PushParMeshIntoMoabF90.F90
00001 ! PushParMeshIntoMoabF90: push parallel mesh into moab, F90 version
00002 !
00003 ! This program shows how to push a mesh into MOAB in parallel from Fortran90, with sufficient
00004 ! information to resolve boundary sharing and exchange a layer of ghost information.
00005 ! To successfully link this example, you need to specify FCFLAGS that include:
00006 !    a) -DMOAB_HAVE_MPI, and
00007 !    b) flags required to link Fortran90 MPI programs with the C++ compiler; these flags
00008 !       can often be found on your system by inspecting the output of 'mpif90 -show'
00009 ! For example, using gcc, the link line looks like:
00010 !   make MOAB_DIR=<moab install dir> FCFLAGS="-DMOAB_HAVE_MPI -I/usr/lib/openmpi/include -pthread -I/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib -lmpi_f90 -lmpi_f77 -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl" PushParMeshIntoMoabF90
00011 !
00012 ! Usage: PushParMeshIntoMoab
00013 #define ERROR(rval) if (0 .ne. rval) call exit(1)
00014
00015 program PushParMeshIntoMoab
00016
00017   use ISO_C_BINDING
00018   implicit none
00019
00020 #include "moab/MOABConfig.h"
00021 #ifdef MOAB_HAVE_MPI
00022 #  include "mpif.h"
00023 #  include "iMeshP_f.h"
00024 #else
00025 #  include "iMesh_f.h"
00026 #endif
00027
00028   ! declarations
00029   ! imesh is the instance handle
00030   iMesh_Instance imesh
00031   ! NUMV, NUME, NVPERE are the hardwired here; these are for the whole mesh,
00032   ! local mesh determined later
00033   integer NUMV, NUME, NVPERE
00034   parameter (NUMV = 8)   ! # vertices in whole mesh
00035   parameter (NUME = 6)   ! # elements in whole mesh
00036   parameter (NVPERE = 4) ! # vertices per element
00037   ! ents, verts will be arrays storing vertex/entity handles
00038   iBase_EntityHandle, pointer :: ents(:), verts(:)
00039   iBase_EntitySetHandle root_set
00040   TYPE(C_PTR) :: vertsPtr, entsPtr
00041   ! storage for vertex positions, element connectivity indices, global vertex ids
00042   real*8 coords(0:3*NUMV-1)
00043   integer iconn(0:4*NUME-1), gids(0:NUMV-1)
00044   !
00045   ! local variables
00046   integer lgids(0:NUMV-1), lconn(0:4*NUME-1)
00047   real*8 lcoords(0:3*NUMV-1)
00048   integer lnumv, lvids(0:NUMV-1), gvids(0:NUMV-1)
00049   integer lvpe, ltp ! lvpe = # vertices per entity, ltp = element type
00050   integer ic, ie, iv, istart, iend, ierr, indv, lnume, rank, sz
00051
00052 #ifdef MOAB_HAVE_MPI
00053   ! local variables for parallel runs
00054   iMeshP_PartitionHandle imeshp
00055 !    integer MPI_COMM_WORLD
00056 #endif
00057
00058   ! vertex positions, cube; side 2
00059   ! (first index varying fastest)
00060   data coords / &
00061        -1., -1., -1,  1., -1., -1.,  1., 1., -1.,  -1., 1., -1., &
00062        -1., -1.,  1,  1., -1.,  1.,  1., 1.,  1.,  -1., 1.,  1. /
00063
00064   ! quad index numbering, each quad ccw, sides then bottom then top
00065   data iconn / &
00066        0, 1, 5, 4,  &
00067        1, 2, 6, 5,  &
00068        2, 3, 7, 6,  &
00069        3, 0, 4, 7,  &
00070        0, 3, 2, 1,  &
00071        4, 5, 6, 7 /
00072
00073   data lvpe /4/ ! quads in this example
00074   data ltp / iMesh_QUADRILATERAL / ! from iBase_f.h
00075
00076   ! initialize global vertex ids
00077   do iv = 0, NUMV-1
00078      lgids(iv) = iv+1
00079   end do
00080
00081 #ifdef MOAB_HAVE_MPI
