QuasiNewton.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2007 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2008) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file QuasiNewton.cpp
00028  *  \brief Port Todd Munson's quasi-Newton solver to Mesquite
00029  *  \author Jason Kraftcheck (Mesquite Port)
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "QuasiNewton.hpp"
00034 #include "MsqDebug.hpp"
00035 #include "MsqError.hpp"
00036 #include "PatchData.hpp"
00037
00038 namespace MBMesquite
00039 {
00040
00041 // Force std::vector to release allocated memory
00042 template < typename T >
00043 static inline void free_vector( std::vector< T >& v )
00044 {
00045     std::vector< T > temp;
00046     temp.swap( v );
00047 }
00048
00049 std::string QuasiNewton::get_name() const
00050 {
00051     return "QuasiNewton";
00052 }
00053
00054 PatchSet* QuasiNewton::get_patch_set()
00055 {
00056     return PatchSetUser::get_patch_set();
00057 }
00058
00059 QuasiNewton::QuasiNewton( ObjectiveFunction* of ) : VertexMover( of ), PatchSetUser( true ), mMemento( 0 ) {}
00060
00061 QuasiNewton::~QuasiNewton()
00062 {
00063     delete mMemento;
00064     mMemento = 0;
00065 }
00066
00067 void QuasiNewton::initialize( PatchData& pd, MsqError& err )
00068 {
00069     if( !mMemento )
00070     {
00071         mMemento = pd.create_vertices_memento( err );MSQ_CHKERR( err );
00072     }
00073 }
00074
00075 void QuasiNewton::initialize_mesh_iteration( PatchData& /*pd*/, MsqError& /*err*/ ) {}
00076
00077 void QuasiNewton::terminate_mesh_iteration( PatchData& /*pd*/, MsqError& /*err*/ ) {}
00078
00079 void QuasiNewton::cleanup()
00080 {
00081     // release memento
00082     delete mMemento;
00083     mMemento = 0;
00084
00085     // release coordinates
00086     for( size_t i = 0; i < ( sizeof( w ) / sizeof( w[0] ) ); ++i )
00087         free_vector( w[i] );
00088     // release gradients
00089     for( size_t i = 0; i < ( sizeof( v ) / sizeof( v[0] ) ); ++i )
00090         free_vector( v[i] );
00091
00092     // release Hessian memory
00093     free_vector( mHess );
00094
00095     // release temporary array memory
00096     free_vector( x );
00097     free_vector( d );
00098 }
00099
00100 // Do v += s * x, where v and x are arrays of length n
00101 static inline void plus_eq_scaled( Vector3D* v, double s, const Vector3D* x, size_t n )
00102 {
00103     Vector3D* end = v + n;
00104     for( ; v != end; ++v, ++x )
00105         *v += s * *x;
00106 }
00107
00108 void QuasiNewton::solve( Vector3D* z_arr, const Vector3D* v_arr ) const
00109 {
00110     SymMatrix3D pd;
00111
00112     const double small = DBL_EPSILON;
00113     const size_t nn    = mHess.size();
00114     for( size_t i = 0; i < nn; ++i )
00115     {
00116
00117         // ensure positive definite: perturb a bit if
00118         // diagonal values are zero.
00119         SymMatrix3D dd = mHess[i];
00120         while( fabs( dd[0] ) < small || fabs( dd[3] ) < small || fabs( dd[5] ) < small )
00121             dd += small;
00122
00123         // factor
00124         pd[0] = 1.0 / dd[0];
00125         pd[1] = dd[1] * pd[0];
00126         pd[2] = dd[2] * pd[0];
00127
00128         pd[3] = 1.0 / ( dd[3] - dd[1] * pd[1] );
00129         pd[5] = dd[4] - dd[2] * pd[1];
00130         pd[4] = pd[3] * pd[5];
00131         pd[5] = 1.0 / ( dd[5] - dd[2] * pd[2] - pd[4] * pd[5] );
00132
00133         if( pd[0] <= 0.0 || pd[3] <= 0.0 || pd[5] <= 0.0 )
00134         {
00135             if( dd[0] + dd[3] + dd[5] <= 0 )
00136             {
00137                 // switch to diagonal
00138                 pd[0] = 1.0 / fabs( dd[0] );
00139                 pd[1] = 0.0;
00140                 pd[2] = 0.0;
00141                 pd[3] = 1.0 / fabs( dd[3] );
00142                 pd[4] = 0.0;
00143                 pd[5] = 1.0 / fabs( dd[5] );
00144             }
00145             else
00146             {
00147                 // diagonal preconditioner
00148                 pd[0] = pd[3] = pd[5] = 1.0 / ( dd[0] + dd[3] + dd[5] );
00149                 pd[1] = pd[2] = pd[4] = 0.0;
00150             }
00151         }
00152
00153         // solve
00154         const Vector3D& vv = v_arr[i];
00155         Vector3D& z        = z_arr[i];
00156         z[0]               = vv[0];
00157         z[1]               = vv[1] - pd[1] * z[0];
00158         z[2]               = vv[2] - pd[2] * z[0] - pd[4] * z[1];
00159
00160         z[0] *= pd[0];
00161         z[1] *= pd[3];
00162         z[2] *= pd[5];
00163
00164         z[1] -= pd[4] * z[2];
00165         z[0] -= pd[1] * z[1] + pd[2] * z[2];
00166     }
00167 }
00168
00169 void QuasiNewton::optimize_vertex_positions( PatchData& pd, MsqError& err )
00170 {
00171     TerminationCriterion& term = *get_inner_termination_criterion();
