #endif
01023         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_edges data in a loop" );
01024
01025         // Increment the index for next subrange
01026         indexInArray += ( endh - starth + 1 ) * EDGES_PER_CELL;
01027     }
01028
01029 #ifdef MOAB_HAVE_PNETCDF
01030     // Wait outside the loop
01031     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01032     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01033 #endif
01034
01035     // GCRM is 0 based, convert edge indices from 0 to 1 based
01036     for( std::size_t idx = 0; idx < edges_on_local_cells.size(); idx++ )
01037         edges_on_local_cells[idx] += 1;
01038
01039     // Collect local edges
01040     std::sort( edges_on_local_cells.begin(), edges_on_local_cells.end() );
01041     std::copy( edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter( localGidEdges ) );
01042     nLocalEdges = localGidEdges.size();
01043
01044     dbgOut.tprintf( 1, "   localGidEdges.psize() = %d\n", (int)localGidEdges.psize() );
01045     dbgOut.tprintf( 1, "   localGidEdges.size() = %d\n", (int)localGidEdges.size() );
01046
01047     // Create local edges
01048     EntityHandle start_edge;
01049     EntityHandle* conn_arr_edges = NULL;
01050     ErrorCode rval =
01051         _readNC->readMeshIface->get_element_connect( nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
01052                                                      // Might have to create gather mesh later
01053                                                      ( createGatherSet ? nLocalEdges + nEdges : nLocalEdges ) );MB_CHK_SET_ERR( rval, "Failed to create local edges" );
01054
01055     // Add local edges to current file set
01056     Range local_edges_range( start_edge, start_edge + nLocalEdges - 1 );
01057     rval = _readNC->mbImpl->add_entities( _fileSet, local_edges_range );MB_CHK_SET_ERR( rval, "Failed to add local edges to current file set" );
01058
01059     // Get ptr to GID memory for edges
01060     int count  = 0;
01061     void* data = NULL;
01062     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local edges" );
01063     assert( count == nLocalEdges );
01064     int* gid_data = (int*)data;
01065     std::copy( localGidEdges.begin(), localGidEdges.end(), gid_data );
01066
01067     int verticesOnEdgeVarId;
01068
01069     // Read vertices on each local edge, to get edge connectivity
01070     success = NCFUNC( inq_varid )( _fileId, "edge_corners", &verticesOnEdgeVarId );
01071     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of edge_corners" );
01072     // Utilize the memory storage pointed by conn_arr_edges
01073     int* vertices_on_local_edges = (int*)conn_arr_edges;
01074 #ifdef MOAB_HAVE_PNETCDF
01075     nb_reads = localGidEdges.psize();
01076     requests.resize( nb_reads );
01077     statuss.resize( nb_reads );
01078     idxReq = 0;
01079 #endif
01080     indexInArray = 0;
01081     for( Range::pair_iterator pair_iter = localGidEdges.pair_begin(); pair_iter != localGidEdges.pair_end();
01082          ++pair_iter )
01083     {
01084         EntityHandle starth      = pair_iter->first;
01085         EntityHandle endh        = pair_iter->second;
01086         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
01087         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ), 2 };
01088
01089         // Do a partial read in each subrange
01090 #ifdef MOAB_HAVE_PNETCDF
01091         success = NCFUNCREQG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
01092                                            &( vertices_on_local_edges[indexInArray] ), &requests[idxReq++] );
01093 #else
01094         success = NCFUNCAG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
01095                                          &( vertices_on_local_edges[indexInArray] ) );
01096 #endif
01097         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edge_corners data in a loop" );
01098
01099         // Increment the index for next subrange
01100         indexInArray += ( endh - starth + 1 ) * 2;
01101     }
01102
01103 #ifdef MOAB_HAVE_PNETCDF
01104     // Wait outside the loop
01105     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01106     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01107 #endif
01108
01109     // Populate connectivity data for local edges
01110     // Convert in-place from int (stored in the first half) to EntityHandle
01111     // Reading backward is the trick
01112     for( int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
01113     {
01114         // Note, indices stored in vertices_on_local_edges are 0 based
01115         int global_vert_idx = vertices_on_local_edges[edge_vert] + 1;  // Global vertex index, 1 based
01116         int local_vert_idx  = localGidVerts.index( global_vert_idx );  // Local vertex index, 0 based
01117         assert( local_vert_idx != -1 );
01118         conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
