NestedRefine.hpp File Reference
#include "moab/MOABConfig.h"
#include "moab/Range.hpp"
#include "moab/CN.hpp"
#include <map>
#include <set>
+ Include dependency graph for NestedRefine.hpp:
+ This graph shows which files directly or indirectly include this file:
Classes
class  moab::NestedRefine
struct  moab::NestedRefine::codeperf
struct  moab::NestedRefine::refPatterns
 refPatterns More...
struct  moab::NestedRefine::intFEdge
 Helper. More...
struct  moab::NestedRefine::level_memory
struct  moab::NestedRefine::pmat
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Defines
#define MAX_DEGREE   3
#define MAX_VERTS   64
#define MAX_CHILDRENS   27
#define MAX_HE   12
#define MAX_HF   6
#define MAX_CONN   8
#define MAX_VHF   20
#define MAX_LEVELS   20
#define MAX_PROCS   64
Detailed Description
This class implements the generation of a hierarchy of meshes via uniform refinement from an input mesh. The internal upper bound on the number of levels is set to 20.
Definition in file NestedRefine.hpp.
Define Documentation
Definition at line 20 of file NestedRefine.hpp.
#define MAX_CONN   8
Definition at line 23 of file NestedRefine.hpp.
Definition at line 18 of file NestedRefine.hpp.
#define MAX_HE   12
Definition at line 21 of file NestedRefine.hpp.
#define MAX_HF   6
Definition at line 22 of file NestedRefine.hpp.
Definition at line 25 of file NestedRefine.hpp.
Definition at line 26 of file NestedRefine.hpp.
Definition at line 19 of file NestedRefine.hpp.
#define MAX_VHF   20
Definition at line 24 of file NestedRefine.hpp.