00082   ! init the parallel partition
00083   call MPI_INIT(ierr)
00084   call MPI_COMM_SIZE(MPI_COMM_WORLD, sz, ierr)
00085   call MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
00086   ERROR(ierr)
00087   ! compute starting/ending element numbers
00088   lnume = NUME / sz
00089   istart = rank * lnume
00090   iend = istart + lnume - 1
00091   if (rank .eq. sz-1) then
00092      iend = NUME-1
00093      lnume = iend - istart + 1
00094   endif
00095   ! for my elements, figure out which vertices I use and accumulate local indices and coords
00096   ! lvids stores the local 0-based index for each vertex; -1 means vertex i isn't used locally
00097   ! also build up connectivity indices for local elements, in lconn
00098   do iv = 0, NUMV-1
00099      lvids(iv) = -1
00100   end do
00101   lnumv = -1
00102   do ie = istart, iend
00103      do iv = 0, lvpe-1
00104         indv = iconn(lvpe*ie + iv)
00105         if (lvids(indv) .eq. -1) then
00106            lnumv = lnumv + 1 ! increment local # verts
00107            do ic = 0, 2 ! cache local coords
00108               lcoords(3*lnumv+ic) = coords(3*indv+ic)
00109            end do
00110            lvids(indv) = lnumv
00111            gvids(lnumv) = 1+indv
00112         end if
00113         lconn(lvpe*(ie-istart)+iv) = lvids(indv)
00114      end do  ! do iv
00115   end do  ! do ie
00116
00117   lnumv = lnumv + 1
00118
00119   ! now create the mesh; this also initializes parallel sharing and ghost exchange
00120   imesh = 0
00121   imeshp = 0
00122   call create_mesh(imesh, imeshp, MPI_COMM_WORLD, lnumv, lnume, gvids, lvpe, ltp, lcoords, lconn, &
00123        vertsPtr, entsPtr, ierr)
00124   ERROR(ierr)
00125   call c_f_pointer(vertsPtr, verts, [lnumv])
00126   call c_f_pointer(entsPtr, ents, [lnume])
00127
00128   ! get/report number of vertices, elements
00129   call iMesh_getRootSet(%VAL(imesh), root_set, ierr)
00130   ERROR(ierr)
00131   iv = 0
00132   ie = 0
00133   call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_VERTEX), iv, ierr)
00134   ERROR(ierr)
00135   call iMeshP_getNumOfTypeAll(%VAL(imesh), %VAL(imeshp), %VAL(root_set), %VAL(iBase_FACE), ie, ierr)
00136   ERROR(ierr)
00137   if (rank .eq. 0) then
00138      write(0,*) "Number of vertices = ", iv
00139      write(0,*) "Number of entities = ", ie
00140   endif
00141
00142   ! from here, can use verts and ents as (1-based) arrays of entity handles for input to other iMesh functions
00143
00144   call MPI_FINALIZE(ierr)
00145 #else
00146   write(0, *) "compile with MPI for better experience\n"
00147 #endif
00148   stop
00149 end program PushParMeshIntoMoab
00150
00151 #ifdef MOAB_HAVE_MPI
00152 subroutine create_mesh( &
00153   !     interfaces
00154      imesh, imeshp, &
00155   !     input
00156      comm, numv, nume, vgids, nvpe, tp, posn, iconn, &
00157   !     output
00158      vertsPtr, entsPtr, ierr)
00159   !
00160   ! create a mesh with numv vertices and nume elements, with elements of type tp
00161   ! vertices have positions in posn (3 coordinates each, interleaved xyzxyz...), indexed from 0
00162   ! elements have nvpe vertices per entity, with connectivity indices stored in iconn, referencing
00163   ! vertices using 0-based indices; vertex and entity handles are output in arrays passed in
00164   !
00165   ! if imesh/imeshp are 0, imesh/imeshp are initialized in this subroutine
00166   !