01119     }
01120
01121     return MB_SUCCESS;
01122 }
01123
01124 ErrorCode NCHelperGCRM::create_padded_local_cells( const std::vector< int >& vertices_on_local_cells,
01125                                                    EntityHandle start_vertex,
01126                                                    Range& faces )
01127 {
01128     Interface*& mbImpl = _readNC->mbImpl;
01129     Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
01130
01131     // Create cells
01132     EntityHandle start_element;
01133     EntityHandle* conn_arr_local_cells = NULL;
01134     ErrorCode rval =
01135         _readNC->readMeshIface->get_element_connect( nLocalCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element,
01136                                                      conn_arr_local_cells,
01137                                                      // Might have to create gather mesh later
01138                                                      ( createGatherSet ? nLocalCells + nCells : nLocalCells ) );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
01139     faces.insert( start_element, start_element + nLocalCells - 1 );
01140
01141     // Add local cells to current file set
01142     Range local_cells_range( start_element, start_element + nLocalCells - 1 );
01143     rval = _readNC->mbImpl->add_entities( _fileSet, local_cells_range );MB_CHK_SET_ERR( rval, "Failed to add local cells to current file set" );
01144
01145     // Get ptr to GID memory for local cells
01146     int count  = 0;
01147     void* data = NULL;
01148     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local cells" );
01149     assert( count == nLocalCells );
01150     int* gid_data = (int*)data;
01151     std::copy( localGidCells.begin(), localGidCells.end(), gid_data );
01152
01153     // Set connectivity array with proper local vertices handles
01154     // vertices_on_local_cells array was already corrected to have
01155     // the last vertices repeated for pentagons, e.g. 122345 => 123455
01156     for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
01157     {
01158         for( int i = 0; i < EDGES_PER_CELL; i++ )
01159         {
01160             // Note, indices stored in vertices_on_local_cells are 1 based
01161             EntityHandle global_vert_idx =
01162                 vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL + i];  // Global vertex index, 1 based
01163             int local_vert_idx = localGidVerts.index( global_vert_idx );       // Local vertex index, 0 based
01164             assert( local_vert_idx != -1 );
01165             conn_arr_local_cells[local_cell_idx * EDGES_PER_CELL + i] = start_vertex + local_vert_idx;
01166         }
01167     }
01168
01169     return MB_SUCCESS;
01170 }
01171
01172 ErrorCode NCHelperGCRM::create_gather_set_vertices( EntityHandle gather_set, EntityHandle& gather_set_start_vertex )
01173 {
01174     Interface*& mbImpl      = _readNC->mbImpl;
01175     Tag& mGlobalIdTag       = _readNC->mGlobalIdTag;
01176     const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
01177
01178     // Create gather set vertices
01179     std::vector< double* > arrays;
01180     // Don't need to specify allocation number here, because we know enough vertices were created
01181     // before
01182     ErrorCode rval = _readNC->readMeshIface->get_node_coords( 3, nVertices, 0, gather_set_start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices" );
01183
01184     // Add vertices to the gather set
01185     Range gather_set_verts_range( gather_set_start_vertex, gather_set_start_vertex + nVertices - 1 );
01186     rval = mbImpl->add_entities( gather_set, gather_set_verts_range );MB_CHK_SET_ERR( rval, "Failed to add vertices to the gather set" );
01187
01188     // Read x coordinates for gather set vertices
01189     double* xptr = arrays[0];
01190     int xVertexVarId;
01191     int success = NCFUNC( inq_varid )( _fileId, "grid_corner_lon", &xVertexVarId );
01192     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lon" );
01193     NCDF_SIZE read_start = 0;
01194     NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nVertices );
01195 #ifdef MOAB_HAVE_PNETCDF
01196     // Enter independent I/O mode, since this read is only for the gather processor
01197     success = NCFUNC( begin_indep_data )( _fileId );
01198     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01199     success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
01200     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lon data" );
01201     success = NCFUNC( end_indep_data )( _fileId );
01202     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01203 #else
01204     success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
01205     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lon data" );
01206 #endif
01207
01208     // Read y coordinates for gather set vertices
