PointInElementSearch.cpp File Reference
#include <iostream>
#include <cstdlib>
#include <cstdio>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/Range.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/ElemEvaluator.hpp"
#include "moab/CN.hpp"
#include "moab/SpatialLocator.hpp"
+ Include dependency graph for PointInElementSearch.cpp:
Functions
int main (int argc, char **argv)
Variables
string test_file_name = string( MESH_DIR ) + string( "/mbtest1.vtk" )
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 29 of file PointInElementSearch.cpp.
References moab::CartVect::array(), moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, moab::CN::EntityTypeName(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::load_file(), moab::SpatialLocator::local_box(), moab::SpatialLocator::locate_point(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, moab::Range::size(), test_file_name, and moab::Core::type_from_handle().
    int num_queries = 1000000;
    if( argc > 3 )
        cout << "Usage: " << argv[0] << " <filename> [num_queries]" << endl;
        return 0;
    else if( argc == 3 )
        test_file_name = argv[1];
        num_queries    = atoi( argv[2] );
    else
        num_queries = 100;
    // Instantiate
    Core mb;
    // Load the file
    ErrorCode rval = mb.load_file( test_file_name.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" );
    // Get all 3d elements in the file
    Range elems;
    rval = mb.get_entities_by_dimension( 0, 3, elems );MB_CHK_SET_ERR( rval, "Error getting 3d elements" );
    // Create a tree to use for the location service
    AdaptiveKDTree tree( &mb );
    // Specify an evaluator based on linear hexes
    ElemEvaluator el_eval( &mb );
    // Build the SpatialLocator
    SpatialLocator sl( &mb, elems, &tree );
    // Get the box extents
    CartVect box_extents, pos;
    BoundBox box = sl.local_box();
    box_extents  = box.bMax - box.bMin;
    // Query at random places in the tree
    CartVect params;
    int is_inside  = 0;
    int num_inside = 0;
    EntityHandle elem;
    for( int i = 0; i < num_queries; i++ )
        pos  = box.bMin + CartVect( box_extents[0] * .01 * ( rand() % 100 ), box_extents[1] * .01 * ( rand() % 100 ),
                                    box_extents[2] * .01 * ( rand() % 100 ) );
        rval = sl.locate_point( pos.array(), elem, params.array(), &is_inside, 0.0, 0.0 );MB_CHK_ERR( rval );
        if( is_inside ) num_inside++;
    cout << "Mesh contains " << elems.size() << " elements of type "
         << CN::EntityTypeName( mb.type_from_handle( *elems.begin() ) ) << endl;
    cout << "Bounding box min-max = (" << box.bMin[0] << "," << box.bMin[1] << "," << box.bMin[2] << ")-("
         << box.bMax[0] << "," << box.bMax[1] << "," << box.bMax[2] << ")" << endl;
    cout << "Queries inside box = " << num_inside << "/" << num_queries << " = "
         << 100.0 * ( (double)num_inside ) / num_queries << "%" << endl;
    return 0;
Variable Documentation
Definition at line 27 of file PointInElementSearch.cpp.
