PMeanPTemplate.hpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file PMeanPTemplate.hpp
00028  *  \brief previous name: PowerMeanP.hpp
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #ifndef MSQ_P_MEAN_P_TEMPLATE_HPP
00033 #define MSQ_P_MEAN_P_TEMPLATE_HPP
00034
00035 #include "Mesquite.hpp"
00036 #include "ObjectiveFunctionTemplate.hpp"
00037 #include "Exponent.hpp"
00038 #include "Matrix3D.hpp"
00039
00040 namespace MBMesquite
00041 {
00042
00043 /**\brief \f$\frac{1}{n}\sum_{i=1}^n\mu(s_i)^p\f$
00044  *
00045  * This class implements an objective function that is the
00046  * power-mean of the quality metric evalutations raised to the
00047  * power-mean power.  That is, the sum of each quality metric value
00048  * raised to a power, divided by the totoal number of quality metric
00049  * values.
00050  */
00051 class PMeanPTemplate : public ObjectiveFunctionTemplate
00052 {
00053   public:
00054     /**
00055      *\param power   The exponent to use for the power-mean
00056      *\param qm      The quality metric.
00057      */
00058     MESQUITE_EXPORT
00059     PMeanPTemplate( double power, QualityMetric* qm = 0 ) : ObjectiveFunctionTemplate( qm )
00060     {
00061         clear();
00062         set_power( power );
00063     }
00064
00065     /**\brief copy constructor
00066      *
00067      * Define a copy constructor because the compiler-provided
00068      * default one would also copy the temporary arrays, which
00069      * would be a waste of time.
00070      */
00071     MESQUITE_EXPORT
00072     PMeanPTemplate( const PMeanPTemplate& copy )
00073         : ObjectiveFunctionTemplate( copy ), mPower( copy.mPower ), mPowerMinus1( copy.mPowerMinus1 ),
00074           mPowerMinus2( copy.mPowerMinus2 ), mCount( copy.mCount ), mPowSum( copy.mPowSum ),
00075           saveCount( copy.saveCount ), savePowSum( copy.savePowSum )
00076     {
00077     }
00078
00079     MESQUITE_EXPORT
00080     virtual ~PMeanPTemplate() {}
00081
00082     MESQUITE_EXPORT
00083     double get_power() const
00084     {
00085         return mPower.value();
00086     }
00087
00088     MESQUITE_EXPORT
00089     void set_power( double p )
00090     {
00091         mPower       = p;
00092         mPowerMinus1 = p - 1;
00093         mPowerMinus2 = p - 2;
00094     }
00095
00096     MESQUITE_EXPORT
00097     virtual bool evaluate( EvalType type, PatchData& pd, double& value_out, bool free, MsqError& err );
00098
00099     MESQUITE_EXPORT
00100     virtual bool evaluate_with_gradient( EvalType type,
00101                                          PatchData& pd,
00102                                          double& value_out,
00103                                          std::vector< Vector3D >& grad_out,
00104                                          MsqError& err );
00105
00106     MESQUITE_EXPORT
00107     virtual bool evaluate_with_Hessian_diagonal( EvalType type,
00108                                                  PatchData& pd,
00109                                                  double& value_out,
00110                                                  std::vector< Vector3D >& grad_out,
00111                                                  std::vector< SymMatrix3D >& hess_diag_out,
00112                                                  MsqError& err );
00113
00114     MESQUITE_EXPORT
00115     virtual bool evaluate_with_Hessian( EvalType type,
00116                                         PatchData& pd,
00117                                         double& value_out,
00118                                         std::vector< Vector3D >& grad_out,
00119                                         MsqHessian& Hessian_out,
00120                                         MsqError& err );
00121
00122     MESQUITE_EXPORT
00123     virtual ObjectiveFunction* clone() const;
00124
00125     MESQUITE_EXPORT
00126     virtual void clear();
00127
00128   protected:
00129     /**\brief Handle EvalType for all eval functions, return OF value
00130      *
00131      * This function implements the common handling of the EvalType
00132      * argument for all forms of the 'evaluate' method.
00133      *
00134      * NOTE:  This function modifies accumulated values depenending
00135      *        on the value of EvalType.
00136      *\param power_sum  The sum over the current patch
00137      *\param count      The number of qm evaluations for the current patch
00138      *\param type       The evaluation type passed to 'evaluate'
00139      *\param global_count The total, accumulated number of QM evaluations
00140      *\return The objective function value to return from 'evaluate'
00141      */
00142     double get_value( double power_sum, size_t count, EvalType type, size_t& global_count );
00143
00144     Exponent mPower;       /**< The power to use */
00145     Exponent mPowerMinus1; /**< mPower - 1.0 */
00146     Exponent mPowerMinus2; /**< mPower - 2.0 */
00147
00148   private:
00149     size_t mCount;     /**< The number of accumulated entires */
00150     double mPowSum;    /**< The accumulated sum of values to the mPower */
00151     size_t saveCount;  /**< Saved count from previous patch */
00152     double savePowSum; /**< Saved sum from previous patch */
00153
00154   protected:
00155     /** Temporary storage for qm sample handles */
00156     mutable std::vector< size_t > qmHandles;
00157     /** Temporary storage for qm vertex indices */
00158     mutable std::vector< size_t > mIndices;
00159     /** Temporary storage for qm gradient */
00160     mutable std::vector< Vector3D > mGradient;
00161     /** Temporary storage for qm hessian diagonal */
00162     mutable std::vector< SymMatrix3D > mDiag;
00163     /** Temporary storage for qm Hessian */
00164     mutable std::vector< Matrix3D > mHessian;
00165 };
00166
00167 }  // namespace MBMesquite
00168
00169 #endif