01209     double* yptr = arrays[1];
01210     int yVertexVarId;
01211     success = NCFUNC( inq_varid )( _fileId, "grid_corner_lat", &yVertexVarId );
01212     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of grid_corner_lat" );
01213 #ifdef MOAB_HAVE_PNETCDF
01214     // Enter independent I/O mode, since this read is only for the gather processor
01215     success = NCFUNC( begin_indep_data )( _fileId );
01216     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01217     success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
01218     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lat data" );
01219     success = NCFUNC( end_indep_data )( _fileId );
01220     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01221 #else
01222     success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
01223     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read grid_corner_lat data" );
01224 #endif
01225
01226     // Convert lon/lat/rad to x/y/z
01227     double* zptr = arrays[2];
01228     double rad   = 8000.0 + levVals[0];
01229     for( int i = 0; i < nVertices; i++ )
01230     {
01231         double cosphi = cos( yptr[i] );
01232         double zmult  = sin( yptr[i] );
01233         double xmult  = cosphi * cos( xptr[i] );
01234         double ymult  = cosphi * sin( xptr[i] );
01235         xptr[i]       = rad * xmult;
01236         yptr[i]       = rad * ymult;
01237         zptr[i]       = rad * zmult;
01238     }
01239
01240     // Get ptr to GID memory for gather set vertices
01241     int count  = 0;
01242     void* data = NULL;
01243     rval =
01244         mbImpl->tag_iterate( mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on gather set vertices" );
01245     assert( count == nVertices );
01246     int* gid_data = (int*)data;
01247     for( int j = 1; j <= nVertices; j++ )
01248         gid_data[j - 1] = j;
01249
01250     // Set the file id tag too, it should be bigger something not interfering with global id
01251     if( mpFileIdTag )
01252     {
01253         rval = mbImpl->tag_iterate( *mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count,
01254                                     data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on gather set vertices" );
01255         assert( count == nVertices );
01256         int bytes_per_tag = 4;
01257         rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
01258         if( 4 == bytes_per_tag )
01259         {
01260             gid_data = (int*)data;
01261             for( int j = 1; j <= nVertices; j++ )
01262                 gid_data[j - 1] = nVertices + j;  // Bigger than global id tag
01263         }
01264         else if( 8 == bytes_per_tag )
01265         {  // Should be a handle tag on 64 bit machine?
01266             long* handle_tag_data = (long*)data;
01267             for( int j = 1; j <= nVertices; j++ )
01268                 handle_tag_data[j - 1] = nVertices + j;  // Bigger than global id tag
01269         }
01270     }
01271
01272     return MB_SUCCESS;
01273 }
01274
01275 ErrorCode NCHelperGCRM::create_gather_set_edges( EntityHandle gather_set, EntityHandle gather_set_start_vertex )
01276 {
01277     Interface*& mbImpl = _readNC->mbImpl;
01278
01279     // Create gather set edges
01280     EntityHandle start_edge;
01281     EntityHandle* conn_arr_gather_set_edges = NULL;
01282     // Don't need to specify allocation number here, because we know enough edges were created
01283     // before
01284     ErrorCode rval =
01285         _readNC->readMeshIface->get_element_connect( nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges );MB_CHK_SET_ERR( rval, "Failed to create gather set edges" );
01286
01287     // Add edges to the gather set
01288     Range gather_set_edges_range( start_edge, start_edge + nEdges - 1 );
01289     rval = mbImpl->add_entities( gather_set, gather_set_edges_range );MB_CHK_SET_ERR( rval, "Failed to add edges to the gather set" );
01290
01291     // Read vertices on each edge
01292     int verticesOnEdgeVarId;
01293     int success = NCFUNC( inq_varid )( _fileId, "edge_corners", &verticesOnEdgeVarId );
01294     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of edge_corners" );
01295     // Utilize the memory storage pointed by conn_arr_gather_set_edges
01296     int* vertices_on_gather_set_edges = (int*)conn_arr_gather_set_edges;
01297     NCDF_SIZE read_starts[2]          = { 0, 0 };
01298     NCDF_SIZE read_counts[2]          = { static_cast< NCDF_SIZE >( nEdges ), 2 };
01299 #ifdef MOAB_HAVE_PNETCDF
01300     // Enter independent I/O mode, since this read is only for the gather processor
01301     success = NCFUNC( begin_indep_data )( _fileId );
01302     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01303     success =
01304         NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
01305     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edge_corners data" );
