Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef READ_GMSH_HPP 00017 #define READ_GMSH_HPP 00018 00019 #include "moab/Forward.hpp" 00020 #include "moab/ReaderIface.hpp" 00021 #include "moab/Range.hpp" 00022 00023 namespace moab 00024 { 00025 00026 class ReadUtilIface; 00027 struct GmshElemType; 00028 00029 /** 00030 * \brief Gmsh (http://www.geuz.org/gmsh) file reader 00031 * \author Jason Kraftcheck 00032 */ 00033 class ReadGmsh : public ReaderIface 00034 { 00035 00036 public: 00037 //! factory method 00038 static ReaderIface* factory( Interface* ); 00039 00040 ErrorCode load_file( const char* file_name, 00041 const EntityHandle* file_set, 00042 const FileOptions& opts, 00043 const SubsetList* subset_list = 0, 00044 const Tag* file_id_tag = 0 ); 00045 00046 ErrorCode read_tag_values( const char* file_name, 00047 const char* tag_name, 00048 const FileOptions& opts, 00049 std::vector< int >& tag_values_out, 00050 const SubsetList* subset_list = 0 ); 00051 00052 //! Constructor 00053 ReadGmsh( Interface* impl = NULL ); 00054 00055 //! Destructor 00056 virtual ~ReadGmsh(); 00057 00058 private: 00059 ErrorCode create_elements( const GmshElemType& type, 00060 const std::vector< int >& elem_ids, 00061 const std::vector< int >& matl_ids, 00062 const std::vector< int >& geom_ids, 00063 const std::vector< int >& prtn_ids, 00064 const std::vector< EntityHandle >& connectivity, 00065 const Tag* file_id_tag ); 00066 00067 ErrorCode create_sets( EntityType element_type, 00068 const Range& elements, 00069 const std::vector< int >& set_ids, 00070 int set_type ); 00071 00072 ErrorCode create_geometric_topology(); 00073 00074 ReadUtilIface* readMeshIface; 00075 00076 //! interface instance 00077 Interface* mdbImpl; 00078 00079 Tag globalId; 00080 Range geomSets; 00081 }; 00082 00083 } // namespace moab 00084 00085 #endif