00172     OFEvaluator& func          = get_objective_function_evaluator();
00173
00174     const double sigma   = 1e-4;
00175     const double beta0   = 0.25;
00176     const double beta1   = 0.80;
00177     const double tol1    = 1e-8;
00178     const double epsilon = 1e-10;
00179
00180     // double norm_r; //, norm_g;
00181     double alpha, beta;
00182     double obj, objn;
00183
00184     size_t i;
00185
00186     // Initialize stuff
00187     const size_t nn = pd.num_free_vertices();
00188     double a[QNVEC], b[QNVEC], r[QNVEC];
00189     for( i = 0; i < QNVEC; ++i )
00190         r[i] = 0;
00191     for( i = 0; i <= QNVEC; ++i )
00192     {
00193         v[i].clear();
00194         v[i].resize( nn, Vector3D( 0.0 ) );
00195         w[i].clear();
00196         w[i].resize( nn, Vector3D( 0.0 ) );
00197     }
00198     d.resize( nn );
00199     mHess.resize( nn );  // hMesh(mesh);
00200
00201     bool valid = func.update( pd, obj, v[QNVEC], mHess, err );MSQ_ERRRTN( err );
00202     if( !valid )
00203     {
00204         MSQ_SETERR( err )( "Initial objective function is not valid", MsqError::INVALID_MESH );
00205         return;
00206     }
00207
00208     while( !term.terminate() )
00209     {
00210         pd.recreate_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
00211         pd.get_free_vertex_coordinates( w[QNVEC] );
00212
00213         x = v[QNVEC];
00214         for( i = QNVEC; i--; )
00215         {
00216             a[i] = r[i] * inner( &( w[i][0] ), arrptr( x ), nn );
00217             plus_eq_scaled( arrptr( x ), -a[i], &v[i][0], nn );
00218         }
00219
00220         solve( arrptr( d ), arrptr( x ) );
00221
00222         for( i = QNVEC; i--; )
00223         {
00224             b[i] = r[i] * inner( &( v[i][0] ), arrptr( d ), nn );
00225             plus_eq_scaled( arrptr( d ), a[i] - b[i], &( w[i][0] ), nn );
00226         }
00227
00228         alpha = -inner( &( v[QNVEC][0] ), arrptr( d ), nn ); /* direction is negated */
00229         if( alpha > 0.0 )
00230         {
00231             MSQ_SETERR( err )( "No descent.", MsqError::INVALID_MESH );
00232             return;
00233         }
00234
00235         alpha *= sigma;
00236         beta = 1.0;
00237
00238         pd.move_free_vertices_constrained( arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err );
00239         valid = func.evaluate( pd, objn, v[QNVEC], err );
00240         if( err.error_code() == err.BARRIER_VIOLATED )
00241             err.clear();  // barrier violated does not represent an actual error here
00242         MSQ_ERRRTN( err );
00243         if( !valid || ( obj - objn < -alpha * beta - epsilon && length( &( v[QNVEC][0] ), nn ) >= tol1 ) )
00244         {
00245
00246             if( !valid )  // function not defined at trial point
00247                 beta *= beta0;
00248             else  // unacceptable iterate
00249                 beta *= beta1;
00250
00251             for( ;; )
00252             {
00253                 if( beta < tol1 )
00254                 {
00255                     pd.set_to_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
00256                     MSQ_SETERR( err )( "Newton step not good", MsqError::INTERNAL_ERROR );
00257                     return;
00258                 }
00259
00260                 pd.set_free_vertices_constrained( mMemento, arrptr( d ), nn, -beta, err );MSQ_ERRRTN( err );
00261                 valid = func.evaluate( pd, objn, err );
00262                 if( err.error_code() == err.BARRIER_VIOLATED )
00263                     err.clear();  // barrier violated does not represent an actual error here
00264                 MSQ_ERRRTN( err );
00265                 if( !valid )  // function undefined at trial point
00266                     beta *= beta0;
00267                 else if( obj - objn < -alpha * beta - epsilon )  // unacceptlable iterate
00268                     beta *= beta1;
00269                 else
00270                     break;
00271             }
00272         }
00273
00274         for( i = 0; i < QNVEC - 1; ++i )
00275         {
00276             r[i] = r[i + 1];
00277             w[i].swap( w[i + 1] );
00278             v[i].swap( v[i + 1] );
00279         }
00280         w[QNVEC - 1].swap( w[0] );
00281         v[QNVEC - 1].swap( v[0] );
00282
00283         func.update( pd, obj, v[QNVEC], mHess, err );MSQ_ERRRTN( err );
00284         // norm_r = length_squared( &(v[QNVEC][0]), nn );
00285         // norm_g = sqrt(norm_r);
00286
00287         // checks stopping criterion
00288         term.accumulate_patch( pd, err );MSQ_ERRRTN( err );
00289         term.accumulate_inner( pd, objn, &v[QNVEC][0], err );MSQ_ERRRTN( err );
00290     }
00291 }
00292
00293 }  // namespace MBMesquite