01306     success = NCFUNC( end_indep_data )( _fileId );
01307     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01308 #else
01309     success =
01310         NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
01311     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edge_corners data" );
01312 #endif
01313
01314     // Populate connectivity data for gather set edges
01315     // Convert in-place from int (stored in the first half) to EntityHandle
01316     // Reading backward is the trick
01317     for( int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
01318     {
01319         // Note, indices stored in vertices_on_gather_set_edges are 0 based
01320         int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert];  // Global vertex index, 0 based
01321         // Connectivity array is shifted by where the gather set vertices start
01322         conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
01323     }
01324
01325     return MB_SUCCESS;
01326 }
01327
01328 ErrorCode NCHelperGCRM::create_padded_gather_set_cells( EntityHandle gather_set, EntityHandle gather_set_start_vertex )
01329 {
01330     Interface*& mbImpl = _readNC->mbImpl;
01331
01332     // Create gather set cells
01333     EntityHandle start_element;
01334     EntityHandle* conn_arr_gather_set_cells = NULL;
01335     // Don't need to specify allocation number here, because we know enough cells were created
01336     // before
01337     ErrorCode rval = _readNC->readMeshIface->get_element_connect( nCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element,
01338        conn_arr_gather_set_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
01339
01340     // Add cells to the gather set
01341     Range gather_set_cells_range( start_element, start_element + nCells - 1 );
01342     rval = mbImpl->add_entities( gather_set, gather_set_cells_range );MB_CHK_SET_ERR( rval, "Failed to add cells to the gather set" );
01343
01344     // Read vertices on each gather set cell (connectivity)
01345     int verticesOnCellVarId;
01346     int success = NCFUNC( inq_varid )( _fileId, "cell_corners", &verticesOnCellVarId );
01347     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of cell_corners" );
01348     // Utilize the memory storage pointed by conn_arr_gather_set_cells
01349     int* vertices_on_gather_set_cells = (int*)conn_arr_gather_set_cells;
01350     NCDF_SIZE read_starts[2]          = { 0, 0 };
01351     NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( nCells ), static_cast< NCDF_SIZE >( EDGES_PER_CELL ) };
01352 #ifdef MOAB_HAVE_PNETCDF
01353     // Enter independent I/O mode, since this read is only for the gather processor
01354     success = NCFUNC( begin_indep_data )( _fileId );
01355     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01356     success =
01357         NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
01358     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_corners data" );
01359     success = NCFUNC( end_indep_data )( _fileId );
01360     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01361 #else
01362     success =
01363         NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
01364     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read cell_corners data" );
01365 #endif
01366
01367     // Correct gather set cell vertices array in the same way as local cell vertices array
01368     // Pentagons as hexagons should have a connectivity like 123455 and not 122345
01369     for( int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++ )
01370     {
01371         int* pvertex = vertices_on_gather_set_cells + gather_set_cell_idx * EDGES_PER_CELL;
01372         for( int k = 0; k < EDGES_PER_CELL - 2; k++ )
01373         {
01374             if( *( pvertex + k ) == *( pvertex + k + 1 ) )
01375             {
01376                 // Shift the connectivity
01377                 for( int kk = k + 1; kk < EDGES_PER_CELL - 1; kk++ )
01378                     *( pvertex + kk ) = *( pvertex + kk + 1 );
01379                 // No need to try next k
01380                 break;
01381             }
01382         }
01383     }
01384
01385     // Populate connectivity data for gather set cells
01386     // Convert in-place from int (stored in the first half) to EntityHandle
01387     // Reading backward is the trick
01388     for( int cell_vert = nCells * EDGES_PER_CELL - 1; cell_vert >= 0; cell_vert-- )
01389     {
01390         // Note, indices stored in vertices_on_gather_set_cells are 0 based
01391         int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert];  // Global vertex index, 0 based
01392         // Connectivity array is shifted by where the gather set vertices start
01393         conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
01394     }
01395
01396     return MB_SUCCESS;
01397 }
01398
01399 }  // namespace moab