00167
00168   use ISO_C_BINDING
00169   implicit none
00170
00171 #  include "iMeshP_f.h"
00172 #  include "mpif.h"
00173
00174   ! subroutine arguments
00175   iMesh_Instance imesh
00176   TYPE(C_PTR) :: vertsPtr, entsPtr
00177   integer numv, nume, nvpe, vgids(0:*), iconn(0:*), ierr, tp
00178   real*8 posn(0:*)
00179 #ifdef MOAB_HAVE_MPI
00180   iMeshP_PartitionHandle imeshp
00181   integer comm
00182 #endif
00183
00184   ! local variables
00185   integer comm_sz, comm_rank, numa, numo, iv, ie
00186   TYPE(C_PTR) :: statsPtr
00187   integer, allocatable, target :: stats(:)
00188   iBase_TagHandle tagh
00189   integer i
00190   iBase_EntityHandle, pointer :: verts(:), ents(:)
00191   iBase_EntityHandle, allocatable :: conn(:)
00192   iBase_EntitySetHandle root_set
00193   iBase_EntitySetHandle file_set
00194 #ifdef MOAB_HAVE_MPI
00195   IBASE_HANDLE_T mpi_comm_c
00196   TYPE(C_PTR) :: partsPtr
00197   iMeshP_PartHandle, pointer :: parts(:)
00198   iMeshP_PartHandle part
00199   integer partsa, partso
00200   character (len=10) filename
00201 #endif
00202
00203   ! create the Mesh instance
00204   if (imesh .eq. 0) then
00205      call iMesh_newMesh("MOAB", imesh, ierr)
00206   end if
00207
00208 #ifdef MOAB_HAVE_MPI
00209   if (imeshp .eq. 0) then
00210      call iMeshP_getCommunicator(%VAL(imesh), MPI_COMM_WORLD, mpi_comm_c, ierr)
00211      ERROR(ierr)
00212      call iMeshP_createPartitionAll(%VAL(imesh), %VAL(mpi_comm_c), imeshp, ierr)
00213      ERROR(ierr)
00214      call iMeshP_createPart(%VAL(imesh), %VAL(imeshp), part, ierr)
00215      ERROR(ierr)
00216   else
00217      partsa = 0
00218      call iMeshP_getLocalParts(%VAL(imesh), %VAL(imeshp), partsPtr, partsa, partso, ierr)
00219      ERROR(ierr)
00220      call c_f_pointer(partsPtr, parts, [partso])
00221      part = parts(1)
00222   end if
00223   call MPI_COMM_RANK(comm, comm_rank, ierr)
00224   ERROR(ierr)
00225   call MPI_COMM_SIZE(comm, comm_sz, ierr)
00226   ERROR(ierr)
00227 #endif
00228
00229   ! create the vertices, all in one call
00230   numa = 0
00231   call iMesh_createVtxArr(%VAL(imesh), %VAL(numv), %VAL(iBase_INTERLEAVED), posn, %VAL(3*numv), &
00232        vertsPtr, numa, numo, ierr)
00233   ERROR(ierr)
00234
00235   ! fill in the connectivity array, based on indexing from iconn
00236   allocate (conn(0:nvpe*nume-1))
00237   call c_f_pointer(vertsPtr, verts, [numv])
00238   do i = 0, nvpe*nume-1
00239      conn(i) = verts(1+iconn(i))
00240   end do
00241   ! create the elements
00242   numa = 0
00243   allocate(stats(0:nume-1))
00244   statsPtr = C_LOC(stats(0))
00245   call iMesh_createEntArr(%VAL(imesh), %VAL(tp), conn, %VAL(nvpe*nume), &
00246        entsPtr, numa, numo, statsPtr, numa, numo, ierr)
00247   deallocate(stats)
00248   deallocate(conn)
00249
00250 #ifdef MOAB_HAVE_MPI
00251   ! take care of parallel stuff
00252
00253   ! add entities to part, using iMesh
00254   call c_f_pointer(entsPtr, ents, [numo])
00255   call iMesh_addEntArrToSet(%VAL(imesh), ents, %VAL(numo), %VAL(part), ierr)
00256   ERROR(ierr)
00257   ! set global ids on vertices, needed for sharing between procs
00258   call iMesh_getTagHandle(%VAL(imesh), "GLOBAL_ID", tagh, ierr, %VAL(9))
00259   if (iBase_SUCCESS .ne. ierr) then
00260      ! didn't get handle, need to create the tag
00261      call iMesh_createTag(%VAL(imesh), "GLOBAL_ID", %VAL(iBase_INTEGER), tagh, ierr)
00262      ERROR(ierr)
00263   end if
00264   call iMesh_setIntArrData(%VAL(imesh), verts, %VAL(numv), %VAL(tagh), vgids, %VAL(numv), ierr)
00265   ERROR(ierr)
00266   ! now resolve shared verts and exchange ghost cells
00267   call iMeshP_syncMeshAll(%VAL(imesh), %VAL(imeshp), ierr)
00268   ERROR(ierr)
00269
00270   call iMeshP_createGhostEntsAll(%VAL(imesh), %VAL(imeshp), %VAL(2), %VAL(1), %VAL(1), %VAL(0), ierr)
00271   ERROR(ierr)
00272
00273 #endif
00274
00275   return
00276 end subroutine create_mesh
00277 #endif
