RangeSeqIntersectIter.hpp
00001 /*
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 /**\file RangeSeqIntersectIter.hpp
00017  *\author Jason Kraftcheck ([email protected])
00018  *\date 2006-08-11
00019  *\date 2007-11-06
00020  */
00021
00022 #ifndef MB_RANGE_SEQ_INTERSECT_ITER_HPP
00023 #define MB_RANGE_SEQ_INTERSECT_ITER_HPP
00024
00025 #include "moab/Types.hpp"
00026 #include "moab/Range.hpp"
00027
00028 namespace moab
00029 {
00030
00031 class SequenceManager;
00032 class EntitySequence;
00033
00034 #define MB_RANGE_SEQ_INTERSECT_ITER_STATS 0
00035
00036 /** \brief Iterate over the blocks of EntityHandles in an Range that
00037  *         are in the same EntitySequence.
00038  *
00039  * Iterate over an Range, returning blocks of entities that are the
00040  * largest ranges of contiguous handles that meet one of the following
00041  * conditions:
00042  *  - All are valid handles belonging to the same EntitySequence
00043  *  - All are invalid handles of the same EntityType
00044  *
00045  * The return type from init() or step() indicates whether or not the
00046  * current range contains valid entities.  If the handles are either
00047  * all valid or all holes in an EntitySequence, that sequence can
00048  * be obtained with get_sequence().  get_sequence() will return NULL if
00049  * there is no corresponding EntitySequence for the block of handles.
00050  *
00051  * This class keeps a data related to the 'current' EntitySequence and
00052  * references to the Range pasesd to init().  Changing either of these
00053  * while an instance of this class is in use would be bad.
00054  */
00055 class RangeSeqIntersectIter
00056 {
00057   public:
00058     RangeSeqIntersectIter( SequenceManager* sequences )
00059         : mSequenceManager( sequences ), mSequence( 0 ), mStartHandle( 0 ), mEndHandle( 0 ), mLastHandle( 0 )
00060     {
00061     }
00062
00063     /** Initialize iterator to first valid subset
00064      *\return - MB_SUCCESS : initial position of iterator is valid
00065      *        - MB_ENITITY_NOT_FOUND : range contains invalid handle -- can step past by calling
00066      *again
00067      *        - MB_FAILURE : No entities (start == end)
00068      */
00069     ErrorCode init( Range::const_iterator start, Range::const_iterator end );
00070
00071     /** Step iterator to next range.
00072      *\return - MB_SUCCESS : there is another range, and iter has been changed to it
00073      *        - MB_ENITITY_NOT_FOUND : range contains invalid handle -- can step past by calling
00074      *again
00075      *        - MB_FAILURE : at end.
00076      */
00077     ErrorCode step();
00078
00079     /**\brief Check if next call to step() will return MB_FAILURE.
00080      *
00081      * Check if the iterator cannot be advanced any further.
00082      * If this method returns true, then the *next* call to step()
00083      * will return MB_FAILURE.
00084      */
00085     bool is_at_end() const
00086     {
00087         return mEndHandle == mLastHandle;
00088     }
00089
00090     /** Get the EntitySequence for the current block.
00091      *  May be NULL for invaild handles.
00092      */
00093     EntitySequence* get_sequence() const
00094     {
00095         return mSequence;
00096     }
00097
00098     /** Get first handle in block */
00099     EntityHandle get_start_handle() const
00100     {
00101         return mStartHandle;
00102     }
00103
00104     /** Get last handle in block */
00105     EntityHandle get_end_handle() const
00106     {
00107         return mEndHandle;
00108     }
00109
00110 #if MB_RANGE_SEQ_INTERSECT_ITER_STATS
00111     static double fragmentation()
00112     {
00113         return ( doubleNumCalls + intNumCalls ) / ( doubleEntCount + intEntCount );
00114     }
00115 #endif
00116
00117   private:
00118     /** Update entity sequence data (mSequence and freeIndex) for current
00119      *  mStartHandle.  If mEndHandle is past end of sequence, trim it.
00120      *  Called by step() and init().  step() handles iterating over the pairs
00121      *  in the Range.  This method handles iterating over the set of
00122      *  EntitySequences that intersect the pair.
00123      */
00124     ErrorCode update_entity_sequence();
00125
00126     /** Handle error case where we encountered an EntityHandle w/out
00127      *  a corresponding EntitySequence.  Trim mEndHandle such that it
00128      *  is before the next valid EntityHandle of the same type.
00129      *\return Always returns MB_ENTITY_NOT_FOUND
00130      */
00131     ErrorCode find_invalid_range();
00132
00133     SequenceManager* mSequenceManager;      //!< THE EntitySequenceManager
00134     EntitySequence* mSequence;              //!< EntitySequence corresponding to current location
00135     Range::const_pair_iterator rangeIter;   //!< Current position in Range.
00136     EntityHandle mStartHandle, mEndHandle;  //!< Subset of current EntitySequence
00137     EntityHandle mLastHandle;               //!< The last of the list of all handles in the Range
00138
00139 #if MB_RANGE_SEQ_INTERSECT_ITER_STATS
00140     static double doubleNumCalls, doubleEntCount;
00141     static unsigned long intNumCalls, intEntCount;
00142     static void update_stats( unsigned long num_ents );
00143 #endif
00144 };
00145
00146 }  // namespace moab
00147
00148 #endif
